| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pcomb.c,v 2.33 2004/06/08 19:48:30 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Combine picture files according to calcomp functions.
| 6 |
| 7 |
* 1/4/89
| 8 |
| 9 |
| 10 |
#include "platform.h"
| 11 |
#include "standard.h"
| 12 |
#include "rtprocess.h"
| 13 |
#include "color.h"
| 14 |
#include "calcomp.h"
| 15 |
#include "view.h"
| 16 |
| 17 |
#define MAXINP 32 /* maximum number of input files */
| 18 |
#define WINSIZ 64 /* scanline window size */
| 19 |
#define MIDSCN ((WINSIZ-1)/2+1)
| 20 |
| 21 |
struct {
| 22 |
char *name; /* file or command name */
| 23 |
FILE *fp; /* stream pointer */
| 24 |
VIEW vw; /* view for picture */
| 25 |
RESOLU rs; /* image resolution and orientation */
| 26 |
float pa; /* pixel aspect ratio */
| 27 |
COLOR *scan[WINSIZ]; /* input scanline window */
| 28 |
COLOR coef; /* coefficient */
| 29 |
COLOR expos; /* recorded exposure */
| 30 |
} input[MAXINP]; /* input pictures */
| 31 |
| 32 |
int nfiles; /* number of input files */
| 33 |
| 34 |
char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
| 35 |
| 36 |
char StandardInput[] = "<stdin>";
| 37 |
char Command[] = "<Command>";
| 38 |
char vcolin[3][4] = {"ri", "gi", "bi"};
| 39 |
char vcolout[3][4] = {"ro", "go", "bo"};
| 40 |
char vbrtin[] = "li";
| 41 |
char vbrtout[] = "lo";
| 42 |
char vcolexp[3][4] = {"re", "ge", "be"};
| 43 |
char vbrtexp[] = "le";
| 44 |
char vpixaspect[] = "pa";
| 45 |
| 46 |
char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
| 47 |
| 48 |
char vpsize[] = "S";
| 49 |
| 50 |
char vnfiles[] = "nfiles";
| 51 |
char vwhteff[] = "WE";
| 52 |
char vxmax[] = "xmax";
| 53 |
char vymax[] = "ymax";
| 54 |
char vxres[] = "xres";
| 55 |
char vyres[] = "yres";
| 56 |
char vxpos[] = "x";
| 57 |
char vypos[] = "y";
| 58 |
| 59 |
int nowarn = 0; /* no warning messages? */
| 60 |
| 61 |
int xmax = 0, ymax = 0; /* input resolution */
| 62 |
| 63 |
int xscan, yscan; /* input position */
| 64 |
| 65 |
int xres, yres; /* output resolution */
| 66 |
| 67 |
int xpos, ypos; /* output position */
| 68 |
| 69 |
char *progname; /* global argv[0] */
| 70 |
| 71 |
int wrongformat = 0;
| 72 |
int gotview;
| 73 |
| 74 |
| 75 |
static gethfunc tabputs;
| 76 |
static void checkfile(void);
| 77 |
static double rgb_bright(COLOR clr);
| 78 |
static double xyz_bright(COLOR clr);
| 79 |
static void init(void);
| 80 |
static void combine(void);
| 81 |
static void advance(void);
| 82 |
static double l_expos(char *nam);
| 83 |
static double l_pixaspect(char *nm);
| 84 |
static double l_colin(char *nam);
| 85 |
static double l_ray(char *nam);
| 86 |
static double l_psize(char *nm);
| 87 |
| 88 |
| 89 |
int
| 90 |
main(
| 91 |
int argc,
| 92 |
char *argv[]
| 93 |
| 94 |
| 95 |
int original;
| 96 |
double f;
| 97 |
int a;
| 98 |
SET_DEFAULT_BINARY();
| 99 |
SET_FILE_BINARY(stdin);
| 100 |
SET_FILE_BINARY(stdout);
| 101 |
progname = argv[0];
| 102 |
/* scan options */
| 103 |
for (a = 1; a < argc; a++) {
| 104 |
if (argv[a][0] == '-')
| 105 |
switch (argv[a][1]) {
| 106 |
case 'x':
| 107 |
case 'y':
| 108 |
a++;
| 109 |
continue;
| 110 |
case 'w':
| 111 |
nowarn = !nowarn;
| 112 |
continue;
| 113 |
case 'f':
| 114 |
case 'e':
| 115 |
a++;
| 116 |
continue;
| 117 |
| 118 |
break;
| 119 |
| 120 |
newheader("RADIANCE", stdout); /* start header */
| 121 |
fputnow(stdout);
| 122 |
/* process files */
| 123 |
for (nfiles = 0; nfiles < MAXINP; nfiles++) {
| 124 |
setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
| 125 |
setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
| 126 |
input[nfiles].vw = stdview;
| 127 |
input[nfiles].pa = 1.0;
| 128 |
| 129 |
nfiles = 0;
| 130 |
original = 0;
| 131 |
for ( ; a < argc; a++) {
| 132 |
if (nfiles >= MAXINP) {
| 133 |
eputs(argv[0]);
| 134 |
eputs(": too many picture files\n");
| 135 |
quit(1);
| 136 |
| 137 |
| 138 |
| 139 |
case '\0':
| 140 |
input[nfiles].name = StandardInput;
| 141 |
input[nfiles].fp = stdin;
| 142 |
break;
| 143 |
case 'o':
| 144 |
original++;
| 145 |
continue;
| 146 |
case 's':
| 147 |
f = atof(argv[++a]);
| 148 |
scalecolor(input[nfiles].coef, f);
| 149 |
continue;
| 150 |
case 'c':
| 151 |
colval(input[nfiles].coef,RED)*=atof(argv[++a]);
| 152 |
colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
| 153 |
colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
| 154 |
continue;
| 155 |
default:
| 156 |
goto usage;
| 157 |
| 158 |
else {
| 159 |
if (argv[a][0] == '!') {
| 160 |
input[nfiles].name = Command;
| 161 |
input[nfiles].fp = popen(argv[a]+1, "r");
| 162 |
} else {
| 163 |
input[nfiles].name = argv[a];
| 164 |
input[nfiles].fp = fopen(argv[a], "r");
| 165 |
| 166 |
if (input[nfiles].fp == NULL) {
| 167 |
perror(argv[a]);
| 168 |
quit(1);
| 169 |
| 170 |
| 171 |
checkfile();
| 172 |
if (original) {
| 173 |
colval(input[nfiles].coef,RED) /=
| 174 |
colval(input[nfiles].expos,RED);
| 175 |
colval(input[nfiles].coef,GRN) /=
| 176 |
colval(input[nfiles].expos,GRN);
| 177 |
colval(input[nfiles].coef,BLU) /=
| 178 |
colval(input[nfiles].expos,BLU);
| 179 |
| 180 |
| 181 |
nfiles++;
| 182 |
original = 0;
| 183 |
| 184 |
init(); /* set constants */
| 185 |
/* go back and get expressions */
| 186 |
| 187 |
| 188 |
| 189 |
case 'x':
| 190 |
varset(vxres, ':', eval(argv[++a]));
| 191 |
continue;
| 192 |
case 'y':
| 193 |
varset(vyres, ':', eval(argv[++a]));
| 194 |
continue;
| 195 |
case 'w':
| 196 |
continue;
| 197 |
case 'f':
| 198 |
fcompile(argv[++a]);
| 199 |
continue;
| 200 |
case 'e':
| 201 |
scompile(argv[++a], NULL, 0);
| 202 |
continue;
| 203 |
| 204 |
break;
| 205 |
| 206 |
/* set/get output resolution */
| 207 |
if (!vardefined(vxres))
| 208 |
varset(vxres, ':', (double)xmax);
| 209 |
if (!vardefined(vyres))
| 210 |
varset(vyres, ':', (double)ymax);
| 211 |
xres = varvalue(vxres) + .5;
| 212 |
yres = varvalue(vyres) + .5;
| 213 |
if (xres <= 0 || yres <= 0) {
| 214 |
eputs(argv[0]);
| 215 |
eputs(": illegal output resolution\n");
| 216 |
quit(1);
| 217 |
| 218 |
/* complete header */
| 219 |
printargs(argc, argv, stdout);
| 220 |
if (strcmp(ourfmt, PICFMT))
| 221 |
fputformat(ourfmt, stdout); /* print format if known */
| 222 |
putchar('\n');
| 223 |
fprtresolu(xres, yres, stdout);
| 224 |
/* combine pictures */
| 225 |
combine();
| 226 |
quit(0);
| 227 |
usage:
| 228 |
eputs("Usage: ");
| 229 |
eputs(argv[0]);
| 230 |
eputs(
| 231 |
" [-w][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] pic ..]\n");
| 232 |
quit(1);
| 233 |
return 1; /* pro forma return */
| 234 |
| 235 |
| 236 |
| 237 |
static int
| 238 |
tabputs( /* put out string preceded by a tab */
| 239 |
char *s,
| 240 |
void *p
| 241 |
| 242 |
| 243 |
char fmt[32];
| 244 |
double d;
| 245 |
COLOR ctmp;
| 246 |
| 247 |
if (isheadid(s)) /* header id */
| 248 |
return(0); /* don't echo */
| 249 |
if (formatval(fmt, s)) { /* check format */
| 250 |
if (globmatch(ourfmt, fmt)) {
| 251 |
wrongformat = 0;
| 252 |
strcpy(ourfmt, fmt);
| 253 |
} else
| 254 |
wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
| 255 |
| 256 |
| 257 |
if (isexpos(s)) { /* exposure */
| 258 |
d = exposval(s);
| 259 |
scalecolor(input[nfiles].expos, d);
| 260 |
} else if (iscolcor(s)) { /* color correction */
| 261 |
colcorval(ctmp, s);
| 262 |
multcolor(input[nfiles].expos, ctmp);
| 263 |
} else if (isaspect(s))
| 264 |
input[nfiles].pa *= aspectval(s);
| 265 |
else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
| 266 |
gotview++;
| 267 |
/* echo line */
| 268 |
putchar('\t');
| 269 |
return(fputs(s, stdout));
| 270 |
| 271 |
| 272 |
| 273 |
static void
| 274 |
checkfile(void) /* ready a file */
| 275 |
| 276 |
register int i;
| 277 |
/* process header */
| 278 |
gotview = 0;
| 279 |
fputs(input[nfiles].name, stdout);
| 280 |
fputs(":\n", stdout);
| 281 |
getheader(input[nfiles].fp, tabputs, NULL);
| 282 |
if (wrongformat < 0) {
| 283 |
eputs(input[nfiles].name);
| 284 |
eputs(": not a Radiance picture\n");
| 285 |
quit(1);
| 286 |
| 287 |
if (wrongformat > 0) {
| 288 |
wputs(input[nfiles].name);
| 289 |
wputs(": warning -- incompatible picture format\n");
| 290 |
| 291 |
if (!gotview || setview(&input[nfiles].vw) != NULL)
| 292 |
input[nfiles].vw.type = 0;
| 293 |
if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
| 294 |
| 295 |
eputs(": bad picture size\n");
| 296 |
quit(1);
| 297 |
| 298 |
if (xmax == 0 && ymax == 0) {
| 299 |
xmax = scanlen(&input[nfiles].rs);
| 300 |
ymax = numscans(&input[nfiles].rs);
| 301 |
} else if (scanlen(&input[nfiles].rs) != xmax ||
| 302 |
numscans(&input[nfiles].rs) != ymax) {
| 303 |
| 304 |
eputs(": resolution mismatch\n");
| 305 |
quit(1);
| 306 |
| 307 |
/* allocate scanlines */
| 308 |
for (i = 0; i < WINSIZ; i++)
| 309 |
input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
| 310 |
| 311 |
| 312 |
| 313 |
static double
| 314 |
rgb_bright(
| 315 |
COLOR clr
| 316 |
| 317 |
| 318 |
return(bright(clr));
| 319 |
| 320 |
| 321 |
| 322 |
static double
| 323 |
xyz_bright(
| 324 |
COLOR clr
| 325 |
| 326 |
| 327 |
return(clr[CIEY]);
| 328 |
| 329 |
| 330 |
| 331 |
double (*ourbright)() = rgb_bright;
| 332 |
| 333 |
| 334 |
static void
| 335 |
init(void) /* perform final setup */
| 336 |
| 337 |
register int i;
| 338 |
/* define constants */
| 339 |
varset("PI", ':', PI);
| 340 |
varset(vnfiles, ':', (double)nfiles);
| 341 |
varset(vxmax, ':', (double)xmax);
| 342 |
varset(vymax, ':', (double)ymax);
| 343 |
/* set functions */
| 344 |
for (i = 0; i < 3; i++) {
| 345 |
funset(vcolexp[i], 1, ':', l_expos);
| 346 |
funset(vcolin[i], 1, '=', l_colin);
| 347 |
| 348 |
funset(vbrtexp, 1, ':', l_expos);
| 349 |
funset(vbrtin, 1, '=', l_colin);
| 350 |
funset(vpixaspect, 1, ':', l_pixaspect);
| 351 |
for (i = 0; i < 7; i++)
| 352 |
funset(vray[i], 1, '=', l_ray);
| 353 |
funset(vpsize, 1, '=', l_psize);
| 354 |
/* set brightness function */
| 355 |
if (!strcmp(ourfmt, CIEFMT)) {
| 356 |
varset(vwhteff, ':', 1.0);
| 357 |
ourbright = xyz_bright;
| 358 |
} else
| 359 |
varset(vwhteff, ':', WHTEFFICACY);
| 360 |
| 361 |
| 362 |
| 363 |
static void
| 364 |
combine(void) /* combine pictures */
| 365 |
| 366 |
EPNODE *coldef[3], *brtdef;
| 367 |
COLOR *scanout;
| 368 |
double d;
| 369 |
register int i, j;
| 370 |
/* check defined variables */
| 371 |
for (j = 0; j < 3; j++) {
| 372 |
if (vardefined(vcolout[j]))
| 373 |
coldef[j] = eparse(vcolout[j]);
| 374 |
else
| 375 |
coldef[j] = NULL;
| 376 |
| 377 |
if (vardefined(vbrtout))
| 378 |
brtdef = eparse(vbrtout);
| 379 |
else
| 380 |
brtdef = NULL;
| 381 |
/* allocate scanline */
| 382 |
scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
| 383 |
/* set input position */
| 384 |
yscan = ymax+MIDSCN;
| 385 |
/* combine files */
| 386 |
for (ypos = yres-1; ypos >= 0; ypos--) {
| 387 |
advance();
| 388 |
varset(vypos, '=', (double)ypos);
| 389 |
for (xpos = 0; xpos < xres; xpos++) {
| 390 |
xscan = (long)xpos*xmax/xres;
| 391 |
varset(vxpos, '=', (double)xpos);
| 392 |
eclock++;
| 393 |
if (brtdef != NULL) {
| 394 |
d = evalue(brtdef);
| 395 |
if (d < 0.0)
| 396 |
d = 0.0;
| 397 |
setcolor(scanout[xpos], d, d, d);
| 398 |
} else {
| 399 |
| 400 |
if (coldef[j] != NULL) {
| 401 |
d = evalue(coldef[j]);
| 402 |
} else {
| 403 |
d = 0.0;
| 404 |
for (i = 0; i < nfiles; i++)
| 405 |
d += colval(input[i].scan[MIDSCN][xscan],j);
| 406 |
| 407 |
if (d < 0.0)
| 408 |
d = 0.0;
| 409 |
colval(scanout[xpos],j) = d;
| 410 |
| 411 |
| 412 |
| 413 |
if (fwritescan(scanout, xres, stdout) < 0) {
| 414 |
perror("write error");
| 415 |
quit(1);
| 416 |
| 417 |
| 418 |
efree((char *)scanout);
| 419 |
| 420 |
| 421 |
| 422 |
static void
| 423 |
advance(void) /* read in data for next scanline */
| 424 |
| 425 |
int ytarget;
| 426 |
register COLOR *st;
| 427 |
register int i, j;
| 428 |
| 429 |
for (ytarget = (long)ypos*ymax/yres; yscan > ytarget; yscan--)
| 430 |
for (i = 0; i < nfiles; i++) {
| 431 |
st = input[i].scan[WINSIZ-1];
| 432 |
for (j = WINSIZ-1; j > 0; j--) /* rotate window */
| 433 |
input[i].scan[j] = input[i].scan[j-1];
| 434 |
input[i].scan[0] = st;
| 435 |
if (yscan <= MIDSCN) /* hit bottom? */
| 436 |
continue;
| 437 |
if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
| 438 |
eputs(input[i].name);
| 439 |
eputs(": read error\n");
| 440 |
quit(1);
| 441 |
| 442 |
if (fabs(colval(input[i].coef,RED)-1.0) > 1e-3 ||
| 443 |
fabs(colval(input[i].coef,GRN)-1.0) > 1e-3 ||
| 444 |
fabs(colval(input[i].coef,BLU)-1.0) > 1e-3)
| 445 |
for (j = 0; j < xmax; j++) /* adjust color */
| 446 |
multcolor(st[j], input[i].coef);
| 447 |
| 448 |
| 449 |
| 450 |
| 451 |
static double
| 452 |
l_expos( /* return picture exposure */
| 453 |
register char *nam
| 454 |
| 455 |
| 456 |
register int fn, n;
| 457 |
| 458 |
fn = argument(1) - .5;
| 459 |
if (fn < 0 || fn >= nfiles)
| 460 |
return(1.0);
| 461 |
if (nam == vbrtexp)
| 462 |
return((*ourbright)(input[fn].expos));
| 463 |
n = 3;
| 464 |
while (n--)
| 465 |
if (nam == vcolexp[n])
| 466 |
return(colval(input[fn].expos,n));
| 467 |
eputs("Bad call to l_expos()!\n");
| 468 |
quit(1);
| 469 |
| 470 |
| 471 |
| 472 |
| 473 |
static double
| 474 |
l_pixaspect(char *nm) /* return pixel aspect ratio */
| 475 |
| 476 |
register int fn;
| 477 |
| 478 |
| 479 |
| 480 |
return(1.0);
| 481 |
return(input[fn].pa);
| 482 |
| 483 |
| 484 |
| 485 |
static double
| 486 |
l_colin( /* return color value for picture */
| 487 |
register char *nam
| 488 |
| 489 |
| 490 |
int fn;
| 491 |
register int n, xoff, yoff;
| 492 |
double d;
| 493 |
| 494 |
| 495 |
if (fn < 0 || fn >= nfiles) {
| 496 |
errno = EDOM;
| 497 |
return(0.0);
| 498 |
| 499 |
xoff = yoff = 0;
| 500 |
n = nargum();
| 501 |
if (n >= 2) {
| 502 |
d = argument(2);
| 503 |
if (d < 0.0) {
| 504 |
xoff = d-.5;
| 505 |
if (xscan+xoff < 0)
| 506 |
xoff = -xscan;
| 507 |
} else {
| 508 |
xoff = d+.5;
| 509 |
if (xscan+xoff >= xmax)
| 510 |
xoff = xmax-1-xscan;
| 511 |
| 512 |
| 513 |
if (n >= 3) {
| 514 |
d = argument(3);
| 515 |
if (d < 0.0) {
| 516 |
yoff = d-.5;
| 517 |
if (yoff+MIDSCN < 0)
| 518 |
yoff = -MIDSCN;
| 519 |
if (yscan+yoff < 0)
| 520 |
yoff = -yscan;
| 521 |
} else {
| 522 |
yoff = d+.5;
| 523 |
if (yoff+MIDSCN >= WINSIZ)
| 524 |
yoff = WINSIZ-1-MIDSCN;
| 525 |
if (yscan+yoff >= ymax)
| 526 |
yoff = ymax-1-yscan;
| 527 |
| 528 |
| 529 |
if (nam == vbrtin)
| 530 |
return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
| 531 |
n = 3;
| 532 |
while (n--)
| 533 |
if (nam == vcolin[n])
| 534 |
return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
| 535 |
eputs("Bad call to l_colin()!\n");
| 536 |
quit(1);
| 537 |
| 538 |
| 539 |
| 540 |
| 541 |
static double
| 542 |
l_ray( /* return ray origin or direction */
| 543 |
register char *nam
| 544 |
| 545 |
| 546 |
static unsigned long ltick[MAXINP];
| 547 |
static FVECT lorg[MAXINP], ldir[MAXINP];
| 548 |
static double ldist[MAXINP];
| 549 |
RREAL loc[2];
| 550 |
int fn;
| 551 |
register int i;
| 552 |
| 553 |
| 554 |
| 555 |
errno = EDOM;
| 556 |
return(0.0);
| 557 |
| 558 |
if (ltick[fn] != eclock) { /* need to compute? */
| 559 |
lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
| 560 |
ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
| 561 |
ldist[fn] = -1.0;
| 562 |
if (input[fn].vw.type == 0)
| 563 |
errno = EDOM;
| 564 |
else {
| 565 |
pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
| 566 |
ldist[fn] = viewray(lorg[fn], ldir[fn],
| 567 |
&input[fn].vw, loc[0], loc[1]);
| 568 |
| 569 |
ltick[fn] = eclock;
| 570 |
| 571 |
if (nam == vray[i=6])
| 572 |
return(ldist[fn]);
| 573 |
while (i--)
| 574 |
if (nam == vray[i])
| 575 |
return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
| 576 |
eputs("Bad call to l_ray()!\n");
| 577 |
quit(1);
| 578 |
| 579 |
| 580 |
| 581 |
| 582 |
static double
| 583 |
l_psize(char *nm) /* compute pixel size in steradians */
| 584 |
| 585 |
| 586 |
static double psize[MAXINP];
| 587 |
FVECT dir0, org, dirx, diry;
| 588 |
RREAL locx[2], locy[2];
| 589 |
double d;
| 590 |
int fn;
| 591 |
register int i;
| 592 |
| 593 |
d = argument(1);
| 594 |
if (d < .5 || d >= nfiles+.5) {
| 595 |
errno = EDOM;
| 596 |
return(0.0);
| 597 |
| 598 |
fn = d - .5;
| 599 |
| 600 |
psize[fn] = 0.0;
| 601 |
| 602 |
errno = EDOM;
| 603 |
else if (input[fn].vw.type != VT_PAR &&
| 604 |
funvalue(vray[6], 1, &d) >= 0) {
| 605 |
| 606 |
dir0[i] = funvalue(vray[3+i], 1, &d);
| 607 |
pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
| 608 |
pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
| 609 |
if (viewray(org, dirx, &input[fn].vw,
| 610 |
locx[0], locx[1]) >= 0 &&
| 611 |
viewray(org, diry, &input[fn].vw,
| 612 |
locy[0], locy[1]) >= 0) {
| 613 |
/* approximate solid angle */
| 614 |
| 615 |
dirx[i] -= dir0[i];
| 616 |
diry[i] -= dir0[i];
| 617 |
| 618 |
fcross(dir0, dirx, diry);
| 619 |
psize[fn] = sqrt(DOT(dir0,dir0));
| 620 |
| 621 |
| 622 |
ltick[fn] = eclock;
| 623 |
| 624 |
return(psize[fn]);
| 625 |
| 626 |
| 627 |
| 628 |
extern void
| 629 |
wputs(char *msg)
| 630 |
| 631 |
if (!nowarn)
| 632 |
eputs(msg);
| 633 |
| 634 |
| 635 |
| 636 |
extern void
| 637 |
eputs(char *msg)
| 638 |
| 639 |
fputs(msg, stderr);
| 640 |
| 641 |
| 642 |
| 643 |
extern void
| 644 |
quit(int code) /* exit gracefully */
| 645 |
| 646 |
register int i;
| 647 |
/* close input files */
| 648 |
| 649 |
if (input[i].name == Command)
| 650 |
pclose(input[i].fp);
| 651 |
else
| 652 |
fclose(input[i].fp);
| 653 |
exit(code);
| 654 |
