root/radiance/src/px/normtiff.c
Wed Oct 2 15:58:56 2024 UTC (13 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.16: +12 -11 lines
Diff to previous 3.16
feat(normtiff): Added ability to ingest hyperspectral radiance pictures
Wed Apr 7 21:13:52 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 3.15
perf: changed default dynamic range from 32 to 100 to reflect modern displays
Fri Jul 19 17:37:56 2019 UTC (6 years, 3 months ago) by greg
Changes since 3.14: +2 -4 lines
Diff to previous 3.14
Thu Aug 2 18:33:43 2018 UTC (7 years, 3 months ago) by greg
Changes since 3.13: +2 -2 lines
Diff to previous 3.13
Fri May 20 02:06:39 2011 UTC (14 years, 5 months ago) by greg
Changes since 3.12: +5 -5 lines
Diff to previous 3.12
Sat Dec 4 00:24:43 2010 UTC (14 years, 11 months ago) by greg
Changes since 3.11: +3 -1 lines
Diff to previous 3.11
Added binary mode setting
Mon Nov 10 19:08:19 2008 UTC (16 years, 11 months ago) by greg
Diff to previous 3.10
Tue Sep 26 12:26:02 2006 UTC (19 years, 1 month ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.9: +3 -2 lines
Diff to previous 3.9
Fixed bug in pixel aspect ratio for some image orientations
Tue Jun 14 22:23:31 2005 UTC (20 years, 4 months ago) by greg
Changes since 3.8: +13 -9 lines
Diff to previous 3.8
Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 3.7: +34 -18 lines
Diff to previous 3.7
Fri Jan 2 11:42:37 2004 UTC (21 years, 10 months ago) by schorsch
Changes since 3.6: +18 -11 lines
Diff to previous 3.6
Sun Jul 27 22:12:03 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 3.5
Mon Jul 14 04:56:54 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.4: +2 -9 lines
Diff to previous 3.4
Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.3: +7 -12 lines
Diff to previous 3.3
Tue Oct 27 08:54:37 1998 UTC (27 years ago) by gwlarson
Changes since 3.2: +57 -40 lines
Diff to previous 3.2
modified openpicture to store header information
Mon Oct 26 17:30:50 1998 UTC (27 years ago) by gwlarson
Changes since 3.1: +22 -12 lines
improved error reporting methods
Mon Oct 26 17:05:28 1998 UTC (27 years ago) by gwlarson
