root/radiance/src/px/normtiff.c
Revision: 3.11
Committed: Mon Nov 10 19:08:19 2008 UTC (16 years, 11 months ago) by greg
2 static const char RCSid[] = "$Id: normtiff.c,v 3.10 2006/09/26 12:26:02 greg Exp $";
5 * Tone map SGILOG TIFF or Radiance picture and output 24-bit RGB TIFF
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include <string.h>
12
13 #include "tiffio.h"
14 #include "color.h"
15 #include "tonemap.h"
16 #include "tmaptiff.h"
17 #include "resolu.h"
18
19
20 TIFF *tifout; /* TIFF output */
21 int flags = TM_F_CAMERA; /* tone-mapping flags */
22 RGBPRIMP rgbp = stdprims; /* display primaries */
23 RGBPRIMS myprims; /* overriding display primaries */
24 double ldmax = 100.; /* maximum display luminance */
25 double lddyn = 32.; /* display dynamic range */
26 double gamv = 2.2; /* display gamma value */
27
28 short ortab[8] = { /* orientation conversion table */
29 YMAJOR|YDECR,
30 YMAJOR|YDECR|XDECR,
31 YMAJOR|XDECR,
32 YMAJOR,
33 YDECR,
34 XDECR|YDECR,
35 XDECR,
36 0
37 };
38
39 typedef struct {
40 FILE *fp; /* file pointer */
41 char fmt[32]; /* picture format */
42 double pa; /* pixel aspect ratio */
43 RESOLU rs; /* picture resolution */
44 } PICTURE;
45
46 uint16 comp = COMPRESSION_NONE; /* TIFF compression mode */
47
48 #define closepicture(p) (fclose((p)->fp),free((void *)(p)))
49
50 static gethfunc headline;
51
52 static int headline(char *s, void *pp);
53 static PICTURE *openpicture(char *fname);
54 static int tmap_picture(char *fname, PICTURE *pp);
55 static int tmap_tiff(char *fname, TIFF *tp);
56 static int putimage(uint16 or, uint32 xs, uint32 ys, float xr, float yr,
57 uint16 ru, BYTE *pd);
58
59
60 int
61 main(
62 int argc,
63 char *argv[]
64 )
65 {
66 PICTURE *pin = NULL;
67 TIFF *tin = NULL;
68 int i, rval;
69
70 for (i = 1; i < argc && argv[i][0] == '-'; i++)
71 switch (argv[i][1]) {
72 case 'h': /* human observer settings */
73 flags = TM_F_HUMAN;
74 break;
75 case 's': /* toggle human contrast */
76 flags ^= TM_F_HCONTR;
77 break;
78 case 'c': /* toggle mesopic sens. */
79 flags ^= TM_F_MESOPIC;
80 break;
81 case 'l': /* toggle linear mapping */
82 flags ^= TM_F_LINEAR;
83 break;
84 case 'b': /* toggle greyscale output */
85 flags ^= TM_F_BW;
86 break;
87 case 'g': /* set display gamma */
88 if (argc-i < 2) goto userr;
89 gamv = atof(argv[++i]);
90 break;
91 case 'u': /* set display maximum */
92 if (argc-i < 2) goto userr;
93 ldmax = atof(argv[++i]);
94 break;
95 case 'd': /* set display dynamic range */
96 if (argc-i < 2) goto userr;
97 lddyn = atof(argv[++i]);
98 break;
99 case 'z': /* LZW compression */
100 comp = COMPRESSION_LZW;
101 break;
102 case 'p': /* set display primaries */
103 if (argc-i < 9) goto userr;
104 myprims[RED][CIEX] = atof(argv[++i]);
105 myprims[RED][CIEY] = atof(argv[++i]);
106 myprims[GRN][CIEX] = atof(argv[++i]);
107 myprims[GRN][CIEY] = atof(argv[++i]);
108 myprims[BLU][CIEX] = atof(argv[++i]);
109 myprims[BLU][CIEY] = atof(argv[++i]);
110 myprims[WHT][CIEX] = atof(argv[++i]);
111 myprims[WHT][CIEY] = atof(argv[++i]);
112 rgbp = myprims;
113 break;
114 default:
115 goto userr;
116 }
117 if (argc-i < 2) goto userr;
118 if ((pin = openpicture(argv[i])) == NULL &&
119 (tin = TIFFOpen(argv[i], "r")) == NULL) {
120 fprintf(stderr, "%s: cannot open or interpret file \"%s\"\n",
121 argv[0], argv[i]);
122 exit(1);
123 }
124 if ((tifout = TIFFOpen(argv[i+1], "w")) == NULL) {
125 fprintf(stderr, "%s: cannot open output TIFF \"%s\"\n",
126 argv[0], argv[i+1]);
127 exit(1);
128 }
129 if (pin != NULL) {
130 rval = tmap_picture(argv[i], pin);
131 closepicture(pin);
132 } else {
133 rval = tmap_tiff(argv[i], tin);
134 TIFFClose(tin);
135 }
136 TIFFClose(tifout);
137 exit(rval==0 ? 0 : 1);
138 userr:
139 fprintf(stderr,
140 "Usage: %s [-h][-s][-c][-l][-b][-g gv][-d ld][-u lm][-z][-p xr yr xg yg xb yb xw yw] input.{tif|hdr} output.tif\n",
141 argv[0]);
142 exit(1);
143 }
144
145
146 static int
147 headline( /* process line from header */
148 char *s,
149 void *pp
150 )
151 {
152 register char *cp;
153
154 for (cp = s; *cp; cp++)
155 if (*cp & 0x80)
156 return(-1); /* non-ascii in header */
157 if (isaspect(s))
158 ((PICTURE *)pp)->pa *= aspectval(s);
159 else
160 formatval(((PICTURE *)pp)->fmt, s);
161 return(0);
162 }
163
164
165 static PICTURE *
166 openpicture( /* open/check Radiance picture file */
167 char *fname
168 )
169 {
170 FILE *fp;
171 register PICTURE *pp;
172 register char *cp;
173 /* check filename suffix */
174 if (fname == NULL) return(NULL);
175 for (cp = fname; *cp; cp++)
176 ;
177 while (cp > fname && cp[-1] != '.')
178 if (*--cp == '/') {
179 cp = fname;
180 break;
181 }
182 if (cp > fname && !strncmp(cp, "tif", 3))
183 return(NULL); /* assume it's a TIFF */
184 /* else try opening it */
185 if ((fp = fopen(fname, "r")) == NULL)
186 return(NULL);
187 /* allocate struct */
188 if ((pp = (PICTURE *)malloc(sizeof(PICTURE))) == NULL)
189 return(NULL); /* serious error -- should exit? */
190 pp->fp = fp; pp->fmt[0] = '\0'; pp->pa = 1.;
191 /* load header */
192 if (getheader(fp, headline, pp) < 0) {
193 closepicture(pp);
194 return(NULL);
195 }
196 if (!pp->fmt[0]) /* assume RGBE if unspecified */
197 strcpy(pp->fmt, COLRFMT);
198 if (!globmatch(PICFMT, pp->fmt) || !fgetsresolu(&pp->rs, fp)) {
199 closepicture(pp); /* failed test -- close file */
200 return(NULL);
201 }
202 rewind(fp); /* passed test -- rewind file */
203 return(pp);
204 }
205
206
207 static int
208 tmap_picture( /* tone map Radiance picture */
209 char *fname,
210 register PICTURE *pp
211 )
212 {
213 uint16 orient;
214 double paspect = (pp->rs.rt & YMAJOR) ? pp->pa : 1./pp->pa;
215 int xsiz, ysiz;
216 BYTE *pix;
217 /* read and tone map picture */
218 if (tmMapPicture(&pix, &xsiz, &ysiz, flags,
219 rgbp, gamv, lddyn, ldmax, fname, pp->fp) != TM_E_OK)
220 return(-1);
221 /* figure out TIFF orientation */
222 for (orient = 8; --orient; )
223 if (ortab[orient] == pp->rs.rt)
224 break;
225 orient++;
226 /* put out our image */
227 if (putimage(orient, (uint32)xsiz, (uint32)ysiz,
228 72., 72./paspect, 2, pix) != 0)
229 return(-1);
230 /* free data and we're done */
231 free((void *)pix);
232 return(0);
233 }
234
235
236 static int
237 tmap_tiff( /* tone map SGILOG TIFF */
238 char *fname,
239 TIFF *tp
240 )
241 {
242 float xres, yres;
243 uint16 orient, resunit, phot;
244 int xsiz, ysiz;
245 BYTE *pix;
246 /* check to make sure it's SGILOG */
247 TIFFGetFieldDefaulted(tp, TIFFTAG_PHOTOMETRIC, &phot);
248 if ((phot == PHOTOMETRIC_LOGL) | (phot == PHOTOMETRIC_MINISBLACK))
249 flags |= TM_F_BW;
250 /* read and tone map TIFF */
251 if (tmMapTIFF(&pix, &xsiz, &ysiz, flags,
252 rgbp, gamv, lddyn, ldmax, fname, tp) != TM_E_OK)
253 return(-1);
254 /* get relevant tags */
255 TIFFGetFieldDefaulted(tp, TIFFTAG_RESOLUTIONUNIT, &resunit);
256 TIFFGetFieldDefaulted(tp, TIFFTAG_XRESOLUTION, &xres);
257 TIFFGetFieldDefaulted(tp, TIFFTAG_YRESOLUTION, &yres);
258 TIFFGetFieldDefaulted(tp, TIFFTAG_ORIENTATION, &orient);
259 /* put out our image */
260 if (putimage(orient, (uint32)xsiz, (uint32)ysiz,
261 xres, yres, resunit, pix) != 0)
262 return(-1);
263 /* free data and we're done */
264 free((void *)pix);
265 return(0);
266 }
267
268
269 static int
270 putimage( /* write out our image */
271 uint16 or,
272 uint32 xs,
273 uint32 ys,
274 float xr,
275 float yr,
276 uint16 ru,
277 BYTE *pd
278 )
279 {
280 register int y;
281 uint32 rowsperstrip;
282
283 TIFFSetField(tifout, TIFFTAG_COMPRESSION, COMPRESSION_NONE);
284 if (flags & TM_F_BW) {
285 TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC,
286 PHOTOMETRIC_MINISBLACK);
287 TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 1);
288 } else {
289 TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC, PHOTOMETRIC_RGB);
290 TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 3);
291 }
292 if (rgbp != stdprims) {
293 TIFFSetField(tifout, TIFFTAG_PRIMARYCHROMATICITIES,
294 (float *)rgbp);
295 TIFFSetField(tifout, TIFFTAG_WHITEPOINT, (float *)rgbp[WHT]);
296 }
297 TIFFSetField(tifout, TIFFTAG_BITSPERSAMPLE, 8);
298 TIFFSetField(tifout, TIFFTAG_IMAGEWIDTH, xs);
299 TIFFSetField(tifout, TIFFTAG_IMAGELENGTH, ys);
300 TIFFSetField(tifout, TIFFTAG_RESOLUTIONUNIT, ru);
301 TIFFSetField(tifout, TIFFTAG_COMPRESSION, comp);
302 TIFFSetField(tifout, TIFFTAG_XRESOLUTION, xr);
303 TIFFSetField(tifout, TIFFTAG_YRESOLUTION, yr);
304 TIFFSetField(tifout, TIFFTAG_PLANARCONFIG, PLANARCONFIG_CONTIG);
305 TIFFSetField(tifout, TIFFTAG_ORIENTATION, or);
306 /* compute good strip size */
307 rowsperstrip = 8192/TIFFScanlineSize(tifout);
308 if (rowsperstrip < 1) rowsperstrip = 1;
309 TIFFSetField(tifout, TIFFTAG_ROWSPERSTRIP, rowsperstrip);
310 /* write out scanlines */
311 if (flags & TM_F_BW) {
312 for (y = 0; y < ys; y++)
313 if (TIFFWriteScanline(tifout, pd + y*xs, y, 0) < 0)
314 goto writerr;
315 } else {
316 for (y = 0; y < ys; y++)
317 if (TIFFWriteScanline(tifout, pd + y*3*xs, y, 0) < 0)
318 goto writerr;
319 }
320 return(0); /* all done! */
321 writerr:
322 fputs("Error writing TIFF output\n", stderr);
323 return(-1);
324 }
