root/radiance/src/px/mt160r.c
Sat Feb 22 02:07:27 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.5: +2 -4 lines
Mon Aug 2 14:39:10 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.4: +0 -3 lines
removed questionable line buffer setting
Mon Sep 21 12:13:29 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.3: +12 -4 lines
Changes for PC port
Wed Jan 29 15:18:34 1992 UTC (33 years, 8 months ago) by greg
Changes since 2.2: +4 -0 lines
removed line buffering of output
Mon Dec 23 22:35:30 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 2.1
removed unnecessary static declarations
Tue Nov 12 16:04:57 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.9
Mon Nov 11 14:01:28 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.8
Mon May 6 13:14:21 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.7
improved dithering slightly
Thu Apr 18 14:35:09 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.6: +4 -1 lines
Diff to previous 1.6
Fri Jan 26 08:17:31 1990 UTC (35 years, 8 months ago) by greg
Diff to previous 1.5
Thu Jan 25 08:28:33 1990 UTC (35 years, 8 months ago) by greg
Changes since 1.4: +1 -3 lines
Diff to previous 1.4
Fri Oct 20 20:35:59 1989 UTC (36 years ago) by greg
Changes since 1.3: +2 -3 lines
Diff to previous 1.3
change to color normalization calls
Fri Oct 20 16:44:32 1989 UTC (36 years ago) by greg
Changes since 1.2: +14 -13 lines
Diff to previous 1.2
eliminated unnecessary use of floating point color
Tue Sep 12 13:04:18 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +1 -2 lines
Diff to previous 1.1
Thu Feb 2 10:49:20 1989 UTC (36 years, 8 months ago) by greg
