| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: macbethcal.c,v 2.22 2003/11/10 12:28:56 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Calibrate a scanned MacBeth Color Checker Chart
| 6 |
| 7 |
* Produce a .cal file suitable for use with pcomb,
| 8 |
* or .cwp file suitable for use with pcwarp.
| 9 |
| 10 |
* Warping code depends on conformance of COLOR and W3VEC types.
| 11 |
| 12 |
| 13 |
#include <stdio.h>
| 14 |
#include <math.h>
| 15 |
#include <time.h>
| 16 |
| 17 |
#include "platform.h"
| 18 |
#include "rtprocess.h"
| 19 |
#include "rtio.h"
| 20 |
#include "color.h"
| 21 |
#include "resolu.h"
| 22 |
#include "pmap.h"
| 23 |
#include "warp3d.h"
| 24 |
#include "mx3.h"
| 25 |
| 26 |
/* MacBeth colors */
| 27 |
#define DarkSkin 0
| 28 |
#define LightSkin 1
| 29 |
#define BlueSky 2
| 30 |
#define Foliage 3
| 31 |
#define BlueFlower 4
| 32 |
#define BluishGreen 5
| 33 |
#define Orange 6
| 34 |
#define PurplishBlue 7
| 35 |
#define ModerateRed 8
| 36 |
#define Purple 9
| 37 |
#define YellowGreen 10
| 38 |
#define OrangeYellow 11
| 39 |
#define Blue 12
| 40 |
#define Green 13
| 41 |
#define Red 14
| 42 |
#define Yellow 15
| 43 |
#define Magenta 16
| 44 |
#define Cyan 17
| 45 |
#define White 18
| 46 |
#define Neutral8 19
| 47 |
#define Neutral65 20
| 48 |
#define Neutral5 21
| 49 |
#define Neutral35 22
| 50 |
#define Black 23
| 51 |
/* computed from 5nm spectral measurements */
| 52 |
/* CIE 1931 2 degree obs, equal-energy white */
| 53 |
float mbxyY[24][3] = {
| 54 |
{0.462, 0.3769, 0.0932961}, /* DarkSkin */
| 55 |
{0.4108, 0.3542, 0.410348}, /* LightSkin */
| 56 |
{0.2626, 0.267, 0.181554}, /* BlueSky */
| 57 |
{0.36, 0.4689, 0.108447}, /* Foliage */
| 58 |
{0.2977, 0.2602, 0.248407}, /* BlueFlower */
| 59 |
{0.2719, 0.3485, 0.401156}, /* BluishGreen */
| 60 |
{0.52, 0.4197, 0.357899}, /* Orange */
| 61 |
{0.229, 0.1866, 0.103911}, /* PurplishBlue */
| 62 |
{0.4909, 0.3262, 0.242615}, /* ModerateRed */
| 63 |
{0.3361, 0.2249, 0.0600102}, /* Purple */
| 64 |
{0.3855, 0.4874, 0.42963}, /* YellowGreen */
| 65 |
{0.4853, 0.4457, 0.476343}, /* OrangeYellow */
| 66 |
{0.2026, 0.1369, 0.0529249}, /* Blue */
| 67 |
{0.3007, 0.4822, 0.221226}, /* Green */
| 68 |
{0.5805, 0.3238, 0.162167}, /* Red */
| 69 |
{0.4617, 0.472, 0.64909}, /* Yellow */
| 70 |
{0.4178, 0.2625, 0.233662}, /* Magenta */
| 71 |
{0.2038, 0.2508, 0.167275}, /* Cyan */
| 72 |
{0.3358, 0.337, 0.916877}, /* White */
| 73 |
{0.3338, 0.3348, 0.604678}, /* Neutral.8 */
| 74 |
{0.3333, 0.3349, 0.364566}, /* Neutral.65 */
| 75 |
{0.3353, 0.3359, 0.200238}, /* Neutral.5 */
| 76 |
{0.3363, 0.336, 0.0878721}, /* Neutral.35 */
| 77 |
{0.3346, 0.3349, 0.0308383} /* Black */
| 78 |
| 79 |
| 80 |
COLOR mbRGB[24]; /* MacBeth RGB values */
| 81 |
| 82 |
#define NMBNEU 6 /* Number of MacBeth neutral colors */
| 83 |
short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
| 84 |
| 85 |
#define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
| 86 |
1L<<Neutral5|1L<<Neutral35|1L<<Black)
| 87 |
| 88 |
#define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
| 89 |
1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
| 90 |
1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
| 91 |
| 92 |
#define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
| 93 |
1L<<BluishGreen|1L<<ModerateRed)
| 94 |
| 95 |
#define REQFLGS NEUFLGS /* need these colors */
| 96 |
#define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
| 97 |
| 98 |
#define RG_BORD 0 /* patch border */
| 99 |
#define RG_CENT 01 /* central region of patch */
| 100 |
#define RG_ORIG 02 /* original color region */
| 101 |
#define RG_CORR 04 /* corrected color region */
| 102 |
| 103 |
#ifndef DISPCOM
| 104 |
#define DISPCOM "ximage -op \"%s\""
| 105 |
#endif
| 106 |
| 107 |
int scanning = 1; /* scanned input (or recorded output)? */
| 108 |
double irrad = 1.0; /* irradiance multiplication factor */
| 109 |
int rawmap = 0; /* put out raw color mapping? */
| 110 |
| 111 |
int xmax, ymax; /* input image dimensions */
| 112 |
int bounds[4][2]; /* image coordinates of chart corners */
| 113 |
double imgxfm[3][3]; /* coordinate transformation matrix */
| 114 |
| 115 |
COLOR inpRGB[24]; /* measured or scanned input colors */
| 116 |
long inpflags = 0; /* flags of which colors were input */
| 117 |
long gmtflags = 0; /* flags of out-of-gamut colors */
| 118 |
| 119 |
COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
| 120 |
COLORMAT solmat; /* color mapping matrix */
| 121 |
COLOR colmin, colmax; /* gamut limits */
| 122 |
| 123 |
WARP3D *wcor = NULL; /* color space warp */
| 124 |
| 125 |
FILE *debugfp = NULL; /* debug output picture */
| 126 |
char *progname;
| 127 |
| 128 |
static void init(void);
| 129 |
static int chartndx(int x, int y, int *np);
| 130 |
static void getpicture(void);
| 131 |
static void getcolors(void);
| 132 |
static void bresp(COLOR y, COLOR x);
| 133 |
static void compute(void);
| 134 |
static void putmapping(void);
| 135 |
static void compsoln(COLOR cin[], COLOR cout[], int n);
| 136 |
static void cwarp(void);
| 137 |
static int cvtcolor(COLOR cout, COLOR cin);
| 138 |
static int cresp(COLOR cout, COLOR cin);
| 139 |
static void xyY2RGB(COLOR rgbout, float xyYin[3]);
| 140 |
static void picdebug(void);
| 141 |
static void clrdebug(void);
| 142 |
static void getpos(char *name, int bnds[2], FILE *fp);
| 143 |
static void pickchartpos(char *pfn);
| 144 |
| 145 |
| 146 |
int
| 147 |
main(
| 148 |
int argc,
| 149 |
char **argv
| 150 |
| 151 |
| 152 |
int i;
| 153 |
| 154 |
progname = argv[0];
| 155 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 156 |
switch (argv[i][1]) {
| 157 |
case 'd': /* debug output */
| 158 |
i++;
| 159 |
if (badarg(argc-i, argv+i, "s"))
| 160 |
goto userr;
| 161 |
if ((debugfp = fopen(argv[i], "w")) == NULL) {
| 162 |
perror(argv[i]);
| 163 |
exit(1);
| 164 |
| 165 |
SET_FILE_BINARY(debugfp);
| 166 |
newheader("RADIANCE", debugfp); /* start */
| 167 |
printargs(argc, argv, debugfp); /* header */
| 168 |
break;
| 169 |
case 'p': /* picture position */
| 170 |
if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
| 171 |
goto userr;
| 172 |
bounds[0][0] = atoi(argv[++i]);
| 173 |
bounds[0][1] = atoi(argv[++i]);
| 174 |
bounds[1][0] = atoi(argv[++i]);
| 175 |
bounds[1][1] = atoi(argv[++i]);
| 176 |
bounds[2][0] = atoi(argv[++i]);
| 177 |
bounds[2][1] = atoi(argv[++i]);
| 178 |
bounds[3][0] = atoi(argv[++i]);
| 179 |
bounds[3][1] = atoi(argv[++i]);
| 180 |
scanning = 2;
| 181 |
break;
| 182 |
case 'P': /* pick position */
| 183 |
scanning = 3;
| 184 |
break;
| 185 |
case 'i': /* irradiance factor */
| 186 |
i++;
| 187 |
if (badarg(argc-i, argv+i, "f"))
| 188 |
goto userr;
| 189 |
irrad = atof(argv[i]);
| 190 |
break;
| 191 |
case 'm': /* raw map output */
| 192 |
rawmap = 1;
| 193 |
break;
| 194 |
case 'c': /* color input */
| 195 |
scanning = 0;
| 196 |
break;
| 197 |
default:
| 198 |
goto userr;
| 199 |
| 200 |
/* open files */
| 201 |
if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
| 202 |
perror(argv[i]);
| 203 |
exit(1);
| 204 |
| 205 |
if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
| 206 |
perror(argv[i+1]);
| 207 |
exit(1);
| 208 |
| 209 |
if (scanning) { /* load input picture header */
| 210 |
SET_FILE_BINARY(stdin);
| 211 |
if (checkheader(stdin, COLRFMT, NULL) < 0 ||
| 212 |
fgetresolu(&xmax, &ymax, stdin) < 0) {
| 213 |
fprintf(stderr, "%s: bad input picture\n", progname);
| 214 |
exit(1);
| 215 |
| 216 |
if (scanning == 3) {
| 217 |
if (i >= argc)
| 218 |
goto userr;
| 219 |
pickchartpos(argv[i]);
| 220 |
scanning = 2;
| 221 |
| 222 |
} else { /* else set default xmax and ymax */
| 223 |
xmax = 512;
| 224 |
ymax = 2*512/3;
| 225 |
| 226 |
if (scanning != 2) { /* use default boundaries */
| 227 |
bounds[0][0] = bounds[2][0] = .029*xmax + .5;
| 228 |
bounds[0][1] = bounds[1][1] = .956*ymax + .5;
| 229 |
bounds[1][0] = bounds[3][0] = .971*xmax + .5;
| 230 |
bounds[2][1] = bounds[3][1] = .056*ymax + .5;
| 231 |
| 232 |
init(); /* initialize */
| 233 |
if (scanning) /* get picture colors */
| 234 |
getpicture();
| 235 |
else
| 236 |
getcolors();
| 237 |
compute(); /* compute color mapping */
| 238 |
if (rawmap) { /* print out raw correspondence */
| 239 |
register int j;
| 240 |
| 241 |
printf("# Color correspondence produced by:\n#\t\t");
| 242 |
printargs(argc, argv, stdout);
| 243 |
printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
| 244 |
i+1 < argc ? argv[i+1] : "{this_file}");
| 245 |
printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
| 246 |
| 247 |
for (j = 0; j < 24; j++)
| 248 |
printf("%f %f %f %f %f %f\n",
| 249 |
colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
| 250 |
colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
| 251 |
colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
| 252 |
if (scanning && debugfp != NULL)
| 253 |
cwarp(); /* color warp for debugging */
| 254 |
} else { /* print color mapping */
| 255 |
/* print header */
| 256 |
printf("{\n\tColor correction file computed by:\n\t\t");
| 257 |
| 258 |
printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
| 259 |
| 260 |
if (!scanning)
| 261 |
printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
| 262 |
| 263 |
printf("}\n");
| 264 |
putmapping(); /* put out color mapping */
| 265 |
| 266 |
if (debugfp != NULL) { /* put out debug picture */
| 267 |
if (scanning)
| 268 |
picdebug();
| 269 |
else
| 270 |
clrdebug();
| 271 |
| 272 |
exit(0);
| 273 |
userr:
| 274 |
fprintf(stderr,
| 275 |
"Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
| 276 |
progname);
| 277 |
fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
| 278 |
progname);
| 279 |
exit(1);
| 280 |
return 1; /* pro forma return */
| 281 |
| 282 |
| 283 |
| 284 |
static void
| 285 |
init(void) /* initialize */
| 286 |
| 287 |
double quad[4][2];
| 288 |
register int i;
| 289 |
/* make coordinate transformation */
| 290 |
quad[0][0] = bounds[0][0];
| 291 |
quad[0][1] = bounds[0][1];
| 292 |
quad[1][0] = bounds[1][0];
| 293 |
quad[1][1] = bounds[1][1];
| 294 |
quad[2][0] = bounds[3][0];
| 295 |
quad[2][1] = bounds[3][1];
| 296 |
quad[3][0] = bounds[2][0];
| 297 |
quad[3][1] = bounds[2][1];
| 298 |
| 299 |
if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
| 300 |
fprintf(stderr, "%s: bad chart boundaries\n", progname);
| 301 |
exit(1);
| 302 |
| 303 |
/* map MacBeth colors to RGB space */
| 304 |
for (i = 0; i < 24; i++) {
| 305 |
xyY2RGB(mbRGB[i], mbxyY[i]);
| 306 |
scalecolor(mbRGB[i], irrad);
| 307 |
| 308 |
| 309 |
| 310 |
| 311 |
static int
| 312 |
chartndx( /* find color number for position */
| 313 |
int x,
| 314 |
int y,
| 315 |
int *np
| 316 |
| 317 |
| 318 |
double ipos[3], cpos[3];
| 319 |
int ix, iy;
| 320 |
double fx, fy;
| 321 |
| 322 |
ipos[0] = x;
| 323 |
ipos[1] = y;
| 324 |
ipos[2] = 1;
| 325 |
mx3d_transform(ipos, imgxfm, cpos);
| 326 |
cpos[0] /= cpos[2];
| 327 |
cpos[1] /= cpos[2];
| 328 |
if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
| 329 |
return(RG_BORD);
| 330 |
ix = cpos[0];
| 331 |
iy = cpos[1];
| 332 |
fx = cpos[0] - ix;
| 333 |
fy = cpos[1] - iy;
| 334 |
*np = iy*6 + ix;
| 335 |
if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
| 336 |
return(RG_CENT);
| 337 |
if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
| 338 |
return(RG_BORD);
| 339 |
if (fx >= 0.5) /* right side is corrected */
| 340 |
return(RG_CORR);
| 341 |
return(RG_ORIG); /* left side is original */
| 342 |
| 343 |
| 344 |
| 345 |
static void
| 346 |
getpicture(void) /* load in picture colors */
| 347 |
| 348 |
COLR *scanln;
| 349 |
COLOR pval;
| 350 |
int ccount[24];
| 351 |
double d;
| 352 |
int y, i;
| 353 |
register int x;
| 354 |
| 355 |
scanln = (COLR *)malloc(xmax*sizeof(COLR));
| 356 |
if (scanln == NULL) {
| 357 |
perror(progname);
| 358 |
exit(1);
| 359 |
| 360 |
| 361 |
setcolor(inpRGB[i], 0., 0., 0.);
| 362 |
ccount[i] = 0;
| 363 |
| 364 |
for (y = ymax-1; y >= 0; y--) {
| 365 |
if (freadcolrs(scanln, xmax, stdin) < 0) {
| 366 |
fprintf(stderr, "%s: error reading input picture\n",
| 367 |
progname);
| 368 |
exit(1);
| 369 |
| 370 |
for (x = 0; x < xmax; x++)
| 371 |
if (chartndx(x, y, &i) == RG_CENT) {
| 372 |
colr_color(pval, scanln[x]);
| 373 |
addcolor(inpRGB[i], pval);
| 374 |
ccount[i]++;
| 375 |
| 376 |
| 377 |
for (i = 0; i < 24; i++) { /* compute averages */
| 378 |
if (ccount[i] == 0)
| 379 |
continue;
| 380 |
d = 1./ccount[i];
| 381 |
scalecolor(inpRGB[i], d);
| 382 |
inpflags |= 1L<<i;
| 383 |
| 384 |
free((void *)scanln);
| 385 |
| 386 |
| 387 |
| 388 |
static void
| 389 |
getcolors(void) /* get xyY colors from standard input */
| 390 |
| 391 |
int gotwhite = 0;
| 392 |
COLOR whiteclr;
| 393 |
int n;
| 394 |
float xyYin[3];
| 395 |
| 396 |
while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
| 397 |
if ((n < 0) | (n > 24) ||
| 398 |
fgetval(stdin, 'f', &xyYin[0]) != 1 ||
| 399 |
fgetval(stdin, 'f', &xyYin[1]) != 1 ||
| 400 |
fgetval(stdin, 'f', &xyYin[2]) != 1 ||
| 401 |
(xyYin[0] < 0.) | (xyYin[1] < 0.) ||
| 402 |
xyYin[0] + xyYin[1] > 1.) {
| 403 |
fprintf(stderr, "%s: bad color input data\n",
| 404 |
progname);
| 405 |
exit(1);
| 406 |
| 407 |
if (n == 0) { /* calibration white */
| 408 |
xyY2RGB(whiteclr, xyYin);
| 409 |
gotwhite++;
| 410 |
} else { /* standard color */
| 411 |
n--;
| 412 |
xyY2RGB(inpRGB[n], xyYin);
| 413 |
inpflags |= 1L<<n;
| 414 |
| 415 |
| 416 |
/* normalize colors */
| 417 |
if (!gotwhite) {
| 418 |
if (!(inpflags & 1L<<White)) {
| 419 |
fprintf(stderr, "%s: missing input for White\n",
| 420 |
progname);
| 421 |
exit(1);
| 422 |
| 423 |
setcolor(whiteclr,
| 424 |
colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
| 425 |
colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
| 426 |
colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
| 427 |
| 428 |
for (n = 0; n < 24; n++)
| 429 |
if (inpflags & 1L<<n)
| 430 |
setcolor(inpRGB[n],
| 431 |
colval(inpRGB[n],RED)/colval(whiteclr,RED),
| 432 |
colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
| 433 |
colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
| 434 |
| 435 |
| 436 |
| 437 |
static void
| 438 |
bresp( /* piecewise linear interpolation of primaries */
| 439 |
COLOR y,
| 440 |
COLOR x
| 441 |
| 442 |
| 443 |
register int i, n;
| 444 |
| 445 |
for (i = 0; i < 3; i++) {
| 446 |
for (n = 0; n < NMBNEU-2; n++)
| 447 |
if (colval(x,i) < colval(bramp[n+1][0],i))
| 448 |
break;
| 449 |
colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
| 450 |
colval(bramp[n][1],i) +
| 451 |
(colval(x,i) - colval(bramp[n][0],i)) *
| 452 |
colval(bramp[n+1][1],i)) /
| 453 |
(colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
| 454 |
| 455 |
| 456 |
| 457 |
| 458 |
static void
| 459 |
compute(void) /* compute color mapping */
| 460 |
| 461 |
COLOR clrin[24], clrout[24];
| 462 |
long cflags;
| 463 |
COLOR ctmp;
| 464 |
register int i, n;
| 465 |
/* did we get what we need? */
| 466 |
if ((inpflags & REQFLGS) != REQFLGS) {
| 467 |
fprintf(stderr, "%s: missing required input colors\n",
| 468 |
progname);
| 469 |
exit(1);
| 470 |
| 471 |
/* compute piecewise luminance curve */
| 472 |
for (i = 0; i < NMBNEU; i++) {
| 473 |
copycolor(bramp[i][0], inpRGB[mbneu[i]]);
| 474 |
copycolor(bramp[i][1], mbRGB[mbneu[i]]);
| 475 |
| 476 |
/* compute color space gamut */
| 477 |
if (scanning) {
| 478 |
copycolor(colmin, cblack);
| 479 |
copycolor(colmax, cwhite);
| 480 |
scalecolor(colmax, irrad);
| 481 |
} else
| 482 |
| 483 |
colval(colmin,i) = colval(bramp[0][0],i) -
| 484 |
colval(bramp[0][1],i) *
| 485 |
(colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
| 486 |
(colval(bramp[1][1],i)-colval(bramp[1][0],i));
| 487 |
colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
| 488 |
(1.-colval(bramp[NMBNEU-2][1],i)) *
| 489 |
(colval(bramp[NMBNEU-1][0],i) -
| 490 |
colval(bramp[NMBNEU-2][0],i)) /
| 491 |
(colval(bramp[NMBNEU-1][1],i) -
| 492 |
colval(bramp[NMBNEU-2][1],i));
| 493 |
| 494 |
| 495 |
do {
| 496 |
cflags = inpflags & ~gmtflags;
| 497 |
n = 0; /* compute transform matrix */
| 498 |
| 499 |
if (cflags & 1L<<i) {
| 500 |
bresp(clrin[n], inpRGB[i]);
| 501 |
copycolor(clrout[n], mbRGB[i]);
| 502 |
n++;
| 503 |
| 504 |
compsoln(clrin, clrout, n);
| 505 |
if (irrad > 0.99 && irrad < 1.01) /* check gamut */
| 506 |
| 507 |
if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
| 508 |
gmtflags |= 1L<<i;
| 509 |
} while (cflags & gmtflags);
| 510 |
if (gmtflags & MODFLGS)
| 511 |
fprintf(stderr,
| 512 |
"%s: warning - some moderate colors are out of gamut\n",
| 513 |
progname);
| 514 |
| 515 |
| 516 |
| 517 |
static void
| 518 |
putmapping(void) /* put out color mapping */
| 519 |
| 520 |
static char cchar[3] = {'r', 'g', 'b'};
| 521 |
register int i, j;
| 522 |
/* print brightness mapping */
| 523 |
for (j = 0; j < 3; j++) {
| 524 |
printf("%cxa(i) : select(i", cchar[j]);
| 525 |
| 526 |
printf(",%g", colval(bramp[i][0],j));
| 527 |
printf(");\n");
| 528 |
printf("%cya(i) : select(i", cchar[j]);
| 529 |
| 530 |
printf(",%g", colval(bramp[i][1],j));
| 531 |
printf(");\n");
| 532 |
printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
| 533 |
cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
| 534 |
cchar[j], cchar[j]);
| 535 |
printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
| 536 |
printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
| 537 |
cchar[j], scanning?'n':'o', cchar[j],
| 538 |
cchar[j], cchar[j], cchar[j], cchar[j]);
| 539 |
printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
| 540 |
| 541 |
| 542 |
printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
| 543 |
| 544 |
| 545 |
| 546 |
if (scanning) {
| 547 |
printf("r = ri(1); g = gi(1); b = bi(1);\n");
| 548 |
printf("ro = %g*rn + %g*gn + %g*bn ;\n",
| 549 |
solmat[0][0], solmat[0][1], solmat[0][2]);
| 550 |
printf("go = %g*rn + %g*gn + %g*bn ;\n",
| 551 |
solmat[1][0], solmat[1][1], solmat[1][2]);
| 552 |
printf("bo = %g*rn + %g*gn + %g*bn ;\n",
| 553 |
solmat[2][0], solmat[2][1], solmat[2][2]);
| 554 |
} else {
| 555 |
printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
| 556 |
printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
| 557 |
| 558 |
printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
| 559 |
| 560 |
printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
| 561 |
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
static void
| 567 |
compsoln( /* solve 3xN system using least-squares */
| 568 |
COLOR cin[],
| 569 |
COLOR cout[],
| 570 |
int n
| 571 |
| 572 |
| 573 |
extern double mx3d_adjoint(), fabs();
| 574 |
double mat[3][3], invmat[3][3];
| 575 |
double det;
| 576 |
double colv[3], rowv[3];
| 577 |
register int i, j, k;
| 578 |
| 579 |
if (n < 3) {
| 580 |
fprintf(stderr, "%s: too few colors to match!\n", progname);
| 581 |
exit(1);
| 582 |
| 583 |
if (n == 3)
| 584 |
| 585 |
| 586 |
mat[i][j] = colval(cin[j],i);
| 587 |
else { /* compute A^t A */
| 588 |
| 589 |
for (j = i; j < 3; j++) {
| 590 |
mat[i][j] = 0.;
| 591 |
for (k = 0; k < n; k++)
| 592 |
mat[i][j] += colval(cin[k],i) *
| 593 |
colval(cin[k],j);
| 594 |
| 595 |
for (i = 1; i < 3; i++) /* using symmetry */
| 596 |
for (j = 0; j < i; j++)
| 597 |
mat[i][j] = mat[j][i];
| 598 |
| 599 |
det = mx3d_adjoint(mat, invmat);
| 600 |
if (fabs(det) < 1e-4) {
| 601 |
fprintf(stderr, "%s: cannot compute color mapping\n",
| 602 |
progname);
| 603 |
solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
| 604 |
solmat[0][1] = solmat[0][2] = solmat[1][0] =
| 605 |
solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
| 606 |
return;
| 607 |
| 608 |
| 609 |
| 610 |
invmat[i][j] /= det;
| 611 |
| 612 |
if (n == 3)
| 613 |
| 614 |
colv[j] = colval(cout[j],i);
| 615 |
else
| 616 |
| 617 |
colv[j] = 0.;
| 618 |
| 619 |
colv[j] += colval(cout[k],i) *
| 620 |
colval(cin[k],j);
| 621 |
| 622 |
mx3d_transform(colv, invmat, rowv);
| 623 |
| 624 |
solmat[i][j] = rowv[j];
| 625 |
| 626 |
| 627 |
| 628 |
| 629 |
static void
| 630 |
cwarp(void) /* compute color warp map */
| 631 |
| 632 |
register int i;
| 633 |
| 634 |
if ((wcor = new3dw(W3EXACT)) == NULL)
| 635 |
goto memerr;
| 636 |
| 637 |
if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
| 638 |
goto memerr;
| 639 |
return;
| 640 |
memerr:
| 641 |
perror(progname);
| 642 |
exit(1);
| 643 |
| 644 |
| 645 |
| 646 |
static int
| 647 |
cvtcolor( /* convert color according to our mapping */
| 648 |
COLOR cout,
| 649 |
COLOR cin
| 650 |
| 651 |
| 652 |
COLOR ctmp;
| 653 |
int clipped;
| 654 |
| 655 |
if (wcor != NULL) {
| 656 |
clipped = warp3d(cout, cin, wcor);
| 657 |
clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
| 658 |
} else if (scanning) {
| 659 |
bresp(ctmp, cin);
| 660 |
clipped = cresp(cout, ctmp);
| 661 |
} else {
| 662 |
clipped = cresp(ctmp, cin);
| 663 |
bresp(cout, ctmp);
| 664 |
| 665 |
return(clipped);
| 666 |
| 667 |
| 668 |
| 669 |
static int
| 670 |
cresp( /* transform color according to matrix */
| 671 |
COLOR cout,
| 672 |
COLOR cin
| 673 |
| 674 |
| 675 |
colortrans(cout, solmat, cin);
| 676 |
return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
| 677 |
| 678 |
| 679 |
| 680 |
static void
| 681 |
xyY2RGB( /* convert xyY to RGB */
| 682 |
COLOR rgbout,
| 683 |
register float xyYin[3]
| 684 |
| 685 |
| 686 |
COLOR ctmp;
| 687 |
double d;
| 688 |
| 689 |
d = xyYin[2] / xyYin[1];
| 690 |
ctmp[0] = xyYin[0] * d;
| 691 |
ctmp[1] = xyYin[2];
| 692 |
ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
| 693 |
/* allow negative values */
| 694 |
colortrans(rgbout, xyz2rgbmat, ctmp);
| 695 |
| 696 |
| 697 |
| 698 |
static void
| 699 |
picdebug(void) /* put out debugging picture */
| 700 |
| 701 |
static COLOR blkcol = BLKCOLOR;
| 702 |
COLOR *scan;
| 703 |
int y, i;
| 704 |
register int x, rg;
| 705 |
| 706 |
if (fseek(stdin, 0L, 0) == EOF) {
| 707 |
fprintf(stderr, "%s: cannot seek on input picture\n", progname);
| 708 |
exit(1);
| 709 |
| 710 |
getheader(stdin, NULL, NULL); /* skip input header */
| 711 |
fgetresolu(&xmax, &ymax, stdin);
| 712 |
/* allocate scanline */
| 713 |
scan = (COLOR *)malloc(xmax*sizeof(COLOR));
| 714 |
if (scan == NULL) {
| 715 |
perror(progname);
| 716 |
exit(1);
| 717 |
| 718 |
/* finish debug header */
| 719 |
fputformat(COLRFMT, debugfp);
| 720 |
putc('\n', debugfp);
| 721 |
fprtresolu(xmax, ymax, debugfp);
| 722 |
/* write debug picture */
| 723 |
| 724 |
if (freadscan(scan, xmax, stdin) < 0) {
| 725 |
fprintf(stderr, "%s: error rereading input picture\n",
| 726 |
progname);
| 727 |
exit(1);
| 728 |
| 729 |
for (x = 0; x < xmax; x++) {
| 730 |
rg = chartndx(x, y, &i);
| 731 |
if (rg == RG_CENT) {
| 732 |
if (!(1L<<i & gmtflags) || (x+y)&07) {
| 733 |
copycolor(scan[x], mbRGB[i]);
| 734 |
clipgamut(scan[x], bright(scan[x]),
| 735 |
CGAMUT, colmin, colmax);
| 736 |
} else
| 737 |
copycolor(scan[x], blkcol);
| 738 |
} else if (rg == RG_CORR)
| 739 |
cvtcolor(scan[x], scan[x]);
| 740 |
else if (rg != RG_ORIG)
| 741 |
| 742 |
| 743 |
if (fwritescan(scan, xmax, debugfp) < 0) {
| 744 |
fprintf(stderr, "%s: error writing debugging picture\n",
| 745 |
progname);
| 746 |
exit(1);
| 747 |
| 748 |
| 749 |
/* clean up */
| 750 |
fclose(debugfp);
| 751 |
free((void *)scan);
| 752 |
| 753 |
| 754 |
| 755 |
static void
| 756 |
clrdebug(void) /* put out debug picture from color input */
| 757 |
| 758 |
static COLR blkclr = BLKCOLR;
| 759 |
COLR mbclr[24], cvclr[24], orclr[24];
| 760 |
COLR *scan;
| 761 |
COLOR ctmp, ct2;
| 762 |
int y, i;
| 763 |
register int x, rg;
| 764 |
/* convert colors */
| 765 |
| 766 |
copycolor(ctmp, mbRGB[i]);
| 767 |
clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
| 768 |
setcolr(mbclr[i], colval(ctmp,RED),
| 769 |
colval(ctmp,GRN), colval(ctmp,BLU));
| 770 |
if (inpflags & 1L<<i) {
| 771 |
copycolor(ctmp, inpRGB[i]);
| 772 |
| 773 |
setcolr(orclr[i], colval(ctmp,RED),
| 774 |
| 775 |
if (rawmap)
| 776 |
copycolr(cvclr[i], mbclr[i]);
| 777 |
else {
| 778 |
bresp(ctmp, inpRGB[i]);
| 779 |
colortrans(ct2, solmat, ctmp);
| 780 |
clipgamut(ct2, bright(ct2), CGAMUT,
| 781 |
cblack, cwhite);
| 782 |
setcolr(cvclr[i], colval(ct2,RED),
| 783 |
colval(ct2,GRN),
| 784 |
colval(ct2,BLU));
| 785 |
| 786 |
| 787 |
| 788 |
| 789 |
scan = (COLR *)malloc(xmax*sizeof(COLR));
| 790 |
if (scan == NULL) {
| 791 |
perror(progname);
| 792 |
exit(1);
| 793 |
| 794 |
| 795 |
| 796 |
| 797 |
| 798 |
| 799 |
| 800 |
| 801 |
| 802 |
| 803 |
| 804 |
copycolr(scan[x], mbclr[i]);
| 805 |
else
| 806 |
copycolr(scan[x], blkclr);
| 807 |
} else if (rg == RG_BORD || !(1L<<i & inpflags))
| 808 |
| 809 |
else if (rg == RG_ORIG)
| 810 |
copycolr(scan[x], orclr[i]);
| 811 |
else /* rg == RG_CORR */
| 812 |
copycolr(scan[x], cvclr[i]);
| 813 |
| 814 |
if (fwritecolrs(scan, xmax, debugfp) < 0) {
| 815 |
| 816 |
progname);
| 817 |
exit(1);
| 818 |
| 819 |
| 820 |
/* clean up */
| 821 |
fclose(debugfp);
| 822 |
free((void *)scan);
| 823 |
| 824 |
| 825 |
| 826 |
static void
| 827 |
getpos( /* get boundary position */
| 828 |
char *name,
| 829 |
int bnds[2],
| 830 |
FILE *fp
| 831 |
| 832 |
| 833 |
char buf[64];
| 834 |
| 835 |
fprintf(stderr, "\tSelect corner: %s\n", name);
| 836 |
if (fgets(buf, sizeof(buf), fp) == NULL ||
| 837 |
sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
| 838 |
fprintf(stderr, "%s: read error from display process\n",
| 839 |
progname);
| 840 |
exit(1);
| 841 |
| 842 |
| 843 |
| 844 |
| 845 |
static void
| 846 |
pickchartpos( /* display picture and pick chart location */
| 847 |
char *pfn
| 848 |
| 849 |
| 850 |
char combuf[PATH_MAX];
| 851 |
FILE *pfp;
| 852 |
| 853 |
sprintf(combuf, DISPCOM, pfn);
| 854 |
if ((pfp = popen(combuf, "r")) == NULL) {
| 855 |
perror(combuf);
| 856 |
exit(1);
| 857 |
| 858 |
fputs("Use middle mouse button to select chart corners:\n", stderr);
| 859 |
getpos("upper left (dark skin)", bounds[0], pfp);
| 860 |
getpos("upper right (bluish green)", bounds[1], pfp);
| 861 |
getpos("lower left (white)", bounds[2], pfp);
| 862 |
getpos("lower right (black)", bounds[3], pfp);
| 863 |
fputs("Got it -- quit display program.\n", stderr);
| 864 |
pclose(pfp);
| 865 |
