root/radiance/src/px/cut.c
Revision: 2.5
Committed: Mon Nov 8 18:49:18 2004 UTC (20 years, 11 months ago) by greg
State: FILE REMOVED
Removed unused modules I missed last time
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.5 static const char RCSid[] = "$Id: cut.c,v 2.4 2004/03/28 20:33:13 schorsch Exp $";
3 greg 1.1 #endif
4 greg 1.2 /*
5 greg 1.1 CUT - Median bisection (k-d tree) algorithm for color image quantization
6
7     flaw: doesn't always create as many colors as requested
8     because the binary subdivision is always done in a balanced tree and when a box
9     contains only one color it's unsplittable
10
11     Paul Heckbert
12     */
13
14     #include "ciq.h"
15
16     struct index {short *o; int freq;};
17     /* offset and pixel count for a box */
18
19     struct pail {struct plum *first; int freak;};
20     /* each pail is a bucket containing plums */
21
22     struct plum {struct plum *next; int code;};
23     /* a color in a pail's linked list */
24
25     static short off[len];
26     /* color codes: offsets of colors in hist array */
27
28 schorsch 2.4 static void splitbox(struct index *ii, struct index *io);
29 greg 1.1
30 schorsch 2.4
31     int
32     makecm( /* subdivide colorspace to generate a colormap*/
33     int nw,
34     int *na /* number of colors wanted, actual */
35     )
36 greg 1.1 {
37     int i,m,n,freq,weight,sr,sg,sb;
38     short *o;
39     struct index index[257]; /* pointers into off */
40     /* index[i].o is pointer to code for first color in box i */
41
42     for (o=off, *na=i=0; i<len; i++)
43     if (hist[i]) {
44     (*na)++;
45     *o++ = i; /* initialize offsets */
46     }
47     index[0].o = off; /* start with one big box which contains all *na colors */
48     index[0].freq = xmax*ymax; /* and (sum of hist[i]) pixels */
49     index[1].o = off+*na;
50
51     /* breadth-first binary subdivision: try to make nw boxes */
52     for (m=1; m<nw; m<<=1) {
53     /*printf("%d ",m);*/
54     index[m<<1].o = index[m].o;
55     for (i=m-1; i>=0; --i) splitbox(index+i,index+(i<<1));
56     }
57     for (n=i=0; i<m && n<nw; i++) if (index[i+1].o>index[i].o) {
58     sr = sg = sb = (freq = index[i].freq)>>1;
59     for (o=index[i].o; o<index[i+1].o; o++) {
60     weight = hist[*o];
61     /* find weighted average of colors in box i */
62     sr += red(*o)*weight;
63     sg += gre(*o)*weight;
64     sb += blu(*o)*weight;
65     }
66     color[0][n] = sr/freq;
67     color[1][n] = sg/freq;
68     color[2][n] = sb/freq;
69     /* printf("color[%d]=(%3d,%3d,%3d) freq=%d\n",
70     n,color[0][n],color[1][n],color[2][n],freq); */
71     n++;
72     }
73     /*printf("[%d empty boxes] from %d to %d colors\n",nw-n,*na,n);*/
74     return n;
75     }
76
77 schorsch 2.4 static void
78     splitbox( /* split a box in two: half of the pixels from */
79     struct index *ii, /* box ii will go into io, the other half into io+1 */
80     struct index *io
81     )
82 greg 1.1 {
83     register short *o,*o1,*o2;
84     register int shift,count,k,freq,r,g,b,r1,g1,b1,r2,g2,b2;
85     struct pail pail[32],*p,*q; /* buckets for sorting colors */
86     struct plum plum[len],*pl=plum,*u; /* colors */
87
88     o1 = ii[0].o;
89     o2 = ii[1].o;
90     freq = ii[0].freq; /* number of pixels with color in this box */
91     r1 = g1 = b1 = 256; r2 = g2 = b2 = -1;
92     for (o=o1; o<o2; o++) {
93     r = red(*o);
94     g = gre(*o);
95     b = blu(*o);
96     if (r<r1) r1 = r; if (r>r2) r2 = r; /* find min&max r, g, and b */
97     if (g<g1) g1 = g; if (g>g2) g2 = g;
98     if (b<b1) b1 = b; if (b>b2) b2 = b;
99     }
100
101     /* adaptive partitioning: find dominant dimension */
102     shift = r2-r1>g2-g1?r2-r1>=b2-b1?10:0:g2-g1>=b2-b1?5:0;
103     /* printf("splitbox %3d-%3d %3dx%3dx%3d %c ",
104     o1-off,o2-off,r2-r1,g2-g1,b2-b1,shift==10?'R':shift==5?'G':'B'); */
105
106     for (p=pail, k=0; k<32; k++, p++) { /* start with empty pails */
107     p->first = 0;
108     p->freak = 0;
109     }
110     for (o=o1; o<o2; o++) {
111     p = pail+(*o>>shift&31); /* find appropriate pail */
112     pl->code = *o;
113     pl->next = p->first;
114     p->first = pl++; /* add new plum to pail */
115     p->freak += hist[*o];
116     }
117
118     /* find median along dominant dimension */
119     for (count=freq>>1, p=pail; count>0; p++) count -= p->freak;
120
121     if (p>pail && count+(p-1)->freak<-count) /* back up one? */
122     count += (--p)->freak;
123
124     io[1].o = o1; /* in case of empty box */
125     for (o=o1, q=pail; o<o2;) { /* dump the pails to reorder colors in box */
126     for (u=q->first; u; u=u->next) *o++ = u->code;
127     if (++q==p) io[1].o = o; /* place partition at offset o */
128     }
129     io[0].o = o1;
130     io[0].freq = (freq>>1)-count;
131 schorsch 2.3 io[1].freq = ((freq+1)>>1)+count;
132 greg 1.1 /* printf(" at %3d %d=%d+%d\n",io[1].o-off,freq,io[0].freq,io[1].freq); */
133     }
