root/radiance/src/px/clrtab.c
Revision: 2.1
Committed: Mon Oct 12 12:58:39 1992 UTC (33 years ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Simple median-cut color quantization based on colortab.c
9 */
10
11 #include "standard.h"
12
13 #include "color.h"
14 /* histogram resolution */
15 #define NRED 36
16 #define NGRN 48
17 #define NBLU 24
18 #define HMAX NGRN
19 /* minimum box count for adaptive partition */
20 #define MINSAMP 7
21 /* color partition */
22 #define set_branch(p,c) ((c)<<2|(p))
23 #define part(cn) ((cn)>>2)
24 #define prim(cn) ((cn)&3)
25 /* our color table (global) */
26 BYTE clrtab[256][3];
27 /* histogram of colors / color assignments */
28 static unsigned histo[NRED][NGRN][NBLU];
29 #define cndx(c) histo[((c)[RED]*NRED)>>8][((c)[GRN]*NGRN)>>8][((c)[BLU]*NBLU)>>8]
30 /* initial color cube boundary */
31 static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU};
32 /* maximum propagated error during dithering */
33 #define MAXERR 20
34
35
36 new_histo() /* clear our histogram */
37 {
38 bzero((char *)histo, sizeof(histo));
39 }
40
41
42 cnt_pixel(col) /* add pixel to our histogram */
43 register BYTE col[];
44 {
45 cndx(col)++;
46 }
47
48
49 cnt_colrs(cs, n) /* add a scanline to our histogram */
50 register COLR *cs;
51 register int n;
52 {
53 while (n-- > 0) {
54 cndx(cs[0])++;
55 cs++;
56 }
57 }
58
59
60 new_clrtab(ncolors) /* make new color table using ncolors */
61 int ncolors;
62 {
63 if (ncolors < 1)
64 return(0);
65 if (ncolors > 256)
66 ncolors = 256;
67 /* partition color space */
68 cut(CLRCUBE, 0, ncolors);
69 /* return new color table size */
70 return(ncolors);
71 }
72
73
74 int
75 map_pixel(col) /* get pixel for color */
76 register BYTE col[];
77 {
78 return(cndx(col));
79 }
80
81
82 map_colrs(bs, cs, n) /* convert a scanline to color index values */
83 register BYTE *bs;
84 register COLR *cs;
85 register int n;
86 {
87 while (n-- > 0) {
88 *bs++ = cndx(cs[0]);
89 cs++;
90 }
91 }
92
93
94 dith_colrs(bs, cs, n) /* convert scanline to dithered index values */
95 register BYTE *bs;
96 register COLR *cs;
97 int n;
98 {
99 static short (*cerr)[3];
100 static int N = 0;
101 int err[3], errp[3];
102 register int x, i;
103
104 if (n != N) { /* get error propogation array */
105 if (N)
106 cerr = (short (*)[3])realloc((char *)cerr,
107 3*n*sizeof(short));
108 else
109 cerr = (short (*)[3])malloc(3*n*sizeof(short));
110 if (cerr == NULL) {
111 N = 0;
112 map_colrs(bs, cs, n);
113 return;
114 }
115 N = n;
116 bzero((char *)cerr, 3*N*sizeof(short));
117 }
118 err[0] = err[1] = err[2] = 0;
119 for (x = 0; x < n; x++) {
120 for (i = 0; i < 3; i++) { /* dither value */
121 errp[i] = err[i];
122 err[i] += cerr[x][i];
123 #ifdef MAXERR
124 if (err[i] > MAXERR) err[i] = MAXERR;
125 else if (err[i] < -MAXERR) err[i] = -MAXERR;
126 #endif
127 err[i] += cs[x][i];
128 if (err[i] < 0) err[i] = 0;
129 else if (err[i] > 255) err[i] = 255;
130 }
131 bs[x] = cndx(err);
132 for (i = 0; i < 3; i++) { /* propagate error */
133 err[i] -= clrtab[bs[x]][i];
134 err[i] /= 3;
135 cerr[x][i] = err[i] + errp[i];
136 }
137 }
138 }
139
140
141 static
142 cut(box, c0, c1) /* partition color space */
143 register int box[3][2];
144 int c0, c1;
145 {
146 register int branch;
147 int kb[3][2];
148
149 if (c1-c0 <= 1) { /* assign pixel */
150 mktabent(c0, box);
151 return;
152 }
153 /* split box */
154 branch = split(box);
155 bcopy((char *)box, (char *)kb, sizeof(kb));
156 /* do left (lesser) branch */
157 kb[prim(branch)][1] = part(branch);
158 cut(kb, c0, (c0+c1)>>1);
159 /* do right branch */
160 kb[prim(branch)][0] = part(branch);
161 kb[prim(branch)][1] = box[prim(branch)][1];
162 cut(kb, (c0+c1)>>1, c1);
163 }
164
165
166 static int
167 split(box) /* find median cut for box */
168 register int box[3][2];
169 {
170 #define c0 r
171 register int r, g, b;
172 int pri;
173 int t[HMAX], med;
174 /* find dominant axis */
175 pri = RED;
176 if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
177 pri = GRN;
178 if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0])
179 pri = BLU;
180 /* sum histogram over box */
181 med = 0;
182 switch (pri) {
183 case RED:
184 for (r = box[RED][0]; r < box[RED][1]; r++) {
185 t[r] = 0;
186 for (g = box[GRN][0]; g < box[GRN][1]; g++)
187 for (b = box[BLU][0]; b < box[BLU][1]; b++)
188 t[r] += histo[r][g][b];
189 med += t[r];
190 }
191 break;
192 case GRN:
193 for (g = box[GRN][0]; g < box[GRN][1]; g++) {
194 t[g] = 0;
195 for (b = box[BLU][0]; b < box[BLU][1]; b++)
196 for (r = box[RED][0]; r < box[RED][1]; r++)
197 t[g] += histo[r][g][b];
198 med += t[g];
199 }
200 break;
201 case BLU:
202 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
203 t[b] = 0;
204 for (r = box[RED][0]; r < box[RED][1]; r++)
205 for (g = box[GRN][0]; g < box[GRN][1]; g++)
206 t[b] += histo[r][g][b];
207 med += t[b];
208 }
209 break;
210 }
211 if (med < MINSAMP) /* if too sparse, split at midpoint */
212 return(set_branch(pri,(box[pri][0]+box[pri][1])>>1));
213 /* find median position */
214 med >>= 1;
215 for (c0 = box[pri][0]; med > 0; c0++)
216 med -= t[c0];
217 if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */
218 c0--; /* part left of median */
219 return(set_branch(pri,c0));
220 #undef c0
221 }
222
223
224 static
225 mktabent(p, box) /* compute average color for box and assign */
226 int p;
227 register int box[3][2];
228 {
229 long sum[3];
230 int r, g, n;
231 register int b, c;
232 /* sum pixels in box */
233 n = 0;
234 sum[RED] = sum[GRN] = sum[BLU] = 0;
235 for (r = box[RED][0]; r < box[RED][1]; r++)
236 for (g = box[GRN][0]; g < box[GRN][1]; g++)
237 for (b = box[BLU][0]; b < box[BLU][1]; b++) {
238 if (c = histo[r][g][b]) {
239 n += c;
240 sum[RED] += (long)c*r;
241 sum[GRN] += (long)c*g;
242 sum[BLU] += (long)c*b;
243 }
244 histo[r][g][b] = p; /* assign pixel */
245 }
246 if (n) { /* compute average */
247 clrtab[p][RED] = sum[RED]*256/NRED/n;
248 clrtab[p][GRN] = sum[GRN]*256/NGRN/n;
249 clrtab[p][BLU] = sum[BLU]*256/NBLU/n;
250 } else { /* empty box -- use midpoint */
251 clrtab[p][RED] = (box[RED][0]+box[RED][1])*256/NRED/2;
252 clrtab[p][GRN] = (box[GRN][0]+box[GRN][1])*256/NGRN/2;
253 clrtab[p][BLU] = (box[BLU][0]+box[BLU][1])*256/NBLU/2;
254 }
255 }
