root/radiance/src/px/SConscript
Revision: 1.23
Committed: Thu Mar 10 21:43:23 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.22: +28 -36 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 mlib = ['$RAD_MLIB']
6 progs = []
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 warp3d = env.Object(source="warp3d.c")
13 clrtab = env.Object(source="clrtab.c")
14 neuclrtab = env.Object(source="neuclrtab.c")
15
16 # standard targets
17 PROGS = (
18 # name files libs
19 ('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d], ['rtrad']),
20 ('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d], ['rtrad']),
21 ('pfilt', Split('pfilt.c pf2.c pf3.c'), ['rtrad']),
22 ('pcwarp', ['pcwarp.c', warp3d], ['rtrad']),
23 ('pvalue', ['pvalue.c'], ['rtrad']),
24 ('pcompos', ['pcompos.c'], ['rtrad']),
25 ('psign', ['psign.c'], ['rtrad']),
26 ('protate', ['protate.c'], ['rtrad']),
27 ('pextrem', ['pextrem.c'], ['rtrad']),
28 ('pflip', ['pflip.c'], ['rtrad']),
29 ('pcomb', ['pcomb.c'], ['rtrad']),
30 ('pinterp', ['pinterp.c'], ['rtrad']),
31
32 ('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtrad']),
33 ('ra_ps', ['ra_ps.c'], ['rtrad']),
34 ('ra_ppm', ['ra_ppm.c'], ['rtrad']),
35 ('ra_bmp', ['ra_bmp.c'], ['rtrad']),
36 ('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtrad']),
37 ('ra_t16', ['ra_t16.c'], ['rtrad']),
38 ('ra_rgbe', ['ra_rgbe.c'], ['rtrad']),
39 ('ra_pict', ['ra_pict.c'], ['rtrad']),
40 ('ra_hexbit',['ra_hexbit.c'], ['rtrad']),
41 ('ra_xyze', ['ra_xyze.c'], ['rtrad']),
42 ('pmblur2', ['pmblur2.c'], ['rtrad']),
43
44 ('ttyimage', ['ttyimage.c'], ['rtrad']),
45 )
46 for p in PROGS:
47 prog = env.Program(target=radbin(p[0]), source=p[1],
48 LIBS=p[2]+mlib)
49 progs.append(prog)
50
51
52 # tiff library (building it is unix-specific for the moment)
53 # If we haven't found one supporting LogLuv installed, build our own.
54 libtiff_fn = radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX'])
55 if os.name == 'posix' and not env.get('TIFFLIB_INSTALLED'):
56 cwd = os.getcwd()
57 upperdir = os.path.split(cwd)[0]
58 libtiff = env.Command(libtiff_fn, None,
59 [('cd "%(tiffdir)s"; '
60 'env CC="$CC" '
61 './configure -C '
62 '"libdir=%(upperdir)s/lib" '
63 '--enable-static --disable-shared --disable-cxx '
64 '--enable-logluv --disable-jpeg --disable-zlib --disable-pixarlog; '
65 'cd %(portdir)s; make all;'
66 'cd %(libtiffdir)s; make install-exec;' # don't install headers
67 ) % {
68 'upperdir':upperdir,
69 'tiffdir':os.path.join(cwd, 'tiff'),
70 'portdir':os.path.join(cwd, 'tiff', 'port'),
71 'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff')
72 }
73 ])
74
75 env['TIFFLIB_INSTALLED'] = 1
76
77 if os.name == 'posix': # cleanup action for a previously built tifflib
78 Clean(libtiff_fn, [libtiff_fn, radlib(env['LIBPREFIX'] + 'tiff.la')])
79
80 if env.get('TIFFLIB_INSTALLED'):
81 libtiff = env.get('RAD_LIBTIFF')
82 # tiff programs
83 tiffi = env.get('RAD_TIFFINCLUDE')
84 if tiffi: tiffincl = [tiffi] + env.get('CPPPATH', [])
85 else: tiffincl = env.get('CPPPATH', [])
86 tiffl = env.get('RAD_TIFFLIB')
87 if tiffl: tifflib = [tiffl] + env.get('LIBPATH', [])
88 else: tifflib = env.get('LIBPATH', [])
89
90 ra_tiff = env.Program(target=radbin('ra_tiff'), source=['ra_tiff.c'],
91 CPPPATH = tiffincl, LIBPATH=tifflib,
92 LIBS=[libtiff,'rtrad'] + mlib)
93 progs.append(ra_tiff)
94
95 normtiff = env.Program(target=radbin('normtiff'),source=['normtiff.c'],
96 CPPPATH = tiffincl, LIBPATH=tifflib,
97 LIBS=[libtiff,'rtrad'] + mlib)
98 progs.append(normtiff)
99
100
101 # X11 targets
102 if env.has_key('X11LIB'):
103 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
104 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
105 xlibs = ['X11','rtrad']
106 env.x11findwind = env.Object(source='../common/x11findwind.c', # XXX remote magic
107 CPPPATH=xincl)
108
109 ximage = env.Program(target=radbin('ximage'),
110 source=Split('x11image.c x11raster.c')+[clrtab],
111 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
112 progs.append(ximage)
113
114 xshowtrace = env.Program(target=radbin('xshowtrace'),
115 source=Split('xshowtrace.c') + [env.x11findwind], # XXX remote magic
116 CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib)
117 progs.append(xshowtrace)
118
119 if os.name == 'posix': # XXX ignoring trad.wsh
120 for s in Split('''normpat pdfblur pmblur pmdblur
121 xyzimage phisto pdelta pgblur ra_pfm ran2tiff pbilat'''):
122 Default(env.InstallScript(radbin(s), s + '.csh'))
123 for s in Split('''falsecolor'''):
124 Default(env.InstallScript(radbin(s), s + '.pl'))
125 # XXX probably needs fixing
126 #else:
127 # for s in Split('''falsecolor'''):
128 # Default(env.InstallScript(radbin(s), s + '.pl'))
129 # ignored by Rmakefile: pacuity phisteq psquish pveil vlpic
130
131 Default('#src/px')
132 env.Install('$RAD_BINDIR', progs)
133
134 # vim: set syntax=python:
