| 1 |
import os |
| 2 |
| 3 |
Import('env') # inherit from parent |
| 4 |
| 5 |
mlib = ['$RAD_MLIB'] |
| 6 |
progs = [] |
| 7 |
| 8 |
# compose paths |
| 9 |
def radbin(name): return os.path.join('$RAD_BUILDBIN', name) |
| 10 |
def radlib(name): return os.path.join('$RAD_BUILDLIB', name) |
| 11 |
| 12 |
warp3d = env.Object(source="warp3d.c") |
| 13 |
clrtab = env.Object(source="clrtab.c") |
| 14 |
neuclrtab = env.Object(source="neuclrtab.c") |
| 15 |
| 16 |
# standard targets |
| 17 |
PROGS = ( |
| 18 |
# name files libs |
| 19 |
('macbethcal', Split('macbethcal.c pmapgen.c mx3.c')+[warp3d], ['rtrad']), |
| 20 |
('pcond', Split('pcond.c pcond2.c pcond3.c pcond4.c')+[warp3d], ['rtrad']), |
| 21 |
('pfilt', Split('pfilt.c pf2.c pf3.c'), ['rtrad']), |
| 22 |
('pcwarp', ['pcwarp.c', warp3d], ['rtrad']), |
| 23 |
('pvalue', ['pvalue.c'], ['rtrad']), |
| 24 |
('pcompos', ['pcompos.c'], ['rtrad']), |
| 25 |
('psign', ['psign.c'], ['rtrad']), |
| 26 |
('protate', ['protate.c'], ['rtrad']), |
| 27 |
('pextrem', ['pextrem.c'], ['rtrad']), |
| 28 |
('pflip', ['pflip.c'], ['rtrad']), |
| 29 |
('pcomb', ['pcomb.c'], ['rtrad']), |
| 30 |
('pinterp', ['pinterp.c'], ['rtrad']), |
| 31 |
| 32 |
('ra_gif', ['ra_gif.c', clrtab, neuclrtab], ['rtrad']), |
| 33 |
('ra_ps', ['ra_ps.c'], ['rtrad']), |
| 34 |
('ra_ppm', ['ra_ppm.c'], ['rtrad']), |
| 35 |
('ra_bmp', ['ra_bmp.c'], ['rtrad']), |
| 36 |
('ra_t8', ['ra_t8.c', clrtab, neuclrtab], ['rtrad']), |
| 37 |
('ra_t16', ['ra_t16.c'], ['rtrad']), |
| 38 |
('ra_rgbe', ['ra_rgbe.c'], ['rtrad']), |
| 39 |
('ra_pict', ['ra_pict.c'], ['rtrad']), |
| 40 |
('ra_hexbit',['ra_hexbit.c'], ['rtrad']), |
| 41 |
('ra_xyze', ['ra_xyze.c'], ['rtrad']), |
| 42 |
('pmblur2', ['pmblur2.c'], ['rtrad']), |
| 43 |
| 44 |
('ttyimage', ['ttyimage.c'], ['rtrad']), |
| 45 |
| 46 |
for p in PROGS: |
| 47 |
prog = env.Program(target=radbin(p[0]), source=p[1], |
| 48 |
LIBS=p[2]+mlib) |
| 49 |
progs.append(prog) |
| 50 |
| 51 |
| 52 |
# tiff library (building it is unix-specific for the moment) |
| 53 |
# If we haven't found one supporting LogLuv installed, build our own. |
| 54 |
libtiff_fn = radlib(env['LIBPREFIX'] + 'tiff' + env['LIBSUFFIX']) |
| 55 |
if os.name == 'posix' and not env.get('TIFFLIB_INSTALLED'): |
| 56 |
cwd = os.getcwd() |
| 57 |
upperdir = os.path.split(cwd)[0] |
| 58 |
libtiff = env.Command(libtiff_fn, None, |
| 59 |
[('cd "%(tiffdir)s"; ' |
| 60 |
'env CC="$CC" ' |
| 61 |
'./configure -C ' |
| 62 |
'"libdir=%(upperdir)s/lib" ' |
| 63 |
'--enable-static --disable-shared --disable-cxx ' |
| 64 |
'--enable-logluv --disable-jpeg --disable-zlib --disable-pixarlog; ' |
| 65 |
'cd %(portdir)s; make all;' |
| 66 |
'cd %(libtiffdir)s; make install-exec;' # don't install headers |
| 67 |
| 68 |
'upperdir':upperdir, |
| 69 |
'tiffdir':os.path.join(cwd, 'tiff'), |
| 70 |
'portdir':os.path.join(cwd, 'tiff', 'port'), |
| 71 |
'libtiffdir':os.path.join(cwd, 'tiff', 'libtiff') |
| 72 |
| 73 |
| 74 |
| 75 |
env['TIFFLIB_INSTALLED'] = 1 |
| 76 |
| 77 |
if os.name == 'posix': # cleanup action for a previously built tifflib |
| 78 |
Clean(libtiff_fn, [libtiff_fn, radlib(env['LIBPREFIX'] + 'tiff.la')]) |
| 79 |
| 80 |
if env.get('TIFFLIB_INSTALLED'): |
| 81 |
libtiff = env.get('RAD_LIBTIFF') |
| 82 |
# tiff programs |
| 83 |
tiffi = env.get('RAD_TIFFINCLUDE') |
| 84 |
if tiffi: tiffincl = [tiffi] + env.get('CPPPATH', []) |
| 85 |
else: tiffincl = env.get('CPPPATH', []) |
| 86 |
tiffl = env.get('RAD_TIFFLIB') |
| 87 |
if tiffl: tifflib = [tiffl] + env.get('LIBPATH', []) |
| 88 |
else: tifflib = env.get('LIBPATH', []) |
| 89 |
| 90 |
ra_tiff = env.Program(target=radbin('ra_tiff'), source=['ra_tiff.c'], |
| 91 |
CPPPATH = tiffincl, LIBPATH=tifflib, |
| 92 |
LIBS=[libtiff,'rtrad'] + mlib) |
| 93 |
progs.append(ra_tiff) |
| 94 |
| 95 |
normtiff = env.Program(target=radbin('normtiff'),source=['normtiff.c'], |
| 96 |
| 97 |
| 98 |
progs.append(normtiff) |
| 99 |
| 100 |
| 101 |
# X11 targets |
| 102 |
if env.has_key('X11LIB'): |
| 103 |
xincl = env.get('CPPPATH', []) + ['$X11INCLUDE'] |
| 104 |
xlibp = env.get('LIBPATH', []) + ['$X11LIB'] |
| 105 |
xlibs = ['X11','rtrad'] |
| 106 |
env.x11findwind = env.Object(source='../common/x11findwind.c', # XXX remote magic |
| 107 |
CPPPATH=xincl) |
| 108 |
| 109 |
ximage = env.Program(target=radbin('ximage'), |
| 110 |
source=Split('x11image.c x11raster.c')+[clrtab], |
| 111 |
CPPPATH=xincl, LIBPATH=xlibp, LIBS=xlibs + mlib) |
| 112 |
progs.append(ximage) |
| 113 |
| 114 |
xshowtrace = env.Program(target=radbin('xshowtrace'), |
| 115 |
source=Split('xshowtrace.c') + [env.x11findwind], # XXX remote magic |
| 116 |
| 117 |
progs.append(xshowtrace) |
| 118 |
| 119 |
if os.name == 'posix': # XXX ignoring trad.wsh |
| 120 |
for s in Split('''normpat pdfblur pmblur pmdblur |
| 121 |
xyzimage phisto pdelta pgblur ra_pfm ran2tiff pbilat'''): |
| 122 |
Default(env.InstallScript(radbin(s), s + '.csh')) |
| 123 |
for s in Split('''falsecolor'''): |
| 124 |
Default(env.InstallScript(radbin(s), s + '.pl')) |
| 125 |
# XXX probably needs fixing |
| 126 |
#else: |
| 127 |
# for s in Split('''falsecolor'''): |
| 128 |
# Default(env.InstallScript(radbin(s), s + '.pl')) |
| 129 |
# ignored by Rmakefile: pacuity phisteq psquish pveil vlpic |
| 130 |
| 131 |
Default('#src/px') |
| 132 |
env.Install('$RAD_BINDIR', progs) |
| 133 |
| 134 |
# vim: set syntax=python: |
