root/radiance/src/px/README
Revision: 2.12
Committed: Sat Sep 17 05:14:14 2005 UTC (20 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 2.11: +3 -0 lines
# User Rev Content
1 greg 1.1 PICTURE FILTERS AND TRANSLATORS
2 greg 2.9 SCCSid "@(#)README 2.8 10/22/96 LBL"
3 greg 1.1
4     This directory contains special and general purpose filters for RADIANCE
5     picture files and converters to and from other image formats.
6
7 greg 2.8 pcond.h header file for picture conditioning program pcond
8 greg 2.4 pic.h header file for reading and writing pictures
9 greg 1.1 pict.h header file defining Macintosh PICT format
10 greg 2.2 rasterfile.h header description for Sun rasterfiles
11 greg 1.1 x11raster.h header file for X11 routines using images
12 greg 2.2 aedimage.c display program for AED 512 color graphics terminal
13 greg 2.11 clrtab.c median-cut color quantization routines for 8-bit output
14 greg 2.6 macbethcal.c program to calibrate image conversion using Macbeth chart
15 greg 2.4 neuclrtab.c neural network color quantization code
16 greg 1.1 pcomb.c combine picture files according to calcomp functions
17     pcompos.c program to composite pictures
18 greg 2.8 pcond.c condition Radiance picture for display/output
19     pcond2.c pcond input and output conditioning routines for pcond.
20     pcond3.c pcond routines for computing and applying brightness mapping.
21     pcond4.c pcond routines for veiling glare and loss of acuity.
22 greg 2.2 pextrem.c program to find min and max values in picture
23 greg 1.1 pf2.c routines used by pfilt
24     pf3.c routines for gaussian and box filtering
25     pfilt.c program to post-process picture file
26     pflip.c flip picture file horizontally and/or vertically
27     pinterp.c interpolate and extrapolate pictures with different views
28 greg 2.6 pmapgen.c affine transformation for image mapping used by macbethcal
29 greg 2.2 protate.c program to rotate picture file 90 degrees clockwise
30 greg 1.1 psign.c produce picture from text
31     pvalue.c program to print pixel values
32 greg 2.4 ra_gif.c program to convert from RADIANCE to GIF format
33 greg 2.2 ra_pict.c convert to Macintosh PICT file
34 greg 1.1 ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
35 greg 2.2 ra_ps.c program to convert to greyscale PostScript file
36 greg 1.1 ra_rgbe.c program to convert from RADIANCE RLE to flat format
37 greg 2.1 ra_skel.c skeletal converter between RADIANCE and generic 24-bit format
38 greg 1.1 ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
39     ra_t8.c program to convert between RADIANCE and Targa 8 bit format
40     ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
41     ttyimage.c program to dump pixel file to dumb terminal
42 greg 2.3 vgaimage.c program to display pixel file on VGA or SVGA card
43 greg 2.2 x11findwind.c function to find X11 window by name
44     x11image.c picture display driver for X11
45 greg 2.4 x11raster.c routines to handle images for X11
46 greg 2.2 xshowtrace.c display a picture under X11 and watch the rays get traced
47 greg 2.4 falsecolor.csh C-shell script to produce false color pictures
48     normpat.csh C-shell script to normalize pictures for tiling patterns
49 greg 2.6 pdfblur.csh compute views for depth of field blurring
50 greg 2.12 pgblur.csh Gaussian blur function
51 greg 2.6 pmblur.csh compute views for motion blurring
52 greg 2.12 pmdblur.csh compute views for combined motion and depth-of-field blurring
53     ran2tiff.csh expose and convert animation frames using pcond and ra_tiff
54 greg 2.6 xyzimage.csh display images correctly for a particular monitor's primaries
55 greg 2.10 tiff/ TIFF image library
