root/radiance/src/px/README
Revision: 2.10
Committed: Fri Nov 5 03:31:38 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.9: +1 -21 lines
1 PICTURE FILTERS AND TRANSLATORS
2 SCCSid "@(#)README 2.8 10/22/96 LBL"
3
4 This directory contains special and general purpose filters for RADIANCE
5 picture files and converters to and from other image formats.
6
7 pcond.h header file for picture conditioning program pcond
8 pic.h header file for reading and writing pictures
9 ciq.h header file for color quantization routines
10 pict.h header file defining Macintosh PICT format
11 rasterfile.h header description for Sun rasterfiles
12 x11raster.h header file for X11 routines using images
13 aedimage.c display program for AED 512 color graphics terminal
14 biq.c simple greyscale quantization
15 ciq.c color quantization routine
16 closest.c color quantization - find closest color
17 clrtab.c more compact but slower replacement for ciq.c+split.c+closest.c
18 cut.c color quantization - median cut algorithm
19 macbethcal.c program to calibrate image conversion using Macbeth chart
20 neuclrtab.c neural network color quantization code
21 pcomb.c combine picture files according to calcomp functions
22 pcompos.c program to composite pictures
23 pcond.c condition Radiance picture for display/output
24 pcond2.c pcond input and output conditioning routines for pcond.
25 pcond3.c pcond routines for computing and applying brightness mapping.
26 pcond4.c pcond routines for veiling glare and loss of acuity.
27 pextrem.c program to find min and max values in picture
28 pf2.c routines used by pfilt
29 pf3.c routines for gaussian and box filtering
30 pfilt.c program to post-process picture file
31 pflip.c flip picture file horizontally and/or vertically
32 pinterp.c interpolate and extrapolate pictures with different views
33 pmapgen.c affine transformation for image mapping used by macbethcal
34 protate.c program to rotate picture file 90 degrees clockwise
35 psign.c produce picture from text
36 pvalue.c program to print pixel values
37 ra_gif.c program to convert from RADIANCE to GIF format
38 ra_pict.c convert to Macintosh PICT file
39 ra_ppm.c program to convert between RADIANCE and Poskanzer Pixmaps
40 ra_ps.c program to convert to greyscale PostScript file
41 ra_rgbe.c program to convert from RADIANCE RLE to flat format
42 ra_skel.c skeletal converter between RADIANCE and generic 24-bit format
43 ra_t16.c program to convert between RADIANCE and Targa 15+ bit formats
44 ra_t8.c program to convert between RADIANCE and Targa 8 bit format
45 ra_tiff.c program to convert between RADIANCE and 24-bit TIFF files
46 ttyimage.c program to dump pixel file to dumb terminal
47 vgaimage.c program to display pixel file on VGA or SVGA card
48 x11findwind.c function to find X11 window by name
49 x11image.c picture display driver for X11
50 x11raster.c routines to handle images for X11
51 xshowtrace.c display a picture under X11 and watch the rays get traced
52 falsecolor.csh C-shell script to produce false color pictures
53 normpat.csh C-shell script to normalize pictures for tiling patterns
54 pdfblur.csh compute views for depth of field blurring
55 pmblur.csh compute views for motion blurring
56 xyzimage.csh display images correctly for a particular monitor's primaries
57 tiff/ TIFF image library
