root/radiance/src/ot/writeoct.c
Fri Feb 19 17:45:37 2021 UTC (4 years, 10 months ago) by greg
Changes since 2.7: +16 -16 lines
fix: added checks for output error
Tue Nov 9 16:09:20 2004 UTC (21 years, 1 month ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Undefined putc macro before redefining it
Thu Apr 29 14:36:49 2004 UTC (21 years, 8 months ago) by greg
Added macros to avoid flockfile(3) overhead
Sat Mar 27 12:41:45 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.4: +36 -24 lines
Fri Mar 14 21:27:46 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.3: +4 -38 lines
Sat Feb 22 02:07:26 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.2: +1 -4 lines
Mon Jul 13 15:43:33 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.1: +29 -34 lines
Diff to previous 2.1
moved portable i/o routines to rt library
Tue Nov 12 17:00:58 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.6
Mon Oct 28 12:21:52 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.5
added advanced static function declarations for SGI compiler
Wed Oct 23 11:32:45 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.4
changed definition of OCTMAGIC
Wed Dec 12 22:46:35 1990 UTC (35 years ago) by greg
Changes since 1.3: +3 -3 lines
Diff to previous 1.3
added missing casts to putint() calls
Thu Sep 6 23:30:13 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.2
Tue Mar 21 15:55:07 1989 UTC (36 years, 9 months ago) by greg
Diff to previous 1.1
fixed putint() portability
Thu Feb 2 10:33:07 1989 UTC (36 years, 11 months ago) by greg
