root/radiance/src/ot/obj2mesh.c
Revision 2.19 - (view) (download) (annotate) - [selected]
Sat Jun 7 05:09:46 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.18
Tue Jun 3 21:31:51 2025 UTC (4 months, 1 week ago) by greg
Diff to previous 2.17 , to selected 2.19
Mon Feb 6 22:40:21 2023 UTC (2 years, 8 months ago) by greg
Changes since 2.16: +6 -6 lines
Diff to previous 2.16 , to selected 2.19
Wed Jul 28 22:16:43 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.15: +3 -12 lines
Diff to previous 2.15 , to selected 2.19
perf(obj2mesh): eliminated unnecessary material file name storage
Fri Mar 3 01:25:27 2017 UTC (8 years, 7 months ago) by greg
Diff to previous 2.14 , to selected 2.19
Added -v option to obj2mesh for reporting mesh statistics
Tue Mar 22 03:56:17 2016 UTC (9 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.19
Made error messages more consistent when library file not found
Wed Nov 12 03:54:31 2008 UTC (16 years, 11 months ago) by greg
Diff to previous 2.12 , to selected 2.19
Fixes for Visual Studio compilation
Thu Jul 12 14:58:53 2007 UTC (18 years, 3 months ago) by greg
Diff to previous 2.11 , to selected 2.19
Decreased default -n setting in obj2mesh from 15 to 9
Fri Apr 23 00:56:27 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.10: +16 -1 lines
Diff to previous 2.10 , to selected 2.19
Thu Apr 22 17:35:54 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 2.9 , to selected 2.19
Correction to last change
Thu Apr 22 17:33:48 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.8: +3 -2 lines
Diff to previous 2.8 , to selected 2.19
Made obj2mesh more robust to set overflow
Sat Mar 27 12:41:45 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.7: +32 -18 lines
Diff to previous 2.7 , to selected 2.19
Mon Jul 14 05:00:45 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +4 -1 lines
Diff to previous 2.6 , to selected 2.19
Added better command-line argument checking
Sun Jun 8 12:03:10 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 2.5 , to selected 2.19
Thu Jun 5 19:29:34 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.4: +2 -4 lines
Diff to previous 2.4 , to selected 2.19
Fri Apr 18 21:47:45 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 2.3 , to selected 2.19
Removed mesh statistics output line from obj2mesh
Fri Mar 14 21:27:46 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.2: +13 -4 lines
Diff to previous 2.2 , to selected 2.19
Wed Mar 12 04:59:04 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.1: +17 -7 lines
Diff to previous 2.1 , to selected 2.19
Tue Mar 11 17:08:55 2003 UTC (22 years, 7 months ago) by greg
Diff to selected 2.19
