root/radiance/src/ot/o_instance.c
Revision: 1.7
Committed: Sat Jan 5 09:41:26 1991 UTC (34 years, 9 months ago) by greg
fixed error introduced in 1.6
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * o_instance.c - routines for creating octrees for other octrees.
9 *
10 * 11/11/88
11 */
12
13 #include "standard.h"
14
15 #include "object.h"
16
17 #include "instance.h"
18
19 #include "plocate.h"
20
21 /*
22 * To determine if two cubes intersect:
23 *
24 * 1) Check to see if any vertices of first cube are inside the
25 * second (intersection).
26 *
27 * 2) Check to see if all vertices of first are to one side of
28 * second (no intersection).
29 *
30 * 3) Perform 1 and 2 with roles reversed.
31 *
32 * 4) Check to see if any portion of any edge of second is inside
33 * first (intersection).
34 *
35 * 5) If test 4 fails, we have no intersection.
36 *
37 * Note that if we were testing two boxes, we would need
38 * to check that neither had any edges inside the other to be sure.
39 * Since an octree is a volume rather than a surface, we will
40 * return a value of 2 if the cube is entirely within the octree.
41 */
42
43
44 o_instance(o, cu) /* determine if cubes intersect */
45 OBJREC *o;
46 CUBE *cu;
47 {
48 static int vstart[4] = {0, 3, 5, 6};
49 FVECT cumin, cumax;
50 FVECT vert[8];
51 FVECT v1, v2;
52 register INSTANCE *in;
53 int vloc, vout;
54 register int i, j;
55 /* get octree arguments */
56 in = getinstance(o, IO_BOUNDS);
57 /* check if cube vertex in octree */
58 for (j = 0; j < 3; j++)
59 cumax[j] = (cumin[j] = in->obj->scube.cuorg[j]) +
60 in->obj->scube.cusize;
61 vloc = ABOVE | BELOW;
62 vout = 0;
63 for (i = 0; i < 8; i++) {
64 for (j = 0; j < 3; j++) {
65 v1[j] = cu->cuorg[j];
66 if (i & 1<<j)
67 v1[j] += cu->cusize;
68 }
69 multp3(v2, v1, in->x.b.xfm);
70 if (j = plocate(v2, cumin, cumax))
71 vout++;
72 vloc &= j;
73 }
74 if (vout == 0) /* all inside */
75 return(O_IN);
76 if (vout < 8) /* some inside */
77 return(O_HIT);
78 if (vloc) /* all to one side */
79 return(O_MISS);
80 /* octree vertices in cube? */
81 for (j = 0; j < 3; j++)
82 cumax[j] = (cumin[j] = cu->cuorg[j]) + cu->cusize;
83 vloc = ABOVE | BELOW;
84 for (i = 0; i < 8; i++) {
85 for (j = 0; j < 3; j++) {
86 v1[j] = in->obj->scube.cuorg[j];
87 if (i & 1<<j)
88 v1[j] += in->obj->scube.cusize;
89 }
90 multp3(vert[i], v1, in->x.f.xfm);
91 if (j = plocate(vert[i], cumin, cumax))
92 vloc &= j;
93 else
94 return(O_HIT); /* vertex inside */
95 }
96 if (vloc) /* all to one side */
97 return(O_MISS);
98 /* check edges */
99 for (i = 0; i < 4; i++)
100 for (j = 0; j < 3; j++) {
101 /* clip modifies vertices! */
102 VCOPY(v1, vert[vstart[i]]);
103 VCOPY(v2, vert[vstart[i] ^ 1<<j]);
104 if (clip(v1, v2, cumin, cumax))
105 return(O_HIT); /* edge inside */
106 }
107
108 return(O_MISS); /* no intersection */
109 }
