| 1 |
greg |
1.1 |
#ifndef lint |
| 2 |
greg |
2.3 |
static const char RCSid[] = "$Id$"; |
| 3 |
greg |
1.1 |
#endif |
| 4 |
| 5 |
greg |
2.3 |
* o_instance.c - routines for creating octrees for other octrees |
| 6 |
greg |
1.1 |
| 7 |
| 8 |
#include "standard.h" |
| 9 |
| 10 |
#include "object.h" |
| 11 |
greg |
2.2 |
| 12 |
#include "octree.h" |
| 13 |
greg |
1.1 |
| 14 |
#include "instance.h" |
| 15 |
| 16 |
greg |
2.3 |
#include "mesh.h" |
| 17 |
| 18 |
greg |
1.1 |
#include "plocate.h" |
| 19 |
| 20 |
| 21 |
* To determine if two cubes intersect: |
| 22 |
| 23 |
* 1) Check to see if any vertices of first cube are inside the |
| 24 |
* second (intersection). |
| 25 |
| 26 |
* 2) Check to see if all vertices of first are to one side of |
| 27 |
* second (no intersection). |
| 28 |
| 29 |
* 3) Perform 1 and 2 with roles reversed. |
| 30 |
| 31 |
* 4) Check to see if any portion of any edge of second is inside |
| 32 |
* first (intersection). |
| 33 |
| 34 |
* 5) If test 4 fails, we have no intersection. |
| 35 |
| 36 |
* Note that if we were testing two boxes, we would need |
| 37 |
* to check that neither had any edges inside the other to be sure. |
| 38 |
* Since an octree is a volume rather than a surface, we will |
| 39 |
* return a value of 2 if the cube is entirely within the octree. |
| 40 |
| 41 |
| 42 |
| 43 |
greg |
2.3 |
static int |
| 44 |
o_cube(cu1, fxf, cu) /* determine if cubes intersect */ |
| 45 |
CUBE *cu1; |
| 46 |
FULLXF *fxf; |
| 47 |
greg |
1.1 |
CUBE *cu; |
| 48 |
| 49 |
greg |
1.2 |
static int vstart[4] = {0, 3, 5, 6}; |
| 50 |
greg |
1.1 |
FVECT cumin, cumax; |
| 51 |
FVECT vert[8]; |
| 52 |
FVECT v1, v2; |
| 53 |
int vloc, vout; |
| 54 |
register int i, j; |
| 55 |
/* check if cube vertex in octree */ |
| 56 |
for (j = 0; j < 3; j++) |
| 57 |
greg |
2.3 |
cumax[j] = (cumin[j] = cu1->cuorg[j]) + cu1->cusize; |
| 58 |
greg |
1.1 |
vloc = ABOVE | BELOW; |
| 59 |
vout = 0; |
| 60 |
for (i = 0; i < 8; i++) { |
| 61 |
for (j = 0; j < 3; j++) { |
| 62 |
v1[j] = cu->cuorg[j]; |
| 63 |
if (i & 1<<j) |
| 64 |
v1[j] += cu->cusize; |
| 65 |
| 66 |
greg |
2.3 |
multp3(v2, v1, fxf->b.xfm); |
| 67 |
greg |
1.1 |
if (j = plocate(v2, cumin, cumax)) |
| 68 |
vout++; |
| 69 |
vloc &= j; |
| 70 |
| 71 |
if (vout == 0) /* all inside */ |
| 72 |
greg |
1.3 |
return(O_IN); |
| 73 |
greg |
1.1 |
if (vout < 8) /* some inside */ |
| 74 |
greg |
1.3 |
return(O_HIT); |
| 75 |
greg |
1.1 |
if (vloc) /* all to one side */ |
| 76 |
greg |
1.3 |
return(O_MISS); |
| 77 |
greg |
1.1 |
/* octree vertices in cube? */ |
| 78 |
| 79 |
cumax[j] = (cumin[j] = cu->cuorg[j]) + cu->cusize; |
| 80 |
| 81 |
| 82 |
| 83 |
greg |
2.3 |
v1[j] = cu1->cuorg[j]; |
| 84 |
greg |
1.1 |
if (i & 1<<j) |
| 85 |
greg |
2.3 |
v1[j] += cu1->cusize; |
| 86 |
greg |
1.1 |
| 87 |
greg |
2.3 |
multp3(vert[i], v1, fxf->f.xfm); |
| 88 |
greg |
1.1 |
if (j = plocate(vert[i], cumin, cumax)) |
| 89 |
vloc &= j; |
| 90 |
else |
| 91 |
greg |
1.3 |
return(O_HIT); /* vertex inside */ |
| 92 |
greg |
1.1 |
| 93 |
| 94 |
greg |
1.3 |
return(O_MISS); |
| 95 |
greg |
1.1 |
/* check edges */ |
| 96 |
for (i = 0; i < 4; i++) |
| 97 |
| 98 |
/* clip modifies vertices! */ |
| 99 |
VCOPY(v1, vert[vstart[i]]); |
| 100 |
VCOPY(v2, vert[vstart[i] ^ 1<<j]); |
| 101 |
if (clip(v1, v2, cumin, cumax)) |
| 102 |
greg |
1.3 |
return(O_HIT); /* edge inside */ |
| 103 |
greg |
1.1 |
| 104 |
| 105 |
greg |
1.3 |
return(O_MISS); /* no intersection */ |
| 106 |
greg |
2.3 |
| 107 |
| 108 |
| 109 |
int |
| 110 |
o_instance(o, cu) /* determine if instance intersects */ |
| 111 |
OBJREC *o; |
| 112 |
CUBE *cu; |
| 113 |
| 114 |
INSTANCE *ins; |
| 115 |
/* get octree bounds */ |
| 116 |
ins = getinstance(o, IO_BOUNDS); |
| 117 |
/* call o_cube to do the work */ |
| 118 |
return(o_cube(&ins->obj->scube, &ins->x, cu)); |
| 119 |
| 120 |
| 121 |
| 122 |
int |
| 123 |
o_mesh(o, cu) /* determine if mesh intersects */ |
| 124 |
OBJREC *o; |
| 125 |
CUBE *cu; |
| 126 |
| 127 |
MESHINST *mip; |
| 128 |
/* get mesh bounds */ |
| 129 |
mip = getmeshinst(o, IO_BOUNDS); |
| 130 |
| 131 |
return(o_cube(&mip->msh->mcube, &mip->x, cu)); |
| 132 |
greg |
1.1 |
