| 1 |
greg |
1.1 |
#ifndef lint |
| 2 |
schorsch |
1.3 |
static const char RCSid[] = "$Id: plot.c,v 1.2 2003/06/08 12:03:10 schorsch Exp $"; |
| 3 |
greg |
1.1 |
#endif |
| 4 |
| 5 |
* Plotting routines for meta-files |
| 6 |
| 7 |
| 8 |
| 9 |
schorsch |
1.3 |
#include "rtio.h" |
| 10 |
greg |
1.1 |
#include "meta.h" |
| 11 |
#include "plot.h" |
| 12 |
| 13 |
| 14 |
int pati[4] = {0, 1, 2, 3}; /* pattern indices */ |
| 15 |
| 16 |
| 17 |
* Patterns are 16 X 16, ordered left to right, bottom to top. |
| 18 |
* Each byte represents a column in an 8-bit high row. |
| 19 |
| 20 |
| 21 |
unsigned char pattern[NPATS+4][PATSIZE/8][PATSIZE] = { |
| 22 |
{ /* solid */ |
| 23 |
| 24 |
0377,0377,0377,0377,0377,0377,0377,0377, |
| 25 |
0377,0377,0377,0377,0377,0377,0377,0377 |
| 26 |
| 27 |
| 28 |
| 29 |
| 30 |
}, { /* thick \\\ (dashed) */ |
| 31 |
| 32 |
0377,0177,077,037,017,0207,0303,0341, |
| 33 |
0360,0370,0374,0376,0377,0377,0377,0377 |
| 34 |
| 35 |
0360,0370,0374,0376,0377,0377,0377,0377, |
| 36 |
0377,0177,077,037,017,0207,0303,0341 |
| 37 |
| 38 |
}, { /* thin \\\ (dotted) */ |
| 39 |
| 40 |
0314,0146,063,0231,0314,0146,063,0231, |
| 41 |
0314,0146,063,0231,0314,0146,063,0231 |
| 42 |
| 43 |
| 44 |
| 45 |
| 46 |
}, { /* mix \\\ (dotted-dashed) */ |
| 47 |
| 48 |
0376,0177,077,037,0217,0307,0343,0161, |
| 49 |
070,034,0216,0307,0343,0361,0370,0374 |
| 50 |
| 51 |
070,034,0216,0307,0343,0361,0370,0374, |
| 52 |
0376,0177,077,037,0217,0307,0343,0161 |
| 53 |
| 54 |
}, { /* thick /// (dashed) */ |
| 55 |
| 56 |
0377,0377,0377,0377,0376,0374,0370,0360, |
| 57 |
0341,0303,0207,017,037,077,0177,0377 |
| 58 |
| 59 |
0341,0303,0207,017,037,077,0177,0377, |
| 60 |
0377,0377,0377,0377,0376,0374,0370,0360 |
| 61 |
| 62 |
}, { /* thin /// (dotted) */ |
| 63 |
| 64 |
0231,063,0146,0314,0231,063,0146,0314, |
| 65 |
0231,063,0146,0314,0231,063,0146,0314 |
| 66 |
| 67 |
| 68 |
| 69 |
| 70 |
}, { /* mix /// (dotted-dashed) */ |
| 71 |
| 72 |
0374,0370,0361,0343,0307,0216,034,070, |
| 73 |
0161,0343,0307,0217,037,077,0177,0376 |
| 74 |
| 75 |
0161,0343,0307,0217,037,077,0177,0376, |
| 76 |
0374,0370,0361,0343,0307,0216,034,070 |
| 77 |
| 78 |
}, { /* crisscross */ |
| 79 |
| 80 |
0201,0102,044,030,030,044,0102,0201, |
| 81 |
0201,0102,044,030,030,044,0102,0201 |
| 82 |
| 83 |
| 84 |
| 85 |
| 86 |
}, { /* web */ |
| 87 |
| 88 |
0377,0300,0240,0220,0210,0204,0202,0201, |
| 89 |
0201,0202,0204,0210,0220,0240,0300,0200 |
| 90 |
| 91 |
0377,02,04,010,020,040,0100,0200, |
| 92 |
0200,0100,040,020,010,04,02,01 |
| 93 |
| 94 |
| 95 |
| 96 |
| 97 |
static int context = 0; |
| 98 |
| 99 |
struct setting { |
| 100 |
int cnx; /* setting context */ |
| 101 |
char *val; /* attribute value */ |
| 102 |
struct setting *snext; /* next setting in list */ |
| 103 |
| 104 |
| 105 |
static struct setting *sets[0200]; |
| 106 |
| 107 |
schorsch |
1.2 |
static void spop(int attrib); |
| 108 |
static int spat(int pat, char *patval); |
| 109 |
greg |
1.1 |
| 110 |
schorsch |
1.2 |
void |
| 111 |
set( /* set attribute to value */ |
| 112 |
int attrib, |
| 113 |
char *value |
| 114 |
| 115 |
greg |
1.1 |
| 116 |
struct setting *newset; |
| 117 |
| 118 |
switch (attrib) { |
| 119 |
case SALL: |
| 120 |
context++; |
| 121 |
return; |
| 122 |
case SPAT0: |
| 123 |
case SPAT1: |
| 124 |
case SPAT2: |
| 125 |
case SPAT3: |
| 126 |
if (!spat(attrib, value)) { |
| 127 |
sprintf(errmsg, "Bad pattern set value: %s", value); |
| 128 |
error(WARNING, errmsg); |
| 129 |
return; |
| 130 |
| 131 |
break; |
| 132 |
default: |
| 133 |
sprintf(errmsg, "Can't set attribute: %o", attrib); |
| 134 |
| 135 |
return; |
| 136 |
| 137 |
newset = (struct setting *)malloc(sizeof(struct setting)); |
| 138 |
newset->cnx = context; |
| 139 |
newset->val = savestr(value); |
| 140 |
newset->snext = sets[attrib]; |
| 141 |
sets[attrib] = newset; |
| 142 |
| 143 |
| 144 |
| 145 |
| 146 |
schorsch |
1.2 |
void |
| 147 |
unset( /* return attribute to previous setting */ |
| 148 |
int attrib |
| 149 |
| 150 |
greg |
1.1 |
| 151 |
register int i; |
| 152 |
| 153 |
if (attrib == SALL) { |
| 154 |
if (context == 0) |
| 155 |
reset(SALL); |
| 156 |
else { |
| 157 |
context--; |
| 158 |
for (i = 0; i < 0200; i++) |
| 159 |
while (sets[i] != NULL && sets[i]->cnx > context) |
| 160 |
spop(i); |
| 161 |
| 162 |
return; |
| 163 |
| 164 |
spop(attrib); |
| 165 |
if (sets[attrib] == NULL) |
| 166 |
reset(attrib); |
| 167 |
| 168 |
switch (attrib) { |
| 169 |
case SPAT0: |
| 170 |
case SPAT1: |
| 171 |
case SPAT2: |
| 172 |
case SPAT3: |
| 173 |
spat(attrib, sets[attrib]->val); |
| 174 |
break; |
| 175 |
default: |
| 176 |
sprintf(errmsg, "Can't unset attribute: %o", attrib); |
| 177 |
| 178 |
return; |
| 179 |
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
schorsch |
1.2 |
void |
| 185 |
reset( /* return attribute to default setting */ |
| 186 |
int attrib |
| 187 |
| 188 |
greg |
1.1 |
| 189 |
switch (attrib) { |
| 190 |
case SALL: |
| 191 |
reset(SPAT0); |
| 192 |
reset(SPAT1); |
| 193 |
reset(SPAT2); |
| 194 |
reset(SPAT3); |
| 195 |
context = 0; |
| 196 |
return; |
| 197 |
case SPAT0: |
| 198 |
spat(SPAT0, "P0"); |
| 199 |
break; |
| 200 |
case SPAT1: |
| 201 |
spat(SPAT1, "P1"); |
| 202 |
break; |
| 203 |
case SPAT2: |
| 204 |
spat(SPAT2, "P2"); |
| 205 |
break; |
| 206 |
case SPAT3: |
| 207 |
spat(SPAT3, "P3"); |
| 208 |
break; |
| 209 |
default: |
| 210 |
sprintf(errmsg, "Can't reset attribute: %o", attrib); |
| 211 |
| 212 |
return; |
| 213 |
| 214 |
while (sets[attrib] != NULL) |
| 215 |
spop(attrib); |
| 216 |
| 217 |
| 218 |
| 219 |
| 220 |
schorsch |
1.2 |
static void |
| 221 |
spop( /* pop top off attrib settings list */ |
| 222 |
int attrib |
| 223 |
| 224 |
greg |
1.1 |
| 225 |
| 226 |
if (sets[attrib] != NULL) { |
| 227 |
if (sets[attrib]->val != NULL) |
| 228 |
freestr(sets[attrib]->val); |
| 229 |
free((char *)sets[attrib]); |
| 230 |
sets[attrib] = sets[attrib]->snext; |
| 231 |
| 232 |
| 233 |
| 234 |
| 235 |
| 236 |
| 237 |
static int |
| 238 |
schorsch |
1.2 |
spat( /* set a pattern */ |
| 239 |
int pat, |
| 240 |
char *patval |
| 241 |
| 242 |
greg |
1.1 |
| 243 |
int n, i, j, v; |
| 244 |
register char *cp; |
| 245 |
| 246 |
if (patval == NULL) return(FALSE); |
| 247 |
| 248 |
if (patval[0] == 'P' || patval[0] == 'p') { |
| 249 |
schorsch |
1.3 |
if (nextscan(patval+1, "%d", (char*)&n) == NULL || n < 0 || n >= NPATS) |
| 250 |
greg |
1.1 |
return(FALSE); |
| 251 |
} else { |
| 252 |
n = NPATS + pat - SPAT0; |
| 253 |
cp = patval; |
| 254 |
for (i = 0; i < PATSIZE>>3; i++) |
| 255 |
for (j = 0; j < PATSIZE; j++) { |
| 256 |
schorsch |
1.3 |
if ((cp = nextscan(cp, "%o", (char*)&v)) == NULL || v < 0 || v > 0377) |
| 257 |
greg |
1.1 |
return(FALSE); |
| 258 |
pattern[n][i][j] = v; |
| 259 |
| 260 |
| 261 |
pati[pat-SPAT0] = n; |
| 262 |
return(TRUE); |
| 263 |
