| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: mplot.c,v 1.3 2003/11/15 02:13:37 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Plotting routines for meta-files to line-at-a-time printers
| 6 |
| 7 |
| 8 |
| 9 |
#include <stdio.h>
| 10 |
#include <string.h>
| 11 |
#include <fcntl.h>
| 12 |
| 13 |
#include "platform.h"
| 14 |
#include "meta.h"
| 15 |
#include "plot.h"
| 16 |
#include "span.h"
| 17 |
| 18 |
| 19 |
| 20 |
int minwidth = 0;
| 21 |
| 22 |
static PLIST inqueue = {NULL, NULL};
| 23 |
| 24 |
static PRIMITIVE nextp;
| 25 |
| 26 |
static void initplot(void);
| 27 |
static void plotspan(FILE *infp);
| 28 |
static void doglobal(PRIMITIVE *g);
| 29 |
static void doprim(PRIMITIVE *p);
| 30 |
static void outputspan(void);
| 31 |
static void tfill(PRIMITIVE *p);
| 32 |
static void fill(int attrib, int xmin, int ymin, int xmax, int ymax);
| 33 |
static void paintline(int x, int y, int run, int rise, int hrad, int vrad,
| 34 |
int lpat, long run2, long rise2, int n);
| 35 |
static void nextspan(void);
| 36 |
| 37 |
| 38 |
void
| 39 |
plot( /* plot meta-file */
| 40 |
FILE *infp
| 41 |
| 42 |
| 43 |
| 44 |
do {
| 45 |
readp(&nextp, infp);
| 46 |
initplot();
| 47 |
while (inqueue.ptop != NULL || isprim(nextp.com))
| 48 |
plotspan(infp);
| 49 |
doglobal(&nextp);
| 50 |
fargs(&nextp);
| 51 |
} while (nextp.com != PEOF);
| 52 |
| 53 |
| 54 |
| 55 |
| 56 |
void
| 57 |
initplot(void) /* initialize this plot */
| 58 |
| 59 |
thispage();
| 60 |
outspan.xleft = 0;
| 61 |
outspan.xright = dxsiz - 1;
| 62 |
outspan.ytop = dysiz + linhite - 1;
| 63 |
outspan.ybot = dysiz;
| 64 |
| 65 |
| 66 |
| 67 |
| 68 |
| 69 |
void
| 70 |
doglobal( /* execute a global command */
| 71 |
PRIMITIVE *g
| 72 |
| 73 |
| 74 |
char c;
| 75 |
int tty;
| 76 |
| 77 |
switch (g->com) {
| 78 |
| 79 |
case PEOF:
| 80 |
break;
| 81 |
| 82 |
case PDRAW:
| 83 |
fflush(stdout);
| 84 |
break;
| 85 |
| 86 |
case PEOP:
| 87 |
if (g->arg0 & 0200) /* advance page */
| 88 |
nextpage();
| 89 |
else if (g->arg0 == 3) /* continue down */
| 90 |
contpage();
| 91 |
else
| 92 |
error(USER, "illegal continue direction in doglobal");
| 93 |
break;
| 94 |
| 95 |
case PPAUS:
| 96 |
fflush(stdout);
| 97 |
tty = open(TTY, O_RDWR);
| 98 |
if (g->args != NULL) {
| 99 |
write(tty, g->args, strlen(g->args));
| 100 |
write(tty, " - (hit return to continue)", 27);
| 101 |
} else
| 102 |
write(tty, "\007", 1);
| 103 |
do {
| 104 |
c = '\n';
| 105 |
read(tty, &c, 1);
| 106 |
} while (c != '\n');
| 107 |
close(tty);
| 108 |
break;
| 109 |
| 110 |
case PSET:
| 111 |
set(g->arg0, g->args);
| 112 |
break;
| 113 |
| 114 |
case PUNSET:
| 115 |
unset(g->arg0);
| 116 |
break;
| 117 |
| 118 |
case PRESET:
| 119 |
reset(g->arg0);
| 120 |
break;
| 121 |
| 122 |
default:
| 123 |
sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
| 124 |
error(WARNING, errmsg);
| 125 |
break;
| 126 |
| 127 |
| 128 |
| 129 |
| 130 |
| 131 |
| 132 |
void
| 133 |
plotspan( /* plot next span */
| 134 |
FILE *infp
| 135 |
| 136 |
| 137 |
PLIST lastinq;
| 138 |
register PRIMITIVE *p;
| 139 |
| 140 |
/* clear span */
| 141 |
nextspan();
| 142 |
/* plot from queue */
| 143 |
lastinq.ptop = inqueue.ptop;
| 144 |
lastinq.pbot = inqueue.pbot;
| 145 |
inqueue.ptop = inqueue.pbot = NULL;
| 146 |
while ((p = pop(&lastinq)) != NULL) {
| 147 |
doprim(p);
| 148 |
pfree(p);
| 149 |
| 150 |
/* plot from file */
| 151 |
while (isprim(nextp.com) && CONV(nextp.xy[YMX],dysiz) >= outspan.ybot) {
| 152 |
doprim(&nextp);
| 153 |
fargs(&nextp);
| 154 |
| 155 |
| 156 |
/* print out span */
| 157 |
outputspan();
| 158 |
| 159 |
| 160 |
| 161 |
| 162 |
void
| 163 |
nextspan(void) /* prepare next span */
| 164 |
| 165 |
register int i;
| 166 |
register char *colp, *tcolp;
| 167 |
| 168 |
if (spanmin <= spanmax) { /* clear span */
| 169 |
| 170 |
i = nrows*dxsiz;
| 171 |
colp = outspan.cols;
| 172 |
tcolp = outspan.tcols;
| 173 |
while (i--)
| 174 |
*colp++ = *tcolp++ = '\0';
| 175 |
| 176 |
| 177 |
outspan.ytop -= linhite; /* advance to next */
| 178 |
outspan.ybot -= linhite;
| 179 |
spanmin = dxsiz;
| 180 |
spanmax = 0;
| 181 |
| 182 |
| 183 |
| 184 |
| 185 |
void
| 186 |
outputspan(void) /* output span to printer */
| 187 |
| 188 |
register int i;
| 189 |
| 190 |
| 191 |
if (spanmin <= spanmax) { /* overlay spans */
| 192 |
| 193 |
i = nrows*dxsiz;
| 194 |
| 195 |
| 196 |
while (i--)
| 197 |
*colp++ |= *tcolp++;
| 198 |
| 199 |
printspan(); /* print span */
| 200 |
| 201 |
| 202 |
| 203 |
void
| 204 |
doprim( /* plot primitive */
| 205 |
| 206 |
| 207 |
| 208 |
register PRIMITIVE *newp;
| 209 |
| 210 |
switch (p->com) {
| 211 |
| 212 |
case PLSEG:
| 213 |
plotlseg(p);
| 214 |
break;
| 215 |
| 216 |
case PRFILL:
| 217 |
fill((p->arg0&0103) | (pati[(p->arg0>>2)&03]<<2),
| 218 |
CONV(p->xy[XMN],dxsiz),CONV(p->xy[YMN],dysiz),
| 219 |
CONV(p->xy[XMX],dxsiz)+(p->arg0&0100?-1:0),
| 220 |
CONV(p->xy[YMX],dysiz)+(p->arg0&0100?-1:0));
| 221 |
break;
| 222 |
| 223 |
case PTFILL:
| 224 |
tfill(p);
| 225 |
break;
| 226 |
| 227 |
case PMSTR:
| 228 |
printstr(p);
| 229 |
break;
| 230 |
| 231 |
default:
| 232 |
sprintf(errmsg, "unknown command '%c' in doprim", p->com);
| 233 |
| 234 |
return;
| 235 |
| 236 |
| 237 |
if (CONV(p->xy[YMN],dysiz) < outspan.ybot) { /* save for next time */
| 238 |
if ((newp = palloc()) == NULL)
| 239 |
error(SYSTEM, "memory limit exceeded in doprim");
| 240 |
mcopy((char *)newp, (char *)p, sizeof(PRIMITIVE));
| 241 |
newp->args = savestr(p->args);
| 242 |
add(newp, &inqueue);
| 243 |
| 244 |
| 245 |
| 246 |
| 247 |
| 248 |
| 249 |
void
| 250 |
plotlseg( /* plot a line segment */
| 251 |
| 252 |
| 253 |
| 254 |
register int ti;
| 255 |
long run2 = 0L, rise2 = 0L;
| 256 |
int x, y, run, rise, xstop, ystop, hrad, vrad, lpat, n;
| 257 |
| 258 |
/* compute line pattern */
| 259 |
lpat = (p->arg0 >> 2) & 014;
| 260 |
if (p->arg0 & 0100 && lpat != 0)
| 261 |
lpat += 014;
| 262 |
lpat |= p->arg0 & 03;
| 263 |
| 264 |
ti = (p->arg0 >> 2) & 03; /* compute line radius */
| 265 |
ti = WIDTH(ti) / 2;
| 266 |
hrad = CONV(ti, dxsiz);
| 267 |
vrad = CONV(ti, dysiz);
| 268 |
if (hrad < minwidth)
| 269 |
hrad = minwidth;
| 270 |
if (vrad < minwidth)
| 271 |
vrad = minwidth;
| 272 |
| 273 |
x = CONV(p->xy[XMX], dxsiz); /* start at top */
| 274 |
y = CONV(p->xy[YMX], dysiz);
| 275 |
run = CONV(p->xy[XMN], dxsiz) - x;
| 276 |
rise = CONV(p->xy[YMN], dysiz) - y;
| 277 |
| 278 |
if (p->arg0 & 0100) /* slope < 0; reverse x */
| 279 |
x -= (run = -run);
| 280 |
| 281 |
xstop = x + run; /* compute end point */
| 282 |
ystop = y + rise;
| 283 |
| 284 |
if ((ti = outspan.ytop+vrad+1-y) < 0) { /* adjust to top of span */
| 285 |
run2 = rise2 = (long)ti*run;
| 286 |
x += rise2/rise;
| 287 |
y += ti;
| 288 |
| 289 |
| 290 |
if ((ti = outspan.ybot-vrad-1-ystop) > 0) { /* adjust to bottom of span */
| 291 |
xstop += (long)ti*run/rise;
| 292 |
ystop += ti;
| 293 |
| 294 |
| 295 |
if (abs(run) > -rise)
| 296 |
n = abs(xstop - x);
| 297 |
else
| 298 |
n = y - ystop;
| 299 |
| 300 |
paintline(x, y, run, rise, hrad, vrad, lpat, run2, rise2, n);
| 301 |
| 302 |
| 303 |
| 304 |
| 305 |
| 306 |
| 307 |
* This routine paints a line with calls to fill(). The line can
| 308 |
* start and end at arbitrary points on a longer line segment.
| 309 |
| 310 |
void
| 311 |
paintline(
| 312 |
register int x,
| 313 |
register int y,
| 314 |
int run,
| 315 |
int rise,
| 316 |
int hrad,
| 317 |
int vrad,
| 318 |
int lpat,
| 319 |
long run2,
| 320 |
long rise2,
| 321 |
int n
| 322 |
| 323 |
| 324 |
int xstep, ystep;
| 325 |
| 326 |
if (run >= 0)
| 327 |
xstep = 1;
| 328 |
else {
| 329 |
xstep = -1;
| 330 |
run = -run;
| 331 |
| 332 |
if (rise >= 0)
| 333 |
ystep = 1;
| 334 |
else {
| 335 |
ystep = -1;
| 336 |
rise = -rise;
| 337 |
| 338 |
if (n < 0)
| 339 |
n = max(run, rise);
| 340 |
| 341 |
if (run > rise)
| 342 |
while (n >= 0)
| 343 |
if (run2 >= rise2) {
| 344 |
fill(lpat, x-hrad, y-vrad, x+hrad, y+vrad);
| 345 |
n--;
| 346 |
x += xstep;
| 347 |
rise2 += rise;
| 348 |
} else {
| 349 |
y += ystep;
| 350 |
run2 += run;
| 351 |
| 352 |
else
| 353 |
while (n >= 0)
| 354 |
if (rise2 >= run2) {
| 355 |
| 356 |
n--;
| 357 |
y += ystep;
| 358 |
run2 += run;
| 359 |
} else {
| 360 |
x += xstep;
| 361 |
rise2 += rise;
| 362 |
| 363 |
| 364 |
| 365 |
| 366 |
| 367 |
void
| 368 |
tfill( /* fill a triangle */
| 369 |
| 370 |
| 371 |
| 372 |
register int x, txmin, txmax;
| 373 |
int xmn, ymn, tpat;
| 374 |
long xsz, ysz;
| 375 |
| 376 |
xmn = CONV(p->xy[XMN], dxsiz);
| 377 |
xsz = CONV(p->xy[XMX], dxsiz) - xmn;
| 378 |
ymn = CONV(p->xy[YMN], dysiz);
| 379 |
ysz = CONV(p->xy[YMX], dysiz) - ymn;
| 380 |
if (xsz <= 0 || ysz <= 0)
| 381 |
return;
| 382 |
txmin = (outspan.ybot - ymn)*xsz/ysz;
| 383 |
txmax = (outspan.ytop - ymn)*xsz/ysz;
| 384 |
if (p->arg0 & 020) { /* up or down */
| 385 |
x = txmin;
| 386 |
txmin = xsz - txmax;
| 387 |
txmax = xsz - x;
| 388 |
| 389 |
txmin += xmn;
| 390 |
txmax += xmn;
| 391 |
txmin = max(txmin, xmn);
| 392 |
txmax = min(txmax, xmn + (int)xsz - 1);
| 393 |
tpat = (p->arg0&0103) | (pati[(p->arg0>>2)&03]<<2);
| 394 |
| 395 |
if (p->arg0 & 040) { /* left or down */
| 396 |
fill(tpat, xmn, ymn, txmin - 1, ymn + (int)ysz - 1);
| 397 |
for (x = txmin; x <= txmax; x++)
| 398 |
if (p->arg0 & 020) /* down */
| 399 |
fill(tpat, x, ymn, x, (int)(ysz-(x-xmn)*ysz/xsz) + ymn - 1);
| 400 |
else /* left */
| 401 |
fill(tpat, x, (int)((x-xmn)*ysz/xsz) + ymn, x, ymn + (int)ysz - 1);
| 402 |
} else { /* right or up */
| 403 |
| 404 |
if (p->arg0 & 020) /* up */
| 405 |
fill(tpat, x, (int)(ysz-(x-xmn)*ysz/xsz) + ymn, x, ymn + (int)ysz - 1);
| 406 |
else /* right */
| 407 |
fill(tpat, x, ymn, x, (int)((x-xmn)*ysz/xsz) + ymn - 1);
| 408 |
fill(tpat, txmax + 1, ymn, xmn + (int)xsz - 1, ymn + (int)ysz - 1);
| 409 |
| 410 |
| 411 |
| 412 |
| 413 |
| 414 |
void
| 415 |
fill( /* fill rectangle with attribute */
| 416 |
int attrib,
| 417 |
int xmin,
| 418 |
int ymin,
| 419 |
int xmax,
| 420 |
int ymax
| 421 |
| 422 |
| 423 |
int filpat;
| 424 |
int rpos;
| 425 |
unsigned char *pattr;
| 426 |
register char *colp;
| 427 |
register int i;
| 428 |
| 429 |
xmin = max(xmin, outspan.xleft) - outspan.xleft;
| 430 |
ymin = max(ymin, outspan.ybot) - outspan.ybot;
| 431 |
xmax = min(xmax, outspan.xright) - outspan.xleft;
| 432 |
ymax = min(ymax, outspan.ytop) - outspan.ybot;
| 433 |
| 434 |
for (rpos = 0; rpos < nrows; rpos++)
| 435 |
| 436 |
if (rpos >= ymin >> 3 && rpos <= ymax >> 3) {
| 437 |
| 438 |
filpat = 0377;
| 439 |
if (rpos == ymin >> 3) {
| 440 |
i = ymin & 07;
| 441 |
filpat = (filpat >> i) << i;
| 442 |
| 443 |
if (rpos == ymax >> 3) {
| 444 |
i = ~ymax & 07;
| 445 |
filpat = ((filpat << i) & 0377) >> i;
| 446 |
| 447 |
| 448 |
pattr = pattern[(attrib&074)>>2]
| 449 |
[((outspan.ybot>>3)+rpos)%(PATSIZE>>3)];
| 450 |
| 451 |
if (attrib & 0100) {
| 452 |
colp = &outspan.tcols[rpos*dxsiz + xmin];
| 453 |
for (i = xmin; i <= xmax; i++)
| 454 |
*colp++ ^= filpat & pattr[i%PATSIZE];
| 455 |
} else {
| 456 |
colp = &outspan.cols[rpos*dxsiz + xmin];
| 457 |
| 458 |
*colp++ |= filpat & pattr[i%PATSIZE];
| 459 |
| 460 |
| 461 |
spanmin = min(xmin, spanmin);
| 462 |
spanmax = max(xmax, spanmax);
| 463 |
| 464 |
| 465 |
