| 1 |
schorsch |
1.4 |
/* RCSid: $Id: mgvars.h,v 1.3 2003/11/14 00:14:40 schorsch Exp $ */ |
| 2 |
greg |
1.1 |
| 3 |
* mgvars.h - header file for graphing routines using variables. |
| 4 |
| 5 |
* 6/23/86 |
| 6 |
| 7 |
* Greg Ward Larson |
| 8 |
| 9 |
schorsch |
1.2 |
#ifndef _RAD_MGVARS_H_ |
| 10 |
#define _RAD_MGVARS_H_ |
| 11 |
| 12 |
#include <errno.h> |
| 13 |
| 14 |
schorsch |
1.3 |
#include "calcomp.h" |
| 15 |
| 16 |
schorsch |
1.2 |
#ifdef __cplusplus |
| 17 |
extern "C" { |
| 18 |
#endif |
| 19 |
greg |
1.1 |
| 20 |
| 21 |
* Data arrays are used to store point data. |
| 22 |
| 23 |
| 24 |
typedef struct { |
| 25 |
int size; /* the size of the array */ |
| 26 |
float *data; /* pointer to the array */ |
| 27 |
} DARRAY; |
| 28 |
| 29 |
| 30 |
* Intermediate variables are not referenced |
| 31 |
* directly by the program, but may be used |
| 32 |
* for defining other variables. |
| 33 |
| 34 |
| 35 |
typedef struct ivar { |
| 36 |
char *name; /* the variable name */ |
| 37 |
char *dfn; /* its definition */ |
| 38 |
struct ivar *next; /* next in list */ |
| 39 |
} IVAR; /* an intermediate variable */ |
| 40 |
| 41 |
| 42 |
* Variables are used for all graph parameters. The four variable |
| 43 |
* types are: REAL, FUNCTION, STRING and DATA. |
| 44 |
* Of these, only STRING and DATA must be interpreted by us; an |
| 45 |
* expression parser will handle the rest. |
| 46 |
| 47 |
/* standard variables */ |
| 48 |
#define FTHICK 0 /* frame thickness */ |
| 49 |
#define GRID 1 /* grid on? */ |
| 50 |
#define LEGEND 2 /* legend title */ |
| 51 |
#define OTHICK 3 /* origin thickness */ |
| 52 |
#define PERIOD 4 /* period of polar plot */ |
| 53 |
#define SUBTITLE 5 /* subtitle */ |
| 54 |
#define SYMFILE 6 /* symbol file */ |
| 55 |
#define TSTYLE 7 /* tick mark style */ |
| 56 |
#define TITLE 8 /* title */ |
| 57 |
#define XLABEL 9 /* x axis label */ |
| 58 |
#define XMAP 10 /* x axis mapping */ |
| 59 |
#define XMAX 11 /* x axis maximum */ |
| 60 |
#define XMIN 12 /* x axis minimum */ |
| 61 |
#define XSTEP 13 /* x axis step */ |
| 62 |
#define YLABEL 14 /* y axis label */ |
| 63 |
#define YMAP 15 /* y axis mapping */ |
| 64 |
#define YMAX 16 /* y axis maximum */ |
| 65 |
#define YMIN 17 /* y axis minimum */ |
| 66 |
#define YSTEP 18 /* y axis step */ |
| 67 |
| 68 |
#define NVARS 19 /* number of standard variables */ |
| 69 |
| 70 |
/* curve variables */ |
| 71 |
#define C 0 /* the curve function */ |
| 72 |
#define CCOLOR 1 /* the curve color */ |
| 73 |
#define CDATA 2 /* the curve data */ |
| 74 |
#define CLABEL 3 /* the curve label */ |
| 75 |
#define CLINTYPE 4 /* the curve line type */ |
| 76 |
#define CNPOINTS 5 /* number of curve points to plot */ |
| 77 |
#define CSYMSIZE 6 /* the curve symbol size */ |
| 78 |
#define CSYMTYPE 7 /* the curve symbol type */ |
| 79 |
#define CTHICK 8 /* the curve line thickness */ |
| 80 |
| 81 |
#define NCVARS 9 /* number of curve variables */ |
| 82 |
| 83 |
#define MAXCUR 8 /* maximum number of curves */ |
| 84 |
| 85 |
/* types */ |
| 86 |
#define REAL 1 /* floating point */ |
| 87 |
#define STRING 2 /* character array */ |
| 88 |
#define FUNCTION 3 /* function definition */ |
| 89 |
#define DATA 4 /* a set of real points */ |
| 90 |
| 91 |
/* flags */ |
| 92 |
#define DEFINED 01 /* variable is defined */ |
| 93 |
| 94 |
typedef struct { |
| 95 |
| 96 |
short type; /* the variable type */ |
| 97 |
char *descrip; /* brief description */ |
| 98 |
unsigned short flags; /* DEFINED, etc. */ |
| 99 |
union { |
| 100 |
char *s; /* STRING value */ |
| 101 |
DARRAY d; /* DATA value */ |
| 102 |
char *dfn; /* variable definition */ |
| 103 |
} v; /* value */ |
| 104 |
} VARIABLE; /* a variable */ |
| 105 |
| 106 |
extern IVAR *ivhead; /* the intermediate list */ |
| 107 |
| 108 |
extern VARIABLE gparam[NVARS]; /* the graph variables */ |
| 109 |
extern VARIABLE cparam[MAXCUR][NCVARS]; /* the curve variables */ |
| 110 |
| 111 |
extern VARIABLE *vlookup(); |
| 112 |
| 113 |
schorsch |
1.3 |
#define mgclear(vname) undefine(vlookup(vname)) |
| 114 |
greg |
1.1 |
| 115 |
schorsch |
1.3 |
extern void mgclearall(void); |
| 116 |
extern void mgload(char *file); |
| 117 |
extern void mgsave(char *file); |
| 118 |
extern void setmgvar(char *fname, FILE *fp, char *string); |
| 119 |
schorsch |
1.4 |
extern int mgcurve(int c, void (*f)(int c, double x, double y)); |
| 120 |
schorsch |
1.3 |
extern void mgtoa(register char *s, VARIABLE *vp); |
| 121 |
schorsch |
1.2 |
| 122 |
| 123 |
| 124 |
| 125 |
#endif |
| 126 |
#endif /* _RAD_MGVARS_H_ */ |
| 127 |
greg |
1.1 |
