root/radiance/src/meta/meta2bmp.c
Revision: 1.5
Committed: Wed May 13 00:27:03 2020 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R3, rad6R0, HEAD
Changes since 1.4: +7 -18 lines
Minor code cleanup
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.5 static const char RCSid[] = "$Id: meta2bmp.c,v 1.4 2019/11/18 22:12:32 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Program to convert meta-files to BMP 8-bit color-mapped format
6     */
7
8     #include "copyright.h"
9
10     #include "rtprocess.h"
11     #include "meta.h"
12     #include "plot.h"
13     #include "rast.h"
14     #include "bmpfile.h"
15 schorsch 1.2 #include "targa.h"
16 greg 1.1
17 greg 1.3 #define MAXALLOC 100000
18 greg 1.1 #define DXSIZE 400 /* default x resolution */
19     #define DYSIZE 400 /* default y resolution */
20     #define XCOM "pexpand +vOCImsp -DP %s | psort +y"
21
22
23     char *progname;
24
25     SCANBLOCK outblock;
26
27 greg 1.4 int dxsiz = DXSIZE, dysiz = DYSIZE;
28 greg 1.1
29     int maxalloc = MAXALLOC;
30
31     int ydown = 0;
32
33     static char outname[64];
34     static char *outtack = NULL;
35
36     static BMPWriter *bmpw = NULL;
37
38     static int lineno = 0;
39
40     static short condonly = FALSE,
41     conditioned = FALSE;
42
43
44
45
46     char *
47 greg 1.5 findtack(char *s) /* find place to tack on suffix */
48 greg 1.1 {
49     while (*s && *s != '.')
50     s++;
51     return(s);
52     }
53
54
55     int
56     main(
57     int argc,
58     char **argv
59     )
60     {
61     FILE *fp;
62     char comargs[200], command[300];
63
64     progname = *argv++;
65     argc--;
66
67     condonly = FALSE;
68     conditioned = FALSE;
69
70     while (argc && **argv == '-') {
71     switch (*(*argv+1)) {
72     case 'c':
73     condonly = TRUE;
74     break;
75     case 'r':
76     conditioned = TRUE;
77     break;
78     case 'm':
79     minwidth = atoi(*++argv);
80     argc--;
81     break;
82     case 'x':
83 greg 1.4 dxsiz = atoi(*++argv);
84 greg 1.1 argc--;
85     break;
86     case 'y':
87 greg 1.4 dysiz = atoi(*++argv);
88 greg 1.1 argc--;
89     break;
90     case 'o':
91     strcpy(outname, *++argv);
92     outtack = findtack(outname);
93     argc--;
94     break;
95     default:
96     error(WARNING, "unknown option");
97     break;
98     }
99     argv++;
100     argc--;
101     }
102
103     if (conditioned) {
104     if (argc)
105     while (argc) {
106     fp = efopen(*argv, "r");
107     plot(fp);
108     fclose(fp);
109     argv++;
110     argc--;
111     }
112     else
113     plot(stdin);
114     if (lineno)
115     nextpage();
116     } else {
117     comargs[0] = '\0';
118     while (argc) {
119     strcat(comargs, " ");
120     strcat(comargs, *argv);
121     argv++;
122     argc--;
123     }
124     sprintf(command, XCOM, comargs);
125     if (condonly)
126     return(system(command));
127     else {
128     if ((fp = popen(command, "r")) == NULL)
129     error(SYSTEM, "cannot execute input filter");
130     plot(fp);
131     pclose(fp);
132     if (lineno)
133     nextpage();
134     }
135     }
136
137     return(0);
138 greg 1.5 }
139 greg 1.1
140
141     void
142     thispage(void) /* rewind current file */
143     {
144     if (lineno)
145     error(USER, "cannot restart page in thispage");
146     }
147
148
149     void
150     initfile(void) /* initialize this file */
151     {
152 schorsch 1.2 static const unsigned char cmap[8][3] = {{0,0,0}, {0,0,255}, {0,188,0},
153     {255,152,0}, {0,200,200}, {255,0,255}, {179,179,0}, {255,255,255}};
154 greg 1.1 static int filenum = 0;
155     BMPHeader *hp;
156 greg 1.5 int i;
157 greg 1.1
158 greg 1.4 hp = BMPmappedHeader(dxsiz, dysiz, 0, 256);
159 greg 1.1 if (hp == NULL)
160     error(USER, "Illegal image parameter(s)");
161 greg 1.5 hp->compr = BI_RLE8;
162 greg 1.1 for (i = 0; i < 8; i++) {
163     hp->palette[i].r = cmap[i][2];
164     hp->palette[i].g = cmap[i][1];
165     hp->palette[i].b = cmap[i][0];
166     }
167     hp->impColors = 8;
168     if (outtack != NULL) {
169     sprintf(outtack, "%d.bmp", ++filenum);
170     bmpw = BMPopenOutputFile(outname, hp);
171     } else {
172     bmpw = BMPopenOutputStream(stdout, hp);
173     }
174     if (bmpw == NULL)
175     error(USER, "Cannot create output");
176     }
177
178
179     void
180     nextpage(void) /* advance to next page */
181     {
182
183     if (lineno == 0)
184     return;
185     if (bmpw != NULL) {
186 greg 1.4 while (lineno < dysiz) {
187 greg 1.1 nextblock();
188     outputblock();
189     }
190     BMPcloseOutput(bmpw);
191     bmpw = NULL;
192     }
193     lineno = 0;
194
195     }
196
197
198     #define MINRUN 4
199
200 greg 1.5 void
201 greg 1.1 printblock(void) /* output scanline block to file */
202     {
203 schorsch 1.2 int i;
204 greg 1.5 unsigned char *scanline;
205 greg 1.1
206     if (lineno == 0)
207     initfile();
208 greg 1.4 for (i = outblock.ybot; i <= outblock.ytop && i < dysiz; i++) {
209 greg 1.1 scanline = outblock.cols[i-outblock.ybot] + outblock.xleft;
210     memcpy((void *)bmpw->scanline, (void *)scanline,
211     sizeof(uint8)*(outblock.xright-outblock.xleft+1));
212     if (BMPwriteScanline(bmpw) != BIR_OK)
213     error(SYSTEM, "Error writing BMP file");
214     lineno++;
215     }
216
217     }
