root/radiance/src/meta/macprt.c
Revision: 1.3
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 11 months ago) by greg
State: FILE REMOVED
2 static const char RCSid[] = "$Id: macprt.c,v 1.2 2003/07/01 21:21:40 greg Exp $";
5 * Program to send meta-files to MacIntosh printer
6 *
7 * cc -o macprt macprt.c macplot.o mfio.o syscalls.o misc.o -lplot
8 */
9
10
11 #include <fcntl.h>
12
13 #include "meta.h"
14
15 #include "macplot.h"
16
17 #include <print.h>
18
19
20
21 char *progname;
22
23 int dxsize, dysize; /* plot dimensions */
24
25 static short newpage = TRUE;
26
27 static PRIMITIVE nextp;
28
29 static GrafPort ourPort;
30
31
32
33 main(argc, argv)
34
35 int argc;
36 char **argv;
37
38 {
39 FILE *fp;
40
41 progname = *argv++;
42 argc--;
43
44 while (argc && **argv == '-') {
45 switch (*(*argv+1)) {
46 default:
47 error(WARNING, "unknown option");
48 break;
49 }
50 argv++;
51 argc--;
52 }
53
54 InitGraf(&thePort);
55
56 if (argc)
57 while (argc) {
58 fp = efopen(*argv, "r");
59 plot(fp);
60 fclose(fp);
61 argv++;
62 argc--;
63 }
64 else
65 plot(stdin);
66
67 return(0);
68 }
69
70
71
72
73 plot(infp) /* plot meta-file */
74
75 register FILE *infp;
76
77 {
78
79 OpenPort(&ourPort);
80 TextFont(4); /* 9-point Monaco */
81 TextSize(9);
82
83 dxsize = dysize = min(ourPort.portRect.right - ourPort.portRect.left,
84 ourPort.portRect.bottom - ourPort.portRect.top);
85
86 do {
87 readp(&nextp, infp);
88 while (isprim(nextp.com)) {
89 doprim(&nextp);
90 fargs(&nextp);
91 readp(&nextp, infp);
92 }
93 doglobal(&nextp);
94 fargs(&nextp);
95 } while (nextp.com != PEOF);
96
97 ClosePort(&ourPort);
98
99 }
100
101
102
103
104
105 doglobal(g) /* execute a global command */
106
107 register PRIMITIVE *g;
108
109 {
110 int tty;
111 char c;
112
113 switch (g->com) {
114
115 case PEOF:
116 break;
117
118 case PDRAW:
119 fflush(stdout);
120 break;
121
122 case PEOP:
123 newpage = TRUE;
124 /* fall through */
125
126 case PPAUS:
127 fflush(stdout);
128 tty = open(TTY, O_RDWR);
129 if (g->args != NULL) {
130 write(tty, g->args, strlen(g->args));
131 write(tty, " - (hit return to continue)", 27);
132 } else
133 write(tty, "\007", 1);
134 do {
135 c = '\n';
136 read(tty, &c, 1);
137 } while (c != '\n' && c != '\r');
138 close(tty);
139 break;
140
141 case PSET:
142 set(g->arg0, g->args);
143 break;
144
145 case PUNSET:
146 unset(g->arg0);
147 break;
148
149 case PRESET:
150 reset(g->arg0);
151 break;
152
153 default:
154 sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
155 error(WARNING, errmsg);
156 break;
157 }
158
159 }
160
161
162
163
164 doprim(p) /* plot primitive */
165
166 register PRIMITIVE *p;
167
168 {
169
170 if (newpage) {
171 EraseRgn(ourPort.visRgn);
172 newpage = FALSE;
173 }
174
175 switch (p->com) {
176
177 case PLSEG:
178 plotlseg(p);
179 break;
180
181 case PMSTR:
182 printstr(p);
183 break;
184
185 case PRFILL:
186 fillrect(p);
187 break;
188
189 case PTFILL:
190 filltri(p);
191 break;
192
193 case PPFILL:
194 fillpoly(p);
195 break;
196
197 default:
198 sprintf(errmsg, "unknown command '%c' in doprim", p->com);
199 error(WARNING, errmsg);
200 return;
201 }
202
203 }
