root/radiance/src/meta/macplot.c
Revision: 1.1
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years, 8 months ago) by greg
CVS Tags: rad3R6P1, rad3R6, rad3R5
# User Rev Content
1 greg 1.1 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4     /*
5     * Plotting routines for MacIntosh
6     */
7
8
9     #include "meta.h"
10
11     #include "macplot.h"
12
13
14     #define NPATS 9 /* number of fill patterns */
15
16
17     int pati[4] = {0, 1, 2, 3}; /* pattern indices */
18
19     /*
20     * Patterns are 8 X 8, ordered left column to right, one byte per column.
21     */
22
23     Pattern macpat[NPATS+4] = {
24     {0377,0377,0377,0377,0377,0377,0377,0377}, /* solid */
25     {0217,0307,0343,0361,0370,0174,076,037}, /* thick \\\ (dashed) */
26     {0231,0314,0146,063,0231,0314,0146,063}, /* thin \\\ (dotted) */
27     {0201,0300,0140,060,030,014,06,03}, /* sparse \\\ */
28     {037,076,0174,0370,0361,0343,0307,0217}, /* thick /// (dashed) */
29     {063,0146,0314,0231,063,0146,0314,0231}, /* thin /// (dotted) */
30     {03,06,014,030,060,0140,0300,0201}, /* sparse /// */
31     {0201,0102,044,030,030,044,0102,0201}, /* crisscross */
32     {0201,0101,041,021,011,05,03,0377} /* web */
33     };
34
35     static int context = 0;
36
37     struct setting {
38     int cnx; /* setting context */
39     char *val; /* attribute value */
40     struct setting *snext; /* next setting in list */
41     };
42
43     static struct setting *sets[0200];
44
45
46
47
48     set(attrib, value) /* set attribute to value */
49
50     int attrib;
51     char *value;
52
53     {
54     struct setting *newset;
55
56     switch (attrib) {
57     case SALL:
58     context++;
59     return;
60     case SPAT0:
61     case SPAT1:
62     case SPAT2:
63     case SPAT3:
64     if (!spat(attrib, value)) {
65     sprintf(errmsg, "Bad pattern set value: %s", value);
66     error(WARNING, errmsg);
67     return;
68     }
69     break;
70     default:
71     sprintf(errmsg, "Can't set attribute: %o", attrib);
72     error(WARNING, errmsg);
73     return;
74     }
75     newset = (struct setting *)malloc(sizeof(struct setting));
76     newset->cnx = context;
77     newset->val = savestr(value);
78     newset->snext = sets[attrib];
79     sets[attrib] = newset;
80     }
81
82
83
84
85     unset(attrib) /* return attribute to previous setting */
86
87     int attrib;
88
89     {
90     register int i;
91
92     if (attrib == SALL) {
93     if (context == 0)
94     reset(SALL);
95     else {
96     context--;
97     for (i = 0; i < 0200; i++)
98     while (sets[i] != NULL && sets[i]->cnx > context)
99     spop(i);
100     }
101     return;
102     }
103     spop(attrib);
104     if (sets[attrib] == NULL)
105     reset(attrib);
106
107     switch (attrib) {
108     case SPAT0:
109     case SPAT1:
110     case SPAT2:
111     case SPAT3:
112     spat(attrib, sets[attrib]->val);
113     break;
114     default:
115     sprintf(errmsg, "Can't unset attribute: %o", attrib);
116     error(WARNING, errmsg);
117     return;
118     }
119     }
120
121
122
123
124
125     reset(attrib) /* return attribute to default setting */
126
127     int attrib;
128
129     {
130     switch (attrib) {
131     case SALL:
132     reset(SPAT0);
133     reset(SPAT1);
134     reset(SPAT2);
135     reset(SPAT3);
136     context = 0;
137     return;
138     case SPAT0:
139     spat(SPAT0, "P0");
140     break;
141     case SPAT1:
142     spat(SPAT1, "P1");
143     break;
144     case SPAT2:
145     spat(SPAT2, "P2");
146     break;
147     case SPAT3:
148     spat(SPAT3, "P3");
149     break;
150     default:
151     sprintf(errmsg, "Can't reset attribute: %o", attrib);
152     error(WARNING, errmsg);
153     return;
154     }
155     while (sets[attrib] != NULL)
156     spop(attrib);
157     }
158
159
160
161
162     static
163     spop(attrib) /* pop top off attrib settings list */
164
165     int attrib;
166
167     {
168
169     if (sets[attrib] != NULL) {
170     if (sets[attrib]->val != NULL)
171     free(sets[attrib]->val);
172     free((char *)sets[attrib]);
173     sets[attrib] = sets[attrib]->snext;
174     }
175
176     }
177
178
179
180
181     static int
182     spat(pat, patval) /* set a pattern */
183
184     int pat;
185     char *patval;
186
187     {
188     int n, v;
189     char *nextscan();
190     register char *cp;
191     register int j;
192
193     if (patval == NULL) return(FALSE);
194
195     if (patval[0] == 'P' || patval[0] == 'p') {
196     if (nextscan(patval+1, "%d", &n) == NULL || n < 0 || n >= NPATS)
197     return(FALSE);
198     } else {
199     n = NPATS + pat - SPAT0;
200     cp = patval;
201     for (j = 0; j < 8; j++) {
202     if ((cp = nextscan(cp, "%o", &v)) == NULL || v < 0 || v > 0377)
203     return(FALSE);
204     macpat[n][j] = v;
205     }
206     }
207     pati[pat-SPAT0] = n;
208     return(TRUE);
209     }
