root/radiance/src/meta/lib4014/lib4014.h
Revision: 1.2
Committed: Fri Nov 5 17:51:17 2004 UTC (20 years, 11 months ago) by greg
State: FILE REMOVED
Removed plotout and lib4014 it depends on
# User Rev Content
1 greg 1.2 /* RCSid: $Id: lib4014.h,v 1.1 2003/11/15 02:13:37 schorsch Exp $ */
2 schorsch 1.1 /*
3     * random.h - header file for random(3) function.
4     *
5     * 10/1/85
6     */
7     #ifndef _RAD_LIB4014_H_
8     #define _RAD_LIB4014_H_
9
10     #include <stdlib.h>
11
12     #ifdef __cplusplus
13     extern "C" {
14     #endif
15
16     extern void openvt(void);
17     extern void openpl(void);
18     extern void closevt(void);
19     extern void closepl(void);
20
21     extern void step(int d);
22     extern void arc(int x, int y, int x0, int y0, int x1, int y1);
23     extern int quad(int x, int y, int xp, int yp);
24     extern int abs_(int a);
25     extern void box(int x0, int y0, int x1, int y1);
26     extern void circle(int x, int y, int r);
27     extern void dot(void);
28     extern void erase(void);
29     extern void label(char *s);
30     extern void line(int x0, int y0, int x1, int y1);
31     extern void linemod(char *s);
32     extern void move(int xi, int yi);
33     extern void point(int xi, int yi);
34     extern void scale(char i, float x, float y);
35     extern void space(int x0, int y0, int x1, int y1);
36     extern void cont(int x, int y);
37     extern void putch(int c);
38
39
40
41     #ifdef __cplusplus
42     }
43     #endif
44     #endif /* _RAD_LIB4014_H_ */
45
