root/radiance/src/meta/igraph.c
Revision: 1.5
Committed: Thu Feb 9 21:54:11 2023 UTC (2 years, 8 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 1.4: +5 -7 lines
Error occurred while calculating annotation data.
fix: compile error fixes related to redeclaration of eputs() and wputs()
2 static const char RCSid[] = "$Id: igraph.c,v 1.4 2003/11/15 02:13:37 schorsch Exp $";
5 * igraph.c - interactive graphing program.
6 *
7 * 6/30/86
8 *
9 * Greg Ward Larson
10 */
11
12 #include <stdio.h>
13 #include <ctype.h>
14 #include <setjmp.h>
15
16 #include "rtprocess.h"
17 #include "rterror.h"
18 #include "meta.h"
19 #include "mgraph.h"
20 #include "mgvars.h"
21
22 typedef struct {
23 char *descrip; /* description */
24 char *value; /* value */
25 } SMAP;
26
27 #define NDEV 10 /* number of devices */
28
29 SMAP dev[NDEV] = {
30 { "Tektronix 4014", "t4014" },
31 { "AED 512", "output aed5" },
32 { "X10 Window System", "xmeta" },
33 { "X11 Window System", "x11meta" },
34 { "Epson Printer", "output mx80" },
35 { "Mannesman-Tally Printer", "output mt160" },
36 { "Mannesman-Tally High Density", "output mt160l" },
37 { "Apple Imagewriter", "output imagew" },
38 { "Imagen Printer", "impress | ipr" },
39 { "Postscript Printer", "psmeta | lpr" },
40 };
41
42 #define NTYP 7 /* number of plot types */
43
44 SMAP typ[NTYP] = {
45 { "Cartesian Plot", "cartesian.plt" },
46 { "Polar Plot (degrees)", "polar.plt" },
47 { "Curve Plot (symbols & lines)", "curve.plt" },
48 { "Scatter Plot (symbols only)", "scatter.plt" },
49 { "Line Plot (lines only)", "line.plt" },
50 { "Function Plot (lines)", "function.plt" },
51 { "Box and Whisker Plot", "boxw.plt" },
52 };
53
54 #define NCAL 3 /* number of calculation types */
55
56 SMAP cal[NCAL] = {
57 { "Extrema, Average", "nma" },
58 { "Integral", "ni" },
59 { "Linear Regression", "nl" },
60 };
61
62 char *progname;
63
64 char *libpath[4];
65
66 static int recover = 0; /* try to recover? */
67
68 static jmp_buf env; /* setjmp buffer */
69
70 static char curfile[64] = "temp.plt"; /* current file name */
71
72 static void mainmenu(void);
73 static void uwait(void);
74 static void gcompute(void);
75 static void setvars(int nvar, VARIABLE vars[]);
76 static void plotout(void);
77 static void settype(void);
78 static char *getfile(void);
79
80 int
81 main(argc, argv)
82 int argc;
83 char *argv[];
84 {
85 char *getenv();
86 int i;
87
88 progname = argv[0];
89 libpath[0] = "./";
90 if ((libpath[i=1] = getenv("MDIR")) != NULL)
91 i++;
92 libpath[i++] = MDIR;
93 libpath[i] = NULL;
94
95 for (i = 1; i < argc; i++)
96 mgload(strcpy(curfile, argv[i]));
97
98 mainmenu();
99
100 quit(0);
101 return 0; /* pro forma return */
102 }
103
104 void
105 eputs(const char *msg) /* print error message */
106 {
107 fputs(msg, stderr);
108 }
109
110 void
111 quit(int code) /* recover or quit */
112 {
113 if (code && recover--)
114 longjmp(env, 1);
115 exit(code);
116 }
117
118
119 static void
120 mainmenu(void) /* the main menu loop */
121 {
122 char sbuf[128];
123
124 for ( ; ; ) {
125 printf("\nGRAPH MENU\n");
126 printf("\t1 New Plot\n");
127 printf("\t2 Set Plot Type\n");
128 printf("\t3 Load Plot File\n");
129 printf("\t4 Save Plot File\n");
130 printf("\t5 Change Plot Variable\n");
131 printf("\t6 Change Curve Variable\n");
132 printf("\t7 Output Plot\n");
133 printf("\t8 Escape Command\n");
134 printf("\t9 Computation\n");
135 printf("\t10 Quit\n");
136
137 printf("\nChoice: ");
138 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
139 if (feof(stdin))
140 return;
141 switch (atoi(sbuf)) {
142 case 1: /* new plot */
143 mgclearall();
144 break;
145 case 2: /* set plot type */
146 settype();
147 break;
148 case 3: /* load plot file */
149 if (setjmp(env) == 0) {
150 recover = 1;
151 mgload(getfile());
152 recover = 0;
153 } else
154 uwait();
155 break;
156 case 4: /* save plot file */
157 if (setjmp(env) == 0) {
158 recover = 1;
159 mgsave(getfile());
160 recover = 0;
161 } else
162 uwait();
163 break;
164 case 5: /* set plot variable */
165 setvars(NVARS, gparam);
166 break;
167 case 6: /* set curve variable */
168 printf("\nCurve (A-%c): ", MAXCUR-1+'A');
169 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
170 if (islower(sbuf[0]))
171 sbuf[0] -= 'a';
172 else if (isupper(sbuf[0]))
173 sbuf[0] -= 'A';
174 else
175 break;
176 if (sbuf[0] < MAXCUR)
177 setvars(NCVARS, cparam[(int)sbuf[0]]);
178 break;
179 case 7: /* output plot */
180 plotout();
181 break;
182 case 8: /* escape command */
183 printf("\nCommand: ");
184 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
185 if (sbuf[0]) {
186 system(sbuf);
187 uwait();
188 }
189 break;
190 case 9: /* computation */
191 gcompute();
192 break;
193 case 10: /* quit */
194 return;
195 }
196 }
197 }
198
199
200 static char *
201 getfile(void) /* get file name from user */
202 {
203 char sbuf[128];
204
205 printf("\nFile (%s): ", curfile);
206 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
207 if (sbuf[0] == '-')
208 return(NULL);
209 if (sbuf[0])
210 strcpy(curfile, sbuf);
211 return(curfile);
212 }
213
214 static void
215 settype(void) /* set plot type */
216 {
217 char sbuf[128];
218 int i;
219
220 printf("\nPLOT TYPE\n");
221
222 for (i = 0; i < NTYP; i++)
223 printf("\t%d %s\n", i+1, typ[i].descrip);
224
225 printf("\nChoice (0): ");
226 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
227 i = atoi(sbuf) - 1;
228 if (i < 0 || i >= NTYP)
229 return;
230 sprintf(sbuf, "include=%s", typ[i].value);
231 setmgvar("plot type", stdin, sbuf);
232 }
233
234
235 static void
236 plotout(void) /* output our graph */
237 {
238 extern FILE *pout;
239 char sbuf[128];
240 char *command = NULL;
241 int i;
242
243 printf("\nOUTPUT PLOT\n");
244
245 for (i = 0; i < NDEV; i++)
246 printf("\t%d %s\n", i+1, dev[i].descrip);
247 printf("\t%d Dumb Terminal\n", NDEV+1);
248 printf("\t%d Other\n", NDEV+2);
249
250 printf("\nChoice (0): ");
251 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
252 i = atoi(sbuf) - 1;
253 if (i < 0 || i > NDEV+1)
254 return;
255 if (i < NDEV)
256 command = dev[i].value;
257 else if (i == NDEV) {
258 if (setjmp(env) == 0) {
259 recover = 1;
260 cgraph(79, 22);
261 recover = 0;
262 }
263 uwait();
264 return;
265 } else if (i == NDEV+1) {
266 printf("\nDriver command: ");
267 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
268 if (!sbuf[0])
269 return;
270 command = sbuf;
271 }
272 if ((pout = popen(command, "w")) == NULL) {
273 fprintf(stderr, "%s: cannot execute device driver: %s\n",
274 progname, dev[i].value);
275 quit(1);
276 }
277 if (setjmp(env) == 0) {
278 recover = 1;
279 mgraph();
280 recover = 0;
281 } else
282 uwait();
283 mdone();
284 pclose(pout);
285 }
286
287
288 static void
289 setvars( /* set variables */
290 int nvar,
291 VARIABLE vars[])
292 {
293 char sbuf[128];
294 int i, j;
295
296 for ( ; ; ) {
297 printf("\nVARIABLES\n");
298
299 for (i = 0; i < nvar; i++)
300 printf("\t%d %s\n", i+1, vars[i].descrip == NULL ?
301 vars[i].name : vars[i].descrip);
302
303 printf("\nChoice (0): ");
304 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
305 i = atoi(sbuf) - 1;
306 if (i < 0 || i >= nvar)
307 return;
308 printf("\n%s", vars[i].name);
309 if (vars[i].type == FUNCTION)
310 printf("(x)");
311 if (vars[i].flags & DEFINED) {
312 mgtoa(sbuf, &vars[i]);
313 printf(" (%s)", sbuf);
314 }
315 printf(": ");
316 if (vars[i].type == FUNCTION)
317 sprintf(sbuf, "%s(x)=", vars[i].name);
318 else
319 sprintf(sbuf, "%s=", vars[i].name);
320 j = strlen(sbuf);
321 clearerr(stdin); fgets(sbuf+j, sizeof(sbuf)-j, stdin);
322 if (sbuf[j]) {
323 if (vars[i].type == DATA && sbuf[j] == '-')
324 sbuf[j] = '\0';
325
326 if (setjmp(env) == 0) {
327 recover = 1;
328 setmgvar("variable set", stdin, sbuf);
329 recover = 0;
330 } else
331 uwait();
332 }
333 }
334 }
335
336
337 static void
338 gcompute(void) /* do a computation */
339 {
340 char sbuf[64];
341 int i;
342
343 printf("\nCOMPUTE\n");
344
345 for (i = 0; i < NCAL; i++)
346 printf("\t%d %s\n", i+1, cal[i].descrip);
347
348 printf("\nChoice (0): ");
349 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
350 i = atoi(sbuf) - 1;
351 if (i < 0 || i >= NCAL)
352 return;
353 printf("\n");
354 if (setjmp(env) == 0) {
355 recover = 1;
356 gcalc(cal[i].value);
357 recover = 0;
358 }
359 printf("\n");
360 uwait();
361 }
362
363
364 static void
365 uwait(void) /* wait for user after command, error */
366 {
367 printf("Hit return to continue: ");
368 while (getchar() != '\n')
369 ;
370 }
