root/radiance/src/meta/aed5.c
Revision: 1.1
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years, 8 months ago) by greg
5 * aed.c - driver for AED 512 terminal.
6 *
7 * 7/8/86
8 */
9
10 #include <fcntl.h>
11
12 #include "meta.h"
13
14
15 /* AED command characters */
16
17 #define AEDFMT "1888N" /* Format string to send to AED */
18 #define SCT 75 /* Set color lookup table */
19 #define SEC 67 /* Set color for vector drawing */
20 #define SBC 91 /* Set background color */
21 #define MOV 81 /* Set CAP (current access pointer) to x, y */
22 #define MVR 105 /* Set CAP relative */
23 #define DVA 65 /* Draw vector to new CAP x, y */
24 #define DVR 108 /* Draw vector relative */
25 #define WHR 92 /* Write horizontal runs */
26 #define OPT 40 /* Miscellaneous terminal control */
27 #define SEN 71 /* Set encoding types */
28 #define RST 48 /* Reset terminal */
29 #define FFD 12 /* Clear screen */
30 #define SCS 96 /* Set status */
31 #define DAI 114 /* Define area of interest */
32 #define EJC 85 /* Enable Joystick cursor positioning */
33 #define DJC 100 /* Disable Joystick cursor positioning */
34 #define SCC 99 /* Set Cursor Colors */
35 #define SCP 93 /* Set Cursor Parameters */
36 #define RCP 106 /* Read Cursor Position */
37 #define SAP 94 /* Set alphanumeric parameters */
38 #define SLS 49 /* Set Line Style */
39 #define DFR 111 /* Draw Filled Rectangle */
40 #define MAXRLEN 255 /* Maximum runlength for a span */
41 #define NUL 0 /* Null terminates run sequences */
42 #define ESC 27 /* Escape starts a command sequence */
43 #define END 1 /* Ctrl-A used to terminate command mode */
44
45 #define command(c) (putc(ESC, stdout), putc(c, stdout))
46 #define byte(b) putc(b, stdout)
47 #define ascii(c) putc(c, stdout)
48
49 #define BKGCOL 7 /* Background color (white) */
50
51 #define NROWS 512 /* # rows for output */
52 #define NCOLS 512 /* # columns for output */
53
54 #define xconv(x) CONV(x, NCOLS)
55 #define yconv(y) CONV(y, NROWS)
56
57 #define XCOM "pexpand +vOCIs -tpSUR %s"
58
59 char *progname;
60
61 static short newpage = TRUE;
62
63 static int curx = -1, /* current position */
64 cury = -1;
65
66 static int curcol = -1; /* current color */
67
68 static short curmod = -1; /* current line drawing mode */
69
70 static short cmode[4] = {0, 1, 2, 4}; /* color map */
71
72 static short lmode[4] = {255, 15, 85, 39}; /* line map */
73
74 static PRIMITIVE nextp;
75
76
77
78 main(argc, argv)
79 int argc;
80 char **argv;
81 {
82 FILE *fp, *popen();
83 char comargs[200], shcom[300];
84 short condonly = FALSE, conditioned = FALSE;
85
86 progname = *argv++;
87 argc--;
88
89 while (argc && **argv == '-') {
90 switch (*(*argv+1)) {
91 case 'c':
92 condonly = TRUE;
93 break;
94 case 'r':
95 conditioned = TRUE;
96 break;
97 default:
98 error(WARNING, "unknown option");
99 break;
100 }
101 argv++;
102 argc--;
103 }
104
105 if (conditioned) {
106 init();
107 if (argc)
108 while (argc) {
109 fp = efopen(*argv, "r");
110 plot(fp);
111 fclose(fp);
112 argv++;
113 argc--;
114 }
115 else
116 plot(stdin);
117 } else {
118 comargs[0] = '\0';
119 while (argc) {
120 strcat(comargs, " ");
121 strcat(comargs, *argv);
122 argv++;
123 argc--;
124 }
125 sprintf(shcom, XCOM, comargs);
126 if (condonly)
127 return(system(shcom));
128 else {
129 init();
130 if ((fp = popen(shcom, "r")) == NULL)
131 error(SYSTEM, "cannot execute input filter");
132 plot(fp);
133 return(pclose(fp));
134 }
135 }
136 return(0);
137 }
138
139
140
141
142
143 plot(infp) /* plot meta-file */
144
145 FILE *infp;
146
147 {
148
149 do {
150 readp(&nextp, infp);
151 while (isprim(nextp.com)) {
152 doprim(&nextp);
153 fargs(&nextp);
154 readp(&nextp, infp);
155 }
156 doglobal(&nextp);
157 fargs(&nextp);
158 }
159 while (nextp.com != PEOF);
160
161 }
162
163
164
165
166
167 doglobal(g) /* execute a global command */
168
169 PRIMITIVE *g;
170
171 {
172 int tty;
173 char c;
174
175 switch (g->com) {
176
177 case PEOF:
178 break;
179
180 case PDRAW:
181 fflush(stdout);
182 break;
183
184 case PEOP:
185 newpage = TRUE;
186 if (!isatty(fileno(stdout)))
187 break;
188 /* fall through */
189
190 case PPAUSE:
191 fflush(stdout);
192 tty = open(TTY, O_RDWR);
193 if (g->args != NULL) {
194 write(tty, g->args, strlen(g->args));
195 write(tty, " - (hit return to continue)", 27);
196 }
197 else
198 write(tty, "\007", 1);
199 do {
200 c = '\n';
201 read(tty, &c, 1);
202 }
203 while (c != '\n' && c != '\r');
204 close(tty);
205 break;
206
207 default:
208 sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
209 error(WARNING, errmsg);
210 break;
211 }
212
213 }
214
215
216
217
218 doprim(p) /* plot primitive */
219
220 register PRIMITIVE *p;
221
222 {
223
224 if (newpage) { /* clear screen */
225 command(FFD);
226 shortwait(50);
227 newpage = FALSE;
228 }
229
230 switch (p->com) {
231
232 case PLSEG:
233 plotlseg(p);
234 break;
235
236 case PMSTR:
237 printstr(p);
238 break;
239
240 case PRFILL:
241 fillrect(p);
242 break;
243
244 default:
245 sprintf(errmsg, "unknown command '%c' in doprim", p->com);
246 error(WARNING, errmsg);
247 return;
248 }
249
250 }
251
252
253
254
255
256
257 printstr(p) /* output a string */
258
259 register PRIMITIVE *p;
260
261 {
262 static int hsp[4] = {6, 5, 4, 3};
263 char font, size;
264 int hspace, vspace = 18;
265
266 hspace = hsp[(p->arg0 >> 4) & 03];
267
268 if (p->arg0 & 04)
269 hspace *= 2;
270
271 if (hspace > 16) {
272 font = '7'; size = '2';
273 } else if (hspace > 12) {
274 font = '5'; size = '2';
275 } else if (hspace > 8) {
276 font = '7'; size = '1';
277 } else {
278 font = '5'; size = '1';
279 }
280
281 command(SAP);
282 ascii(size); ascii(font);
283 byte(hspace); byte(vspace);
284 ascii('L');
285
286 setcolor(p->arg0 & 03);
287
288 move(p->xy[XMN], p->xy[YMX]);
289
290 putc(END, stdout);
291 fputs(p->args, stdout);
292
293 curx = -1;
294 cury = -1;
295 }
296
297
298
299
300
301 plotlseg(p) /* plot a line segment */
302
303 register PRIMITIVE *p;
304
305 {
306 static short right = FALSE;
307 int y1, y2;
308 short lm = (p->arg0 >> 4) & 03;
309
310 if (p->arg0 & 0100) {
311 y1 = p->xy[YMX];
312 y2 = p->xy[YMN];
313 }
314 else {
315 y1 = p->xy[YMN];
316 y2 = p->xy[YMX];
317 }
318
319 setcolor(p->arg0 & 03);
320
321 if (lm != curmod) {
322 command(SLS);
323 byte(lmode[lm]); byte(85);
324 curmod = lm;
325 }
326
327 if (p->xy[XMN] == curx && y1 == cury)
328 draw(p->xy[XMX], y2);
329 else if (p->xy[XMX] == curx && y2 == cury)
330 draw(p->xy[XMN], y1);
331 else if (right = !right) {
332 move(p->xy[XMN], y1);
333 draw(p->xy[XMX], y2);
334 } else {
335 move(p->xy[XMX], y2);
336 draw(p->xy[XMN], y1);
337 }
338 }
339
340
341 fillrect(p)
342
343 register PRIMITIVE *p;
344
345 {
346
347 setcolor(p->arg0 & 03);
348 move(p->xy[XMN], p->xy[YMN]);
349 curx = xconv(p->xy[XMX]);
350 cury = yconv(p->xy[YMX]);
351 command(DFR);
352 aedcoord(curx, cury);
353
354 }
355
356 init() /* initialize terminal */
357 {
358 /* Reset AED and tell it the data format */
359 command(RST);
360 longwait(2);
361 command(OPT);
362 byte(6); byte(1); /* AED command set */
363 command(SEN); fputs(AEDFMT, stdout);
364 command(SBC); byte(BKGCOL);
365 }
366
367
368 setcolor(cn) /* set color */
369 int cn;
370 {
371 if (cn != curcol) {
372 command(SEC);
373 byte(cmode[cn]);
374 curcol = cn;
375 }
376 }
377
378
379 move(x, y) /* move to coordinate (x,y) */
380 int x, y;
381 {
382 command(MOV);
383 aedcoord(xconv(x), yconv(y));
384 curx = x;
385 cury = y;
386 }
387
388
389 draw(x, y) /* draw vector from CAP to (x,y) */
390 int x, y;
391 {
392 command(DVA);
393 aedcoord(xconv(x), yconv(y));
394 curx = x;
395 cury = y;
396 }
397
398
399 /*
400 * aedcoord - puts out an (x, y) coordinate in AED 8 bit format.
401 */
402
403 aedcoord(x, y)
404 register int x, y;
405 {
406 putc(((x >> 4) & 0x30) | ((y >> 8) & 0x3), stdout);
407 putc(x & 0xff, stdout);
408 putc(y & 0xff, stdout);
409 }
410
411
412 longwait(t) /* longer wait */
413 int t;
414 {
415 fflush(stdout);
416 sleep(t);
417 }
418
419
420 shortwait(t) /* shorter wait */
421 int t;
422 {
423 register long l = t*1000;
424
425 fflush(stdout);
426 while (l--)
427 ;
428 }
