| 1 |
import os |
| 2 |
| 3 |
Import ('env') |
| 4 |
| 5 |
# compose paths |
| 6 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name) |
| 7 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name) |
| 8 |
| 9 |
# extra flag |
| 10 |
MDIRFLAGS = env.get('CPPFLAGS', []) + [ |
| 11 |
'-DMDIR=\\"%s\\"' % os.path.join(env['RAD_RLIBDIR'], 'meta')] |
| 12 |
bgraph = env.Object(source='bgraph.c', CPPFLAGS=MDIRFLAGS) |
| 13 |
igraph = env.Object(source='igraph.c', CPPFLAGS=MDIRFLAGS) |
| 14 |
dgraph = env.Object(source='dgraph.c', CPPFLAGS=MDIRFLAGS) |
| 15 |
gcomp = env.Object(source='gcomp.c', CPPFLAGS=MDIRFLAGS) |
| 16 |
syscalls = env.Object(source='syscalls.c', CPPFLAGS=MDIRFLAGS) |
| 17 |
# used by several targets |
| 18 |
mfio = env.Object(source='mfio.c') |
| 19 |
misc = env.Object(source='misc.c') |
| 20 |
primout = env.Object(source='primout.c') |
| 21 |
plot = env.Object(source='plot.c') |
| 22 |
rplot = env.Object(source='rplot.c') |
| 23 |
palloc = env.Object(source='palloc.c') |
| 24 |
plotin = env.Object(source='plotin.c') |
| 25 |
mgvars = env.Object(source='mgvars.c') |
| 26 |
mgraph = env.Object(source='mgraph.c') |
| 27 |
cgraph = env.Object(source='cgraph.c') |
| 28 |
gcalc = env.Object(source='gcalc.c') |
| 29 |
# multiple output from same source |
| 30 |
| 31 |
common = [mfio, misc, syscalls] |
| 32 |
| 33 |
libmeta = env.StaticLibrary(radlib('meta'), |
| 34 |
Split ('metacalls.c progname.c') +[primout] + common) |
| 35 |
| 36 |
# standard targets |
| 37 |
PROGS = ( |
| 38 |
('meta2bmp', Split('meta2bmp.c') +[rplot, palloc, plot] + common, |
| 39 |
['rtproc','rtpath','rtpic','rtio', # proc/path/rtio for win_popen() |
| 40 |
'rtcont','rtmem','rterror']), |
| 41 |
('meta2tga', Split('meta2tga.c') +[rplot, palloc, plot] + common, |
| 42 |
['rtproc','rtpath','rtio', # proc/path/rtio for win_popen() |
| 43 |
| 44 |
('pexpand', Split('pexpand.c expand.c segment.c') +[palloc]+ common, |
| 45 |
['rtcont','rtmem','rterror']), |
| 46 |
('psort', Split('psort.c sort.c') +[palloc]+ common, |
| 47 |
['rtpath','rtcont','rtmem','rterror']), |
| 48 |
('cv', Split('cv.c cvhfio.c') + common, |
| 49 |
| 50 |
('psmeta', Split('psmeta.c psplot.c') + common, |
| 51 |
| 52 |
('plotin', [plotin, primout] + common, |
| 53 |
| 54 |
('bgraph', [bgraph, mgraph, mgvars], |
| 55 |
| 56 |
'rtfunc','rtcont','rtmem','meta','rterror']), |
| 57 |
('igraph', [igraph, gcalc, cgraph, mgraph, mgvars], |
| 58 |
| 59 |
| 60 |
('dgraph', [dgraph, cgraph, mgvars], |
| 61 |
| 62 |
'rtfunc','rtcont','rtmem','rterror']), |
| 63 |
('gcomp', [gcomp, gcalc, mgvars], |
| 64 |
| 65 |
| 66 |
('plot4', Split('plot4.c') +[primout]+ common, |
| 67 |
| 68 |
| 69 |
| 70 |
for p in PROGS: |
| 71 |
prog = env.Program(target=radbin(p[0]), source=p[1], |
| 72 |
LIBS=p[2]+env['RAD_MLIB']) |
| 73 |
Default(prog) |
| 74 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) |
| 75 |
| 76 |
| 77 |
| 78 |
# X11 targets |
| 79 |
if env.has_key('X11LIB'): |
| 80 |
x11meta = env.Program(radbin('x11meta'), [plotin, primout]+ common, |
| 81 |
CPPPATH=env.get('CPPPATH',[])+[env['X11INCLUDE']], |
| 82 |
LIBPATH=env.get('LIBPATH',[])+[env['X11LIB']], |
| 83 |
LIBS=['rtcont','rtmem','rterror', 'X11'] + env['RAD_MLIB']) |
| 84 |
Default(x11meta) |
| 85 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], x11meta)]) |
| 86 |
| 87 |
