root/radiance/src/meta/Rmakefile
Wed Apr 7 17:03:13 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 1.16 , to selected 1.14
chore: fixed issue with read-only library files in distribution
Tue Jul 3 22:29:01 2018 UTC (7 years, 3 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.15: +3 -2 lines
Diff to previous 1.15 , to selected 1.14
Added AR variable to provide a way to override standard library builder
Mon Oct 12 20:10:50 2015 UTC (10 years ago) by greg
Changes since 1.14: +8 -2 lines
Diff to previous 1.14
Added installation of required library files
Revision 1.14 - (view) (download) (annotate) - [selected]
Sat Apr 26 15:59:38 2014 UTC (11 years, 5 months ago) by greg
Changes since 1.13: +2 -2 lines
Diff to previous 1.13
Thu Feb 7 23:02:14 2008 UTC (17 years, 8 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Diff to previous 1.12 , to selected 1.14
Sat Nov 24 00:37:27 2007 UTC (17 years, 10 months ago) by greg
Changes since 1.11: +10 -10 lines
Diff to previous 1.11 , to selected 1.14
Fri Mar 10 19:40:13 2006 UTC (19 years, 7 months ago) by schorsch
Changes since 1.10: +17 -17 lines
Diff to previous 1.10 , to selected 1.14
Wed May 4 23:43:19 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.9: +12 -6 lines
Diff to previous 1.9 , to selected 1.14
Created meta2bmp file to generate BMP output from metafile graphics
Fri Nov 5 17:51:16 2004 UTC (20 years, 11 months ago) by greg
Changes since 1.8: +4 -18 lines
Diff to previous 1.8 , to selected 1.14
Removed plotout and lib4014 it depends on
Fri Nov 5 03:31:37 2004 UTC (20 years, 11 months ago) by greg
Changes since 1.7: +9 -53 lines
Diff to previous 1.7 , to selected 1.14
Wed Oct 22 02:15:07 2003 UTC (22 years ago) by greg
Changes since 1.6: +33 -32 lines
Diff to previous 1.6 , to selected 1.14
Fixed Rmakefile for FreeBSD version of make, which wasn't happy
Sat Aug 30 08:18:43 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 1.5 , to selected 1.14
Fixed special target selection.
Wed Aug 20 09:28:07 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 1.4: +88 -109 lines
Diff to previous 1.4 , to selected 1.14
Adapted Rmakefile to work the same way as the others.
Fri Aug 1 14:14:24 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 1.3 , to selected 1.14
Eliminated CPM, MAC, and UNIX conditional compiles.
Mon Jul 14 16:07:41 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 1.2 , to selected 1.14
Changed to relying on error() call in Radiance library
Thu Jun 26 00:49:15 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 1.1: +5 -5 lines
Diff to previous 1.1 , to selected 1.14
Compile fixes for "special" target on Linux.
Sat Feb 22 02:07:26 2003 UTC (22 years, 7 months ago) by greg
Diff to selected 1.14
