root/radiance/src/meta/Rmakefile
Wed May 4 23:43:19 2005 UTC (20 years, 8 months ago) by greg
Changes since 1.9: +12 -6 lines
Diff to previous 1.9
Created meta2bmp file to generate BMP output from metafile graphics
Fri Nov 5 17:51:16 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.8: +4 -18 lines
Diff to previous 1.8
Removed plotout and lib4014 it depends on
Fri Nov 5 03:31:37 2004 UTC (21 years, 2 months ago) by greg
Changes since 1.7: +9 -53 lines
Diff to previous 1.7
Wed Oct 22 02:15:07 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.6: +33 -32 lines
Diff to previous 1.6
Fixed Rmakefile for FreeBSD version of make, which wasn't happy
Sat Aug 30 08:18:43 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 1.5
Fixed special target selection.
Wed Aug 20 09:28:07 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 1.4: +88 -109 lines
Diff to previous 1.4
Adapted Rmakefile to work the same way as the others.
Fri Aug 1 14:14:24 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 1.3
Eliminated CPM, MAC, and UNIX conditional compiles.
Mon Jul 14 16:07:41 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.2
Changed to relying on error() call in Radiance library
Thu Jun 26 00:49:15 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 1.1: +5 -5 lines
Diff to previous 1.1
Compile fixes for "special" target on Linux.
Sat Feb 22 02:07:26 2003 UTC (22 years, 10 months ago) by greg
