root/radiance/src/hd/sm_test.c
Revision: 3.2
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 11 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.2 static const char RCSid[] = "$Id: sm_test.c,v 3.1 2003/02/22 02:07:25 greg Exp $";
3 greg 3.1 #endif
4     /*
5     * sm_test.c
6     *
7     * A simple OGL display program to test sm code
8     */
9     #include "standard.h"
10
11     #include <glut.h>
12     #include "ui.h"
13     #include "sm_geom.h"
14     #include "sm_qtree.h"
15     #include "sm_stree.h"
16     #include "sm.h"
17     #include "sm_draw.h"
18
19     struct driver odev;
20     char *progname;
21     double
22     test_normalize(v) /* normalize a vector, return old magnitude */
23     register FVECT v;
24     {
25     register double len;
26
27     len = DOT(v, v);
28
29     if (len <= 0.0)
30     return(0.0);
31
32     if (len <= 1.0+FTINY && len >= 1.0-FTINY)
33     len = 0.5 + 0.5*len; /* first order approximation */
34     else
35     len = sqrt(len);
36
37     v[0] /= len;
38     v[1] /= len;
39     v[2] /= len;
40
41     return(len);
42     }
43
44     void
45     print_usage(char *program)
46     {
47     fprintf(stderr, "usage: %s \n", program);
48     }
49
50
51     /* Parse the command line arguments to get the input file name. The depth
52     * thresholding size may also be specified, as well as the disparity
53     * threshold, specified in number of depth ranges, for creating depth
54     * disparity lines.
55     */
56     void
57     parse_cmd_line(int argc, char* argv[])
58     {
59     int i;
60     if(argc < 2)
61     return;
62
63     for(i=1;i<argc;i++)
64     if(argv[i][0] == '-')
65     switch(argv[i][1]) {
66     case 't':
67     Tri_intersect = TRUE;
68     break;
69     case 'd':
70     Pt_delete = TRUE;
71     break;
72     case 'f':
73     if(i+1 < argc)
74     {
75     Filename = &(argv[i+1][0]);
76     i++;
77     }
78     else
79     fprintf(stderr,"Must include file name\n");
80     }
81     /* Nothing for now */
82     }
83
84     void
85     display()
86     {
87     glutMainLoop();
88     }
89
90     VIEW View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0};
91     int
92     main(int argc, char *argv[])
93     {
94     COLR colr;
95     FVECT v0,v1,v2,a,b,c,dir;
96     double d[3];
97     double phi,theta;
98
99     progname = argv[0];
100     parse_cmd_line(argc,argv);
101     /* Open a display window */
102     smDraw_open_window(argc,argv);
103     /* First read in the command line arguments */
104
105     odev.v = View;
106
107     if(Filename)
108     {
109     next_sample(a,a,colr,1);
110     /* Initialize the data structures for 10 samples*/
111     smInit(262000);
112     }
113     else
114     smInit(100);
115     display();
116     }
117
118
119
120
121
122
123
124
125
126
127
128
129
