root/radiance/src/hd/sm_ogl.c
Revision: 3.16
Committed: Sat Feb 22 02:07:25 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.15: +111 -105 lines
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.16 static const char RCSid[] = "$Id$";
3 gwlarson 3.1 #endif
4     /*
5     * sm_ogl.c
6 gwlarson 3.14 *
7     * Rendering routines for triangle mesh representation utilizing OpenGL
8 greg 3.16 *
9     * smClean(tmflag) : display has been wiped clean
10     * int tmflag;
11     * Called after display has been effectively cleared, meaning that all
12     * geometry must be resent down the pipeline in the next call to smUpdate().
13     * If tmflag is set, tone-mapping should be performed
14     *
15     * smUpdate(vp, qua) : update OpenGL output geometry for view vp
16     * VIEW *vp; : desired view
17     * int qua; : quality level (percentage on linear time scale)
18     *
19     * Draw new geometric representation using OpenGL calls. Assume that the
20     * view has already been set up and the correct frame buffer has been
21     * selected for drawing. The quality level is on a linear scale, where 100%
22     * is full (final) quality. It is not necessary to redraw geometry that has
23     * been output since the last call to smClean(). (The last view drawn will
24     * be vp==&odev.v each time.)
25     */
26 gwlarson 3.1 #include "standard.h"
27
28     #include <GL/gl.h>
29
30 gwlarson 3.8 #include "sm_flag.h"
31 gwlarson 3.3 #include "sm_list.h"
32 gwlarson 3.1 #include "sm_geom.h"
33     #include "sm.h"
34
35 greg 3.16 int smClean_notify = TRUE; /*If TRUE:Do full redraw on next update*/
36     static int smCompute_mapping = TRUE; /*If TRUE:re-tonemap on next update */
37     static int smIncremental = FALSE; /*If TRUE: there has been incremental
38     rendering since last full draw */
39     #define NEW_TRI_CNT 1000 /* Default number of tris to allocate
40     space to sort for incremental update*/
41 gwlarson 3.14 #define SM_RENDER_FG 0 /* Render foreground tris only*/
42     #define SM_RENDER_BG 1 /* Render background tris only */
43 gwlarson 3.15 #define SM_RENDER_CULL 8 /* Perform view frustum culling */
44     #define BASE 1 /* Indicates base triangle */
45     #define DIR 2 /* Indicates triangle w/directional pts*/
46 gwlarson 3.14 /* FOR DISPLAY LIST RENDERING: **********************************************/
47 greg 3.16 #define SM_DL_LEVELS 2 /* # of levels down to create display lists */
48     #define SM_DL_LISTS 42 /* # of qtree nodes in tree at above level:
49     should be 2*(4^(SM_DL_LEVELS+1)-1)/(4-1) */
50 gwlarson 3.14 static GLuint Display_lists[SM_DL_LISTS][2] = {0};
51     /****************************************************************************/
52 gwlarson 3.1
53 gwlarson 3.14 /* FOR APPROXIMATION RENDERING **********************************************/
54 gwlarson 3.3 typedef struct {
55 gwlarson 3.4 float dist; /* average distance */
56 gwlarson 3.3 BYTE rgb[3]; /* average color */
57     } QTRAVG; /* average quadtree value */
58
59 gwlarson 3.4 typedef struct {
60     QUADTREE qt; /* quadtree node (key & hash value) */
61     QTRAVG av; /* node average */
62     } QT_LUENT; /* lookup table entry */
63 gwlarson 3.3
64 gwlarson 3.5 static QT_LUENT *qt_htbl = NULL; /* quadtree cache */
65     static int qt_hsiz = 0; /* quadtree cache size */
66 gwlarson 3.14 /****************************************************************************/
67 gwlarson 3.3
68 gwlarson 3.14 /* For DEPTH SORTING ********************************************************/
69 gwlarson 3.13 typedef struct _T_DEPTH {
70     int tri;
71     double depth;
72     }T_DEPTH;
73 gwlarson 3.14 /**********************************************************************/
74 gwlarson 3.13
75 gwlarson 3.10 /*
76 gwlarson 3.13 * smClean(tmflag) : display has been wiped clean
77     * int tmflag;
78 gwlarson 3.10 * Called after display has been effectively cleared, meaning that all
79     * geometry must be resent down the pipeline in the next call to smUpdate().
80 gwlarson 3.13 * If tmflag is set, tone-mapping should be performed
81 gwlarson 3.10 */
82 gwlarson 3.13 smClean(tmflag)
83     int tmflag;
84 gwlarson 3.1 {
85     smClean_notify = TRUE;
86 greg 3.16 smCompute_mapping = tmflag;
87 gwlarson 3.1 }
88
89 gwlarson 3.4 int
90 gwlarson 3.5 qtCache_init(nel) /* initialize for at least nel elements */
91 gwlarson 3.4 int nel;
92     {
93 greg 3.16 static int hsiztab[] = {
94     8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0
95     };
96     register int i;
97
98     if (nel <= 0) { /* call to free table */
99     if (qt_hsiz) {
100     free((void *)qt_htbl);
101     qt_htbl = NULL;
102     qt_hsiz = 0;
103 gwlarson 3.4 }
104 greg 3.16 return(0);
105     }
106     nel += nel>>1; /* 66% occupancy */
107     for (i = 0; hsiztab[i]; i++)
108     if (hsiztab[i] > nel)
109     break;
110     if (!(qt_hsiz = hsiztab[i]))
111     qt_hsiz = nel*2 + 1; /* not always prime */
112     qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT));
113     if (qt_htbl == NULL)
114     qt_hsiz = 0;
115     for (i = qt_hsiz; i--; )
116     qt_htbl[i].qt = EMPTY;
117     return(qt_hsiz);
118 gwlarson 3.4 }
119
120     QT_LUENT *
121 gwlarson 3.5 qtCache_find(qt) /* find a quadtree table entry */
122 gwlarson 3.4 QUADTREE qt;
123     {
124 greg 3.16 int i, n;
125     register int ndx;
126     register QT_LUENT *le;
127 gwlarson 3.4
128 greg 3.16 if (qt_hsiz == 0 && !qtCache_init(1))
129     return(NULL);
130 gwlarson 3.4 tryagain: /* hash table lookup */
131 greg 3.16 ndx = (unsigned long)qt % qt_hsiz;
132     for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) {
133     le = &qt_htbl[ndx];
134     if (QT_IS_EMPTY(le->qt) || le->qt == qt)
135     return(le);
136     if ((ndx += n) >= qt_hsiz) /* this happens rarely */
137     ndx = ndx % qt_hsiz;
138     }
139     /* table is full, reallocate */
140     le = qt_htbl;
141     ndx = qt_hsiz;
142     if (!qtCache_init(ndx+1)) { /* no more memory! */
143     qt_htbl = le;
144     qt_hsiz = ndx;
145     return(NULL);
146     }
147 gwlarson 3.5 /* copy old table to new and free */
148 greg 3.16 while (ndx--)
149     if (!QT_IS_EMPTY(le[ndx].qt))
150     copystruct(qtCache_find(le[ndx].qt), &le[ndx]);
151     free((void *)le);
152     goto tryagain; /* should happen only once! */
153 gwlarson 3.4 }
154
155 gwlarson 3.3 stCount_level_leaves(lcnt, qt) /* count quadtree leaf nodes at each level */
156     int lcnt[];
157     register QUADTREE qt;
158     {
159     if (QT_IS_EMPTY(qt))
160     return;
161     if (QT_IS_TREE(qt)) {
162     if (!QT_IS_FLAG(qt)) /* not in our frustum */
163     return;
164     stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,0));
165     stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,1));
166     stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,2));
167     stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,3));
168     }
169     else
170 gwlarson 3.10 if(QT_LEAF_IS_FLAG(qt))
171     lcnt[0]++;
172 gwlarson 3.3 }
173
174     QTRAVG *
175     qtRender_level(qt,v0,v1,v2,sm,lvl)
176     QUADTREE qt;
177     FVECT v0,v1,v2;
178 gwlarson 3.1 SM *sm;
179 gwlarson 3.3 int lvl;
180     {
181     FVECT a,b,c;
182 gwlarson 3.4 register QT_LUENT *le;
183 gwlarson 3.3 QTRAVG *rc[4];
184 gwlarson 3.7 TRI *tri;
185 gwlarson 3.3
186     if (QT_IS_EMPTY(qt)) /* empty leaf node */
187     return(NULL);
188     if (QT_IS_TREE(qt) && !QT_IS_FLAG(qt)) /* not in our frustum */
189     return(NULL);
190 gwlarson 3.10 if(QT_IS_LEAF(qt) && !QT_LEAF_IS_FLAG(qt)) /* not in our frustum */
191     return(NULL);
192 gwlarson 3.3 /* else look up node */
193 gwlarson 3.5 if ((le = qtCache_find(qt)) == NULL)
194 gwlarson 3.4 error(SYSTEM, "out of memory in qtRender_level");
195     if (QT_IS_TREE(qt) && (QT_IS_EMPTY(le->qt) || lvl > 0))
196 gwlarson 3.3 { /* compute children */
197     qtSubdivide_tri(v0,v1,v2,a,b,c);
198 gwlarson 3.11 rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,c,b,sm,lvl-1);
199     rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),c,v1,a,sm,lvl-1);
200     rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),b,a,v2,sm,lvl-1);
201     rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),a,b,c,sm,lvl-1);
202 gwlarson 3.3 }
203 gwlarson 3.4 if (QT_IS_EMPTY(le->qt))
204 gwlarson 3.3 { /* let's make some data! */
205     int rgbs[3];
206     double distsum;
207 gwlarson 3.4 register int i, n;
208 gwlarson 3.3 /* average our triangle vertices */
209     rgbs[0] = rgbs[1] = rgbs[2] = 0;
210     distsum = 0.; n = 0;
211     if(QT_IS_TREE(qt))
212     { /* from subtree */
213     for (i = 4; i--; )
214 gwlarson 3.4 if (rc[i] != NULL)
215 gwlarson 3.3 {
216 gwlarson 3.4 rgbs[0] += rc[i]->rgb[0]; rgbs[1] += rc[i]->rgb[1];
217     rgbs[2] += rc[i]->rgb[2]; distsum += rc[i]->dist; n++;
218 gwlarson 3.3 }
219     }
220     else
221     { /* from triangle set */
222 greg 3.16 S_ID *os;
223     S_ID s0, s1, s2,s_id;
224     int t_id;
225 gwlarson 3.15 TRI *tri,*t;
226
227 gwlarson 3.5 os = qtqueryset(qt);
228 gwlarson 3.11 for (i = os[0]; i; i--)
229 gwlarson 3.3 {
230 gwlarson 3.15 s_id = os[i];
231     t_id = SM_NTH_VERT(smMesh,s_id);
232     tri = t = SM_NTH_TRI(smMesh,t_id);
233     do
234     {
235     if(!SM_IS_NTH_T_BASE(sm,t_id))
236     {
237     n++;
238     s0 = T_NTH_V(t,0);
239     s1 = T_NTH_V(t,1);
240     s2 = T_NTH_V(t,2);
241     VCOPY(a,SM_NTH_WV(sm,s0));
242     VCOPY(b,SM_NTH_WV(sm,s1));
243     VCOPY(c,SM_NTH_WV(sm,s2));
244     distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax
245 gwlarson 3.3 : sqrt(dist2(a,SM_VIEW_CENTER(sm)));
246 gwlarson 3.15 distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax
247     : sqrt(dist2(b,SM_VIEW_CENTER(sm)));
248     distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax
249 gwlarson 3.3 : sqrt(dist2(c,SM_VIEW_CENTER(sm)));
250 gwlarson 3.15 rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0]
251     + SM_NTH_RGB(sm,s2)[0];
252     rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1]
253     + SM_NTH_RGB(sm,s2)[1];
254     rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2]
255     + SM_NTH_RGB(sm,s2)[2];
256     }
257
258     t_id = smTri_next_ccw_nbr(smMesh,t,s_id);
259     t = SM_NTH_TRI(smMesh,t_id);
260
261     }while(t != tri);
262 gwlarson 3.3 }
263 gwlarson 3.11 n *= 3;
264 gwlarson 3.3 }
265     if (!n)
266     return(NULL);
267 gwlarson 3.4 le->qt = qt;
268     le->av.rgb[0] = rgbs[0]/n; le->av.rgb[1] = rgbs[1]/n;
269     le->av.rgb[2] = rgbs[2]/n; le->av.dist = distsum/(double)n;
270 gwlarson 3.3 }
271     if (lvl == 0 || (lvl > 0 && QT_IS_LEAF(qt)))
272     { /* render this node */
273     /* compute pseudo vertices */
274     VCOPY(a,v0); VCOPY(b,v1); VCOPY(c,v2);
275     normalize(a); normalize(b); normalize(c);
276 gwlarson 3.4 VSUM(a,SM_VIEW_CENTER(sm),a,le->av.dist);
277     VSUM(b,SM_VIEW_CENTER(sm),b,le->av.dist);
278     VSUM(c,SM_VIEW_CENTER(sm),c,le->av.dist);
279 gwlarson 3.3 /* draw triangle */
280 gwlarson 3.4 glColor3ub(le->av.rgb[0],le->av.rgb[1],le->av.rgb[2]);
281 gwlarson 3.9 glVertex3d(a[0],a[1],a[2]);
282     glVertex3d(b[0],b[1],b[2]);
283 gwlarson 3.3 glVertex3d(c[0],c[1],c[2]);
284 gwlarson 3.9
285 gwlarson 3.3 }
286 gwlarson 3.4 return(&le->av);
287 gwlarson 3.3 }
288
289
290 gwlarson 3.14 smRender_approx_stree_level(sm,lvl)
291 gwlarson 3.3 SM *sm;
292     int lvl;
293     {
294 gwlarson 3.10 QUADTREE qt;
295 gwlarson 3.3 int i;
296     FVECT t0,t1,t2;
297 gwlarson 3.8 STREE *st;
298
299 gwlarson 3.11 if (lvl < 0)
300 gwlarson 3.3 return;
301 gwlarson 3.8 st = SM_LOCATOR(sm);
302 gwlarson 3.3 glPushAttrib(GL_LIGHTING_BIT);
303     glShadeModel(GL_FLAT);
304     glBegin(GL_TRIANGLES);
305 gwlarson 3.8 for(i=0; i < ST_NUM_ROOT_NODES; i++)
306 gwlarson 3.3 {
307 gwlarson 3.10 qt = ST_ROOT_QT(st,i);
308     qtRender_level(qt,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1),ST_NTH_V(st,i,2),
309 gwlarson 3.11 sm,lvl);
310 gwlarson 3.3 }
311     glEnd();
312     glPopAttrib();
313     }
314
315 gwlarson 3.14 /*
316     * smRender_approx(sm,qual,view)
317     * SM *sm; : mesh
318     * int qual; : quality level
319     * VIEW *view; : current view
320     *
321     * Renders an approximation to the current mesh based on the quadtree
322     * subdivision. The quadtree is traversed to a level (based upon the quality:
323     * the lower the quality, the fewer levels visited, and the coarser, and
324     * faster, the approximation). The quadtree triangles are drawn relative to
325     * the current viewpoint, with a depth and color averaged from all of the
326     * triangles that lie beneath the node.
327     */
328     smRender_approx(sm, qual,view)
329 gwlarson 3.3 SM *sm;
330     int qual;
331 gwlarson 3.14 VIEW *view;
332 gwlarson 3.3 {
333 gwlarson 3.13 int i, n,ntarget;
334 gwlarson 3.3 int lvlcnt[QT_MAX_LEVELS];
335 gwlarson 3.10 STREE *st;
336 gwlarson 3.13 int4 *active_flag;
337 gwlarson 3.14
338 gwlarson 3.3 if (qual <= 0)
339     return;
340 gwlarson 3.14 smCull(sm,view,SM_ALL_LEVELS);
341 gwlarson 3.3 /* compute rendering target */
342     ntarget = 0;
343 gwlarson 3.13
344     active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG);
345     for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;)
346     if(active_flag[n])
347     for(i=0; i < 32; i++)
348     if(active_flag[n] & (1L << i))
349     ntarget++;
350
351     ntarget = ntarget*qual/MAXQUALITY;
352 gwlarson 3.3 if (!ntarget)
353     return;
354     for (i = QT_MAX_LEVELS; i--; )
355     lvlcnt[i] = 0;
356 gwlarson 3.10
357     st = SM_LOCATOR(sm);
358     for(i=0; i < ST_NUM_ROOT_NODES;i++)
359     stCount_level_leaves(lvlcnt, ST_ROOT_QT(st,i));
360
361 gwlarson 3.3 for (ntarget -= lvlcnt[i=0]; i < QT_MAX_LEVELS-1; ntarget -= lvlcnt[++i])
362     if (ntarget < lvlcnt[i+1])
363     break;
364     /* compute and render target level */
365 gwlarson 3.14 smRender_approx_stree_level(sm,i);
366 gwlarson 3.3 }
367
368 greg 3.16
369 gwlarson 3.15 #define GLVERTEX3V(v) glVertex3fv(v)
370 greg 3.16
371 gwlarson 3.15
372 gwlarson 3.12 #define render_tri(v0,v1,v2,rgb0,rgb1,rgb2) \
373 gwlarson 3.15 {glColor3ub(rgb0[0],rgb0[1],rgb0[2]); GLVERTEX3V(v0); \
374     glColor3ub(rgb1[0],rgb1[1],rgb1[2]); GLVERTEX3V(v1); \
375     glColor3ub(rgb2[0],rgb2[1],rgb2[2]); GLVERTEX3V(v2);}
376 gwlarson 3.1
377 gwlarson 3.14 /*
378     * render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,b0,b1,b2)
379 gwlarson 3.15 * SFLOAT v0[3],v1[3],v2[3]; : triangle vertex coordinates
380 gwlarson 3.14 * BYTE rgb0[3],rgb1[3],rgb2[3]; : vertex RGBs
381     * int b0,b1,b2; : background or base vertex flag
382     *
383 gwlarson 3.15 * For triangles with one or more base or directional vertices.
384     * render base vertex color as average of the background and foreground
385     * vertex RGBs. The coordinates for a fg vertex are calculated by
386     * subtracting off the current view,normalizing, then scaling to fit
387     * into the current frustum.
388 gwlarson 3.14 */
389     render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,vc,bg0,bg1,bg2)
390 gwlarson 3.15 SFLOAT v0[3],v1[3],v2[3];
391 gwlarson 3.12 BYTE rgb0[3],rgb1[3],rgb2[3];
392 gwlarson 3.14 FVECT vp,vc;
393 gwlarson 3.12 int bg0,bg1,bg2;
394 gwlarson 3.1 {
395 gwlarson 3.14 double d,p[3];
396 gwlarson 3.15 int j,cnt,rgb[3];
397 gwlarson 3.14
398 gwlarson 3.15 /* Average color from bg vertices */
399     cnt = 0;
400     if(bg0 == BASE || bg1==BASE || bg2 == BASE)
401 gwlarson 3.14 {
402     rgb[0] = rgb[1] = rgb[2] = 0;
403     if(bg0 != BASE)
404 gwlarson 3.15 {
405     IADDV3(rgb,rgb0);
406     cnt++;
407     }
408     if(bg1 != BASE)
409     {
410     IADDV3(rgb,rgb1);
411     cnt++;
412     }
413 gwlarson 3.14 if(bg2 != BASE)
414 gwlarson 3.15 {
415     IADDV3(rgb,rgb2);
416     cnt++;
417     }
418 gwlarson 3.14 IDIVV3(rgb,cnt);
419     }
420 gwlarson 3.15 if(bg0 == BASE)
421     glColor3i(rgb[0],rgb[1],rgb[2]);
422 gwlarson 3.14 else
423     glColor3ub(rgb0[0],rgb0[1],rgb0[2]);
424
425     if(!bg0)
426     {
427     VSUB(p,v0,vp);
428     normalize(p);
429     IADDV3(p,vc);
430     glVertex3dv(p);
431     }
432     else
433 gwlarson 3.15 GLVERTEX3V(v0);
434 gwlarson 3.14
435 gwlarson 3.15 if(bg1 == BASE)
436     glColor3i(rgb[0],rgb[1],rgb[2]);
437 gwlarson 3.14 else
438     glColor3ub(rgb1[0],rgb1[1],rgb1[2]);
439
440     if(!bg1)
441     {
442     VSUB(p,v1,vp);
443     normalize(p);
444     IADDV3(p,vc);
445     glVertex3dv(p);
446     }
447     else
448 gwlarson 3.15 GLVERTEX3V(v1);
449 gwlarson 3.14
450 gwlarson 3.15 if(bg2 == BASE)
451     glColor3i(rgb[0],rgb[1],rgb[2]);
452 gwlarson 3.14 else
453     glColor3ub(rgb2[0],rgb2[1],rgb2[2]);
454
455     if(!bg2)
456     {
457     VSUB(p,v2,vp);
458     normalize(p);
459     IADDV3(p,vc);
460     glVertex3dv(p);
461     }
462     else
463 gwlarson 3.15 GLVERTEX3V(v2);
464 gwlarson 3.14 }
465
466     /*
467     * smRender_bg_tris(sm,vp,t_flag,bg_flag,wp,rgb)
468     * SM *sm; : mesh
469     * FVECT vp; : current viewpoint
470     * int4 *t_flag,*bg_flag; : triangle flags: t_flag is generic,
471     * and bg_flag indicates if background tri;
472 gwlarson 3.15 * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors
473 gwlarson 3.14 *
474 gwlarson 3.15 * Sequentially traverses triangle list and renders all valid tris who
475 gwlarson 3.14 * have t_flag set, and bg_flag set.
476     */
477
478     smRender_bg_tris(sm,vp,t_flag,bg_flag,wp,rgb)
479     SM *sm;
480     FVECT vp;
481     int4 *t_flag,*bg_flag;
482 gwlarson 3.15 SFLOAT (*wp)[3];
483 gwlarson 3.14 BYTE (*rgb)[3];
484     {
485     double d;
486     int v0_id,v1_id,v2_id;
487     int i,n,bg0,bg1,bg2;
488     TRI *tri;
489
490     glMatrixMode(GL_MODELVIEW);
491
492     glPushMatrix();
493     glTranslated(vp[0],vp[1],vp[2]);
494     /* The points are a distance of 1 away from the origin: if necessary scale
495     so that they fit in frustum and are therefore not clipped away
496     */
497     if(dev_zmin >= 0.99)
498     {
499     d = (dev_zmin+dev_zmax)/2.0;
500     glScaled(d,d,d);
501     }
502     /* move relative to the new view */
503     /* move points to unit sphere at origin */
504     glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1],
505     -SM_VIEW_CENTER(sm)[2]);
506     glBegin(GL_TRIANGLES);
507     for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;)
508     if(t_flag[n] & bg_flag[n])
509     for(i=0; i < 32; i++)
510     if(t_flag[n] & bg_flag[n] & (1L << i))
511     {
512     tri = SM_NTH_TRI(sm,(n<<5)+i);
513     v0_id = T_NTH_V(tri,0);
514     v1_id = T_NTH_V(tri,1);
515     v2_id = T_NTH_V(tri,2);
516     bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0;
517     bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0;
518     bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0;
519     if(bg0==DIR && bg1==DIR && bg2==DIR)
520     render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
521     rgb[v2_id])
522     else
523     render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
524 gwlarson 3.15 rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2);
525 gwlarson 3.14 }
526     glEnd();
527
528     glPopMatrix();
529
530     }
531     /*
532 greg 3.16 * smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb)
533 gwlarson 3.15 * SM *sm; : mesh
534     * FVECT vp; : current viewpoint
535 greg 3.16 * int4 *new_flag,*active,*bg_flag; : triangle flags: idicates if tri is,
536     * new,active,bg_flag
537 gwlarson 3.15 * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors
538     *
539     * Sequentially traverses triangle list and renders all valid tris who
540 greg 3.16 * have new_flag set and active_flag and bg_flag set.
541 gwlarson 3.15 */
542     smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb)
543     SM *sm;
544     FVECT vp;
545     int4 *new_flag,*active_flag,*bg_flag;
546     SFLOAT (*wp)[3];
547     BYTE (*rgb)[3];
548     {
549     double d;
550     int v0_id,v1_id,v2_id;
551     int i,n,bg0,bg1,bg2;
552     TRI *tri;
553
554     glMatrixMode(GL_MODELVIEW);
555
556     glPushMatrix();
557     glTranslated(vp[0],vp[1],vp[2]);
558     /* The points are a distance of 1 away from the origin: if necessary scale
559     so that they fit in frustum and are therefore not clipped away
560     */
561     if(dev_zmin >= 0.99)
562     {
563     d = (dev_zmin+dev_zmax)/2.0;
564     glScaled(d,d,d);
565     }
566     /* move relative to the new view */
567     /* move points to unit sphere at origin */
568     glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1],
569     -SM_VIEW_CENTER(sm)[2]);
570     glBegin(GL_TRIANGLES);
571     for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;)
572     if(new_flag[n] & active_flag[n] & bg_flag[n])
573     for(i=0; i < 32; i++)
574     if(new_flag[n] & active_flag[n] & bg_flag[n] & (1L << i))
575     {
576     tri = SM_NTH_TRI(sm,(n<<5)+i);
577     v0_id = T_NTH_V(tri,0);
578     v1_id = T_NTH_V(tri,1);
579     v2_id = T_NTH_V(tri,2);
580     bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0;
581     bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0;
582     bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0;
583     if(bg0==DIR && bg1==DIR && bg2==DIR)
584     render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
585     rgb[v2_id])
586     else
587     render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
588     rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2);
589     }
590     glEnd();
591
592     glPopMatrix();
593
594     }
595
596     /*
597 gwlarson 3.14 * render_base_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,b0,b1,b2)
598 gwlarson 3.15 * SFLOAT v0[3],v1[3],v2[3]; : triangle vertex coordinates
599 gwlarson 3.14 * BYTE rgb0[3],rgb1[3],rgb2[3]; : vertex RGBs
600     * FVECT vp; : current viewpoint
601     * int b0,b1,b2; : vertex base flag
602     *
603     * render base vertex color as average of the non-base vertex RGBs. The
604     * base vertex coordinate is taken as the stored vector, scaled out by
605     * the average distance to the non-base vertices
606     */
607     render_base_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,b0,b1,b2)
608 gwlarson 3.15 SFLOAT v0[3],v1[3],v2[3];
609 gwlarson 3.14 BYTE rgb0[3],rgb1[3],rgb2[3];
610     FVECT vp;
611     int b0,b1,b2;
612     {
613     int cnt;
614 gwlarson 3.2 int rgb[3];
615 gwlarson 3.14 double d;
616     double p[3];
617 gwlarson 3.1
618     cnt = 0;
619 gwlarson 3.14 rgb[0] = rgb[1] = rgb[2] = 0;
620 gwlarson 3.3 d = 0.0;
621 greg 3.16 /* If all vertices are base: don't render */
622 gwlarson 3.14 if(b0&&b1&&b2)
623     return;
624     /* First calculate color and coordinates
625     for base vertices based on world space vertices*/
626     if(!b0)
627 gwlarson 3.1 {
628 gwlarson 3.14 IADDV3(rgb,rgb0);
629     d += DIST(v0,vp);
630 gwlarson 3.12 cnt++;
631 gwlarson 3.1 }
632 gwlarson 3.14 if(!b1)
633 gwlarson 3.12 {
634 gwlarson 3.14 IADDV3(rgb,rgb1);
635     d += DIST(v1,vp);
636 gwlarson 3.12 cnt++;
637     }
638 gwlarson 3.14 if(!b2)
639 gwlarson 3.12 {
640 gwlarson 3.14 IADDV3(rgb,rgb2);
641     d += DIST(v2,vp);
642 gwlarson 3.12 cnt++;
643     }
644 gwlarson 3.14 IDIVV3(rgb,cnt);
645     d /= (double)cnt;
646
647     /* Now render triangle */
648     if(b0)
649 gwlarson 3.1 {
650 gwlarson 3.12 glColor3ub(rgb[0],rgb[1],rgb[2]);
651 gwlarson 3.14 SUBV3(p,v0,vp);
652     ISCALEV3(p,d);
653     IADDV3(p,vp);
654     glVertex3dv(p);
655 gwlarson 3.12 }
656     else
657     {
658     glColor3ub(rgb0[0],rgb0[1],rgb0[2]);
659 gwlarson 3.15 GLVERTEX3V(v0);
660 gwlarson 3.14 }
661     if(b1)
662 gwlarson 3.12 {
663     glColor3ub(rgb[0],rgb[1],rgb[2]);
664 gwlarson 3.14 SUBV3(p,v1,vp);
665     ISCALEV3(p,d);
666     IADDV3(p,vp);
667 gwlarson 3.12 glVertex3dv(p);
668     }
669     else
670     {
671     glColor3ub(rgb1[0],rgb1[1],rgb1[2]);
672 gwlarson 3.15 GLVERTEX3V(v1);
673 gwlarson 3.14 }
674     if(b2)
675 gwlarson 3.12 {
676     glColor3ub(rgb[0],rgb[1],rgb[2]);
677 gwlarson 3.14 SUBV3(p,v2,vp);
678     ISCALEV3(p,d);
679     IADDV3(p,vp);
680 gwlarson 3.12 glVertex3dv(p);
681     }
682     else
683     {
684     glColor3ub(rgb2[0],rgb2[1],rgb2[2]);
685 gwlarson 3.15 GLVERTEX3V(v2);
686 gwlarson 3.12 }
687 gwlarson 3.1 }
688 gwlarson 3.14 /*
689     * smRender_fg_tris(sm,vp,t_flag,bg_flag,wp,rgb)
690     * SM *sm; : mesh
691     * FVECT vp; : current viewpoint
692     * int4 *t_flag,*bg_flag; : triangle flags: t_flag is generic,bg_flag
693     * indicates if background tri;
694 gwlarson 3.15 * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors
695 gwlarson 3.14 *
696     * Sequentially gos through triangle list and renders all valid tris who
697     * have t_flag set, and NOT bg_flag set.
698     */
699     smRender_fg_tris(sm,vp,t_flag,bg_flag,wp,rgb)
700 gwlarson 3.1 SM *sm;
701     FVECT vp;
702 gwlarson 3.14 int4 *t_flag,*bg_flag;
703 gwlarson 3.15 SFLOAT (*wp)[3];
704 gwlarson 3.14 BYTE (*rgb)[3];
705 gwlarson 3.1 {
706 gwlarson 3.14 TRI *tri;
707     int i,n,b0,b1,b2;
708 greg 3.16 S_ID v0_id,v1_id,v2_id;
709 gwlarson 3.1
710     glBegin(GL_TRIANGLES);
711 gwlarson 3.13 for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;)
712 gwlarson 3.14 if(t_flag[n])
713 gwlarson 3.13 for(i=0; i < 32; i++)
714 gwlarson 3.14 if(t_flag[n] & (1L << i) & ~bg_flag[n])
715 gwlarson 3.13 {
716     tri = SM_NTH_TRI(sm,(n<<5)+i);
717     v0_id = T_NTH_V(tri,0);
718     v1_id = T_NTH_V(tri,1);
719     v2_id = T_NTH_V(tri,2);
720 gwlarson 3.14 b0 = SM_BASE_ID(sm,v0_id);
721     b1 = SM_BASE_ID(sm,v1_id);
722     b2 = SM_BASE_ID(sm,v2_id);
723     if(b0 || b1 || b2)
724     render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
725     rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2);
726     else
727 gwlarson 3.13 render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
728     rgb[v2_id])
729 gwlarson 3.15
730 gwlarson 3.13 }
731 gwlarson 3.1 glEnd();
732
733     }
734 gwlarson 3.3
735 gwlarson 3.15 /*
736 greg 3.16 * smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb)
737 gwlarson 3.15 * SM *sm; : mesh
738     * FVECT vp; : current viewpoint
739 greg 3.16 * int4 *new_flag,*active_flag,*bg_flag; : triangle flags: indicate if
740     * tri is new,active,background
741 gwlarson 3.15 * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors
742     *
743     * Sequentially gos through triangle list and renders all valid tris who
744 greg 3.16 * have new_flag and active_flag set, and NOT bg_flag set.
745 gwlarson 3.15 */
746     smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb)
747     SM *sm;
748     FVECT vp;
749     int4 *new_flag,*active_flag,*bg_flag;
750     SFLOAT (*wp)[3];
751     BYTE (*rgb)[3];
752     {
753     TRI *tri;
754     int i,n,b0,b1,b2;
755 greg 3.16 S_ID v0_id,v1_id,v2_id;
756 gwlarson 3.15
757     glBegin(GL_TRIANGLES);
758     for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;)
759     if(new_flag[n] & active_flag[n])
760     for(i=0; i < 32; i++)
761     if(new_flag[n] & active_flag[n] & (1L << i) & ~bg_flag[n])
762     {
763     tri = SM_NTH_TRI(sm,(n<<5)+i);
764     v0_id = T_NTH_V(tri,0);
765     v1_id = T_NTH_V(tri,1);
766     v2_id = T_NTH_V(tri,2);
767     b0 = SM_BASE_ID(sm,v0_id);
768     b1 = SM_BASE_ID(sm,v1_id);
769     b2 = SM_BASE_ID(sm,v2_id);
770     if(b0 || b1 || b2)
771     render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
772     rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2);
773     else
774     render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
775     rgb[v2_id])
776     }
777     glEnd();
778
779     }
780
781 greg 3.16 /* Test for qsort to depth sort triangles */
782 gwlarson 3.12 int
783     compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2)
784 gwlarson 3.1 {
785 gwlarson 3.12 double d;
786 gwlarson 3.1
787 gwlarson 3.12 d = td2->depth-td1->depth;
788     if(d > 0.0)
789     return(1);
790     if(d < 0.0)
791     return(-1);
792     return(0);
793 gwlarson 3.1 }
794
795
796 gwlarson 3.14 /*
797     * smOrder_new_tris(sm,vp,td)
798     * SM *sm; : mesh
799     * FVECT vp; : current viewpoint
800     * T_DEPTH *td; : holds returned list of depth sorted tris
801     *
802     * Creates list of all new tris, with their distance from the current
803     * viewpoint, and sorts the list based on this distance
804     */
805 gwlarson 3.15 T_DEPTH
806     *smOrder_new_tris(sm,vp)
807 gwlarson 3.12 SM *sm;
808     FVECT vp;
809     {
810 gwlarson 3.15 T_DEPTH *td;
811     int n,i,j,tcnt,v,size;
812 gwlarson 3.12 TRI *tri;
813     double d,min_d;
814     FVECT diff;
815 gwlarson 3.15 int4 *new_flag,*bg_flag,*active_flag;
816
817 greg 3.16 td = (T_DEPTH *)tempbuf(NEW_TRI_CNT*sizeof(T_DEPTH),FALSE);
818     size = NEW_TRI_CNT;
819 gwlarson 3.12
820 gwlarson 3.13 tcnt=0;
821     new_flag = SM_NTH_FLAGS(sm,T_NEW_FLAG);
822     bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG);
823 gwlarson 3.15 active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG);
824 gwlarson 3.13 for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;)
825 gwlarson 3.15 if(active_flag[n] & new_flag[n] & ~bg_flag[n])
826 gwlarson 3.13 for(i=0; i < 32; i++)
827 gwlarson 3.15 if(active_flag[n] & new_flag[n] & (1L << i) & ~bg_flag[n])
828 gwlarson 3.13 {
829     tri = SM_NTH_TRI(sm,(n<<5)+i);
830 gwlarson 3.15 if(tcnt+1 >= size)
831     {
832     size += 100;
833     td = (T_DEPTH *)tempbuf(size*sizeof(T_DEPTH),TRUE);
834     }
835 gwlarson 3.13 td[tcnt].tri = (n << 5)+i;
836     min_d = -1;
837     for(j=0;j < 3;j++)
838     {
839     v = T_NTH_V(tri,j);
840 gwlarson 3.14 VSUB(diff,SM_NTH_WV(sm,v),vp);
841     d = DOT(diff,diff);
842     if(min_d == -1 || d < min_d)
843     min_d = d;
844 gwlarson 3.13 }
845     td[tcnt++].depth = min_d;
846 gwlarson 3.12 }
847 gwlarson 3.13 td[tcnt].tri = -1;
848     if(tcnt)
849     qsort((void *)td,tcnt,sizeof(T_DEPTH),compare_tri_depths);
850 gwlarson 3.15 return(td);
851 gwlarson 3.12 }
852
853 gwlarson 3.14 /*
854     * smUpdate_tm(sm) : Update the tone-mapping
855     * SM *sm; : mesh
856     *
857     */
858     smUpdate_tm(sm)
859     SM *sm;
860     {
861     int t = SM_TONE_MAP(sm);
862 gwlarson 3.12
863 gwlarson 3.14 if(t==0 || smCompute_mapping)
864     {
865     tmClearHisto();
866     tmAddHisto(SM_BRT(sm),SM_NUM_SAMP(sm),1);
867     if(tmComputeMapping(0.,0.,0.) != TM_E_OK)
868     return;
869     t = 0;
870     smCompute_mapping = FALSE;
871     }
872     tmMapPixels(SM_NTH_RGB(sm,t),&SM_NTH_BRT(sm,t),SM_NTH_CHR(sm,t),
873     SM_NUM_SAMP(sm)-t);
874     SM_TONE_MAP(sm) = SM_NUM_SAMP(sm);
875     }
876
877     /*
878     * smRender_inc(sm,vp) : Incremental update of mesh
879     * SM * sm; : mesh
880     * FVECT vp; : current view point
881     *
882     * If a relatively small number of new triangles have been created,
883     * do an incremental update. Render new triangles with depth buffering
884     * turned off, if the current viewpoint is not the same as canonical view-
885     * point, must use painter's approach to resolve visibility:first depth sort
886     * triangles, then render back-to-front.
887     */
888     smRender_inc(sm,vp)
889 gwlarson 3.1 SM *sm;
890 gwlarson 3.3 FVECT vp;
891 gwlarson 3.1 {
892 greg 3.16 S_ID v0_id,v1_id,v2_id;
893     int i,n,b0,b1,b2;
894 gwlarson 3.12 TRI *tri;
895 gwlarson 3.15 SFLOAT (*wp)[3];
896 gwlarson 3.12 BYTE (*rgb)[3];
897 gwlarson 3.15 int4 *new_flag,*bg_flag,*active_flag;
898 gwlarson 3.13 T_DEPTH *td = NULL;
899 gwlarson 3.14
900
901 greg 3.16 /* For all of the NEW and ACTIVE triangles (since last update):
902     Go through and sort on depth value (from vp). Turn
903 gwlarson 3.1 Depth Buffer test off and render back-front
904 greg 3.16 */
905 gwlarson 3.15
906 greg 3.16 /* Must depth sort if current view point is not same as canonical */
907 gwlarson 3.13 if(!EQUAL_VEC3(SM_VIEW_CENTER(sm),vp))
908 gwlarson 3.15 td = smOrder_new_tris(sm,vp);
909 gwlarson 3.12 wp = SM_WP(sm);
910     rgb =SM_RGB(sm);
911 gwlarson 3.14 new_flag = SM_NTH_FLAGS(sm,T_NEW_FLAG);
912 gwlarson 3.15 active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG);
913 gwlarson 3.14 bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG);
914 gwlarson 3.3 /* Turn Depth Test off -- using Painter's algorithm */
915 gwlarson 3.1 glPushAttrib(GL_DEPTH_BUFFER_BIT);
916 gwlarson 3.9 glDepthFunc(GL_ALWAYS);
917 gwlarson 3.13
918 gwlarson 3.15 smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb);
919 gwlarson 3.13 if(!td)
920 gwlarson 3.15 smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb);
921 gwlarson 3.13 else
922     {
923 gwlarson 3.14 glBegin(GL_TRIANGLES);
924 gwlarson 3.13 for(i=0; td[i].tri != -1;i++)
925     {
926     tri = SM_NTH_TRI(sm,td[i].tri);
927     /* Dont need to check for valid tri because flags are
928     cleared on delete
929     */
930     v0_id = T_NTH_V(tri,0);
931     v1_id = T_NTH_V(tri,1);
932     v2_id = T_NTH_V(tri,2);
933 gwlarson 3.14 b0 = SM_BASE_ID(sm,v0_id);
934     b1 = SM_BASE_ID(sm,v1_id);
935     b2 = SM_BASE_ID(sm,v2_id);
936     if(b0 || b1 || b2)
937     render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
938     rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2);
939     else
940 gwlarson 3.13 render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
941     rgb[v2_id])
942     }
943 gwlarson 3.14 glEnd();
944 gwlarson 3.13 freebuf(td);
945     }
946 gwlarson 3.14 /* Restore Depth Test */
947     glPopAttrib();
948     }
949
950     /*
951     * smRender_qtree_dl(sm,qt,vp,wp,rgb,i,level_i,max_level,leaf_cnt,which)
952     * SM *sm; : mesh
953     * QUADTREE qt; : quadtree base node
954     * FVECT vp; : current viewpoint
955 gwlarson 3.15 * SFLOAT (*wp)[3]; : array of sample points
956 gwlarson 3.14 * BYTE (*rgb)[3]; : array of RGB values for samples
957     * int i,level_i,level,max_level,leaf_cnt;
958 greg 3.16 * : variables to keep track of where
959 gwlarson 3.14 * we are in the quadtree traversal in order to map nodes to
960     * corresponding array locations, where nodes are stored in breadth-
961     * first order. i is the index of the current node,level_i is the
962     * index of the first node on the current quadtree level, max_level is
963     * the maximum number of levels to traverse, and leaf_cnt is the number
964     * of leaves on the current level
965     * int which; flag indicates whether to render fg or bg tris
966     *
967     *
968     * Render the tris stored in qtree using display lists. For each node at
969     * the leaf or max_level, call the display_list if it exists, else traverse
970     * down the subtree and render the nodes into a new display list which is
971     * stored for future use.
972     */
973     smRender_qtree_dl(sm,qt,vp,wp,rgb,i,level_i,level,max_level,leaf_cnt,which)
974     SM *sm;
975     QUADTREE qt;
976     FVECT vp;
977 gwlarson 3.15 SFLOAT (*wp)[3];
978 gwlarson 3.14 BYTE (*rgb)[3];
979     int i,level_i,level,max_level,leaf_cnt;
980     int which;
981     {
982     int j;
983
984     if(QT_IS_EMPTY(qt))
985     return;
986
987     if(QT_IS_LEAF(qt) || level == max_level)
988     {
989     if(QT_IS_LEAF(qt))
990     {
991     if(!QT_LEAF_IS_FLAG(qt))
992     return;
993     }
994     else
995     if(!QT_IS_FLAG(qt))
996     return;
997
998     if(!Display_lists[i][which])
999     {
1000     Display_lists[i][which] = i+1 + which*SM_DL_LISTS;
1001     glNewList(Display_lists[i][which],GL_COMPILE_AND_EXECUTE);
1002     smClear_flags(sm,T_NEW_FLAG);
1003     glBegin(GL_TRIANGLES);
1004     smRender_qtree(sm,qt,vp,wp,rgb,which,FALSE);
1005     glEnd();
1006     glEndList();
1007     }
1008     else
1009     {
1010     glCallList(Display_lists[i][which]);
1011     }
1012     }
1013     else
1014     if(QT_IS_FLAG(qt))
1015     {
1016     i = ((i - level_i)<< 2) + level_i + leaf_cnt;
1017     level_i += leaf_cnt;
1018     leaf_cnt <<= 2;
1019     for(j=0; j < 4; j++)
1020     smRender_qtree_dl(sm,QT_NTH_CHILD(qt,j),vp,wp,rgb,
1021     i+j,level_i,level+1,max_level,leaf_cnt,which);
1022     }
1023
1024     }
1025
1026     /*
1027     * smRender_qtree(sm,qt,vp,wp,rgb,which,cull) : Render the tris stored in qtree
1028     * SM *sm; : mesh
1029     * QUADTREE qt; : quadtree base node
1030     * FVECT vp; : current viewpoint
1031 gwlarson 3.15 * SFLOAT (*wp)[3] : array of sample points
1032 gwlarson 3.14 * BYTE (*rgb)[3] : array of RGB values for samples
1033     * int which; : flag indicates whether to render fg or bg tris
1034     * int cull; : if true, only traverse active (flagged) nodes
1035     *
1036     */
1037     smRender_qtree(sm,qt,vp,wp,rgb,which,cull)
1038     SM *sm;
1039     QUADTREE qt;
1040     FVECT vp;
1041 gwlarson 3.15 SFLOAT (*wp)[3];
1042 gwlarson 3.14 BYTE (*rgb)[3];
1043     int which,cull;
1044     {
1045     int i;
1046
1047     if(QT_IS_EMPTY(qt))
1048     return;
1049
1050     if(QT_IS_LEAF(qt))
1051     {
1052 gwlarson 3.15 TRI *t,*tri;
1053 greg 3.16 S_ID *optr,s_id,v0_id,v1_id,v2_id;
1054     int bg0,bg1,bg2,t_id;
1055 gwlarson 3.14
1056     if(cull && !QT_LEAF_IS_FLAG(qt))
1057     return;
1058
1059     optr = qtqueryset(qt);
1060 gwlarson 3.15 for (i = QT_SET_CNT(optr);i > 0; i--)
1061 gwlarson 3.14 {
1062 gwlarson 3.15 s_id = QT_SET_NEXT_ELEM(optr);
1063     t_id = SM_NTH_VERT(smMesh,s_id);
1064     tri = t = SM_NTH_TRI(smMesh,t_id);
1065     do
1066 gwlarson 3.14 {
1067 gwlarson 3.15 if((!cull || SM_IS_NTH_T_ACTIVE(sm,t_id)) && !SM_IS_NTH_T_NEW(sm,t_id))
1068     {
1069     bg0 = SM_IS_NTH_T_BG(sm,t_id);
1070     if((which == SM_RENDER_FG && !bg0) || (which== SM_RENDER_BG && bg0))
1071     {
1072     v0_id = T_NTH_V(t,0);
1073     v1_id = T_NTH_V(t,1);
1074     v2_id = T_NTH_V(t,2);
1075     if(bg0)
1076     {
1077     bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0;
1078     bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0;
1079     bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0;
1080     SM_SET_NTH_T_NEW(sm,t_id);
1081     if(bg0==DIR && bg1==DIR && bg2==DIR)
1082     render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
1083     rgb[v2_id])
1084     else
1085     render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
1086     rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2);
1087     }
1088     else
1089     {
1090     SM_SET_NTH_T_NEW(sm,t_id);
1091     bg0 = SM_BASE_ID(sm,v0_id);
1092     bg1 = SM_BASE_ID(sm,v1_id);
1093     bg2 = SM_BASE_ID(sm,v2_id);
1094     if(bg0 || bg1 || bg2)
1095     render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],
1096     rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),bg0,bg1,bg2);
1097     else
1098     render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id],
1099     rgb[v2_id])
1100     }
1101     }
1102     }
1103     t_id = smTri_next_ccw_nbr(smMesh,t,s_id);
1104     t = SM_NTH_TRI(smMesh,t_id);
1105     }while(t!=tri);
1106 gwlarson 3.14 }
1107     }
1108     else
1109     if(!cull || QT_IS_FLAG(qt))
1110     for(i=0; i < 4; i++)
1111     smRender_qtree(sm,QT_NTH_CHILD(qt,i),vp,wp,rgb,which,cull);
1112     }
1113
1114 gwlarson 3.15
1115 gwlarson 3.14 /*
1116     * smRender_mesh(sm,view,cull) : Render mesh Triangles
1117     * SM *sm; : mesh
1118     * VIEW *view; : current view
1119     * int cull; : cull Flag
1120     *
1121     * If cull is TRUE, first mark tris in current
1122     * frustum and only render them. Normally, cull will be FALSE only if
1123     * it is known that all tris lie in frustum, e.g. after a rebuild
1124     *
1125     */
1126     smRender_mesh(sm,view,cull)
1127     SM *sm;
1128     VIEW *view;
1129     int cull;
1130     {
1131 gwlarson 3.15 SFLOAT (*wp)[3];
1132 gwlarson 3.14 BYTE (*rgb)[3];
1133     int i;
1134     STREE *st= SM_LOCATOR(sm);
1135
1136     wp = SM_WP(sm);
1137     rgb =SM_RGB(sm);
1138
1139     smClear_flags(sm,T_NEW_FLAG);
1140
1141     if(cull)
1142     smCull(sm,view,SM_ALL_LEVELS);
1143
1144     glPushAttrib(GL_DEPTH_BUFFER_BIT);
1145     glDisable(GL_DEPTH_TEST);
1146
1147     glMatrixMode(GL_MODELVIEW);
1148     glPushMatrix();
1149     /* move relative to the new view */
1150     glTranslated(view->vp[0],view->vp[1],view->vp[2]);
1151
1152     /* The points are a distance of 1 away from the origin: if necessary
1153     scale so that they fit in frustum and are therefore not clipped away
1154     */
1155     if(dev_zmin >= 0.99)
1156     {
1157     double d;
1158
1159     d = (dev_zmin+dev_zmax)/2.0;
1160     glScaled(d,d,d);
1161     }
1162     /* move points to unit sphere at origin */
1163     glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1],
1164     -SM_VIEW_CENTER(sm)[2]);
1165
1166     glBegin(GL_TRIANGLES);
1167     for(i=0; i < ST_NUM_ROOT_NODES; i++)
1168     smRender_qtree(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,SM_RENDER_BG,cull);
1169 gwlarson 3.1 glEnd();
1170
1171 gwlarson 3.14 glPopMatrix();
1172
1173     glEnable(GL_DEPTH_TEST);
1174
1175     glBegin(GL_TRIANGLES);
1176     for(i=0; i < ST_NUM_ROOT_NODES; i++)
1177     smRender_qtree(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,SM_RENDER_FG,cull);
1178     glEnd();
1179
1180 gwlarson 3.1 glPopAttrib();
1181     }
1182
1183 gwlarson 3.14 /*
1184     * smRender_mesh_dl(sm,view) : Render stree utilizing display lists
1185     * SM *sm; : mesh
1186     * VIEW *view; : current view
1187     */
1188     smRender_mesh_dl(sm,view)
1189     SM *sm;
1190     VIEW *view;
1191     {
1192 gwlarson 3.15 SFLOAT (*wp)[3];
1193 gwlarson 3.14 BYTE (*rgb)[3];
1194     STREE *st;
1195     int i;
1196
1197     if(SM_DL_LEVELS == 0)
1198     {
1199     if(!Display_lists[0][0])
1200     {
1201     Display_lists[0][0] = 1;
1202     glNewList(Display_lists[0][0],GL_COMPILE_AND_EXECUTE);
1203     smRender_mesh(sm,view,FALSE);
1204     glEndList();
1205     }
1206     else
1207     glCallList(Display_lists[0][0]);
1208
1209     return;
1210     }
1211 gwlarson 3.15 smClear_flags(sm,T_NEW_FLAG);
1212
1213 gwlarson 3.14 smCull(sm,view,SM_DL_LEVELS);
1214
1215     st = SM_LOCATOR(sm);
1216
1217     wp = SM_WP(sm);
1218     rgb =SM_RGB(sm);
1219
1220     /* For all active quadtree nodes- first render bg tris, then fg */
1221     /* If display list exists, use otherwise create/display list */
1222     glPushAttrib(GL_DEPTH_BUFFER_BIT);
1223     glDisable(GL_DEPTH_TEST);
1224
1225     glMatrixMode(GL_MODELVIEW);
1226     glPushMatrix();
1227
1228     /* move relative to the new view */
1229     glTranslated(view->vp[0],view->vp[1],view->vp[2]);
1230
1231     /* The points are a distance of 1 away from the origin: if necessary
1232     scale so that they fit in frustum and are therefore not clipped away
1233     */
1234     if(dev_zmin >= 0.99)
1235     {
1236     double d;
1237     d = (dev_zmin+dev_zmax)/2.0;
1238     glScaled(d,d,d);
1239     }
1240     /* move points to unit sphere at origin */
1241     glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1],
1242     -SM_VIEW_CENTER(sm)[2]);
1243     for(i=0; i < ST_NUM_ROOT_NODES; i++)
1244     smRender_qtree_dl(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,i,0,1,
1245     SM_DL_LEVELS,8,SM_RENDER_BG);
1246     glPopMatrix();
1247
1248     glEnable(GL_DEPTH_TEST);
1249     for(i=0; i < ST_NUM_ROOT_NODES; i++)
1250     smRender_qtree_dl(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,i,0,1,
1251     SM_DL_LEVELS,8,SM_RENDER_FG);
1252     glPopAttrib();
1253     }
1254
1255
1256
1257 gwlarson 3.1 /*
1258 gwlarson 3.14 * smRender_tris(sm,view,render_flag) : Render all of the mesh triangles
1259     * SM *sm : current geometry
1260     * VIEW *view : current view
1261     * int render_flag : if render_flag & SM_RENDER_CULL: do culling first
1262     *
1263     * Renders mesh by traversing triangle list and drawing all active tris-
1264     * background tris first, then foreground and mixed tris
1265     */
1266     smRender_tris(sm,view,render_flag)
1267     SM *sm;
1268     VIEW *view;
1269     int render_flag;
1270     {
1271     int4 *active_flag,*bg_flag;
1272 gwlarson 3.15 SFLOAT (*wp)[3];
1273 gwlarson 3.14 BYTE (*rgb)[3];
1274
1275     wp = SM_WP(sm);
1276 gwlarson 3.15 rgb = SM_RGB(sm);
1277 gwlarson 3.14 active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG);
1278     bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG);
1279
1280     if(render_flag & SM_RENDER_CULL)
1281     smCull(sm,view,SM_ALL_LEVELS);
1282
1283     /* Render triangles made up of points at infinity by turning off
1284     depth-buffering and projecting the points onto a sphere around the view*/
1285     glPushAttrib(GL_DEPTH_BUFFER_BIT);
1286     glDisable(GL_DEPTH_TEST);
1287     smRender_bg_tris(sm,view->vp,active_flag,bg_flag,wp,rgb);
1288
1289     /* Render triangles containing world-space points */
1290     glEnable(GL_DEPTH_TEST);
1291     smRender_fg_tris(sm,view->vp,active_flag,bg_flag,wp,rgb);
1292
1293     glPopAttrib();
1294
1295     }
1296
1297     /* Clear all of the display lists */
1298     clear_display_lists()
1299     {
1300     int i;
1301     for(i=0; i< SM_DL_LISTS; i++)
1302     {
1303     if(Display_lists[i][0])
1304     { /* Clear the foreground display list */
1305     glDeleteLists(Display_lists[i][0],1);
1306     Display_lists[i][0] = 0;
1307     }
1308     if(Display_lists[i][1])
1309     { /* Clear the background display list */
1310     glDeleteLists(Display_lists[i][1],1);
1311     Display_lists[i][1] = 0;
1312     }
1313     }
1314     }
1315
1316     /*
1317     * qtClear_dl(qt,i,level_i,level,max_level,leaf_cnt) :clear display lists
1318     * QUADTREE *qt; : Quadtree node
1319     * int i; : index into list of display lists for this node
1320     * int level_i; : index for first node at this level
1321     * int level,max_level; : current level, maximum level to descend
1322     * int leaf_cnt; : number of leaves at this level
1323     *
1324     * For each node under this node that has its flag set: delete all
1325     * existing display lists. Display lists are stored in an array indexed as
1326     * if the quadtree was traversed in a breadth first order (indices 0-7 are
1327     * the 8 quadtree roots, indices 8-11 the first level children of root 0,
1328     * indices 12-15 the children of root 1, etc). It is assumes that the display
1329     * lists will only be stored for a small number of levels: if this is not
1330     * true, a hashing scheme would work better for storing/retrieving the
1331     * display lists
1332     */
1333     qtClear_dl(qt,i,level_i,level,max_level,leaf_cnt)
1334     QUADTREE qt;
1335     int i,level_i,level,max_level,leaf_cnt;
1336     {
1337     int j;
1338
1339     if(QT_IS_EMPTY(qt))
1340     return;
1341     if(QT_IS_LEAF(qt) || level== max_level)
1342     {
1343     if(QT_IS_LEAF(qt))
1344     {
1345     if(!QT_LEAF_IS_FLAG(qt))
1346     return;
1347     }
1348     else
1349     if(!QT_IS_FLAG(qt))
1350     return;
1351     if(Display_lists[i][0])
1352     {
1353     glDeleteLists(Display_lists[i][0],1);
1354     Display_lists[i][0] = 0;
1355     }
1356     if(Display_lists[i][1])
1357     {
1358     glDeleteLists(Display_lists[i][1],1);
1359     Display_lists[i][1] = 0;
1360     }
1361     }
1362     else
1363     if(QT_IS_FLAG(qt))
1364     {
1365     /* Calculate the index for the first child given the values
1366     of the parent at the current level
1367     */
1368     i = ((i - level_i)<< 2) + level_i + leaf_cnt;
1369     level_i += leaf_cnt;
1370     leaf_cnt <<= 2;
1371     for(j=0; j < 4; j++)
1372     qtClear_dl(QT_NTH_CHILD(qt,j),i+j,level_i,level+1,max_level,
1373     leaf_cnt);
1374     }
1375     }
1376
1377     /*
1378     * smInvalidate_view(sm,view) : Invalidate rendering representation for view
1379     * SM *sm; : mesh
1380     * VIEW *view; : current view
1381     *
1382     * Delete the existing display lists for geometry in the current
1383     * view frustum: Called when the geometry in the frustum has been changed
1384     */
1385     smInvalidate_view(sm,view)
1386     SM *sm;
1387     VIEW *view;
1388     {
1389     int i;
1390
1391     if(SM_DL_LEVELS == 0)
1392     {
1393     if(Display_lists[0][0])
1394     {
1395     glDeleteLists(Display_lists[0][0],1);
1396     Display_lists[0][0] = 0;
1397     }
1398     return;
1399     }
1400     /* Mark qtree nodes/tris in frustum */
1401     smCull(sm,view,SM_DL_LEVELS);
1402
1403     /* Invalidate display_lists in marked qtree nodes */
1404     for(i=0; i < ST_NUM_ROOT_NODES; i++)
1405     qtClear_dl(ST_ROOT_QT(SM_LOCATOR(sm),i),i,0,1,SM_DL_LEVELS,8);
1406
1407     }
1408
1409
1410     /*
1411     * smRender(sm,view, qual): render OpenGL output geometry
1412     * SM *sm; : current mesh representation
1413     * VIEW *view; : desired view
1414     * int qual; : quality level (percentage on linear time scale)
1415     *
1416     * Render the current mesh:
1417     * recompute tone mapping if full redraw and specified:
1418     * if moving (i.e. qual < MAXQUALITY)
1419     * render the cached display lists, if quality drops
1420     * below threshold, render approximation instead
1421     * if stationary
1422     * render mesh geometry without display lists, unless up-to-date
1423     * display lists already exist.
1424     */
1425     smRender(sm,view,qual)
1426     SM *sm;
1427     VIEW *view;
1428     int qual;
1429     {
1430     /* Unless quality > MAXQUALITY, render using display lists */
1431     if(qual <= MAXQUALITY)
1432     {
1433     /* If quality above threshold: render mesh*/
1434 gwlarson 3.15 if(qual > (MAXQUALITY*2/4) )
1435 gwlarson 3.14 /* render stree using display lists */
1436     smRender_mesh_dl(sm,view);
1437     else
1438 gwlarson 3.15 {
1439 gwlarson 3.14 /* If quality below threshold, use approximate rendering */
1440     smRender_approx(sm,qual,view);
1441 gwlarson 3.15 }
1442 gwlarson 3.14 }
1443     else
1444 gwlarson 3.15 {
1445     /* render stree without display lists */
1446 gwlarson 3.14 smRender_mesh(sm,view,TRUE);
1447 gwlarson 3.15 }
1448 gwlarson 3.14 }
1449
1450
1451     /*
1452     * smUpdate(view, qual) : update OpenGL output geometry
1453 gwlarson 3.3 * VIEW *view; : desired view
1454 gwlarson 3.1 * int qual; : quality level (percentage on linear time scale)
1455     *
1456     * Draw new geometric representation using OpenGL calls. Assume that the
1457     * view has already been set up and the correct frame buffer has been
1458     * selected for drawing. The quality level is on a linear scale, where 100%
1459     * is full (final) quality. It is not necessary to redraw geometry that has
1460 gwlarson 3.14 * been output since the last call to smClean().(The last view drawn will
1461 gwlarson 3.3 * be view==&odev.v each time.)
1462 gwlarson 3.1 */
1463 gwlarson 3.3 smUpdate(view,qual)
1464     VIEW *view;
1465 gwlarson 3.1 int qual;
1466     {
1467 greg 3.16
1468 gwlarson 3.14 /* Is there anything to render? */
1469     if(!smMesh || SM_NUM_TRI(smMesh)<=0)
1470     return;
1471 greg 3.16
1472 gwlarson 3.14 /* Is viewer MOVING?*/
1473     if(qual < MAXQUALITY)
1474     {
1475 gwlarson 3.15 if(smIncremental)
1476     smUpdate_tm(smMesh);
1477 greg 3.16
1478 gwlarson 3.14 /* Render mesh using display lists */
1479     smRender(smMesh,view,qual);
1480 gwlarson 3.13 return;
1481 gwlarson 3.14 }
1482     /* Viewer is STATIONARY */
1483     /* Has view moved epsilon from canonical view? (epsilon= percentage
1484     (SM_VIEW_FRAC) of running average of the distance of the sample points
1485     from the canonical view */
1486     if(DIST(view->vp,SM_VIEW_CENTER(smMesh)) > SM_ALLOWED_VIEW_CHANGE(smMesh))
1487 gwlarson 3.1 {
1488 gwlarson 3.14 /* Must rebuild mesh with current view as new canonical view */
1489 gwlarson 3.15 smRebuild(smMesh,view);
1490 gwlarson 3.14 /* Existing display lists and tonemapping are no longer valid */
1491     clear_display_lists();
1492 gwlarson 3.15 smCompute_mapping = FALSE;
1493     smUpdate_tm(smMesh);
1494 gwlarson 3.14 /* Render all the triangles in the new mesh */
1495     smRender(smMesh,view,qual+1);
1496 gwlarson 3.1 }
1497 gwlarson 3.14 else
1498     /* Has a complete redraw been requested ?*/
1499     if(smClean_notify)
1500 gwlarson 3.3 {
1501 gwlarson 3.15 if(smIncremental)
1502     smUpdate_tm(smMesh);
1503 gwlarson 3.14 smIncremental = FALSE;
1504     smRender(smMesh,view,qual);
1505 gwlarson 3.3 }
1506     else
1507 gwlarson 3.14 {
1508 gwlarson 3.15 smUpdate_tm(smMesh);
1509 gwlarson 3.14 /* If number of new triangles relatively small: do incremental update */
1510 gwlarson 3.15 /* Mark Existing display lists in frustum invalid */
1511     if(!smIncremental)
1512     {
1513     smInvalidate_view(smMesh,view);
1514     smIncremental = TRUE;
1515     }
1516     smRender_inc(smMesh,view->vp);
1517 gwlarson 3.1 }
1518 gwlarson 3.14 /* This is our final update iff qual==MAXQUALITY and view==&odev.v */
1519     if( (qual >= MAXQUALITY) && (view == &(odev.v)))
1520 gwlarson 3.3 {
1521 gwlarson 3.14 /* reset rendering flags */
1522 gwlarson 3.3 smClean_notify = FALSE;
1523 gwlarson 3.15 if(smIncremental)
1524     smClear_flags(smMesh,T_NEW_FLAG);
1525 gwlarson 3.5 qtCache_init(0);
1526 gwlarson 3.3 }
1527
1528 gwlarson 3.1 }
1529 greg 3.16
1530 gwlarson 3.15
1531
1532
1533
1534
1535
