root/radiance/src/hd/sm_geom.h
Mon Jul 14 22:24:00 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.12: +11 -1 lines
Diff to previous 3.12
Sat Feb 22 02:07:25 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.11: +23 -48 lines
Diff to previous 3.11
Thu Jun 10 15:22:23 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.10: +1 -1 lines
Diff to previous 3.10
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
Fri Mar 5 16:32:21 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.9: +13 -0 lines
Diff to previous 3.9
small clean-up changes
Sun Jan 10 10:27:46 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.8: +0 -0 lines
Diff to previous 3.8
sm.c, sm_del.c sm_ogl.c sm.h
Fixed failure to tone-map on start up
added code for temporary buffer allocation
added bg flag, and fast flag checking routines for drawing
provided graceful backout if deletion triangulation fails
Tue Jan 5 16:52:37 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.7: +1 -1 lines
Diff to previous 3.7
fixed logic in smTest to handle nearby and coincident points, added base tris to rendering, made list of new triangles to speed up rendering
Mon Dec 28 18:07:35 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.6: +12 -10 lines
Diff to previous 3.6
New insertion routine
New Culling routine based on insertion algorithm
Adapted old insertion code: now used by picking
Point location code returns on-vertex,on-edge, or in-triangle
Added on_edge case for subdivision
Implemented unordered sets
Removed deletion from quadtree- added set compression to replace functionality
Wed Nov 11 12:05:39 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.5: +8 -1 lines
Diff to previous 3.5
new triangulation code
changed triangle vertex order to CCW
changed numbering of triangle neighbors to match quadtree
fixed tone-mapping bug
removed errant printf() statements
redid logic for adding and testing samples with new epsilon
Tue Oct 6 18:16:54 1998 UTC (27 years ago) by gwlarson
Changes since 3.4: +21 -1 lines
Diff to previous 3.4
new triangulate routine
added smTestSample to check for occlusion
added frustum culling before rebuild
changed base quadtree to use octahedron and created new point locate
added "sample active" flags and implemented LRU replacement
started handling case of too many triangles
set sizes are now unbounded
changed all quadtree pointers to quadtrees
Wed Sep 16 18:16:28 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.3: +13 -0 lines
Diff to previous 3.3
implemented integer triangle tracing
Fri Sep 11 11:52:26 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.2: +5 -0 lines
Diff to previous 3.2
fixed triangle insertion using edge tracing
Thu Aug 20 16:47:22 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.1: +1 -0 lines
switched to barycentric coordinates
fixed background poly rendering
Wed Aug 19 17:45:24 1998 UTC (27 years, 2 months ago) by gwlarson
