root/radiance/src/hd/rhpict2.c
Revision: 3.18
Committed: Thu May 14 20:58:03 2020 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R3, rad6R0, HEAD
2 static const char RCSid[] = "$Id: rhpict2.c,v 3.17 2018/10/05 19:19:16 greg Exp $";
5 * Rendering routines for rhpict.
6 */
7
8 #include <string.h>
9
10 #include "holo.h"
11 #include "view.h"
12 #include "random.h"
13
14 #ifndef DEPS
15 #define DEPS 0.02 /* depth epsilon */
16 #endif
17 #ifndef PEPS
18 #define PEPS 0.04 /* pixel value epsilon */
19 #endif
20 #ifndef MAXRAD
21 #define MAXRAD 64 /* maximum kernel radius */
22 #endif
23 #ifndef NNEIGH
24 #define NNEIGH 5 /* find this many neighbors */
25 #endif
26
27 #define NINF 16382
28
29 #define MAXRAD2 (MAXRAD*MAXRAD+1)
30
31 #define G0NORM 0.286 /* ground zero normalization (1/x integral) */
32
33 #ifndef FL4OP
34 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
35 #define CHK4(f,i) FL4OP(f,i,&)
36 #define SET4(f,i) FL4OP(f,i,|=)
37 #define CLR4(f,i) FL4OP(f,i,&=~)
38 #define TGL4(f,i) FL4OP(f,i,^=)
39 #define FL4NELS(n) (((n)+0x1f)>>5)
40 #define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32))
41 #endif
42
43 static int32 *pixFlags; /* pixel occupancy flags */
44 static float pixWeight[MAXRAD2]; /* pixel weighting function */
45 static short isqrttab[MAXRAD2]; /* integer square root table */
46
47 #define isqrt(i2) (isqrttab[i2])
48
49 extern VIEW myview; /* current output view */
50 extern COLOR *mypixel; /* pixels being rendered */
51 extern float *myweight; /* weights (used to compute final pixels) */
52 extern float *mydepth; /* depth values (visibility culling) */
53 extern int hres, vres; /* current horizontal and vertical res. */
54
55 extern void pixFinish(double ransamp);
56 extern void pixBeam(BEAM *bp, HDBEAMI *hb);
57
58 typedef int (sampfunc)(int h, int v, short nl[NNEIGH][2], int nd[NNEIGH],
59 int n, double *rf);
60 static sampfunc kill_occl;
61 static sampfunc smooth_samp;
62 static sampfunc random_samp;
63 static void meet_neighbors(int occ, sampfunc *nf, double *dp);
64 static void reset_flags(void);
65 static void init_wfunc(void);
66 static int findneigh(short nl[NNEIGH][2], int nd[NNEIGH], int h, int v,
67 short (*rnl)[NNEIGH]);
68
69
70 void
71 pixBeam( /* render a particular beam */
72 BEAM *bp,
73 HDBEAMI *hb
74 )
75 {
76 GCOORD gc[2];
77 RAYVAL *rv;
78 FVECT rorg, rdir, wp, ip;
79 double d, prox;
80 COLOR col;
81 int n;
82 int32 p;
83
84 if (!hdbcoord(gc, hb->h, hb->b))
85 error(CONSISTENCY, "bad beam in render_beam");
86 for (n = bp->nrm, rv = hdbray(bp); n--; rv++) {
87 /* reproject each sample */
88 hdray(rorg, rdir, hb->h, gc, rv->r);
89 if (rv->d < DCINF) {
90 d = hddepth(hb->h, rv->d);
91 VSUM(wp, rorg, rdir, d);
92 VSUB(ip, wp, myview.vp);
93 d = DOT(ip,rdir);
94 prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */
95 prox *= prox; prox *= prox; prox *= prox; prox *= prox;
96 } else {
97 if (myview.type == VT_PAR || myview.vaft > FTINY)
98 continue; /* inf. off view */
99 VSUM(wp, myview.vp, rdir, FHUGE);
100 prox = 1.;
101 }
102 if (viewloc(ip, &myview, wp) != VL_GOOD)
103 continue; /* frustum clipping */
104 if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore)
105 continue; /* not exact for VT_PER */
106 p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres);
107 if (mydepth[p] > FTINY) { /* check depth */
108 if (ip[2] > mydepth[p]*(1.+DEPS))
109 continue;
110 if (ip[2] < mydepth[p]*(1.-DEPS)) {
111 setcolor(mypixel[p], 0., 0., 0.);
112 myweight[p] = 0.;
113 }
114 }
115 colr_color(col, rv->v);
116 scalecolor(col, prox);
117 addcolor(mypixel[p], col);
118 myweight[p] += prox;
119 mydepth[p] = ip[2];
120 }
121 }
122
123
124 static int
125 kill_occl( /* check for occlusion errors */
126 int h,
127 int v,
128 short nl[NNEIGH][2],
129 int nd[NNEIGH],
130 int n,
131 double *rf
132 )
133 {
134 short forequad[2][2];
135 int d;
136 int i;
137 int32 p;
138
139 if (n <= 0) {
140 #ifdef DEBUG
141 error(WARNING, "neighborless sample in kill_occl");
142 #endif
143 return(1);
144 }
145 p = v*hres + h;
146 forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0;
147 for (i = n; i--; ) {
148 d = isqrt(nd[i]);
149 if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p])
150 forequad[nl[i][0]<h][nl[i][1]<v] = 1;
151 }
152 if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) {
153 setcolor(mypixel[p], 0., 0., 0.);
154 myweight[p] = 0.; /* occupancy reset afterwards */
155 }
156 return(1);
157 }
158
159
160 static int
161 smooth_samp( /* grow sample point smoothly */
162 int h,
163 int v,
164 short nl[NNEIGH][2],
165 int nd[NNEIGH],
166 int n,
167 double *rf
168 )
169 {
170 int dis[NNEIGH], ndis;
171 COLOR mykern[MAXRAD2];
172 int maxr2;
173 double d;
174 int32 p;
175 int r2;
176 int i, r, maxr, h2, v2;
177
178 if (n <= 0)
179 return(1);
180 p = v*hres + h; /* build kernel values */
181 maxr2 = nd[n-1];
182 DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor");
183 maxr = isqrt(maxr2);
184 for (v2 = 1; v2 <= maxr; v2++)
185 for (h2 = 0; h2 <= v2; h2++) {
186 r2 = h2*h2 + v2*v2;
187 if (r2 > maxr2) break;
188 copycolor(mykern[r2], mypixel[p]);
189 scalecolor(mykern[r2], pixWeight[r2]);
190 }
191 ndis = 0; /* find discontinuities */
192 for (i = n; i--; ) {
193 r = isqrt(nd[i]);
194 d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p];
195 d = d>=1. ? d-1. : 1.-d;
196 if (d > r*DEPS || bigdiff(mypixel[p],
197 mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS))
198 dis[ndis++] = i;
199 }
200 /* stamp out that kernel */
201 for (v2 = v-maxr; v2 <= v+maxr; v2++) {
202 if (v2 < 0) v2 = 0;
203 else if (v2 >= vres) break;
204 for (h2 = h-maxr; h2 <= h+maxr; h2++) {
205 if (h2 < 0) h2 = 0;
206 else if (h2 >= hres) break;
207 r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v);
208 if (r2 > maxr2) continue;
209 if (CHK4(pixFlags, v2*hres+h2))
210 continue; /* occupied */
211 for (i = ndis; i--; ) {
212 r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) +
213 (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]);
214 if (r < r2) break;
215 }
216 if (i >= 0) continue; /* outside edge */
217 addcolor(mypixel[v2*hres+h2], mykern[r2]);
218 myweight[v2*hres+h2] += pixWeight[r2] * myweight[p];
219 }
220 }
221 return(1);
222 }
223
224
225 static int
226 random_samp( /* gather samples randomly */
227 int h,
228 int v,
229 short nl[NNEIGH][2],
230 int nd[NNEIGH],
231 int n,
232 double *rf
233 )
234 {
235 float rnt[NNEIGH];
236 double rvar;
237 int32 p, pn;
238 int ni;
239
240 if (n <= 0)
241 return(1);
242 p = v*hres + h;
243 if (*rf <= FTINY) /* straight Voronoi regions */
244 ni = 0;
245 else { /* weighted choice */
246 DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor");
247 rnt[0] = pixWeight[nd[0]];
248 for (ni = 1; ni < n; ni++)
249 rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]];
250 rvar = rnt[n-1]*pow(frandom(), 1. / *rf);
251 for (ni = 0; rvar > rnt[ni]+FTINY; ni++)
252 ;
253 }
254 pn = nl[ni][1]*hres + nl[ni][0];
255 addcolor(mypixel[p], mypixel[pn]);
256 myweight[p] += myweight[pn];
257 return(1);
258 }
259
260
261 void
262 pixFinish( /* done with beams -- compute pixel values */
263 double ransamp
264 )
265 {
266 if (pixWeight[0] <= FTINY)
267 init_wfunc(); /* initialize weighting function */
268 reset_flags(); /* set occupancy flags */
269 meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */
270 reset_flags(); /* reset occupancy flags */
271 if (ransamp >= 0.) /* spread samples over image */
272 meet_neighbors(0,random_samp,&ransamp);
273 else
274 meet_neighbors(1,smooth_samp,NULL);
275 free((void *)pixFlags); /* free pixel flags */
276 pixFlags = NULL;
277 }
278
279
280 static void
281 reset_flags(void) /* allocate/set/reset occupancy flags */
282 {
283 int32 p;
284
285 if (pixFlags == NULL) {
286 pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32));
287 CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags");
288 } else
289 CLR4ALL(pixFlags, hres*vres);
290 for (p = hres*vres; p--; )
291 if (myweight[p] > FTINY)
292 SET4(pixFlags, p);
293 }
294
295
296 static void
297 init_wfunc(void) /* initialize weighting function */
298 {
299 int r2;
300 double d;
301
302 for (r2 = MAXRAD2; --r2; ) {
303 d = sqrt((double)r2);
304 pixWeight[r2] = G0NORM/d;
305 isqrttab[r2] = d + 0.99;
306 }
307 pixWeight[0] = 1.;
308 isqrttab[0] = 0;
309 }
310
311
312 static int
313 findneigh( /* find NNEIGH neighbors for pixel */
314 short nl[NNEIGH][2],
315 int nd[NNEIGH],
316 int h,
317 int v,
318 short (*rnl)[NNEIGH]
319 )
320 {
321 int nn = 0;
322 int d, n, hoff;
323 int h2, n2;
324
325 nd[NNEIGH-1] = MAXRAD2;
326 for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) {
327 h2 = h + hoff;
328 if ((h2 < 0) | (h2 >= hres))
329 continue;
330 if ((h2-h)*(h2-h) >= nd[NNEIGH-1])
331 break;
332 for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) {
333 d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]);
334 if ((d == 0) | (d >= nd[NNEIGH-1]))
335 continue;
336 if (nn < NNEIGH) /* insert neighbor */
337 nn++;
338 for (n2 = nn; n2--; ) {
339 if (!n2 || d >= nd[n2-1]) {
340 nd[n2] = d;
341 nl[n2][0] = h2;
342 nl[n2][1] = rnl[h2][n];
343 break;
344 }
345 nd[n2] = nd[n2-1];
346 nl[n2][0] = nl[n2-1][0];
347 nl[n2][1] = nl[n2-1][1];
348 }
349 }
350 }
351 return(nn);
352 }
353
354
355 static void
356 meet_neighbors( /* run through samples and their neighbors */
357 int occ,
358 sampfunc *nf,
359 double *dp
360 )
361 {
362 short ln[NNEIGH][2];
363 int nd[NNEIGH];
364 int h, v, n, v2;
365 short (*rnl)[NNEIGH];
366 /* initialize bottom row list */
367 rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres);
368 CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors");
369 for (h = 0; h < hres; h++) {
370 for (n = v = 0; v < vres; v++)
371 if (CHK4(pixFlags, v*hres+h)) {
372 rnl[h][n++] = v;
373 if (n >= NNEIGH)
374 break;
375 }
376 while (n < NNEIGH)
377 rnl[h][n++] = NINF;
378 }
379 v = 0; /* do each row */
380 for ( ; ; ) {
381 for (h = 0; h < hres; h++) {
382 if (!CHK4(pixFlags, v*hres+h) != !occ)
383 continue; /* occupancy mismatch */
384 /* find neighbors */
385 n = findneigh(ln, nd, h, v, rnl);
386 /* call on neighbors */
387 (*nf)(h, v, ln, nd, n, dp);
388 }
389 if (++v >= vres) /* reinitialize row list */
390 break;
391 for (h = 0; h < hres; h++)
392 for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) {
393 if (v2 - v > v - rnl[h][0])
394 break; /* not close enough */
395 if (CHK4(pixFlags, v2*hres+h)) {
396 for (n = 0; n < NNEIGH-1; n++)
397 rnl[h][n] = rnl[h][n+1];
398 rnl[h][NNEIGH-1] = v2;
399 }
400 }
401 }
402 free((void *)rnl); /* free row list */
403 }
