root/radiance/src/hd/rhpict.c
Wed Jul 2 16:54:44 2025 UTC (3 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.25: +2 -2 lines
Diff to previous 3.25 , to selected 3.4
perf: Made +/-0.5% threshold for caring about pixel aspect ratio consistent
Tue Jul 1 19:40:35 2025 UTC (3 months, 1 week ago) by greg
Diff to previous 3.24 , to selected 3.4
fix: Made PIXASPECT= output a little more stringent (+/-0.1% rather than 1%)
Sat Jun 7 05:09:46 2025 UTC (4 months ago) by greg
Changes since 3.23: +1 -2 lines
Diff to previous 3.23 , to selected 3.4
Fri Jun 6 19:11:21 2025 UTC (4 months, 1 week ago) by greg
Changes since 3.22: +3 -4 lines
Diff to previous 3.22 , to selected 3.4
refactor: Making use of printargs() more consistent with fixargv0()
Mon Feb 6 22:40:21 2023 UTC (2 years, 8 months ago) by greg
Changes since 3.21: +2 -3 lines
Diff to previous 3.21 , to selected 3.4
Mon Oct 21 18:19:32 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 3.20 , to selected 3.4
Added binary option for Windows
Fri Oct 5 19:19:16 2018 UTC (7 years ago) by greg
Changes since 3.19: +7 -7 lines
Diff to previous 3.19 , to selected 3.4
Wed Mar 29 01:10:23 2017 UTC (8 years, 6 months ago) by greg
Changes since 3.18: +3 -3 lines
Diff to previous 3.18 , to selected 3.4
Fixed fatal bug in rhpict pointed out by Lars Grobe
Tue Jun 8 19:48:30 2004 UTC (21 years, 4 months ago) by greg
Changes since 3.17: +1 -2 lines
Diff to previous 3.17 , to selected 3.4
Thu Jan 1 11:21:55 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.16: +34 -15 lines
Diff to previous 3.16 , to selected 3.4
Ansification and prototypes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 3.15 , to selected 3.4
Mon Oct 20 16:01:55 2003 UTC (21 years, 11 months ago) by greg
Changes since 3.14: +3 -2 lines
Diff to previous 3.14 , to selected 3.4
Sun Jul 27 22:12:02 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.13: +5 -5 lines
Diff to previous 3.13 , to selected 3.4
Mon Jul 21 22:30:18 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.12: +3 -2 lines
Diff to previous 3.12 , to selected 3.4
Mon Jul 7 17:21:51 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 3.11 , to selected 3.4
Mon Jun 30 14:59:12 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.10: +6 -4 lines
Diff to previous 3.10 , to selected 3.4
Fri Jun 20 00:25:49 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.9: +4 -4 lines
Diff to previous 3.9 , to selected 3.4
Thu May 29 16:26:22 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.8: +0 -1 lines
Diff to previous 3.8 , to selected 3.4
Sat Feb 22 02:07:25 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.7: +5 -8 lines
Diff to previous 3.7 , to selected 3.4
Tue Mar 9 15:10:26 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.6: +4 -1 lines
Diff to previous 3.6 , to selected 3.4
added printing of command arguments in header
Tue Mar 9 14:55:53 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.5: +7 -5 lines
Diff to previous 3.5 , to selected 3.4
second cut at random sampling -- variable randomness
Tue Mar 9 14:23:51 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.4: +9 -2 lines
Diff to previous 3.4
first cut at random resampling algorithm
Revision 3.4 - (view) (download) (annotate) - [selected]
Tue Mar 9 10:55:24 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.3: +13 -6 lines
Diff to previous 3.3
added brain-dead pixel filling for unrendered pixels
Mon Mar 8 14:09:11 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.2: +8 -6 lines
Diff to previous 3.2 , to selected 3.4
finished discontinuity implementation and fixed various bugs
Fri Mar 5 17:02:41 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.1: +7 -3 lines
Diff to previous 3.1 , to selected 3.4
added kernel and occlusion culling
Thu Mar 4 10:30:04 1999 UTC (26 years, 7 months ago) by gwlarson
Diff to selected 3.4
