| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: rhoptimize.c,v 3.10 2003/05/29 16:26:22 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Optimize holodeck for quick access. |
| 6 |
| 7 |
* 11/4/98 Greg Ward Larson |
| 8 |
| 9 |
| 10 |
#include "holo.h" |
| 11 |
| 12 |
#include <signal.h> |
| 13 |
| 14 |
#ifndef BKBSIZE |
| 15 |
#define BKBSIZE 256 /* beam clump size (kilobytes) */ |
| 16 |
#endif |
| 17 |
| 18 |
char *progname; |
| 19 |
char tempfile[128]; |
| 20 |
int dupchecking = 0; |
| 21 |
| 22 |
extern char *rindex(); |
| 23 |
extern long rhinitcopy(); |
| 24 |
| 25 |
| 26 |
main(argc, argv) |
| 27 |
int argc; |
| 28 |
char *argv[]; |
| 29 |
| 30 |
char *inpname, *outname; |
| 31 |
int hdfd[2]; |
| 32 |
long nextipos, lastopos, thisopos; |
| 33 |
| 34 |
progname = argv[0]; |
| 35 |
argv++; argc--; /* duplicate checking flag? */ |
| 36 |
if (argc > 1 && !strcmp(argv[0], "-u")) { |
| 37 |
dupchecking++; |
| 38 |
argv++; argc--; |
| 39 |
| 40 |
if (argc < 1 | argc > 2) { |
| 41 |
fprintf(stderr, "Usage: %s [-u] input.hdk [output.hdk]\n", |
| 42 |
progname); |
| 43 |
exit(1); |
| 44 |
| 45 |
inpname = argv[0]; /* get input file */ |
| 46 |
argv++; argc--; |
| 47 |
if (argc == 1) /* use given output file */ |
| 48 |
outname = argv[0]; |
| 49 |
else { /* else use temporary file */ |
| 50 |
if (access(inpname, R_OK|W_OK) < 0) { /* check permissions */ |
| 51 |
sprintf(errmsg, "cannot access \"%s\"", inpname); |
| 52 |
error(SYSTEM, errmsg); |
| 53 |
| 54 |
strcpy(tempfile, inpname); |
| 55 |
if ((outname = rindex(tempfile, '/')) != NULL) |
| 56 |
outname++; |
| 57 |
else |
| 58 |
outname = tempfile; |
| 59 |
sprintf(outname, "rho%d.hdk", getpid()); |
| 60 |
| 61 |
| 62 |
/* copy holodeck file header */ |
| 63 |
nextipos = rhinitcopy(hdfd, inpname, outname); |
| 64 |
lastopos = 0L; /* copy sections one by one */ |
| 65 |
while (nextipos != 0L) { |
| 66 |
/* set input position; get next */ |
| 67 |
lseek(hdfd[0], (off_t)nextipos, 0); |
| 68 |
read(hdfd[0], (char *)&nextipos, sizeof(nextipos)); |
| 69 |
/* get output position; set last */ |
| 70 |
thisopos = lseek(hdfd[1], (off_t)0, 2); |
| 71 |
if (lastopos > 0L) { |
| 72 |
lseek(hdfd[1], (off_t)lastopos, 0); |
| 73 |
write(hdfd[1], (char *)&thisopos, sizeof(thisopos)); |
| 74 |
| 75 |
| 76 |
lastopos = thisopos; |
| 77 |
thisopos = 0L; /* write place holder */ |
| 78 |
| 79 |
/* copy holodeck section */ |
| 80 |
copysect(hdfd[0], hdfd[1]); |
| 81 |
| 82 |
/* clean up */ |
| 83 |
close(hdfd[0]); |
| 84 |
close(hdfd[1]); |
| 85 |
if (outname == tempfile && rename(outname, inpname) < 0) { |
| 86 |
sprintf(errmsg, "cannot rename \"%s\" to \"%s\"", |
| 87 |
outname, inpname); |
| 88 |
| 89 |
| 90 |
exit(0); |
| 91 |
| 92 |
| 93 |
| 94 |
long |
| 95 |
rhinitcopy(hfd, infn, outfn) /* open files and copy header */ |
| 96 |
int hfd[2]; /* returned file descriptors */ |
| 97 |
char *infn, *outfn; |
| 98 |
| 99 |
FILE *infp, *outfp; |
| 100 |
long ifpos; |
| 101 |
/* open files for i/o */ |
| 102 |
if ((infp = fopen(infn, "r")) == NULL) { |
| 103 |
sprintf(errmsg, "cannot open \"%s\" for reading", infn); |
| 104 |
| 105 |
| 106 |
if (access(outfn, F_OK) == 0) { |
| 107 |
sprintf(errmsg, "output file \"%s\" already exists!", outfn); |
| 108 |
error(USER, errmsg); |
| 109 |
| 110 |
if ((outfp = fopen(outfn, "w+")) == NULL) { |
| 111 |
sprintf(errmsg, "cannot open \"%s\" for writing", outfn); |
| 112 |
| 113 |
| 114 |
/* set up signal handling */ |
| 115 |
if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); |
| 116 |
if (signal(SIGHUP, quit) == SIG_IGN) signal(SIGHUP, SIG_IGN); |
| 117 |
if (signal(SIGTERM, quit) == SIG_IGN) signal(SIGTERM, SIG_IGN); |
| 118 |
#ifdef SIGXCPU |
| 119 |
if (signal(SIGXCPU, quit) == SIG_IGN) signal(SIGXCPU, SIG_IGN); |
| 120 |
if (signal(SIGXFSZ, quit) == SIG_IGN) signal(SIGXFSZ, SIG_IGN); |
| 121 |
#endif |
| 122 |
/* copy and verify header */ |
| 123 |
if (checkheader(infp, HOLOFMT, outfp) < 0 || getw(infp) != HOLOMAGIC) |
| 124 |
error(USER, "input not in holodeck format"); |
| 125 |
fputformat(HOLOFMT, outfp); |
| 126 |
fputc('\n', outfp); |
| 127 |
putw(HOLOMAGIC, outfp); |
| 128 |
/* get descriptors and free stdio */ |
| 129 |
if ((hfd[0] = dup(fileno(infp))) < 0 || |
| 130 |
(hfd[1] = dup(fileno(outfp))) < 0) |
| 131 |
error(SYSTEM, "dup call failed in rhinitcopy"); |
| 132 |
ifpos = ftell(infp); |
| 133 |
fclose(infp); |
| 134 |
if (fclose(outfp) == EOF) |
| 135 |
error(SYSTEM, "file flushing error in rhinitcopy"); |
| 136 |
/* check cache size */ |
| 137 |
if (BKBSIZE*1024*1.5 > hdcachesize) |
| 138 |
hdcachesize = BKBSIZE*1024*1.5; |
| 139 |
/* return input position */ |
| 140 |
return(ifpos); |
| 141 |
| 142 |
| 143 |
| 144 |
int |
| 145 |
nuniq(rva, n) /* sort unique rays to front of beam list */ |
| 146 |
register RAYVAL *rva; |
| 147 |
int n; |
| 148 |
| 149 |
register int i, j; |
| 150 |
RAYVAL rtmp; |
| 151 |
| 152 |
for (j = 0; j < n; j++) |
| 153 |
for (i = j+1; i < n; i++) |
| 154 |
if ( rva[i].d == rva[j].d && |
| 155 |
rva[i].r[0][0]==rva[j].r[0][0] && |
| 156 |
rva[i].r[0][1]==rva[j].r[0][1] && |
| 157 |
rva[i].r[1][0]==rva[j].r[1][0] && |
| 158 |
rva[i].r[1][1]==rva[j].r[1][1] ) { |
| 159 |
n--; /* swap duplicate with end */ |
| 160 |
copystruct(&rtmp, rva+n); |
| 161 |
copystruct(rva+n, rva+i); |
| 162 |
copystruct(rva+i, &rtmp); |
| 163 |
i--; /* recheck one we swapped */ |
| 164 |
| 165 |
return(n); |
| 166 |
| 167 |
| 168 |
| 169 |
static BEAMI *beamdir; |
| 170 |
| 171 |
static int |
| 172 |
bpcmp(b1p, b2p) /* compare beam positions on disk */ |
| 173 |
int *b1p, *b2p; |
| 174 |
| 175 |
register off_t pdif = beamdir[*b1p].fo - beamdir[*b2p].fo; |
| 176 |
| 177 |
if (pdif < 0L) return(-1); |
| 178 |
return(pdif > 0L); |
| 179 |
| 180 |
| 181 |
static HOLO *hout; |
| 182 |
| 183 |
static int |
| 184 |
xferclump(hp, bq, nb) /* transfer the given clump to hout and free */ |
| 185 |
HOLO *hp; |
| 186 |
int *bq, nb; |
| 187 |
| 188 |
register int i; |
| 189 |
register BEAM *bp; |
| 190 |
int n; |
| 191 |
| 192 |
beamdir = hp->bi; /* sort based on file position */ |
| 193 |
qsort((void *)bq, nb, sizeof(*bq), bpcmp); |
| 194 |
/* transfer and free each beam */ |
| 195 |
for (i = 0; i < nb; i++) { |
| 196 |
bp = hdgetbeam(hp, bq[i]); |
| 197 |
DCHECK(bp==NULL, CONSISTENCY, "empty beam in xferclump"); |
| 198 |
n = dupchecking ? nuniq(hdbray(bp),bp->nrm) : bp->nrm; |
| 199 |
bcopy((void *)hdbray(bp), (void *)hdnewrays(hout,bq[i],n), |
| 200 |
n*sizeof(RAYVAL)); |
| 201 |
hdfreebeam(hp, bq[i]); |
| 202 |
| 203 |
hdfreebeam(hout, 0); /* write & free clump */ |
| 204 |
return(0); |
| 205 |
| 206 |
| 207 |
copysect(ifd, ofd) /* copy holodeck section from ifd to ofd */ |
| 208 |
int ifd, ofd; |
| 209 |
| 210 |
HOLO *hinp; |
| 211 |
/* load input section directory */ |
| 212 |
hinp = hdinit(ifd, NULL); |
| 213 |
/* create output section directory */ |
| 214 |
hout = hdinit(ofd, (HDGRID *)hinp); |
| 215 |
/* clump the beams */ |
| 216 |
clumpbeams(hinp, 0, BKBSIZE*1024, xferclump); |
| 217 |
/* clean up */ |
| 218 |
hddone(hinp); |
| 219 |
hddone(hout); |
| 220 |
| 221 |
| 222 |
| 223 |
void |
| 224 |
eputs(s) /* put error message to stderr */ |
| 225 |
register char *s; |
| 226 |
| 227 |
static int midline = 0; |
| 228 |
| 229 |
if (!*s) |
| 230 |
return; |
| 231 |
if (!midline++) { /* prepend line with program name */ |
| 232 |
fputs(progname, stderr); |
| 233 |
fputs(": ", stderr); |
| 234 |
| 235 |
fputs(s, stderr); |
| 236 |
if (s[strlen(s)-1] == '\n') { |
| 237 |
fflush(stderr); |
| 238 |
midline = 0; |
| 239 |
| 240 |
| 241 |
| 242 |
| 243 |
void |
| 244 |
quit(code) /* exit the program gracefully */ |
| 245 |
int code; |
| 246 |
| 247 |
if (tempfile[0]) |
| 248 |
unlink(tempfile); |
| 249 |
exit(code); |
| 250 |
