root/radiance/src/hd/rholo4.c
Revision: 3.24
Committed: Sun Dec 20 20:39:31 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.23: +13 -7 lines
added new "portals" variable for multiple section geometry
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdi"
17 #endif
18
19 #ifndef FNONBLK
20 #define FNONBLK O_NONBLOCK
21 #endif
22
23 static int inp_flags;
24 static int dpd[3];
25 static FILE *dpout;
26
27
28 disp_open(dname) /* open the named display driver */
29 char *dname;
30 {
31 char buf[128], fd0[8], fd1[8], *cmd[5], *sfn;
32 int i, n, len;
33 /* get full display program name */
34 #ifdef DEVPATH
35 sprintf(buf, "%s/%s%s", DEVPATH, dname, HDSUF);
36 #else
37 sprintf(buf, "dev/%s%s", dname, HDSUF);
38 #endif
39 /* dup stdin and stdout */
40 if (readinp)
41 sprintf(fd0, "%d", dup(0));
42 else
43 strcpy(fd0, "-1");
44 sprintf(fd1, "%d", dup(1));
45 /* start the display process */
46 cmd[0] = buf;
47 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
48 cmd[4] = NULL;
49 i = open_process(dpd, cmd);
50 if (i <= 0)
51 error(USER, "cannot start display process");
52 if ((dpout = fdopen(dpd[1], "w")) == NULL)
53 error(SYSTEM, "cannot associate FILE with display pipe");
54 dpd[1] = -1; /* causes ignored error in close_process() */
55 inp_flags = 0;
56 /* close dup'ed stdin and stdout */
57 if (readinp)
58 close(atoi(fd0));
59 close(atoi(fd1));
60 /* check if outside */
61 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
62 disp_result(DS_OUTSECT, 0, NULL);
63 /* send eye separation if specified */
64 if (vdef(EYESEP)) {
65 sprintf(buf, "%.9e", vflt(EYESEP));
66 disp_result(DS_EYESEP, strlen(buf)+1, buf);
67 }
68 /* write out hologram grids & octrees */
69 for (i = 0; hdlist[i] != NULL; i++) {
70 bcopy((char *)hdlist[i], buf, sizeof(HDGRID));
71 len = sizeof(HDGRID);
72 n = vdef(GEOMETRY);
73 sfn = i<n ? nvalue(GEOMETRY,i) :
74 n ? nvalue(GEOMETRY,n-1) : vval(OCTREE);
75 strcpy(buf+len, sfn);
76 len += strlen(sfn) + 1;
77 n = vdef(PORTS);
78 sfn = i<n ? nvalue(PORTS,i) : n ? nvalue(PORTS,n-1) : "";
79 strcpy(buf+len, sfn);
80 len += strlen(sfn) + 1;
81 disp_result(DS_ADDHOLO, len, buf);
82 }
83 disp_flush();
84 }
85
86
87 disp_packet(p) /* display a packet */
88 register PACKHEAD *p;
89 {
90 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
91 }
92
93
94 disp_check(block) /* check display process */
95 int block;
96 {
97 MSGHEAD msg;
98 int n;
99 char *buf = NULL;
100
101 if (dpout == NULL)
102 return(-1);
103 /* flush display output */
104 disp_flush();
105 /* check read blocking */
106 if (block != (inp_flags == 0)) {
107 inp_flags = block ? 0 : FNONBLK;
108 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
109 goto fcntlerr;
110 }
111 /* read message header */
112 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
113 if (n != sizeof(MSGHEAD)) {
114 if (n >= 0) {
115 dpout = NULL;
116 error(USER, "display process died");
117 }
118 if (errno != EAGAIN & errno != EINTR)
119 goto readerr;
120 return(2); /* acceptable failure */
121 }
122 if (msg.nbytes) { /* get the message body */
123 if (msg.nbytes < 0)
124 error(INTERNAL, "anti-message from display process");
125 buf = (char *)malloc(msg.nbytes);
126 if (buf == NULL)
127 error(SYSTEM, "out of memory in disp_check");
128 if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
129 goto fcntlerr;
130 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
131 goto readerr;
132 }
133 switch (msg.type) { /* take appropriate action */
134 case DR_BUNDLE: /* new bundle to calculate */
135 if (msg.nbytes != sizeof(PACKHEAD))
136 error(INTERNAL, "bad DR_BUNDLE from display process");
137 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
138 break;
139 case DR_NEWSET: /* new calculation set */
140 if (msg.nbytes % sizeof(PACKHEAD))
141 error(INTERNAL, "bad DR_NEWSET from display process");
142 if (msg.nbytes)
143 disp_result(DS_STARTIMM, 0, NULL);
144 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
145 if (msg.nbytes) {
146 disp_result(DS_ENDIMM, 0, NULL);
147 disp_flush();
148 }
149 break;
150 case DR_ADDSET: /* add to calculation set */
151 if (!msg.nbytes)
152 break;
153 if (msg.nbytes % sizeof(PACKHEAD))
154 error(INTERNAL, "bad DR_ADDSET from display process");
155 disp_result(DS_STARTIMM, 0, NULL);
156 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
157 disp_result(DS_ENDIMM, 0, NULL);
158 disp_flush();
159 break;
160 case DR_ADJSET: /* adjust calculation set members */
161 if (!msg.nbytes)
162 break;
163 if (msg.nbytes % sizeof(PACKHEAD))
164 error(INTERNAL, "bad DR_ADJSET from display process");
165 disp_result(DS_STARTIMM, 0, NULL);
166 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
167 disp_result(DS_ENDIMM, 0, NULL);
168 disp_flush();
169 break;
170 case DR_DELSET: /* delete from calculation set */
171 if (!msg.nbytes)
172 break;
173 if (msg.nbytes % sizeof(PACKHEAD))
174 error(INTERNAL, "bad DR_DELSET from display process");
175 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
176 break;
177 case DR_VIEWPOINT: /* set target eye position */
178 if (msg.nbytes != sizeof(VIEWPOINT))
179 error(INTERNAL, "bad DR_VIEWPOINT from display process");
180 copystruct(&myeye, (VIEWPOINT *)buf);
181 break;
182 case DR_ATTEN: /* block for priority request */
183 if (msg.nbytes)
184 error(INTERNAL, "bad DR_ATTEN from display process");
185 /* send acknowledgement */
186 disp_result(DS_ACKNOW, 0, NULL);
187 return(disp_check(1)); /* block on following request */
188 case DR_KILL: /* kill computation process(es) */
189 if (msg.nbytes)
190 error(INTERNAL, "bad DR_KILL from display process");
191 if (nprocs > 0)
192 done_rtrace();
193 else
194 error(WARNING, "no rtrace process to kill");
195 break;
196 case DR_RESTART: /* restart computation process(es) */
197 if (msg.nbytes)
198 error(INTERNAL, "bad DR_RESTART from display process");
199 if (ncprocs > nprocs)
200 new_rtrace();
201 else if (nprocs > 0)
202 error(WARNING, "rtrace already runnning");
203 else
204 error(WARNING, "holodeck not open for writing");
205 break;
206 case DR_CLOBBER: /* clobber holodeck */
207 if (msg.nbytes)
208 error(INTERNAL, "bad DR_CLOBBER from display process");
209 if (!force || !ncprocs)
210 error(WARNING, "request to clobber holodeck denied");
211 else {
212 error(WARNING, "clobbering holodeck contents");
213 hdclobber(NULL);
214 }
215 break;
216 case DR_SHUTDOWN: /* shut down program */
217 if (msg.nbytes)
218 error(INTERNAL, "bad DR_SHUTDOWN from display process");
219 return(0); /* zero return signals shutdown */
220 case DR_NOOP: /* do nothing */
221 break;
222 default:
223 error(INTERNAL, "unrecognized request from display process");
224 }
225 if (msg.nbytes) /* clean up */
226 free(buf);
227 return(1); /* normal return value */
228 fcntlerr:
229 error(SYSTEM, "cannot change display blocking mode");
230 readerr:
231 error(SYSTEM, "error reading from display process");
232 }
233
234
235 int
236 disp_close() /* close our display process */
237 {
238 int rval;
239
240 if (dpout == NULL)
241 return(-1);
242 myeye.rng = 0;
243 disp_result(DS_SHUTDOWN, 0, NULL);
244 fclose(dpout);
245 dpout = NULL;
246 return(close_process(dpd));
247 }
248
249
250 disp_result(type, nbytes, p) /* queue result message to display process */
251 int type, nbytes;
252 char *p;
253 {
254 MSGHEAD msg;
255 /* consistency checks */
256 #ifdef DEBUG
257 if (nbytes < 0 || nbytes > 0 & p == NULL)
258 error(CONSISTENCY, "bad buffer handed to disp_result");
259 #endif
260 if (dpout == NULL)
261 return;
262 msg.type = type;
263 msg.nbytes = nbytes;
264 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
265 if (nbytes > 0)
266 fwrite(p, 1, nbytes, dpout);
267 }
268
269
270 disp_flush() /* flush output to display */
271 {
272 if (fflush(dpout) < 0)
273 error(SYSTEM, "error writing to the display process");
274 }
