root/radiance/src/hd/rholo4.c
Revision: 3.22
Committed: Tue Nov 24 17:05:36 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.21: +5 -0 lines
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck display process communication
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include <sys/uio.h>
14
15 #ifndef HDSUF
16 #define HDSUF ".hdi"
17 #endif
18
19 #ifndef FNONBLK
20 #define FNONBLK O_NONBLOCK
21 #endif
22
23 static int inp_flags;
24 static int dpd[3];
25 static FILE *dpout;
26
27
28 disp_open(dname) /* open the named display driver */
29 char *dname;
30 {
31 char dpath[128], fd0[8], fd1[8], *cmd[5];
32 int i;
33 /* get full display program name */
34 #ifdef DEVPATH
35 sprintf(dpath, "%s/%s%s", DEVPATH, dname, HDSUF);
36 #else
37 sprintf(dpath, "dev/%s%s", dname, HDSUF);
38 #endif
39 /* dup stdin and stdout */
40 if (readinp)
41 sprintf(fd0, "%d", dup(0));
42 else
43 strcpy(fd0, "-1");
44 sprintf(fd1, "%d", dup(1));
45 /* start the display process */
46 cmd[0] = dpath;
47 cmd[1] = froot; cmd[2] = fd1; cmd[3] = fd0;
48 cmd[4] = NULL;
49 i = open_process(dpd, cmd);
50 if (i <= 0)
51 error(USER, "cannot start display process");
52 if ((dpout = fdopen(dpd[1], "w")) == NULL)
53 error(SYSTEM, "cannot associate FILE with display pipe");
54 dpd[1] = -1; /* causes ignored error in close_process() */
55 inp_flags = 0;
56 /* close dup'ed stdin and stdout */
57 if (readinp)
58 close(atoi(fd0));
59 close(atoi(fd1));
60 /* check if outside */
61 if (vdef(OBSTRUCTIONS) && vbool(OBSTRUCTIONS))
62 disp_result(DS_OUTSECT, 0, NULL);
63 /* send eye separation if specified */
64 if (vdef(EYESEP)) {
65 char fbuf[32];
66 sprintf(fbuf, "%.9e", vflt(EYESEP));
67 disp_result(DS_EYESEP, strlen(fbuf)+1, fbuf);
68 }
69 /* write out hologram grids */
70 for (i = 0; hdlist[i] != NULL; i++)
71 disp_result(DS_ADDHOLO, sizeof(HDGRID), (char *)hdlist[i]);
72 disp_flush();
73 }
74
75
76 disp_packet(p) /* display a packet */
77 register PACKHEAD *p;
78 {
79 disp_result(DS_BUNDLE, packsiz(p->nr), (char *)p);
80 }
81
82
83 disp_check(block) /* check display process */
84 int block;
85 {
86 MSGHEAD msg;
87 int n;
88 char *buf = NULL;
89
90 if (dpout == NULL)
91 return(-1);
92 /* flush display output */
93 disp_flush();
94 /* check read blocking */
95 if (block != (inp_flags == 0)) {
96 inp_flags = block ? 0 : FNONBLK;
97 if (fcntl(dpd[0], F_SETFL, inp_flags) < 0)
98 goto fcntlerr;
99 }
100 /* read message header */
101 n = read(dpd[0], (char *)&msg, sizeof(MSGHEAD));
102 if (n != sizeof(MSGHEAD)) {
103 if (n >= 0) {
104 dpout = NULL;
105 error(USER, "display process died");
106 }
107 if (errno != EAGAIN & errno != EINTR)
108 goto readerr;
109 return(2); /* acceptable failure */
110 }
111 if (msg.nbytes) { /* get the message body */
112 if (msg.nbytes < 0)
113 error(INTERNAL, "anti-message from display process");
114 buf = (char *)malloc(msg.nbytes);
115 if (buf == NULL)
116 error(SYSTEM, "out of memory in disp_check");
117 if (inp_flags != 0 && fcntl(dpd[0], F_SETFL, inp_flags=0) < 0)
118 goto fcntlerr;
119 if (readbuf(dpd[0], buf, msg.nbytes) != msg.nbytes)
120 goto readerr;
121 }
122 switch (msg.type) { /* take appropriate action */
123 case DR_BUNDLE: /* new bundle to calculate */
124 if (msg.nbytes != sizeof(PACKHEAD))
125 error(INTERNAL, "bad DR_BUNDLE from display process");
126 bundle_set(BS_ADD, (PACKHEAD *)buf, 1);
127 break;
128 case DR_NEWSET: /* new calculation set */
129 if (msg.nbytes % sizeof(PACKHEAD))
130 error(INTERNAL, "bad DR_NEWSET from display process");
131 if (msg.nbytes)
132 disp_result(DS_STARTIMM, 0, NULL);
133 bundle_set(BS_NEW, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
134 if (msg.nbytes) {
135 disp_result(DS_ENDIMM, 0, NULL);
136 disp_flush();
137 }
138 break;
139 case DR_ADDSET: /* add to calculation set */
140 if (!msg.nbytes)
141 break;
142 if (msg.nbytes % sizeof(PACKHEAD))
143 error(INTERNAL, "bad DR_ADDSET from display process");
144 disp_result(DS_STARTIMM, 0, NULL);
145 bundle_set(BS_ADD, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
146 disp_result(DS_ENDIMM, 0, NULL);
147 disp_flush();
148 break;
149 case DR_ADJSET: /* adjust calculation set members */
150 if (!msg.nbytes)
151 break;
152 if (msg.nbytes % sizeof(PACKHEAD))
153 error(INTERNAL, "bad DR_ADJSET from display process");
154 disp_result(DS_STARTIMM, 0, NULL);
155 bundle_set(BS_ADJ, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
156 disp_result(DS_ENDIMM, 0, NULL);
157 disp_flush();
158 break;
159 case DR_DELSET: /* delete from calculation set */
160 if (!msg.nbytes)
161 break;
162 if (msg.nbytes % sizeof(PACKHEAD))
163 error(INTERNAL, "bad DR_DELSET from display process");
164 bundle_set(BS_DEL, (PACKHEAD *)buf, msg.nbytes/sizeof(PACKHEAD));
165 break;
166 case DR_VIEWPOINT: /* set target eye position */
167 if (msg.nbytes != sizeof(VIEWPOINT))
168 error(INTERNAL, "bad DR_VIEWPOINT from display process");
169 copystruct(&myeye, (VIEWPOINT *)buf);
170 break;
171 case DR_ATTEN: /* block for priority request */
172 if (msg.nbytes)
173 error(INTERNAL, "bad DR_ATTEN from display process");
174 /* send acknowledgement */
175 disp_result(DS_ACKNOW, 0, NULL);
176 return(disp_check(1)); /* block on following request */
177 case DR_KILL: /* kill computation process(es) */
178 if (msg.nbytes)
179 error(INTERNAL, "bad DR_KILL from display process");
180 if (nprocs > 0)
181 done_rtrace();
182 else
183 error(WARNING, "no rtrace process to kill");
184 break;
185 case DR_RESTART: /* restart computation process(es) */
186 if (msg.nbytes)
187 error(INTERNAL, "bad DR_RESTART from display process");
188 if (ncprocs > nprocs)
189 new_rtrace();
190 else if (nprocs > 0)
191 error(WARNING, "rtrace already runnning");
192 else
193 error(WARNING, "holodeck not open for writing");
194 break;
195 case DR_CLOBBER: /* clobber holodeck */
196 if (msg.nbytes)
197 error(INTERNAL, "bad DR_CLOBBER from display process");
198 if (!force || !ncprocs)
199 error(WARNING, "request to clobber holodeck denied");
200 else {
201 error(WARNING, "clobbering holodeck contents");
202 hdclobber(NULL);
203 }
204 break;
205 case DR_SHUTDOWN: /* shut down program */
206 if (msg.nbytes)
207 error(INTERNAL, "bad DR_SHUTDOWN from display process");
208 return(0); /* zero return signals shutdown */
209 case DR_NOOP: /* do nothing */
210 break;
211 default:
212 error(INTERNAL, "unrecognized request from display process");
213 }
214 if (msg.nbytes) /* clean up */
215 free(buf);
216 return(1); /* normal return value */
217 fcntlerr:
218 error(SYSTEM, "cannot change display blocking mode");
219 readerr:
220 error(SYSTEM, "error reading from display process");
221 }
222
223
224 int
225 disp_close() /* close our display process */
226 {
227 int rval;
228
229 if (dpout == NULL)
230 return(-1);
231 disp_result(DS_SHUTDOWN, 0, NULL);
232 fclose(dpout);
233 dpout = NULL;
234 return(close_process(dpd));
235 }
236
237
238 disp_result(type, nbytes, p) /* queue result message to display process */
239 int type, nbytes;
240 char *p;
241 {
242 MSGHEAD msg;
243 /* consistency checks */
244 #ifdef DEBUG
245 if (nbytes < 0 || nbytes > 0 & p == NULL)
246 error(CONSISTENCY, "bad buffer handed to disp_result");
247 #endif
248 if (dpout == NULL)
249 return;
250 msg.type = type;
251 msg.nbytes = nbytes;
252 fwrite((char *)&msg, sizeof(MSGHEAD), 1, dpout);
253 if (nbytes > 0)
254 fwrite(p, 1, nbytes, dpout);
255 }
256
257
258 disp_flush() /* flush output to display */
259 {
260 if (fflush(dpout) < 0)
261 error(SYSTEM, "error writing to the display process");
262 }
