root/radiance/src/hd/rholo3.c
Revision: 3.9
Committed: Fri Nov 21 17:47:56 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.8: +1 -4 lines
fixed problem with allocating huge array for unreasonable request
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for tracking beam compuatations
9 */
10
11 #include "rholo.h"
12
13
14 #define abs(x) ((x) > 0 ? (x) : -(x))
15 #define sgn(x) ((x) > 0 ? 1 : (x) < 0 ? -1 : 0)
16
17
18 static PACKHEAD *complist=NULL; /* list of beams to compute */
19 static int complen=0; /* length of complist */
20 static int listpos=0; /* current list position for next_packet */
21 static int lastin= -1; /* last ordered position in list */
22
23
24 int
25 beamcmp(b0, b1) /* comparison for descending compute order */
26 register PACKHEAD *b0, *b1;
27 {
28 return( b1->nr*(bnrays(hdlist[b0->hd],b0->bi)+1) -
29 b0->nr*(bnrays(hdlist[b1->hd],b1->bi)+1) );
30 }
31
32
33 bundle_set(op, clist, nents) /* bundle set operation */
34 int op;
35 PACKHEAD *clist;
36 int nents;
37 {
38 BEAM *b;
39 PACKHEAD *p;
40 register int i, n;
41
42 switch (op) {
43 case BS_NEW: /* new computation set */
44 if (complen)
45 free((char *)complist);
46 if (nents <= 0) {
47 complist = NULL;
48 listpos = complen = 0;
49 lastin = -1;
50 return;
51 }
52 complist = (PACKHEAD *)malloc(nents*sizeof(PACKHEAD));
53 if (complist == NULL)
54 goto memerr;
55 bcopy((char *)clist, (char *)complist, nents*sizeof(PACKHEAD));
56 complen = nents;
57 listpos = 0;
58 lastin = -1; /* flag for initial sort */
59 break;
60 case BS_ADD: /* add to computation set */
61 if (nents <= 0)
62 return;
63 /* merge any common members */
64 for (i = 0; i < complen; i++)
65 for (n = 0; n < nents; n++)
66 if (clist[n].bi == complist[i].bi &&
67 clist[n].hd == complist[i].hd) {
68 complist[i].nr += clist[n].nr;
69 clist[n].nr = 0;
70 lastin = -1; /* flag full sort */
71 break;
72 }
73 /* sort updated list */
74 sortcomplist();
75 /* sort new entries */
76 qsort((char *)clist, nents, sizeof(PACKHEAD), beamcmp);
77 /* what can't we satisfy? */
78 for (n = 0; n < nents && clist[n].nr >
79 bnrays(hdlist[clist[n].hd],clist[n].bi); n++)
80 ;
81 if (n) { /* allocate space for merged list */
82 PACKHEAD *newlist;
83 newlist = (PACKHEAD *)malloc(
84 (complen+n)*sizeof(PACKHEAD) );
85 if (newlist == NULL)
86 goto memerr;
87 /* merge lists */
88 mergeclists(newlist, clist, n, complist, complen);
89 if (complen)
90 free((char *)complist);
91 complist = newlist;
92 complen += n;
93 }
94 listpos = 0;
95 lastin = complen-1; /* list is now sorted */
96 break;
97 case BS_DEL: /* delete from computation set */
98 if (nents <= 0)
99 return;
100 /* find each member */
101 for (i = 0; i < complen; i++)
102 for (n = 0; n < nents; n++)
103 if (clist[n].bi == complist[i].bi &&
104 clist[n].hd == complist[i].hd) {
105 if (clist[n].nr == 0 ||
106 clist[n].nr >= complist[i].nr)
107 complist[i].nr = 0;
108 else
109 complist[i].nr -= clist[n].nr;
110 lastin = -1; /* flag full sort */
111 break;
112 }
113 if (lastin < 0) /* sort updated list */
114 sortcomplist();
115 return; /* no display */
116 default:
117 error(CONSISTENCY, "bundle_set called with unknown operation");
118 }
119 if (outdev == NULL)
120 return;
121 n = 8*RPACKSIZ; /* allocate packet holder */
122 p = (PACKHEAD *)malloc(packsiz(n));
123 if (p == NULL)
124 goto memerr;
125 /* display what we have */
126 for (i = 0; i < nents; i++)
127 if ((b = hdgetbeam(hdlist[clist[i].hd], clist[i].bi)) != NULL) {
128 if (b->nrm > n) {
129 n = b->nrm;
130 p = (PACKHEAD *)realloc((char *)p, packsiz(n));
131 if (p == NULL)
132 goto memerr;
133 }
134 bcopy((char *)hdbray(b), (char *)packra(p),
135 (p->nr=b->nrm)*sizeof(RAYVAL));
136 p->hd = clist[i].hd;
137 p->bi = clist[i].bi;
138 disp_packet(p);
139 }
140 free((char *)p); /* clean up */
141 return;
142 memerr:
143 error(SYSTEM, "out of memory in bundle_set");
144 }
145
146
147 int
148 weightf(hp, x0, x1, x2) /* voxel weighting function */
149 register HOLO *hp;
150 register int x0, x1, x2;
151 {
152 switch (vlet(OCCUPANCY)) {
153 case 'U': /* uniform weighting */
154 return(1);
155 case 'C': /* center weighting (crude) */
156 x0 += x0 - hp->grid[0] + 1;
157 x0 = abs(x0)*hp->grid[1]*hp->grid[2];
158 x1 += x1 - hp->grid[1] + 1;
159 x1 = abs(x1)*hp->grid[0]*hp->grid[2];
160 x2 += x2 - hp->grid[2] + 1;
161 x2 = abs(x2)*hp->grid[0]*hp->grid[1];
162 return(hp->grid[0]*hp->grid[1]*hp->grid[2] -
163 (x0+x1+x2)/3);
164 default:
165 badvalue(OCCUPANCY);
166 }
167 }
168
169
170 /* The following is by Daniel Cohen, taken from Graphics Gems IV, p. 368 */
171 long
172 lineweight(hp, x, y, z, dx, dy, dz) /* compute weights along a line */
173 HOLO *hp;
174 int x, y, z, dx, dy, dz;
175 {
176 long wres = 0;
177 int n, sx, sy, sz, exy, exz, ezy, ax, ay, az, bx, by, bz;
178
179 sx = sgn(dx); sy = sgn(dy); sz = sgn(dz);
180 ax = abs(dx); ay = abs(dy); az = abs(dz);
181 bx = 2*ax; by = 2*ay; bz = 2*az;
182 exy = ay-ax; exz = az-ax; ezy = ay-az;
183 n = ax+ay+az + 1; /* added increment to visit last */
184 while (n--) {
185 wres += weightf(hp, x, y, z);
186 if (exy < 0) {
187 if (exz < 0) {
188 x += sx;
189 exy += by; exz += bz;
190 } else {
191 z += sz;
192 exz -= bx; ezy += by;
193 }
194 } else {
195 if (ezy < 0) {
196 z += sz;
197 exz -= bx; ezy += by;
198 } else {
199 y += sy;
200 exy -= bx; ezy -= bz;
201 }
202 }
203 }
204 return(wres);
205 }
206
207
208 init_global() /* initialize global ray computation */
209 {
210 long wtotal = 0;
211 int i, j;
212 int lseg[2][3];
213 double frac;
214 register int k;
215 /* free old list */
216 if (complen > 0)
217 free((char *)complist);
218 /* allocate beam list */
219 complen = 0;
220 for (j = 0; hdlist[j] != NULL; j++)
221 complen += nbeams(hdlist[j]);
222 complist = (PACKHEAD *)malloc(complen*sizeof(PACKHEAD));
223 if (complist == NULL)
224 error(SYSTEM, "out of memory in init_global");
225 /* compute beam weights */
226 k = 0;
227 for (j = 0; hdlist[j] != NULL; j++)
228 for (i = nbeams(hdlist[j]); i > 0; i--) {
229 hdlseg(lseg, hdlist[j], i);
230 complist[k].hd = j;
231 complist[k].bi = i;
232 complist[k].nr = lineweight( hdlist[j],
233 lseg[0][0], lseg[0][1], lseg[0][2],
234 lseg[1][0] - lseg[0][0],
235 lseg[1][1] - lseg[0][1],
236 lseg[1][2] - lseg[0][2] );
237 wtotal += complist[k++].nr;
238 }
239 /* adjust weights */
240 if (vdef(DISKSPACE)) {
241 frac = 1024.*1024.*vflt(DISKSPACE) / (wtotal*sizeof(RAYVAL));
242 if (frac < 0.95 | frac > 1.05)
243 while (k--)
244 complist[k].nr = frac * complist[k].nr;
245 }
246 listpos = 0; lastin = -1; /* flag initial sort */
247 }
248
249
250 mergeclists(cdest, cl1, n1, cl2, n2) /* merge two sorted lists */
251 PACKHEAD *cdest;
252 PACKHEAD *cl1, *cl2;
253 int n1, n2;
254 {
255 int cmp;
256
257 while (n1 | n2) {
258 if (!n1) cmp = 1;
259 else if (!n2) cmp = -1;
260 else cmp = beamcmp(cl1, cl2);
261 if (cmp > 0) {
262 copystruct(cdest, cl2);
263 cl2++; n2--;
264 } else {
265 copystruct(cdest, cl1);
266 cl1++; n1--;
267 }
268 cdest++;
269 }
270 }
271
272
273 sortcomplist() /* fix our list order */
274 {
275 PACKHEAD *list2;
276 register int i;
277
278 /* empty queue */
279 done_packets(flush_queue());
280 if (complen <= 0) /* check to see if there is even a list */
281 return;
282 if (lastin < 0 || listpos*4 >= complen*3)
283 qsort((char *)complist, complen, sizeof(PACKHEAD), beamcmp);
284 else if (listpos) { /* else sort and merge sublist */
285 list2 = (PACKHEAD *)malloc(listpos*sizeof(PACKHEAD));
286 if (list2 == NULL)
287 error(SYSTEM, "out of memory in sortcomplist");
288 bcopy((char *)complist,(char *)list2,listpos*sizeof(PACKHEAD));
289 qsort((char *)list2, listpos, sizeof(PACKHEAD), beamcmp);
290 mergeclists(complist, list2, listpos,
291 complist+listpos, complen-listpos);
292 free((char *)list2);
293 }
294 /* check for all finished */
295 if (complist[0].nr <= bnrays(hdlist[complist[0].hd],complist[0].bi)) {
296 free((char *)complist);
297 complist = NULL;
298 complen = 0;
299 }
300 /* drop satisfied requests */
301 for (i = complen; i-- && complist[i].nr <=
302 bnrays(hdlist[complist[i].hd],complist[i].bi); )
303 ;
304 if (i < 0) {
305 free((char *)complist);
306 complist = NULL;
307 complen = 0;
308 } else if (i < complen-1) {
309 list2 = (PACKHEAD *)realloc((char *)complist,
310 (i+1)*sizeof(PACKHEAD));
311 if (list2 != NULL) {
312 complist = list2;
313 complen = i+1;
314 }
315 }
316 listpos = 0; lastin = i;
317 }
318
319
320 /*
321 * The following routine works on the assumption that the bundle weights are
322 * more or less evenly distributed, such that computing a packet causes
323 * a given bundle to move way down in the computation order. We keep
324 * track of where the computed bundle with the highest priority would end
325 * up, and if we get further in our compute list than this, we resort the
326 * list and start again from the beginning. We have to flush the queue
327 * each time we sort, to ensure that we are not disturbing the order.
328 * If our major assumption is violated, and we have a very steep
329 * descent in our weights, then we will end up resorting much more often
330 * than necessary, resulting in frequent flushing of the queue. Since
331 * a merge sort is used, the sorting costs will be minimal.
332 */
333 next_packet(p) /* prepare packet for computation */
334 register PACKET *p;
335 {
336 int ncomp;
337 register int i;
338
339 if (complen <= 0)
340 return(0);
341 if (listpos > lastin) /* time to sort the list */
342 sortcomplist();
343 p->hd = complist[listpos].hd;
344 p->bi = complist[listpos].bi;
345 ncomp = bnrays(hdlist[p->hd],p->bi);
346 p->nr = complist[listpos].nr - ncomp;
347 if (p->nr <= 0)
348 return(0);
349 if (p->nr > RPACKSIZ)
350 p->nr = RPACKSIZ;
351 ncomp += p->nr; /* find where this one would go */
352 while (lastin > listpos && complist[listpos].nr *
353 (bnrays(hdlist[complist[lastin].hd],complist[lastin].bi)+1)
354 > complist[lastin].nr * (ncomp+1))
355 lastin--;
356 listpos++;
357 return(1);
358 }
