root/radiance/src/hd/rholo2l.c
Revision: 3.24
Committed: Thu Feb 6 03:54:32 2025 UTC (9 months ago) by greg
CVS Tags: rad6R0, HEAD
fix(rholo): Safer option setting for rtrace to avoid non-RGB results
2 static const char RCSid[] = "$Id: rholo2l.c,v 3.23 2025/01/22 18:28:32 greg Exp $";
5 * Routines for local rtrace execution
6 */
7
8 #include <signal.h>
9 #include <sys/time.h>
10 #include <string.h>
11
12 #include "rholo.h"
13 #include "random.h"
14 #include "paths.h"
15 #include "selcall.h"
16 #include "rtprocess.h"
17
18 #ifndef MAXPROC
19 #define MAXPROC 64
20 #endif
21
22 int nprocs = 0; /* running process count */
23
24 static char pfile[] = TEMPLATE; /* persist file name */
25
26 static SUBPROC rtpd[MAXPROC]; /* process descriptors */
27 static float *rtbuf = NULL; /* allocated i/o buffer */
28 static int maxqlen; /* maximum packets per queue */
29
30 static PACKET *pqueue[MAXPROC]; /* packet queues */
31 static int pqlen[MAXPROC]; /* packet queue lengths */
32
33 static int bestout(void);
34 static int slots_avail(void);
35 static void queue_packet(PACKET *p);
36 static PACKET * get_packets(int poll);
37 static void killpersist(void);
38
39
40 int
41 start_rtrace(void) /* start rtrace process */
42 {
43 static char buf1[8];
44 int rmaxpack = 0;
45 int psiz, n;
46 /* get number of processes */
47 if (ncprocs <= 0 || nprocs > 0)
48 return(0);
49 if (ncprocs > MAXPROC) {
50 sprintf(errmsg,
51 "number of rtrace processes reduced from %d to %d",
52 ncprocs, MAXPROC);
53 error(WARNING, errmsg);
54 ncprocs = MAXPROC;
55 }
56 if (rtargv[rtargc-1] != vval(OCTREE)) {
57 /* add compulsory options */
58 rtargv[rtargc++] = "-i-";
59 rtargv[rtargc++] = "-I-";
60 rtargv[rtargc++] = "-h-";
61 rtargv[rtargc++] = "-ld-";
62 rtargv[rtargc++] = "-pRGB";
63 sprintf(buf1, "%d", RPACKSIZ);
64 rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1;
65 rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0";
66 rtargv[rtargc++] = "-fff";
67 rtargv[rtargc++] = vbool(VDIST) ? "-ovl" : "-ovL";
68 if (nowarn)
69 rtargv[rtargc++] = "-w-";
70 if (ncprocs > 1) {
71 mktemp(pfile);
72 rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = pfile;
73 }
74 rtargv[rtargc++] = vval(OCTREE);
75 rtargv[rtargc] = NULL;
76 }
77 maxqlen = 0;
78 for (nprocs = 0; nprocs < ncprocs; nprocs++) { /* spawn children */
79 psiz = open_process(&rtpd[nprocs], rtargv);
80 if (psiz <= 0)
81 error(SYSTEM, "cannot start rtrace process");
82 n = psiz/(RPACKSIZ*6*sizeof(float)) + 1;
83 if (!maxqlen) {
84 maxqlen = n;
85 sleep(2);
86 } else if (n != maxqlen)
87 error(INTERNAL, "varying pipe buffer size!");
88 rmaxpack += n;
89 }
90 rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen);
91 if (rtbuf == NULL)
92 error(SYSTEM, "malloc failure in start_rtrace");
93 return(rmaxpack);
94 }
95
96
97 static int
98 bestout(void) /* get best process to process packet */
99 {
100 int cnt;
101 int pn, i;
102
103 pn = 0; /* find shortest queue */
104 for (i = 1; i < nprocs; i++)
105 if (pqlen[i] < pqlen[pn])
106 pn = i;
107 /* sanity check */
108 if (pqlen[pn] == maxqlen)
109 return(-1);
110 cnt = 0; /* count number of ties */
111 for (i = pn; i < nprocs; i++)
112 if (pqlen[i] == pqlen[pn])
113 cnt++;
114 /* break ties fairly */
115 if ((cnt = irandom(cnt)))
116 for (i = pn; i < nprocs; i++)
117 if (pqlen[i] == pqlen[pn] && !cnt--)
118 return(i);
119 return(pn);
120 }
121
122
123 static int
124 slots_avail(void) /* count packet slots available */
125 {
126 int nslots = 0;
127 int i;
128
129 for (i = nprocs; i--; )
130 nslots += maxqlen - pqlen[i];
131 return(nslots);
132 }
133
134
135 static void
136 queue_packet( /* queue up a beam packet */
137 PACKET *p
138 )
139 {
140 int pn, n;
141 /* determine process to write to */
142 if ((pn = bestout()) < 0)
143 error(INTERNAL, "rtrace input queues are full!");
144 /* write out the packet */
145 packrays(rtbuf, p);
146 if ((n = p->nr) < RPACKSIZ) /* add flush block? */
147 memset((char *)(rtbuf+6*n++), '\0', 6*sizeof(float));
148 if (writebuf(rtpd[pn].w, rtbuf, 6*sizeof(float)*n) < 0)
149 error(SYSTEM, "write error in queue_packet");
150 p->next = NULL;
151 if (!pqlen[pn]++) /* add it to the end of the queue */
152 pqueue[pn] = p;
153 else {
154 PACKET *rpl = pqueue[pn];
155 while (rpl->next != NULL)
156 rpl = rpl->next;
157 rpl->next = p;
158 }
159 }
160
161
162 static PACKET *
163 get_packets( /* read packets from rtrace processes */
164 int poll
165 )
166 {
167 static struct timeval tpoll; /* zero timeval struct */
168 fd_set readset, errset;
169 PACKET *pldone = NULL, *plend;
170 PACKET *p;
171 int n, nr;
172 int pn;
173 float *bp;
174 /* prepare select call */
175 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
176 for (pn = nprocs; pn--; ) {
177 if (pqlen[pn])
178 FD_SET(rtpd[pn].r, &readset);
179 FD_SET(rtpd[pn].r, &errset);
180 if (rtpd[pn].r >= n)
181 n = rtpd[pn].r + 1;
182 }
183 /* make the call */
184 n = select(n, &readset, (fd_set *)NULL, &errset,
185 poll ? &tpoll : (struct timeval *)NULL);
186 if (n < 0) {
187 if (errno == EINTR) /* interrupted select call */
188 return(NULL);
189 error(SYSTEM, "select call failure in get_packets");
190 }
191 if (n == 0) /* is nothing ready? */
192 return(NULL);
193 /* make read call(s) */
194 for (pn = 0; pn < nprocs; pn++) {
195 if (!FD_ISSET(rtpd[pn].r, &readset) &&
196 !FD_ISSET(rtpd[pn].r, &errset))
197 continue;
198 reread:
199 n = read(rtpd[pn].r, (char *)rtbuf,
200 4*sizeof(float)*RPACKSIZ*pqlen[pn]);
201 if (n < 0) {
202 if ((errno == EINTR) | (errno == EAGAIN))
203 goto reread;
204 error(SYSTEM, "read error in get_packets");
205 }
206 if (n == 0)
207 goto eoferr;
208 bp = rtbuf; /* finish processing */
209 for (p = pqueue[pn]; n && p != NULL; p = p->next) {
210 if ((nr = p->nr) < RPACKSIZ)
211 nr++; /* add flush block */
212 n -= 4*sizeof(float)*nr;
213 if (n < 0) { /* get remainder */
214 n += readbuf(rtpd[pn].r,
215 (char *)(bp+4*nr)+n, -n);
216 if (n)
217 goto eoferr;
218 }
219 donerays(p, bp);
220 bp += 4*nr;
221 pqlen[pn]--;
222 }
223 if (n) /* read past end? */
224 error(INTERNAL, "packet sync error in get_packets");
225 /* take from queue */
226 if (pldone == NULL)
227 pldone = plend = pqueue[pn];
228 else
229 plend->next = pqueue[pn];
230 while (plend->next != p)
231 plend = plend->next;
232 plend->next = NULL;
233 pqueue[pn] = p;
234 }
235 return(pldone); /* return finished packets */
236 eoferr:
237 error(USER, "rtrace process died");
238 return NULL; /* pro forma return */
239 }
240
241
242 PACKET *
243 do_packets( /* queue a packet list, return finished */
244 PACKET *pl
245 )
246 {
247 PACKET *p;
248 /* consistency check */
249 if (nprocs < 1)
250 error(CONSISTENCY, "do_packets called with no active process");
251 /* queue each new packet */
252 while (pl != NULL) {
253 p = pl; pl = p->next; p->next = NULL;
254 queue_packet(p);
255 }
256 return(get_packets(slots_avail())); /* return processed packets */
257 }
258
259
260 PACKET *
261 flush_queue(void) /* empty all rtrace queues */
262 {
263 PACKET *rpdone = NULL;
264 PACKET *rpl = NULL;
265 float *bp;
266 PACKET *p;
267 int i, n, nr;
268
269 for (i = 0; i < nprocs; i++)
270 if (pqlen[i]) {
271 if (rpdone == NULL) { /* tack on queue */
272 rpdone = rpl = pqueue[i];
273 if ((nr = rpl->nr) < RPACKSIZ) nr++;
274 } else {
275 rpl->next = pqueue[i];
276 nr = 0;
277 }
278 while (rpl->next != NULL) {
279 nr += (rpl = rpl->next)->nr;
280 if (rpl->nr < RPACKSIZ)
281 nr++; /* add flush block */
282 }
283 n = readbuf(rtpd[i].r, rtbuf, 4*sizeof(float)*nr);
284 if (n < 0)
285 error(SYSTEM, "read failure in flush_queue");
286 bp = rtbuf; /* process packets */
287 for (p = pqueue[i]; p != NULL; p = p->next) {
288 if ((nr = p->nr) < RPACKSIZ)
289 nr++; /* add flush block */
290 n -= 4*sizeof(float)*nr;
291 if (n >= 0)
292 donerays(p, bp);
293 else
294 p->nr = 0; /* short data error */
295 bp += 4*nr;
296 }
297 pqueue[i] = NULL; /* zero this queue */
298 pqlen[i] = 0;
299 }
300 return(rpdone); /* return all packets completed */
301 }
302
303
304 static void
305 killpersist(void) /* kill persistent process */
306 {
307 FILE *fp;
308 int pid;
309
310 if ((fp = fopen(pfile, "r")) == NULL)
311 return;
312 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
313 unlink(pfile);
314 fclose(fp);
315 }
316
317
318 int
319 end_rtrace(void) /* close rtrace process(es) */
320 {
321 int status = 0, rv;
322
323 if (nprocs > 1)
324 killpersist();
325 status = close_processes(rtpd, nprocs);
326 nprocs = 0;
327 free((void *)rtbuf);
328 rtbuf = NULL;
329 maxqlen = 0;
330 return(status);
331 }
