root/radiance/src/hd/rholo2l.c
Revision: 3.6
Committed: Mon Dec 1 16:32:49 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.5: +7 -5 lines
added "VDISTANCE" variable for virtual distance calculation
made persist file vary with process id so multiple rholo's don't interfere
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for local rtrace execution
9 */
10
11 #include "rholo.h"
12 #include "random.h"
13 #include "paths.h"
14 #include "selcall.h"
15 #include <signal.h>
16 #include <sys/time.h>
17
18 #ifndef MAXPROC
19 #define MAXPROC 16
20 #endif
21
22 static char pfile[] = TEMPLATE; /* persist file name */
23
24 static int rtpd[MAXPROC][3]; /* process descriptors */
25 static float *rtbuf = NULL; /* allocated i/o buffer */
26 static int maxqlen = 0; /* maximum packets per queue */
27 static int nprocs = 0; /* number of processes */
28
29 static PACKET *pqueue[MAXPROC]; /* packet queues */
30 static int pqlen[MAXPROC]; /* packet queue lengths */
31
32
33 int
34 start_rtrace() /* start rtrace process */
35 {
36 static char buf1[8];
37 int rmaxpack = 0;
38 int psiz, npt, n;
39 /* get number of processes */
40 if ((npt = ncprocs) <= 0)
41 return(0);
42 if (npt > MAXPROC) {
43 sprintf(errmsg,
44 "number of rtrace processes reduced from %d to %d",
45 npt, MAXPROC);
46 error(WARNING, errmsg);
47 npt = MAXPROC;
48 }
49 /* add compulsory options */
50 rtargv[rtargc++] = "-i-";
51 rtargv[rtargc++] = "-I-";
52 rtargv[rtargc++] = "-h-";
53 rtargv[rtargc++] = "-ld-";
54 sprintf(buf1, "%d", RPACKSIZ);
55 rtargv[rtargc++] = "-x"; rtargv[rtargc++] = buf1;
56 rtargv[rtargc++] = "-y"; rtargv[rtargc++] = "0";
57 rtargv[rtargc++] = "-fff";
58 rtargv[rtargc++] = vbool(VDIST) ? "-ovl" : "-ovL";
59 rtargv[rtargc++] = nowarn ? "-w-" : "-w+";
60 if (npt > 1) {
61 mktemp(pfile);
62 rtargv[rtargc++] = "-PP"; rtargv[rtargc++] = pfile;
63 }
64 rtargv[rtargc++] = vval(OCTREE);
65 rtargv[rtargc] = NULL;
66 maxqlen = 0;
67 for (nprocs = 0; nprocs < npt; nprocs++) { /* spawn children */
68 psiz = open_process(rtpd[nprocs], rtargv);
69 if (psiz <= 0)
70 error(SYSTEM, "cannot start rtrace process");
71 n = psiz/(RPACKSIZ*6*sizeof(float));
72 if (maxqlen == 0) {
73 if (!(maxqlen = n))
74 error(INTERNAL,
75 "bad pipe buffer size assumption");
76 } else if (n != maxqlen)
77 error(INTERNAL, "varying pipe buffer size!");
78 rmaxpack += n;
79 }
80 rtbuf = (float *)malloc(RPACKSIZ*6*sizeof(float)*maxqlen);
81 if (rtbuf == NULL)
82 error(SYSTEM, "malloc failure in start_rtrace");
83 return(rmaxpack);
84 }
85
86
87 static int
88 bestout() /* get best process to process packet */
89 {
90 int cnt;
91 register int pn, i;
92
93 pn = 0; /* find shortest queue */
94 for (i = 1; i < nprocs; i++)
95 if (pqlen[i] < pqlen[pn])
96 pn = i;
97 /* sanity check */
98 if (pqlen[pn] == maxqlen)
99 return(-1);
100 cnt = 0; /* count number of ties */
101 for (i = pn; i < nprocs; i++)
102 if (pqlen[i] == pqlen[pn])
103 cnt++;
104 /* break ties fairly */
105 if ((cnt = random() % cnt))
106 for (i = pn; i < nprocs; i++)
107 if (pqlen[i] == pqlen[pn] && !cnt--)
108 return(i);
109 return(pn);
110 }
111
112
113 int
114 slots_avail() /* count packet slots available */
115 {
116 register int nslots = 0;
117 register int i;
118
119 for (i = nprocs; i--; )
120 nslots += maxqlen - pqlen[i];
121 return(nslots);
122 }
123
124
125 queue_packet(p) /* queue up a beam packet */
126 register PACKET *p;
127 {
128 int pn, n;
129 /* determine process to write to */
130 if ((pn = bestout()) < 0)
131 error(INTERNAL, "rtrace input queues are full!");
132 /* write out the packet */
133 packrays(rtbuf, p);
134 if ((n = p->nr) < RPACKSIZ) /* add flush block? */
135 bzero((char *)(rtbuf+6*n++), 6*sizeof(float));
136 if (writebuf(rtpd[pn][1], (char *)rtbuf, 6*sizeof(float)*n) < 0)
137 error(SYSTEM, "write error in queue_packet");
138 p->next = NULL;
139 if (!pqlen[pn]++) /* add it to the end of the queue */
140 pqueue[pn] = p;
141 else {
142 register PACKET *rpl = pqueue[pn];
143 while (rpl->next != NULL)
144 rpl = rpl->next;
145 rpl->next = p;
146 }
147 }
148
149
150 PACKET *
151 get_packets(poll) /* read packets from rtrace processes */
152 int poll;
153 {
154 static struct timeval tpoll; /* zero timeval struct */
155 fd_set readset, errset;
156 PACKET *pldone = NULL, *plend;
157 register PACKET *p;
158 int n, nr;
159 register int pn;
160 float *bp;
161 /* prepare select call */
162 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
163 for (pn = nprocs; pn--; ) {
164 if (pqlen[pn])
165 FD_SET(rtpd[pn][0], &readset);
166 FD_SET(rtpd[pn][0], &errset);
167 if (rtpd[pn][0] >= n)
168 n = rtpd[pn][0] + 1;
169 }
170 /* make the call */
171 n = select(n, &readset, (fd_set *)NULL, &errset,
172 poll ? &tpoll : (struct timeval *)NULL);
173 if (n < 0) {
174 if (errno == EINTR) /* interrupted select call */
175 return(NULL);
176 error(SYSTEM, "select call failure in get_packets");
177 }
178 if (n == 0) /* is nothing ready? */
179 return(NULL);
180 /* make read call(s) */
181 for (pn = 0; pn < nprocs; pn++) {
182 if (!FD_ISSET(rtpd[pn][0], &readset) &&
183 !FD_ISSET(rtpd[pn][0], &errset))
184 continue;
185 reread:
186 n = read(rtpd[pn][0], (char *)rtbuf,
187 4*sizeof(float)*RPACKSIZ*pqlen[pn]);
188 if (n < 0) {
189 if (errno == EINTR | errno == EAGAIN)
190 goto reread;
191 error(SYSTEM, "read error in get_packets");
192 }
193 if (n == 0)
194 goto eoferr;
195 bp = rtbuf; /* finish processing */
196 for (p = pqueue[pn]; n && p != NULL; p = p->next) {
197 if ((nr = p->nr) < RPACKSIZ)
198 nr++; /* add flush block */
199 n -= 4*sizeof(float)*nr;
200 if (n < 0) { /* get remainder */
201 n += readbuf(rtpd[pn][0],
202 (char *)(bp+4*nr)+n, -n);
203 if (n)
204 goto eoferr;
205 }
206 donerays(p, bp);
207 bp += 4*nr;
208 pqlen[pn]--;
209 }
210 if (n) /* read past end? */
211 error(INTERNAL, "packet sync error in get_packets");
212 /* take from queue */
213 if (pldone == NULL)
214 pldone = plend = pqueue[pn];
215 else
216 plend->next = pqueue[pn];
217 while (plend->next != p)
218 plend = plend->next;
219 plend->next = NULL;
220 pqueue[pn] = p;
221 }
222 return(pldone); /* return finished packets */
223 eoferr:
224 error(USER, "rtrace process died");
225 }
226
227
228 PACKET *
229 do_packets(pl) /* queue a packet list, return finished */
230 register PACKET *pl;
231 {
232 register PACKET *p;
233 /* consistency check */
234 if (nprocs < 1)
235 error(CONSISTENCY, "do_packets called with no active process");
236 /* queue each new packet */
237 while (pl != NULL) {
238 p = pl; pl = p->next; p->next = NULL;
239 queue_packet(p);
240 }
241 return(get_packets(slots_avail())); /* return processed packets */
242 }
243
244
245 PACKET *
246 flush_queue() /* empty all rtrace queues */
247 {
248 PACKET *rpdone = NULL;
249 register PACKET *rpl;
250 float *bp;
251 register PACKET *p;
252 int i, n, nr;
253
254 for (i = 0; i < nprocs; i++)
255 if (pqlen[i]) {
256 if (rpdone == NULL) { /* tack on queue */
257 rpdone = rpl = pqueue[i];
258 if ((nr = rpl->nr) < RPACKSIZ) nr++;
259 } else {
260 rpl->next = pqueue[i];
261 nr = 0;
262 }
263 while (rpl->next != NULL) {
264 nr += (rpl = rpl->next)->nr;
265 if (rpl->nr < RPACKSIZ)
266 nr++; /* add flush block */
267 }
268 n = readbuf(rtpd[i][0], (char *)rtbuf,
269 4*sizeof(float)*nr);
270 if (n < 0)
271 error(SYSTEM, "read failure in flush_queue");
272 bp = rtbuf; /* process packets */
273 for (p = pqueue[i]; p != NULL; p = p->next) {
274 if ((nr = p->nr) < RPACKSIZ)
275 nr++; /* add flush block */
276 n -= 4*sizeof(float)*nr;
277 if (n >= 0)
278 donerays(p, bp);
279 else
280 p->nr = 0; /* short data error */
281 bp += 4*nr;
282 }
283 pqueue[i] = NULL; /* zero this queue */
284 pqlen[i] = 0;
285 }
286 return(rpdone); /* return all packets completed */
287 }
288
289
290 static
291 killpersist() /* kill persistent process */
292 {
293 FILE *fp;
294 int pid;
295
296 if ((fp = fopen(pfile, "r")) == NULL)
297 return;
298 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
299 unlink(pfile);
300 fclose(fp);
301 }
302
303
304 int
305 end_rtrace() /* close rtrace process(es) */
306 {
307 int status = 0, rv;
308
309 if (nprocs > 1)
310 killpersist();
311 while (nprocs > 0) {
312 rv = close_process(rtpd[--nprocs]);
313 if (rv > 0)
314 status = rv;
315 }
316 free((char *)rtbuf);
317 rtbuf = NULL;
318 maxqlen = 0;
319 return(status);
320 }
