root/radiance/src/hd/rhdriver.h
Revision: 3.1
Committed: Wed Nov 19 18:01:03 1997 UTC (27 years, 11 months ago) by gregl
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* preferred view parameters */
14 int hres, vres; /* device resolution */
15 int ifd; /* input file descriptor (for select) */
16 } odev; /* our open device */
17
18 /* dev_input() return flags */
19 #define DEV_SHUTDOWN 01 /* user shutdown request */
20 #define DEV_NEWVIEW 02 /* view change (new view in odev.v) */
21 #define DEV_NEWSIZE 04 /* device resolution change */
22
23
24 /************************************************************************
25 * Driver routines (all are required):
26
27
28 void
29 dev_open(nm) : prepare the device
30 char *nm; : appropriate title bar annotation
31
32 Sets fields of odev structure and prepares the display for i/o.
33 The view type, horizontal and vertical view angles and other default
34 parameters in odev.v should also be assigned.
35
36
37 void
38 dev_view(nv) : set display view parameters
39 VIEW *nv; : the new view
40
41 Updates the display for the given view change.
42 Look for nv==&odev.v when making view current after dev_input()
43 returns DEV_NEWVIEW flag.
44
45
46 void
47 dev_value(c, p) : register new point of light
48 COLR c; : pixel color (RGBE)
49 FVECT p; : world intersection point
50
51 Add the given color point to the display output queue.
52
53
54 int
55 dev_flush() : flush the output and prepare for select call
56
57 Updates display, taking any pending action required before select(2) call.
58 Returns non-zero if there is device input available.
59
60
61 int
62 dev_input() : process pending display input
63
64 Called when odev struct file descriptor shows input is ready.
65 Returns flags indicating actions to take in the control process.
66 If the DEV_NEWVIEW or DEV_NEWSIZE flag is returned, the odev
67 structure must be updated beforehand.
68
69
70 void
71 dev_close() : close the display
72
73 Close the display device and free up resources in preparation for exit.
74 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
75
76
77 ************************************************************************/
