root/radiance/src/hd/rhdobj.c
Fri Aug 2 18:46:27 2024 UTC (14 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 3.22
refactor: removed out-dated casts to (char *)
Fri Feb 28 05:18:49 2020 UTC (5 years, 7 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 3.21: +5 -4 lines
Diff to previous 3.21
Fri Oct 5 19:19:16 2018 UTC (7 years ago) by greg
Changes since 3.20: +36 -36 lines
Diff to previous 3.20
Fri May 20 02:06:39 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 3.19
Fri Feb 18 17:31:09 2011 UTC (14 years, 7 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18
Fix for new gcc compiler
Fri Jan 7 20:33:02 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.17: +5 -4 lines
Diff to previous 3.17
Tue Mar 30 20:40:04 2004 UTC (21 years, 6 months ago) by greg
Changes since 3.16: +2 -3 lines
Diff to previous 3.16
Thu Jan 1 11:21:55 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.15: +113 -67 lines
Diff to previous 3.15
Ansification and prototypes.
Mon Jul 21 22:30:18 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.14: +3 -3 lines
Diff to previous 3.14
Mon Jun 30 14:59:11 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.13: +7 -5 lines
Diff to previous 3.13
Thu Jun 26 00:58:10 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.12: +7 -6 lines
Diff to previous 3.12
Tue May 13 17:58:33 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.11: +5 -6 lines
Diff to previous 3.11
Sat Feb 22 02:07:24 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.10: +6 -9 lines
Diff to previous 3.10
Fri Jan 29 15:33:36 1999 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.9: +3 -2 lines
Diff to previous 3.9
added number of lists for proper list deallocation
Thu Dec 31 12:57:06 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.8: +12 -13 lines
Diff to previous 3.8
fixed redrawing of local objects in OpenGL driver
Wed Dec 23 17:41:14 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.7: +13 -6 lines
Diff to previous 3.7
made it so dobj_command() only calls dev_view() if necessary
Fri Dec 18 11:06:45 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.6: +5 -2 lines
Diff to previous 3.6
changed dobj_render() to return the number of objects rendered
Fri Oct 9 17:34:00 1998 UTC (27 years ago) by gwlarson
Changes since 3.5: +38 -9 lines
Diff to previous 3.5
changed moved command to do rotations and scaling relative to object center
Thu Aug 27 19:32:43 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.4: +6 -6 lines
Diff to previous 3.4
bug fix in dobj_command()
Wed Aug 26 17:26:26 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.3: +6 -5 lines
Diff to previous 3.3
replaced error message for insufficient lighting samples
fixed drawing mode, which wasn't restored exactly by dobj_render()
Tue Aug 25 18:10:12 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.2: +24 -13 lines
minor improvements
Fri Aug 21 11:38:22 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.1: +75 -32 lines
changed dobj_trace() to return name of intersected object
improved "show" lighting with front-directed light source
changed MINTHRESH and cosmetic fixes
Wed Aug 19 17:45:24 1998 UTC (27 years, 2 months ago) by gwlarson
