root/radiance/src/hd/rhdisp2.c
Revision: 3.7
Committed: Tue Nov 25 10:48:38 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.6: +13 -8 lines
bug fixes and minor improvements
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam tracking for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "rhdriver.h"
14
15 extern GCOORD *getviewcells();
16
17 static VIEW dvw; /* current view corresponding to beam list */
18
19 typedef struct {
20 int hd; /* holodeck section number (-1 if inactive) */
21 int i[3]; /* voxel index (may be outside section) */
22 } VOXL; /* a voxel */
23
24 static VOXL voxel[8] = { /* current voxel list */
25 {-1}, {-1}, {-1}, {-1},
26 {-1}, {-1}, {-1}, {-1}
27 };
28
29 #define CBEAMBLK 1024 /* cbeam allocation block size */
30
31 static struct beamcomp {
32 short wants; /* flags telling which voxels want us */
33 short hd; /* holodeck section number */
34 int bi; /* beam index */
35 } *cbeam = NULL; /* current beam list */
36
37 static int ncbeams = 0; /* number of sorted beams in cbeam */
38 static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
39 static int maxcbeam = 0; /* size of cbeam array */
40
41 struct cellact {
42 short vi; /* voxel index */
43 short add; /* zero means delete */
44 short rev; /* reverse ray direction? */
45 }; /* action for cell */
46
47 struct beamact {
48 struct cellact ca; /* cell action */
49 GCOORD gc; /* grid coordinate */
50 }; /* beam origin and action */
51
52
53 int
54 newcbeam() /* allocate new entry at end of cbeam array */
55 {
56 int i;
57
58 if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
59 maxcbeam += CBEAMBLK;
60 if (cbeam == NULL)
61 cbeam = (struct beamcomp *)malloc(
62 maxcbeam*sizeof(struct beamcomp) );
63 else
64 cbeam = (struct beamcomp *)realloc( (char *)cbeam,
65 maxcbeam*sizeof(struct beamcomp) );
66 if (cbeam == NULL)
67 error(SYSTEM, "out of memory in newcbeam");
68 }
69 return(i);
70 }
71
72
73 int
74 cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */
75 register struct beamcomp *cb1, *cb2;
76 {
77 register int c;
78
79 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
80 return(c);
81 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
82 }
83
84
85 int
86 cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */
87 register struct beamcomp *cb1, *cb2;
88 {
89 register int c;
90
91 if (!cb1->wants) /* put orphans at the end, unsorted */
92 return(cb2->wants);
93 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
94 return(c);
95 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
96 }
97
98
99 int
100 findcbeam(hd, bi) /* find the specified beam in our sorted list */
101 int hd, bi;
102 {
103 struct beamcomp cb;
104 register struct beamcomp *p;
105
106 if (ncbeams <= 0)
107 return(-1);
108 cb.wants = 0; cb.hd = hd; cb.bi = bi;
109 p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
110 sizeof(struct beamcomp), cbeamcmp);
111 if (p == NULL)
112 return(-1);
113 return(p - cbeam);
114 }
115
116
117 int
118 getcbeam(hd, bi) /* get the specified beam, allocating as necessary */
119 register int hd;
120 int bi;
121 {
122 register int n;
123 /* first, look in sorted list */
124 if ((n = findcbeam(hd, bi)) >= 0)
125 return(n);
126 /* linear search through xcbeams to be sure */
127 for (n = ncbeams+xcbeams; n-- > ncbeams; )
128 if (cbeam[n].bi == bi && cbeam[n].hd == hd)
129 return(n);
130 /* check legality */
131 if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL)
132 error(INTERNAL, "illegal holodeck number in getcbeam");
133 if (bi < 1 | bi > nbeams(hdlist[hd]))
134 error(INTERNAL, "illegal beam index in getcbeam");
135 n = newcbeam(); /* allocate and assign */
136 cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi;
137 return(n);
138 }
139
140
141 cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */
142 int adopt;
143 {
144 register int i;
145
146 if (!(ncbeams += xcbeams))
147 return;
148 xcbeams = 0;
149 qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp),
150 adopt ? cbeamcmp : cbeamcmp2);
151 if (adopt)
152 return;
153 for (i = ncbeams; i--; ) /* identify orphans */
154 if (cbeam[i].wants)
155 break;
156 xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
157 ncbeams = i;
158 }
159
160
161 cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */
162 int op;
163 register struct beamcomp *bl;
164 int n;
165 VIEW *v;
166 int hr, vr;
167 {
168 register PACKHEAD *pa;
169 register int i;
170
171 if (n <= 0)
172 return;
173 pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD));
174 if (pa == NULL)
175 error(SYSTEM, "out of memory in cbeamadd");
176 for (i = 0; i < n; i++) {
177 pa[i].hd = bl[i].hd;
178 pa[i].bi = bl[i].bi;
179 pa[i].nr = v==NULL ? 0 :
180 npixels(v, hr, vr, hdlist[bl[i].hd], bl[i].bi);
181 }
182 serv_request(op, n*sizeof(PACKHEAD), (char *)pa);
183 free((char *)pa);
184 }
185
186
187 int
188 set_voxels(vl, n) /* set new voxel array */
189 VOXL vl[8];
190 int n;
191 {
192 short wmap[256];
193 int vmap[8];
194 int comn = 0;
195 int no;
196 register int i, j;
197 /* find common voxels */
198 for (j = 0; j < 8 && voxel[j].hd >= 0; j++) {
199 vmap[j] = -1;
200 for (i = n; i--; )
201 if (!bcmp((char *)(vl+i), (char *)(voxel+j),
202 sizeof(VOXL))) {
203 vmap[j] = i;
204 comn |= 1<<i;
205 break;
206 }
207 }
208 no = comn ? j : 0; /* compute flag mapping */
209 for (i = 256; i--; ) {
210 wmap[i] = 0;
211 for (j = no; j--; )
212 if (vmap[j] >= 0 && i & 1<<j)
213 wmap[i] |= 1<<vmap[j];
214 }
215 /* fix cbeam flags */
216 for (i = ncbeams; i--; )
217 cbeam[i].wants = wmap[cbeam[i].wants];
218 /* update our voxel list */
219 bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL));
220 for (j = n; j < 8; j++)
221 voxel[j].hd = -1;
222 return(comn); /* return bit array of common voxels */
223 }
224
225
226 int
227 get_voxels(vl, vp) /* find voxels corresponding to view point */
228 VOXL vl[8];
229 FVECT vp;
230 {
231 static int lastn = 0, lastd = -1;
232 int n = 0;
233 FVECT gp;
234 double d;
235 int dist, bestd = 0x7fff;
236 VOXL vox;
237 register int i, j, k;
238 /* find closest voxels */
239 for (i = 0; n < 8 && hdlist[i]; i++) {
240 hdgrid(gp, hdlist[i], vp);
241 for (j = 0; n < 8 && j < 8; j++) {
242 dist = 0;
243 for (k = 0; k < 3; k++) {
244 d = gp[k] - .5 + (j>>k & 1);
245 if (d < 0.)
246 dist += -(vox.i[k] = (int)d - 1);
247 else if ((vox.i[k] = d) >= hdlist[i]->grid[k])
248 dist += vox.i[k] -
249 hdlist[i]->grid[k] + 1;
250 }
251 if (dist > bestd) /* others were closer */
252 continue;
253 if (dist < bestd) { /* start closer list */
254 n = 0;
255 bestd = dist;
256 }
257 vox.hd = i; /* add this voxel */
258 copystruct(&vl[n], &vox);
259 n++;
260 }
261 }
262 /* warn of dangerous moves */
263 if (n < lastn && bestd >= lastd)
264 error(WARNING, "moving outside holodeck section");
265 else if (n > lastn && bestd <= lastd)
266 error(WARNING, "moving inside holodeck section");
267 lastd = bestd;
268 return(lastn = n);
269 }
270
271
272 int
273 dobeam(gcp, bp) /* express interest or disintrest in a beam */
274 GCOORD *gcp;
275 register struct beamact *bp;
276 {
277 GCOORD gc[2];
278 int bi, i;
279 /* compute beam index */
280 if (bp->ca.rev) {
281 copystruct(gc, &bp->gc);
282 copystruct(gc+1, gcp);
283 } else {
284 copystruct(gc, gcp);
285 copystruct(gc+1, &bp->gc);
286 }
287 if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0)
288 error(CONSISTENCY, "bad grid coordinate in dobeam");
289 if (bp->ca.add) { /* add it in */
290 i = getcbeam(voxel[bp->ca.vi].hd, bi);
291 cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */
292 return(i == ncbeams+xcbeams-1); /* return 1 if totally new */
293 }
294 /* else delete it */
295 i = findcbeam(voxel[bp->ca.vi].hd, bi);
296 if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) {
297 cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */
298 return(1); /* indicate change */
299 }
300 return(0);
301 }
302
303
304
305 int
306 docell(gcp, cap) /* find beams corresponding to cell and voxel */
307 GCOORD *gcp;
308 register struct cellact *cap;
309 {
310 FVECT org, dir[4];
311 FVECT gp, cv[4], vc;
312 struct beamact bo;
313 register int i;
314 /* compute cell vertices */
315 hdcell(cv, hdlist[voxel[cap->vi].hd], gcp);
316 /* compute cell and voxel centers */
317 for (i = 0; i < 3; i++) {
318 org[i] = 0.5*(cv[0][i] + cv[2][i]);
319 gp[i] = voxel[cap->vi].i[i] + 0.5;
320 }
321 hdworld(vc, hdlist[voxel[cap->vi].hd], gp);
322 /* compute voxel pyramid using vector trick */
323 for (i = 0; i < 3; i++) {
324 dir[0][i] = vc[i] - cv[0][i]; /* to 3 */
325 dir[2][i] = vc[i] - cv[3][i]; /* to 0 */
326 if (gcp->w & 1) { /* watch vertex order! */
327 dir[1][i] = vc[i] - cv[2][i]; /* to 1 */
328 dir[3][i] = vc[i] - cv[1][i]; /* to 2 */
329 } else {
330 dir[1][i] = vc[i] - cv[1][i]; /* to 2 */
331 dir[3][i] = vc[i] - cv[2][i]; /* to 1 */
332 }
333 }
334 /* visit beams for opposite cells */
335 copystruct(&bo.ca, cap);
336 copystruct(&bo.gc, gcp);
337 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo));
338 }
339
340
341 int
342 doview(cap, vp) /* visit cells for a given view */
343 struct cellact *cap;
344 VIEW *vp;
345 {
346 int orient;
347 FVECT org, dir[4];
348 /* compute view pyramid */
349 orient = viewpyramid(org, dir, hdlist[voxel[cap->vi].hd], vp);
350 if (!orient)
351 error(INTERNAL, "unusable view in doview");
352 cap->rev = orient < 0;
353 /* visit cells within pyramid */
354 return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap));
355 }
356
357
358 mvview(voxi, vold, vnew) /* move view for a voxel */
359 int voxi;
360 VIEW *vold, *vnew;
361 {
362 int netchange = 0;
363 struct cellact oca, nca;
364 int ocnt, ncnt;
365 int c;
366 GCOORD *ogcl, *ngcl;
367 register GCOORD *ogcp, *ngcp;
368 /* get old and new cell lists */
369 ogcp = ogcl = getviewcells(&ocnt, hdlist[voxel[voxi].hd], vold);
370 ngcp = ngcl = getviewcells(&ncnt, hdlist[voxel[voxi].hd], vnew);
371 /* set up actions */
372 oca.vi = nca.vi = voxi;
373 oca.rev = nca.rev = 0;
374 oca.add = 0; nca.add = 1;
375 if ((oca.rev = ocnt < 0))
376 ocnt = -ocnt;
377 if ((nca.rev = ncnt < 0))
378 ncnt = -ncnt;
379 if (nca.rev == oca.rev) /* add and delete cells in order */
380 while (ocnt > 0 & ncnt > 0)
381 if ((c = cellcmp(ogcp, ngcp)) > 0) { /* new cell */
382 netchange += docell(ngcp++, &nca);
383 ncnt--;
384 } else if (c < 0) { /* old cell */
385 netchange -= docell(ogcp++, &oca);
386 ocnt--;
387 } else { /* same cell */
388 ogcp++; ocnt--;
389 ngcp++; ncnt--;
390 }
391 /* take care of list tails */
392 for ( ; ncnt > 0; ncnt--)
393 netchange += docell(ngcp++, &nca);
394 for ( ; ocnt > 0; ocnt--)
395 netchange -= docell(ogcp++, &oca);
396 /* clean up */
397 if (ogcl != NULL) free((char *)ogcl);
398 if (ngcl != NULL) free((char *)ngcl);
399 return(netchange);
400 }
401
402
403 beam_sync() /* synchronize beams on server */
404 {
405 cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres);
406 }
407
408
409 beam_view(vn) /* change beam view */
410 VIEW *vn;
411 {
412 struct cellact ca;
413 VOXL vlnew[8];
414 int n, comn;
415
416 if (!vn->type) { /* clear our beam list */
417 set_voxels(vlnew, 0);
418 cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0);
419 ncbeams = 0;
420 copystruct(&dvw, vn);
421 return;
422 }
423 /* find our new voxels */
424 n = get_voxels(vlnew, vn->vp);
425 /* set the new voxels */
426 comn = set_voxels(vlnew, n);
427 if (!dvw.type)
428 comn = 0;
429 ca.add = 1; /* update our beam list */
430 for (ca.vi = n; ca.vi--; )
431 if (comn & 1<<ca.vi) /* change which cells we see */
432 mvview(ca.vi, &dvw, vn);
433 else /* else add all new cells */
434 doview(&ca, vn);
435 /* inform server of new beams */
436 cbeamop(DR_ADDSET, cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres);
437 /* sort list to put orphans at end */
438 cbeamsort(0);
439 /* tell server to delete orphans */
440 cbeamop(DR_DELSET, cbeam+ncbeams, xcbeams, NULL, 0, 0);
441 xcbeams = 0; /* truncate our list */
442 copystruct(&dvw, vn); /* record new view */
443 }
