root/radiance/src/hd/rhdisp2.c
Revision: 3.35
Committed: Fri Jun 20 00:25:49 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.34: +3 -3 lines
2 static const char RCSid[] = "$Id: rhdisp2.c,v 3.34 2003/04/23 00:52:33 greg Exp $";
5 * Holodeck beam tracking for display process
6 */
7
8 #include "rholo.h"
9 #include "rhdisp.h"
10 #include "rhdriver.h"
11
12 #ifndef MEYERNG
13 #define MEYERNG 0.2 /* target mean eye range (rel. to grid) */
14 #endif
15
16 #define CBEAMBLK 1024 /* cbeam allocation block size */
17
18 static PACKHEAD *cbeam = NULL; /* current beam list */
19 static int ncbeams = 0; /* number of sorted beams in cbeam */
20 static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */
21 static int maxcbeam = 0; /* size of cbeam array */
22
23 VIEWPOINT cureye; /* current eye position */
24
25
26 int
27 newcbeam() /* allocate new entry at end of cbeam array */
28 {
29 int i;
30
31 if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */
32 maxcbeam += CBEAMBLK;
33 if (cbeam == NULL)
34 cbeam = (PACKHEAD *)malloc(
35 maxcbeam*sizeof(PACKHEAD) );
36 else
37 cbeam = (PACKHEAD *)realloc((void *)cbeam,
38 maxcbeam*sizeof(PACKHEAD) );
39 if (cbeam == NULL)
40 error(SYSTEM, "out of memory in newcbeam");
41 }
42 return(i);
43 }
44
45
46 int
47 cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */
48 register PACKHEAD *cb1, *cb2;
49 {
50 register int c;
51
52 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
53 return(c);
54 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
55 }
56
57
58 int
59 cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */
60 register PACKHEAD *cb1, *cb2;
61 {
62 register int c;
63
64 if (!cb1->nr) /* put orphans at the end, unsorted */
65 return(cb2->nr);
66 if (!cb2->nr)
67 return(-1);
68 if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */
69 return(c);
70 return(cb1->hd - cb2->hd); /* use hd to resolve matches */
71 }
72
73
74 int
75 findcbeam(hd, bi) /* find the specified beam in our sorted list */
76 int hd, bi;
77 {
78 PACKHEAD cb;
79 register PACKHEAD *p;
80
81 if (ncbeams <= 0)
82 return(-1);
83 cb.hd = hd; cb.bi = bi; cb.nr = cb.nc = 0;
84 p = (PACKHEAD *)bsearch((char *)&cb, (char *)cbeam, ncbeams,
85 sizeof(PACKHEAD), cbeamcmp);
86 if (p == NULL)
87 return(-1);
88 return(p - cbeam);
89 }
90
91
92 int
93 getcbeam(hd, bi) /* get the specified beam, allocating as necessary */
94 register int hd;
95 int bi;
96 {
97 register int n;
98 /* first, look in sorted list */
99 if ((n = findcbeam(hd, bi)) >= 0)
100 return(n);
101 /* linear search through xcbeams to be sure */
102 for (n = ncbeams+xcbeams; n-- > ncbeams; )
103 if (cbeam[n].bi == bi && cbeam[n].hd == hd)
104 return(n);
105 /* check legality */
106 if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL)
107 error(INTERNAL, "illegal holodeck number in getcbeam");
108 if (bi < 1 | bi > nbeams(hdlist[hd]))
109 error(INTERNAL, "illegal beam index in getcbeam");
110 n = newcbeam(); /* allocate and assign */
111 cbeam[n].hd = hd; cbeam[n].bi = bi; cbeam[n].nr = cbeam[n].nc = 0;
112 return(n);
113 }
114
115
116 cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */
117 int adopt;
118 {
119 register int i;
120
121 if (!(ncbeams += xcbeams))
122 return;
123 xcbeams = 0;
124 qsort((char *)cbeam, ncbeams, sizeof(PACKHEAD),
125 adopt ? cbeamcmp : cbeamcmp2);
126 if (adopt)
127 return;
128 for (i = ncbeams; i--; ) /* identify orphans */
129 if (cbeam[i].nr)
130 break;
131 xcbeams = ncbeams - ++i; /* put orphans after ncbeams */
132 ncbeams = i;
133 }
134
135
136 beam_init(fresh) /* clear beam list for new view(s) */
137 int fresh;
138 {
139 register int i;
140
141 if (fresh) /* discard old beams? */
142 ncbeams = xcbeams = 0;
143 else /* else clear sample requests */
144 for (i = ncbeams+xcbeams; i--; )
145 cbeam[i].nr = 0;
146 cureye.rng = 0.;
147 }
148
149
150 int16 *
151 beam_view(vn, hr, vr) /* add beam view (if advisable) */
152 VIEW *vn;
153 int hr, vr;
154 {
155 int16 *slist;
156 BEAMLIST blist;
157 double eravg, d;
158 register HOLO *hp;
159 register int i, n;
160 /* compute beams for view */
161 slist = viewbeams(vn, hr, vr, &blist);
162 if (*slist < 0) {
163 error(COMMAND, "no sections visible from this view");
164 return(NULL);
165 }
166 /* sort current beam list */
167 cbeamsort(1);
168 /* add new beams to list */
169 for (i = blist.nb; i--; ) {
170 n = getcbeam(blist.bl[i].hd, blist.bl[i].bi);
171 if (blist.bl[i].nr > cbeam[n].nr)
172 cbeam[n].nr = blist.bl[i].nr;
173 }
174 free((void *)blist.bl); /* free list */
175 if (MEYERNG <= FTINY)
176 return(slist);
177 /* compute average eye range */
178 eravg = 0.;
179 for (n = 0; slist[n] >= 0; n++) {
180 hp = hdlist[slist[n]];
181 eravg += MEYERNG/3. / VLEN(hp->wg[0]) +
182 MEYERNG/3. / VLEN(hp->wg[1]) +
183 MEYERNG/3. / VLEN(hp->wg[2]) ;
184 }
185 eravg /= (double)n;
186 /* add to current eye position */
187 if (cureye.rng <= FTINY) {
188 VCOPY(cureye.vpt, vn->vp);
189 cureye.rng = eravg;
190 } else if ((d = sqrt(dist2(vn->vp,cureye.vpt))) + eravg > cureye.rng) {
191 for (i = 3; i--; )
192 cureye.vpt[i] = 0.5*(cureye.vpt[i] + vn->vp[i]);
193 cureye.rng = 0.5*(cureye.rng + eravg + d);
194 }
195 return(slist);
196 }
197
198
199 int
200 beam_sync(all) /* update beam list on server */
201 int all;
202 {
203 /* set new eye position */
204 serv_request(DR_VIEWPOINT, sizeof(VIEWPOINT), (char *)&cureye);
205 /* sort list (put orphans at end) */
206 cbeamsort(all < 0);
207 /* send beam request */
208 if (all) {
209 if (ncbeams > 0)
210 serv_request(DR_NEWSET,
211 ncbeams*sizeof(PACKHEAD), cbeam);
212 } else {
213 if (ncbeams+xcbeams > 0)
214 serv_request(DR_ADJSET,
215 (ncbeams+xcbeams)*sizeof(PACKHEAD), cbeam);
216 }
217 xcbeams = 0; /* truncate our list */
218 return(ncbeams);
219 }
220
221
222 gridlines(f) /* run through holodeck section grid lines */
223 int (*f)();
224 {
225 register int hd, w, i;
226 int g0, g1;
227 FVECT wp[2], mov;
228 double d;
229 /* do each wall on each section */
230 for (hd = 0; hdlist[hd] != NULL; hd++)
231 for (w = 0; w < 6; w++) {
232 g0 = hdwg0[w];
233 g1 = hdwg1[w];
234 d = 1.0/hdlist[hd]->grid[g0];
235 mov[0] = d * hdlist[hd]->xv[g0][0];
236 mov[1] = d * hdlist[hd]->xv[g0][1];
237 mov[2] = d * hdlist[hd]->xv[g0][2];
238 if (w & 1) {
239 VSUM(wp[0], hdlist[hd]->orig,
240 hdlist[hd]->xv[w>>1], 1.);
241 VSUM(wp[0], wp[0], mov, 1.);
242 } else
243 VCOPY(wp[0], hdlist[hd]->orig);
244 VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
245 for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
246 (*f)(wp);
247 if (!--i) break;
248 wp[0][0] += mov[0]; wp[0][1] += mov[1];
249 wp[0][2] += mov[2]; wp[1][0] += mov[0];
250 wp[1][1] += mov[1]; wp[1][2] += mov[2];
251 }
252 d = 1.0/hdlist[hd]->grid[g1];
253 mov[0] = d * hdlist[hd]->xv[g1][0];
254 mov[1] = d * hdlist[hd]->xv[g1][1];
255 mov[2] = d * hdlist[hd]->xv[g1][2];
256 if (w & 1)
257 VSUM(wp[0], hdlist[hd]->orig,
258 hdlist[hd]->xv[w>>1], 1.);
259 else
260 VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
261 VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
262 for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
263 (*f)(wp);
264 if (!--i) break;
265 wp[0][0] += mov[0]; wp[0][1] += mov[1];
266 wp[0][2] += mov[2]; wp[1][0] += mov[0];
267 wp[1][1] += mov[1]; wp[1][2] += mov[2];
268 }
269 }
270 }
