| 1 |
schorsch |
3.17 |
/* RCSid $Id: rhd_qtree.h,v 3.16 2003/07/14 22:24:00 schorsch Exp $ */ |
| 2 |
gregl |
3.1 |
| 3 |
* Quadtree data structures for holodeck display drivers. |
| 4 |
| 5 |
schorsch |
3.16 |
#ifndef _RAD_RHD_QTREE_H_ |
| 6 |
#define _RAD_RHD_QTREE_H_ |
| 7 |
gregl |
3.1 |
| 8 |
gwlarson |
3.11 |
#include "color.h" |
| 9 |
gregl |
3.1 |
#include "tonemap.h" |
| 10 |
#include "rhdriver.h" |
| 11 |
gregl |
3.7 |
| 12 |
schorsch |
3.16 |
#ifdef __cplusplus |
| 13 |
extern "C" { |
| 14 |
#endif |
| 15 |
| 16 |
gregl |
3.1 |
#define DL 0 /* down left */ |
| 17 |
#define DR 1 /* down right */ |
| 18 |
#define UL 2 /* up left */ |
| 19 |
#define UR 3 /* up right */ |
| 20 |
| 21 |
gregl |
3.3 |
#define BRF(i) (0x1<<(i)) /* branch flag bit */ |
| 22 |
#define LFF(i) (0x10<<(i)) /* leaf flag bit */ |
| 23 |
#define CHF(i) (0x100<<(i)) /* change flag bit */ |
| 24 |
#define CHBRF(i) (0x101<<(i)) /* changed branch bit */ |
| 25 |
#define CHLFF(i) (0x110<<(i)) /* changed leaf bit */ |
| 26 |
#define BR_ANY 0xf /* flags for any branches */ |
| 27 |
#define LF_ANY 0xf0 /* flags for any leaves */ |
| 28 |
#define CH_ANY 0xf00 /* flags for any change */ |
| 29 |
gregl |
3.1 |
| 30 |
typedef struct rtree { |
| 31 |
gregl |
3.3 |
short flgs; /* content flags (defined above) */ |
| 32 |
gregl |
3.1 |
union { |
| 33 |
struct rtree *b; /* if branch */ |
| 34 |
gregl |
3.3 |
int li; /* if leaf */ |
| 35 |
gregl |
3.1 |
} k[4]; /* children */ |
| 36 |
} RTREE; |
| 37 |
| 38 |
gregl |
3.3 |
extern struct rleaves { |
| 39 |
float (*wp)[3]; /* world intersection point array */ |
| 40 |
greg |
3.15 |
int32 *wd; /* world direction array */ |
| 41 |
gregl |
3.3 |
TMbright *brt; /* encoded brightness array */ |
| 42 |
BYTE (*chr)[3]; /* encoded chrominance array */ |
| 43 |
BYTE (*rgb)[3]; /* tone-mapped color array */ |
| 44 |
int nl; /* count of leaves in our pile */ |
| 45 |
int bl, tl; /* bottom and top (next) leaf index */ |
| 46 |
int tml; /* next leaf needing tone-mapping */ |
| 47 |
char *base; /* base of allocated memory */ |
| 48 |
} qtL; /* our pile of leaves */ |
| 49 |
| 50 |
gregl |
3.5 |
#define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY))) |
| 51 |
| 52 |
gregl |
3.1 |
extern RTREE qtrunk; /* trunk of quadtree */ |
| 53 |
extern double qtDepthEps; /* epsilon to compare depths (z fraction) */ |
| 54 |
extern int qtMinNodesiz; /* minimum node dimension (pixels) */ |
| 55 |
gregl |
3.8 |
| 56 |
gregl |
3.9 |
extern int rayqleft; /* number of rays to queue before flush */ |
| 57 |
| 58 |
schorsch |
3.17 |
| 59 |
greg |
3.15 |
extern int32 encodedir(); |
| 60 |
gregl |
3.8 |
extern double fdir2diff(), dir2diff(); |
| 61 |
schorsch |
3.17 |
| 62 |
| 63 |
/* rhd_qtree.c */ |
| 64 |
extern int qtAllocLeaves(register int n); |
| 65 |
extern void qtFreeLeaves(void); |
| 66 |
extern int qtCompost(int pct); |
| 67 |
extern void qtReplant(void); |
| 68 |
extern int qtFindLeaf(int x, int y); |
| 69 |
extern int qtMapLeaves(int redo); |
| 70 |
/* rhd_qtree2c.c rhd_qtree2r.c */ |
| 71 |
extern void qtRedraw(int x0, int y0, int x1, int y1); |
| 72 |
extern void qtUpdate(void); |
| 73 |
schorsch |
3.16 |
| 74 |
| 75 |
| 76 |
#endif |
| 77 |
#endif /* _RAD_RHD_QTREE_H_ */ |
| 78 |
