| 1 |
gregl |
3.1 |
#ifndef lint
| 2 |
greg |
3.30 |
static const char RCSid[] = "$Id: rhd_qtree.c,v 3.29 2018/10/05 19:19:16 greg Exp $";
| 3 |
gregl |
3.1 |
#endif
| 4 |
| 5 |
* Quadtree driver support routines.
| 6 |
| 7 |
| 8 |
schorsch |
3.23 |
#include <string.h>
| 9 |
| 10 |
gregl |
3.1 |
#include "standard.h"
| 11 |
#include "rhd_qtree.h"
| 12 |
gregl |
3.6 |
/* quantity of leaves to free at a time */
| 13 |
#ifndef LFREEPCT
| 14 |
#define LFREEPCT 25
| 15 |
#endif
| 16 |
gregl |
3.10 |
/* maximum allowed angle difference (deg.) */
| 17 |
#ifndef MAXANG
| 18 |
gregl |
3.12 |
#define MAXANG 20
| 19 |
gregl |
3.10 |
#endif
| 20 |
gregl |
3.12 |
#if MAXANG>0
| 21 |
#define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.))
| 22 |
#endif
| 23 |
gregl |
3.1 |
| 24 |
gregl |
3.10 |
#define abs(i) ((i) < 0 ? -(i) : (i))
| 25 |
| 26 |
gregl |
3.2 |
RTREE qtrunk; /* our quadtree trunk */
| 27 |
gregl |
3.10 |
double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */
| 28 |
gregl |
3.2 |
int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
| 29 |
gregl |
3.5 |
struct rleaves qtL; /* our pile of leaves */
| 30 |
gregl |
3.2 |
| 31 |
gregl |
3.17 |
int rayqleft = 0; /* rays left to queue before flush */
| 32 |
| 33 |
greg |
3.22 |
static int32 falleaves; /* our list of fallen leaves */
| 34 |
gregl |
3.15 |
| 35 |
#define composted(li) (qtL.bl <= qtL.tl ? \
| 36 |
((li) < qtL.bl || (li) >= qtL.tl) : \
| 37 |
((li) < qtL.bl && (li) >= qtL.tl))
| 38 |
| 39 |
gregl |
3.1 |
#define TBUNDLESIZ 409 /* number of twigs in a bundle */
| 40 |
| 41 |
static RTREE **twigbundle; /* free twig blocks (NULL term.) */
| 42 |
static int nexttwig; /* next free twig */
| 43 |
| 44 |
schorsch |
3.25 |
static RTREE *newtwig(void);
| 45 |
static void qtFreeTree(int really);
| 46 |
static void shaketree(RTREE *tp);
| 47 |
static int putleaf(int li, int drop);
| 48 |
| 49 |
gregl |
3.1 |
| 50 |
static RTREE *
| 51 |
schorsch |
3.25 |
newtwig(void) /* allocate a twig */
| 52 |
gregl |
3.1 |
| 53 |
greg |
3.29 |
int bi;
| 54 |
gregl |
3.1 |
| 55 |
if (twigbundle == NULL) { /* initialize */
| 56 |
twigbundle = (RTREE **)malloc(sizeof(RTREE *));
| 57 |
| 58 |
goto memerr;
| 59 |
twigbundle[0] = NULL;
| 60 |
| 61 |
bi = nexttwig / TBUNDLESIZ;
| 62 |
if (twigbundle[bi] == NULL) { /* new block */
| 63 |
greg |
3.21 |
twigbundle = (RTREE **)realloc((void *)twigbundle,
| 64 |
gregl |
3.1 |
(bi+2)*sizeof(RTREE *));
| 65 |
| 66 |
goto memerr;
| 67 |
twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
| 68 |
| 69 |
goto memerr;
| 70 |
twigbundle[bi+1] = NULL;
| 71 |
| 72 |
/* nexttwig++ % TBUNDLESIZ */
| 73 |
return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
| 74 |
memerr:
| 75 |
error(SYSTEM, "out of memory in newtwig");
| 76 |
schorsch |
3.25 |
return NULL; /* pro forma return */
| 77 |
gregl |
3.1 |
| 78 |
| 79 |
| 80 |
schorsch |
3.25 |
static void
| 81 |
qtFreeTree( /* free allocated twigs */
| 82 |
int really
| 83 |
| 84 |
gregl |
3.1 |
| 85 |
greg |
3.29 |
int i;
| 86 |
gregl |
3.1 |
| 87 |
gregl |
3.7 |
qtrunk.flgs = CH_ANY; /* chop down tree */
| 88 |
gregl |
3.1 |
| 89 |
return;
| 90 |
gregl |
3.7 |
i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ;
| 91 |
nexttwig = 0;
| 92 |
gregl |
3.1 |
if (!really) { /* just clear allocated blocks */
| 93 |
gregl |
3.7 |
while (i--)
| 94 |
schorsch |
3.23 |
memset((char *)twigbundle[i], '\0', TBUNDLESIZ*sizeof(RTREE));
| 95 |
gregl |
3.1 |
return;
| 96 |
| 97 |
/* else "really" means free up memory */
| 98 |
for (i = 0; twigbundle[i] != NULL; i++)
| 99 |
greg |
3.19 |
free((void *)twigbundle[i]);
| 100 |
free((void *)twigbundle);
| 101 |
gregl |
3.1 |
twigbundle = NULL;
| 102 |
| 103 |
| 104 |
| 105 |
greg |
3.22 |
#define LEAFSIZ (3*sizeof(float)+sizeof(int32)+\
| 106 |
greg |
3.27 |
sizeof(TMbright)+6*sizeof(uby8))
| 107 |
gregl |
3.5 |
| 108 |
greg |
3.29 |
int
| 109 |
schorsch |
3.25 |
qtAllocLeaves( /* allocate space for n leaves */
| 110 |
greg |
3.29 |
int n
| 111 |
schorsch |
3.25 |
| 112 |
gregl |
3.1 |
| 113 |
unsigned nbytes;
| 114 |
greg |
3.29 |
unsigned i;
| 115 |
gregl |
3.1 |
| 116 |
gregl |
3.3 |
qtFreeTree(0); /* make sure tree is empty */
| 117 |
gregl |
3.1 |
if (n <= 0)
| 118 |
return(0);
| 119 |
gregl |
3.5 |
if (qtL.nl >= n)
| 120 |
return(qtL.nl);
| 121 |
else if (qtL.nl > 0)
| 122 |
free(qtL.base);
| 123 |
gregl |
3.1 |
/* round space up to nearest power of 2 */
| 124 |
gregl |
3.5 |
nbytes = n*LEAFSIZ + 8;
| 125 |
gregl |
3.1 |
for (i = 1024; nbytes > i; i <<= 1)
| 126 |
| 127 |
gregl |
3.5 |
n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
| 128 |
qtL.base = (char *)malloc(n*LEAFSIZ);
| 129 |
if (qtL.base == NULL)
| 130 |
return(0);
| 131 |
/* assign larger alignment types earlier */
| 132 |
qtL.wp = (float (*)[3])qtL.base;
| 133 |
greg |
3.22 |
qtL.wd = (int32 *)(qtL.wp + n);
| 134 |
gregl |
3.10 |
qtL.brt = (TMbright *)(qtL.wd + n);
| 135 |
greg |
3.27 |
qtL.chr = (uby8 (*)[3])(qtL.brt + n);
| 136 |
qtL.rgb = (uby8 (*)[3])(qtL.chr + n);
| 137 |
gregl |
3.5 |
qtL.nl = n;
| 138 |
qtL.tml = qtL.bl = qtL.tl = 0;
| 139 |
gregl |
3.15 |
falleaves = -1;
| 140 |
gregl |
3.5 |
return(n);
| 141 |
gregl |
3.1 |
| 142 |
| 143 |
gregl |
3.5 |
#undef LEAFSIZ
| 144 |
gregl |
3.1 |
| 145 |
gregl |
3.5 |
| 146 |
greg |
3.29 |
void
| 147 |
schorsch |
3.25 |
qtFreeLeaves(void) /* free our allocated leaves and twigs */
| 148 |
gregl |
3.1 |
| 149 |
gregl |
3.3 |
qtFreeTree(1); /* free tree also */
| 150 |
gregl |
3.5 |
if (qtL.nl <= 0)
| 151 |
gregl |
3.1 |
return;
| 152 |
gregl |
3.5 |
free(qtL.base);
| 153 |
qtL.base = NULL;
| 154 |
qtL.nl = 0;
| 155 |
gregl |
3.1 |
| 156 |
| 157 |
| 158 |
schorsch |
3.25 |
static void
| 159 |
shaketree( /* shake dead leaves from tree */
| 160 |
greg |
3.29 |
RTREE *tp
| 161 |
schorsch |
3.25 |
| 162 |
gregl |
3.1 |
| 163 |
greg |
3.29 |
int i, li;
| 164 |
gregl |
3.1 |
| 165 |
for (i = 0; i < 4; i++)
| 166 |
gregl |
3.5 |
if (tp->flgs & BRF(i)) {
| 167 |
gregl |
3.2 |
shaketree(tp->k[i].b);
| 168 |
gregl |
3.5 |
if (is_stump(tp->k[i].b))
| 169 |
tp->flgs &= ~BRF(i);
| 170 |
} else if (tp->flgs & LFF(i)) {
| 171 |
li = tp->k[i].li;
| 172 |
gregl |
3.15 |
if (composted(li))
| 173 |
gregl |
3.5 |
tp->flgs &= ~LFF(i);
| 174 |
gregl |
3.1 |
| 175 |
| 176 |
| 177 |
| 178 |
greg |
3.29 |
int
| 179 |
schorsch |
3.25 |
qtCompost( /* free up some leaves */
| 180 |
int pct
| 181 |
| 182 |
gregl |
3.1 |
| 183 |
greg |
3.29 |
int32 *fl;
| 184 |
gregl |
3.5 |
int nused, nclear, nmapped;
| 185 |
gregl |
3.1 |
/* figure out how many leaves to clear */
| 186 |
gregl |
3.5 |
nclear = qtL.nl * pct / 100;
| 187 |
nused = qtL.tl - qtL.bl;
| 188 |
if (nused <= 0) nused += qtL.nl;
| 189 |
nclear -= qtL.nl - nused;
| 190 |
gregl |
3.1 |
if (nclear <= 0)
| 191 |
return(0);
| 192 |
if (nclear >= nused) { /* clear them all */
| 193 |
gregl |
3.3 |
qtFreeTree(0);
| 194 |
gregl |
3.5 |
| 195 |
gregl |
3.15 |
falleaves = -1;
| 196 |
gregl |
3.1 |
return(nused);
| 197 |
| 198 |
/* else clear leaves from bottom */
| 199 |
gregl |
3.5 |
nmapped = qtL.tml - qtL.bl;
| 200 |
if (nmapped < 0) nmapped += qtL.nl;
| 201 |
qtL.bl += nclear;
| 202 |
if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
| 203 |
if (nmapped <= nclear) qtL.tml = qtL.bl;
| 204 |
gregl |
3.15 |
shaketree(&qtrunk); /* dereference composted leaves */
| 205 |
for (fl = &falleaves; *fl >= 0; fl = qtL.wd + *fl)
| 206 |
while (composted(*fl))
| 207 |
if ((*fl = qtL.wd[*fl]) < 0)
| 208 |
return(nclear);
| 209 |
gregl |
3.1 |
return(nclear);
| 210 |
| 211 |
| 212 |
| 213 |
greg |
3.29 |
int
| 214 |
schorsch |
3.25 |
qtFindLeaf( /* find closest leaf to (x,y) */
| 215 |
int x,
| 216 |
int y
| 217 |
| 218 |
gregl |
3.3 |
| 219 |
greg |
3.29 |
RTREE *tp = &qtrunk;
| 220 |
gregl |
3.5 |
int li = -1;
| 221 |
gregl |
3.3 |
int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
| 222 |
int mx, my;
| 223 |
greg |
3.29 |
int q;
| 224 |
gregl |
3.3 |
/* check limits */
| 225 |
if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
| 226 |
gregl |
3.5 |
return(-1);
| 227 |
gregl |
3.3 |
/* find nearby leaf in our tree */
| 228 |
for ( ; ; ) {
| 229 |
for (q = 0; q < 4; q++) /* find any leaf this level */
| 230 |
gregl |
3.5 |
if (tp->flgs & LFF(q)) {
| 231 |
li = tp->k[q].li;
| 232 |
gregl |
3.3 |
break;
| 233 |
| 234 |
q = 0; /* which quadrant are we? */
| 235 |
mx = (x0 + x1) >> 1;
| 236 |
my = (y0 + y1) >> 1;
| 237 |
if (x < mx) x1 = mx;
| 238 |
else {x0 = mx; q |= 01;}
| 239 |
if (y < my) y1 = my;
| 240 |
else {y0 = my; q |= 02;}
| 241 |
if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
| 242 |
tp = tp->k[q].b;
| 243 |
continue;
| 244 |
| 245 |
gregl |
3.5 |
if (tp->flgs & LFF(q)) /* good shot! */
| 246 |
return(tp->k[q].li);
| 247 |
return(li); /* else return what we have */
| 248 |
gregl |
3.3 |
| 249 |
| 250 |
| 251 |
| 252 |
schorsch |
3.25 |
static int
| 253 |
putleaf( /* put a leaf in our tree */
| 254 |
greg |
3.29 |
int li,
| 255 |
schorsch |
3.25 |
int drop
| 256 |
| 257 |
gregl |
3.1 |
| 258 |
greg |
3.29 |
| 259 |
gregl |
3.1 |
| 260 |
greg |
3.29 |
int lo = -1;
| 261 |
gregl |
3.11 |
double d2;
| 262 |
gregl |
3.1 |
int x, y, mx, my;
| 263 |
double z;
| 264 |
gregl |
3.11 |
FVECT ip, wp, vd;
| 265 |
greg |
3.29 |
int q;
| 266 |
gregl |
3.15 |
/* check for dead leaf */
| 267 |
if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2]))
| 268 |
return(0);
| 269 |
gregl |
3.10 |
/* compute leaf location in view */
| 270 |
gregl |
3.5 |
VCOPY(wp, qtL.wp[li]);
| 271 |
greg |
3.30 |
if (viewloc(ip, &odev.v, wp) != VL_GOOD)
| 272 |
gregl |
3.15 |
goto dropit; /* behind or outside view */
| 273 |
gregl |
3.10 |
#ifdef DEBUG
| 274 |
if (odev.v.type == VT_PAR | odev.v.vfore > FTINY)
| 275 |
gregl |
3.15 |
error(INTERNAL, "bad view assumption in putleaf");
| 276 |
gregl |
3.10 |
#endif
| 277 |
for (q = 0; q < 3; q++)
| 278 |
gregl |
3.11 |
vd[q] = (wp[q] - odev.v.vp[q])/ip[2];
| 279 |
d2 = fdir2diff(qtL.wd[li], vd);
| 280 |
gregl |
3.12 |
#ifdef MAXDIFF2
| 281 |
gregl |
3.10 |
if (d2 > MAXDIFF2)
| 282 |
gregl |
3.15 |
goto dropit; /* leaf dir. too far off */
| 283 |
gregl |
3.12 |
#endif
| 284 |
gregl |
3.1 |
x = ip[0] * odev.hres;
| 285 |
y = ip[1] * odev.vres;
| 286 |
z = ip[2];
| 287 |
/* find the place for it */
| 288 |
for ( ; ; ) {
| 289 |
q = 0; /* which quadrant? */
| 290 |
| 291 |
| 292 |
| 293 |
| 294 |
| 295 |
| 296 |
if (tp->flgs & BRF(q)) { /* move to next branch */
| 297 |
tp->flgs |= CHF(q); /* not sure; guess */
| 298 |
tp = tp->k[q].b;
| 299 |
continue;
| 300 |
| 301 |
gregl |
3.5 |
if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
| 302 |
tp->k[q].li = li;
| 303 |
tp->flgs |= CHLFF(q);
| 304 |
gregl |
3.15 |
return(1);
| 305 |
gregl |
3.1 |
| 306 |
gregl |
3.10 |
if (lo != tp->k[q].li) { /* check old leaf */
| 307 |
gregl |
3.5 |
lo = tp->k[q].li;
| 308 |
VCOPY(wp, qtL.wp[lo]);
| 309 |
gregl |
3.1 |
viewloc(ip, &odev.v, wp);
| 310 |
| 311 |
/* is node minimum size? */
| 312 |
gregl |
3.10 |
if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
| 313 |
if (z > (1.+qtDepthEps)*ip[2])
| 314 |
gregl |
3.15 |
break; /* old one closer */
| 315 |
gregl |
3.10 |
if (z >= (1.-qtDepthEps)*ip[2] &&
| 316 |
gregl |
3.11 |
fdir2diff(qtL.wd[lo], vd) < d2)
| 317 |
gregl |
3.15 |
break; /* old one better */
| 318 |
tp->k[q].li = li; /* attach new */
| 319 |
gregl |
3.1 |
tp->flgs |= CHF(q);
| 320 |
gregl |
3.15 |
li = lo; /* drop old... */
| 321 |
gregl |
3.1 |
break;
| 322 |
| 323 |
gregl |
3.5 |
tp->flgs &= ~LFF(q); /* else grow tree */
| 324 |
tp->flgs |= CHBRF(q);
| 325 |
gregl |
3.1 |
tp = tp->k[q].b = newtwig();
| 326 |
q = 0; /* old leaf -> new branch */
| 327 |
mx = ip[0] * odev.hres;
| 328 |
my = ip[1] * odev.vres;
| 329 |
if (mx >= (x0 + x1) >> 1) q |= 01;
| 330 |
if (my >= (y0 + y1) >> 1) q |= 02;
| 331 |
gregl |
3.11 |
tp->flgs = CH_ANY|LFF(q); /* all new */
| 332 |
gregl |
3.5 |
tp->k[q].li = lo;
| 333 |
gregl |
3.1 |
| 334 |
gregl |
3.15 |
dropit:
| 335 |
schorsch |
3.24 |
if (drop) {
| 336 |
gregl |
3.16 |
if (li+1 == (qtL.tl ? qtL.tl : qtL.nl))
| 337 |
qtL.tl = li; /* special case */
| 338 |
else {
| 339 |
qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0;
| 340 |
qtL.wd[li] = falleaves;
| 341 |
falleaves = li;
| 342 |
| 343 |
schorsch |
3.24 |
| 344 |
gregl |
3.15 |
return(li == lo);
| 345 |
gregl |
3.1 |
| 346 |
| 347 |
| 348 |
greg |
3.29 |
void
| 349 |
schorsch |
3.25 |
dev_value( /* add a pixel value to our quadtree */
| 350 |
COLR c,
| 351 |
FVECT d,
| 352 |
FVECT p
| 353 |
| 354 |
gregl |
3.1 |
| 355 |
greg |
3.29 |
int li;
| 356 |
gregl |
3.15 |
int mapit;
| 357 |
/* grab a leaf */
| 358 |
gregl |
3.16 |
if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */
| 359 |
gregl |
3.15 |
li = falleaves;
| 360 |
falleaves = qtL.wd[li];
| 361 |
mapit = qtL.tml <= qtL.tl ?
| 362 |
(li < qtL.tml || li >= qtL.tl) :
| 363 |
(li < qtL.tml && li >= qtL.tl) ;
| 364 |
gregl |
3.16 |
} else { /* else allocate new one */
| 365 |
gregl |
3.15 |
li = qtL.tl++;
| 366 |
gregl |
3.16 |
if (qtL.tl >= qtL.nl) /* next leaf in ring */
| 367 |
gregl |
3.15 |
qtL.tl = 0;
| 368 |
gregl |
3.16 |
if (qtL.tl == qtL.bl) /* need to shake some free */
| 369 |
gregl |
3.15 |
qtCompost(LFREEPCT);
| 370 |
gregl |
3.16 |
mapit = 0; /* we'll map it later */
| 371 |
gregl |
3.15 |
| 372 |
gwlarson |
3.18 |
if (p == NULL)
| 373 |
VSUM(qtL.wp[li], odev.v.vp, d, FHUGE);
| 374 |
else
| 375 |
VCOPY(qtL.wp[li], p);
| 376 |
qtL.wd[li] = encodedir(d);
| 377 |
greg |
3.26 |
tmCvColrs(tmGlobal, &qtL.brt[li], qtL.chr[li], (COLR *)c, 1);
| 378 |
gregl |
3.17 |
if (putleaf(li, 1)) {
| 379 |
if (mapit)
| 380 |
greg |
3.27 |
tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+li), qtL.brt+li,
| 381 |
(uby8 *)(qtL.chr+li), 1);
| 382 |
gregl |
3.17 |
if (--rayqleft == 0)
| 383 |
dev_flush(); /* flush output */
| 384 |
| 385 |
gregl |
3.1 |
| 386 |
| 387 |
| 388 |
greg |
3.29 |
void
| 389 |
schorsch |
3.25 |
qtReplant(void) /* replant our tree using new view */
| 390 |
gregl |
3.1 |
| 391 |
greg |
3.29 |
int i;
| 392 |
gregl |
3.5 |
/* anything to replant? */
| 393 |
if (qtL.bl == qtL.tl)
| 394 |
gregl |
3.1 |
return;
| 395 |
gregl |
3.5 |
qtFreeTree(0); /* blow the old tree away */
| 396 |
/* regrow it in new place */
| 397 |
for (i = qtL.bl; i != qtL.tl; ) {
| 398 |
gregl |
3.15 |
putleaf(i, 0);
| 399 |
gregl |
3.5 |
if (++i >= qtL.nl) i = 0;
| 400 |
gregl |
3.1 |
| 401 |
| 402 |
| 403 |
| 404 |
greg |
3.29 |
int
| 405 |
schorsch |
3.25 |
qtMapLeaves( /* map our leaves to RGB */
| 406 |
int redo
| 407 |
| 408 |
gregl |
3.5 |
| 409 |
int aorg, alen, borg, blen;
| 410 |
gregl |
3.6 |
/* recompute mapping? */
| 411 |
if (redo)
| 412 |
qtL.tml = qtL.bl;
| 413 |
gregl |
3.5 |
/* already done? */
| 414 |
if (qtL.tml == qtL.tl)
| 415 |
return(1);
| 416 |
/* compute segments */
| 417 |
aorg = qtL.tml;
| 418 |
if (qtL.tl >= aorg) {
| 419 |
alen = qtL.tl - aorg;
| 420 |
blen = 0;
| 421 |
} else {
| 422 |
alen = qtL.nl - aorg;
| 423 |
borg = 0;
| 424 |
blen = qtL.tl;
| 425 |
| 426 |
/* (re)compute tone mapping? */
| 427 |
if (qtL.tml == qtL.bl) {
| 428 |
greg |
3.26 |
tmClearHisto(tmGlobal);
| 429 |
tmAddHisto(tmGlobal, qtL.brt+aorg, alen, 1);
| 430 |
gregl |
3.5 |
if (blen > 0)
| 431 |
greg |
3.26 |
tmAddHisto(tmGlobal, qtL.brt+borg, blen, 1);
| 432 |
if (tmComputeMapping(tmGlobal, 0., 0., 0.) != TM_E_OK)
| 433 |
gregl |
3.5 |
return(0);
| 434 |
| 435 |
greg |
3.27 |
if (tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+aorg), qtL.brt+aorg,
| 436 |
(uby8 *)(qtL.chr+aorg), alen) != TM_E_OK)
| 437 |
gregl |
3.5 |
return(0);
| 438 |
if (blen > 0)
| 439 |
greg |
3.27 |
tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+borg), qtL.brt+borg,
| 440 |
(uby8 *)(qtL.chr+borg), blen);
| 441 |
gregl |
3.5 |
qtL.tml = qtL.tl;
| 442 |
return(1);
| 443 |
gregl |
3.1 |
