root/radiance/src/hd/rhd_ogl.c
Revision: 3.33
Committed: Fri Oct 5 19:19:16 2018 UTC (7 years ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 3.32: +11 -11 lines
2 static const char RCSid[] = "$Id: rhd_ogl.c,v 3.32 2016/04/28 16:28:20 greg Exp $";
5 * OpenGL driver for holodeck display.
6 * Based on GLX driver using T-mesh.
7 *
8 * Define symbol STEREO for stereo viewing.
9 * Define symbol DOBJ for display object viewing.
10 */
11
12 #ifdef NOSTEREO
13 #ifdef STEREO
14 #undef STEREO
15 #else
16 #undef NOSTEREO
17 #endif
18 #endif
19
20
21 #include <time.h>
22 #include <GL/glx.h>
23 #include <GL/glu.h>
24 #ifdef STEREO
25 #include <X11/extensions/SGIStereo.h>
26 #endif
27
28 #include "standard.h"
29 #include "rhd_odraw.h"
30 #include "rhdisp.h"
31 #include "paths.h"
32 #ifdef DOBJ
33 #include "rhdobj.h"
34 #endif
35
36 #include "x11icon.h"
37
38 #ifndef RAYQLEN
39 #define RAYQLEN 0 /* max. rays to queue before flush */
40 #endif
41 #ifndef MINWIDTH
42 #define MINWIDTH 480 /* minimum graphics window width */
43 #define MINHEIGHT 400 /* minimum graphics window height */
44 #endif
45 #ifndef VIEWDIST
46 #define VIEWDIST 356 /* assumed viewing distance (mm) */
47 #endif
48 #ifndef BORWIDTH
49 #define BORWIDTH 5 /* border width */
50 #endif
51
52 #ifndef FEQ
53 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
54 #endif
55
56 #define VWHEADLOCK 01 /* head position is locked flag */
57 #define VWPERSP 02 /* perspective view is set */
58 #define VWORTHO 04 /* orthographic view is set */
59 #define VWCHANGE 010 /* view has changed */
60 #define VWSTEADY 020 /* view is now steady */
61 #define VWMAPPED 040 /* window is mapped */
62
63 #define GAMMA 1.4 /* default gamma correction */
64
65 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
66
67 #define MOVPCT 7 /* percent distance to move /frame */
68 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
69 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
70 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
71
72 #define setstereobuf(bid) (glXWaitGL(), \
73 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
74 glXWaitX())
75
76 #define ourscreen DefaultScreen(ourdisplay)
77 #define ourroot RootWindow(ourdisplay,ourscreen)
78 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
79 ButtonPressMask|ButtonReleaseMask)
80
81 #define levptr(etype) ((etype *)&currentevent)
82
83 struct driver odev; /* global device driver structure */
84
85 TMstruct *tmGlobal; /* global tone-mapping structure */
86
87 char odev_args[64]; /* command arguments */
88
89 static GLfloat *depthbuffer = NULL; /* depth buffer */
90
91 #ifdef STEREO
92 static VIEW vwright; /* right eye view */
93 static GLfloat *depthright = NULL; /* right depth buffer */
94 #endif
95
96 static int rayqleft = 0; /* rays left to queue before flush */
97
98 static XEvent currentevent; /* current event */
99
100 static unsigned long ourblack=0, ourwhite=~0;
101
102 static Display *ourdisplay = NULL; /* our display */
103 static XVisualInfo *ourvinf; /* our visual information */
104 static Window gwind = 0; /* our graphics window */
105 static GLXContext gctx; /* our GLX context */
106
107 static double pwidth, pheight; /* pixel dimensions (mm) */
108
109 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
110 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
111
112 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
113 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
114
115 static int inpresflags; /* input result flags */
116
117 static int viewflags; /* what's happening with view */
118
119 /*
120 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
121 xferdepth(), freedepth(), setglortho(),
122 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
123
124 static double getdistance();
125 */
126 static void checkglerr(char *where);
127 static void xferdepth(void);
128 static void freedepth(void);
129 static double getdistance(int dx, int dy, FVECT direc);
130 static int mytmflags(void);
131 static void getevent(void);
132 static void draw3dline(FVECT wp[2]);
133 static void draw_grids(int fore);
134 static int moveview(int dx, int dy, int mov, int orb);
135 static void getframe(XButtonPressedEvent *ebut);
136 static void getmove(XButtonPressedEvent *ebut);
137 static void getkey(XKeyPressedEvent *ekey);
138 static void fixwindow(XExposeEvent *eexp);
139 static void resizewindow(XConfigureEvent *ersz);
140 static void waitabit(void);
141 static void setglpersp(void);
142 static void setglortho(void);
143 static void wipeclean(void);
144
145
146 #ifdef STEREO
147 static void pushright(void);
148 static void popright(void);
149 #endif
150
151 extern int gmPortals; /* GL portal list id */
152
153 extern time_t time();
154
155
156 void
157 dev_open(id) /* initialize GLX driver */
158 char *id;
159 {
160 extern char *getenv();
161 static RGBPRIMS myprims = STDPRIMS;
162 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
163 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
164 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
165 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
166 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
167 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
168 char *ev;
169 double gamval = GAMMA;
170 RGBPRIMP dpri = stdprims;
171 XSetWindowAttributes ourwinattr;
172 XWMHints ourxwmhints;
173 XSizeHints oursizhints;
174 /* check for unsupported stereo */
175 #ifdef NOSTEREO
176 error(INTERNAL, "stereo display driver unavailable");
177 #endif
178 /* open display server */
179 ourdisplay = XOpenDisplay(NULL);
180 CHECK(ourdisplay==NULL, USER,
181 "cannot open X-windows; DISPLAY variable set?");
182 #ifdef STEREO
183 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
184 case STEREO_TOP:
185 case STEREO_BOTTOM:
186 break;
187 case STEREO_OFF:
188 error(USER,
189 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
190 case X_STEREO_UNSUPPORTED:
191 error(USER, "stereo mode not supported on this screen");
192 default:
193 error(INTERNAL, "unknown stereo mode");
194 }
195 #endif
196 /* find a usable visual */
197 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
198 if (ourvinf == NULL)
199 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
200 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
201 /* get a context */
202 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
203 /* set gamma and tone mapping */
204 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
205 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
206 gamval = atof(ev);
207 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
208 sscanf(ev, "%f %f %f %f %f %f %f %f",
209 &myprims[RED][CIEX],&myprims[RED][CIEY],
210 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
211 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
212 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
213 dpri = myprims;
214 tmGlobal = tmInit(mytmflags(), dpri, gamval);
215 if (tmGlobal == NULL)
216 error(SYSTEM, "not enough memory in dev_open");
217 /* open window */
218 ourwinattr.background_pixel = ourblack;
219 ourwinattr.border_pixel = ourblack;
220 ourwinattr.event_mask = ourmask;
221 /* this is stupid */
222 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
223 ourvinf->visual, AllocNone);
224 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
225 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
226 #ifdef STEREO
227 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
228 #else
229 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
230 #endif
231 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
232 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
233 CHECK(gwind==0, SYSTEM, "cannot create window");
234 XStoreName(ourdisplay, gwind, id);
235 /* set window manager hints */
236 ourxwmhints.flags = InputHint|IconPixmapHint;
237 ourxwmhints.input = True;
238 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay, gwind,
239 (char *)x11icon_bits, x11icon_width, x11icon_height);
240 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
241 oursizhints.min_width = MINWIDTH;
242 #ifdef STEREO
243 oursizhints.min_height = MINHEIGHT/2;
244 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
245 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
246 2*BORWIDTH)/2;
247 oursizhints.flags = PMinSize|PMaxSize;
248 #else
249 oursizhints.min_height = MINHEIGHT;
250 oursizhints.flags = PMinSize;
251 #endif
252 XSetNormalHints(ourdisplay, gwind, &oursizhints);
253 /* set GLX context */
254 glXMakeCurrent(ourdisplay, gwind, gctx);
255 glEnable(GL_DEPTH_TEST);
256 glDepthFunc(GL_LEQUAL);
257 glClearColor(0, 0, 0, 0);
258 glFrontFace(GL_CCW);
259 glDisable(GL_CULL_FACE);
260 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
261 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
262 glPixelStorei(GL_PACK_ALIGNMENT, 1);
263 glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
264 /* figure out sensible view */
265 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
266 DisplayWidth(ourdisplay, ourscreen);
267 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
268 DisplayHeight(ourdisplay, ourscreen);
269 #ifdef STEREO
270 pheight *= 2.;
271 setstereobuf(STEREO_BUFFER_LEFT);
272 #endif
273 checkglerr("setting rendering parameters");
274 odev.v = stdview;
275 odev.v.type = VT_PER;
276 viewflags = VWSTEADY; /* view starts static */
277 /* map the window */
278 XMapWindow(ourdisplay, gwind);
279 dev_input(); /* sets size and view angles */
280 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
281 DisplayHeight(ourdisplay,ourscreen) / 3))
282 error(SYSTEM, "insufficient memory for value storage");
283 odev.name = id;
284 odev.firstuse = 1; /* can't recycle samples */
285 odev.ifd = ConnectionNumber(ourdisplay);
286 }
287
288
289 void
290 dev_close(void) /* close our display and free resources */
291 {
292 #ifdef DOBJ
293 dobj_cleanup();
294 #endif
295 freedepth();
296 gmEndGeom();
297 gmEndPortal();
298 odDone();
299 glXMakeCurrent(ourdisplay, None, NULL);
300 glXDestroyContext(ourdisplay, gctx);
301 XDestroyWindow(ourdisplay, gwind);
302 gwind = 0;
303 XCloseDisplay(ourdisplay);
304 ourdisplay = NULL;
305 tmDone(tmGlobal);
306 odev.v.type = 0;
307 odev.hres = odev.vres = 0;
308 odev.ifd = -1;
309 }
310
311
312 void
313 dev_clear(void) /* clear our representation */
314 {
315 viewflags |= VWCHANGE; /* pretend our view has changed */
316 wipeclean(); /* clean off display and samples */
317 dev_flush(); /* redraw geometry & get depth */
318 rayqleft = 0; /* hold off update */
319 }
320
321
322 int
323 dev_view( /* assign new driver view */
324 VIEW *nv
325 )
326 {
327 #ifdef STEREO
328 double d;
329 #endif
330 if (nv->type != VT_PER || /* check view legality */
331 nv->horiz > 160. || nv->vert > 160.) {
332 error(COMMAND, "illegal view type/angle");
333 nv->type = odev.v.type;
334 nv->horiz = odev.v.horiz;
335 nv->vert = odev.v.vert;
336 return(0);
337 }
338 if (nv != &odev.v) {
339 /* resize window? */
340 if (!FEQ(nv->horiz,odev.v.horiz) ||
341 !FEQ(nv->vert,odev.v.vert)) {
342 int dw = DisplayWidth(ourdisplay,ourscreen);
343 int dh = DisplayHeight(ourdisplay,ourscreen);
344
345 dw -= 25; /* for window frame */
346 dh -= 50;
347 #ifdef STEREO
348 dh /= 2;
349 #endif
350 odev.hres = 2.*VIEWDIST/pwidth *
351 tan(PI/180./2.*nv->horiz);
352 odev.vres = 2.*VIEWDIST/pheight *
353 tan(PI/180./2.*nv->vert);
354 if (odev.hres > dw) {
355 odev.vres = dw * odev.vres / odev.hres;
356 odev.hres = dw;
357 }
358 if (odev.vres > dh) {
359 odev.hres = dh * odev.hres / odev.vres;
360 odev.vres = dh;
361 }
362 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
363 dev_input(); /* get resize event */
364 }
365 odev.v = *nv; /* setview() already called */
366 viewflags |= VWCHANGE;
367 }
368 #ifdef STEREO
369 vwright = *nv;
370 d = eyesepdist / sqrt(nv->hn2);
371 VSUM(vwright.vp, nv->vp, nv->hvec, d);
372 /* setview(&vwright); -- Unnecessary */
373 #endif
374 wipeclean();
375 return(1);
376 }
377
378
379 void
380 dev_section( /* add octree for geometry rendering */
381 char *gfn,
382 char *pfn
383 )
384 {
385 if (gfn == NULL) {
386 gmEndGeom();
387 gmEndPortal();
388 wipeclean(); /* new geometry, so redraw it */
389 return;
390 }
391 if (access(gfn, R_OK) == 0)
392 gmNewGeom(gfn);
393 #ifdef DEBUG
394 else {
395 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
396 error(WARNING, errmsg);
397 }
398 #endif
399 if (pfn != NULL)
400 gmNewPortal(pfn);
401 }
402
403
404 void
405 dev_auxcom( /* process an auxiliary command */
406 char *cmd,
407 char *args
408 )
409 {
410 #ifdef DOBJ
411 int vischange;
412
413 if ((vischange = dobj_command(cmd, args)) >= 0) {
414 if (vischange) {
415 imm_mode = beam_sync(1) > 0;
416 dev_clear();
417 }
418 return;
419 }
420 #endif
421 sprintf(errmsg, "%s: unknown command", cmd);
422 error(COMMAND, errmsg);
423 }
424
425
426 VIEW *
427 dev_auxview( /* return nth auxiliary view */
428 int n,
429 int hvres[2]
430 )
431 {
432 hvres[0] = odev.hres; hvres[1] = odev.vres;
433 if (n == 0)
434 return(&odev.v);
435 #ifdef STEREO
436 if (n == 1)
437 return(&vwright);
438 #endif
439 return(NULL);
440 }
441
442
443 int
444 dev_input(void) /* get X11 input */
445 {
446 inpresflags = 0;
447
448 do
449 getevent();
450
451 while (XPending(ourdisplay) > 0);
452
453 odev.inpready = 0;
454
455 return(inpresflags);
456 }
457
458
459 void
460 dev_value( /* add a pixel value to our texture */
461 COLR c,
462 FVECT d,
463 FVECT p
464 )
465 {
466 #ifdef DOBJ
467 if (dobj_lightsamp != NULL) { /* in light source sampling */
468 (*dobj_lightsamp)(c, d, p);
469 return;
470 }
471 #endif
472 odSample(c, d, p); /* add to display representation */
473 if (!--rayqleft)
474 dev_flush(); /* flush output */
475 }
476
477
478 int
479 dev_flush(void) /* flush output as appropriate */
480 {
481 int ndrawn;
482
483 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
484 #ifdef STEREO
485 pushright(); /* draw right eye */
486 ndrawn = gmDrawGeom();
487 #ifdef DOBJ
488 ndrawn += dobj_render();
489 #endif
490 checkglerr("rendering right eye");
491 popright(); /* draw left eye */
492 #endif
493 ndrawn = gmDrawGeom();
494 #ifdef DOBJ
495 ndrawn += dobj_render();
496 #endif
497 glXSwapBuffers(ourdisplay, gwind);
498 checkglerr("rendering base view");
499 }
500 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
501 (VWMAPPED|VWSTEADY|VWPERSP)) {
502 /* first time after steady */
503 if (ndrawn)
504 xferdepth(); /* transfer and clear depth */
505 setglortho(); /* set orthographic view */
506
507 }
508 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
509 (VWMAPPED|VWSTEADY|VWORTHO)) {
510 /* else update cones */
511 #ifdef STEREO
512 pushright();
513 odUpdate(1); /* draw right eye */
514 popright();
515 #endif
516 odUpdate(0); /* draw left eye */
517 glFlush(); /* flush OpenGL */
518 }
519 rayqleft = RAYQLEN;
520 /* flush X11 and return # pending */
521 return(odev.inpready = XPending(ourdisplay));
522 }
523
524
525 static void
526 checkglerr( /* check for GL or GLU error */
527 char *where
528 )
529 {
530 GLenum errcode;
531
532 while ((errcode = glGetError()) != GL_NO_ERROR) {
533 sprintf(errmsg, "OpenGL error %s: %s",
534 where, gluErrorString(errcode));
535 error(WARNING, errmsg);
536 }
537 }
538
539
540 static void
541 xferdepth(void) /* load and clear depth buffer */
542 {
543 GLfloat *dbp;
544 GLubyte *pbuf;
545
546 if (depthbuffer == NULL) { /* allocate private depth buffer */
547 #ifdef STEREO
548 depthright = (GLfloat *)malloc(
549 odev.hres*odev.vres*sizeof(GLfloat));
550 #endif
551 depthbuffer = (GLfloat *)malloc(
552 odev.hres*odev.vres*sizeof(GLfloat));
553 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
554 }
555 /* allocate alpha buffer for portals */
556 if (gmPortals)
557 pbuf = (GLubyte *)malloc(odev.hres*odev.vres*sizeof(GLubyte));
558 else
559 pbuf = NULL;
560 #ifdef STEREO
561 pushright();
562 glReadPixels(0, 0, odev.hres, odev.vres,
563 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
564 if (pbuf != NULL) {
565 glClear(GL_COLOR_BUFFER_BIT);
566 gmDrawPortals(0xff, -1, -1, -1);
567 glReadPixels(0, 0, odev.hres, odev.vres,
568 GL_RED, GL_UNSIGNED_BYTE, pbuf);
569 }
570 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
571 if (pbuf != NULL && pbuf[dbp-depthright]&0x40)
572 *dbp = FHUGE;
573 else
574 *dbp = mapdepth(*dbp);
575 glClear(GL_DEPTH_BUFFER_BIT);
576 odDepthMap(1, depthright);
577 popright();
578 #endif
579 /* read back depth buffer */
580 glReadPixels(0, 0, odev.hres, odev.vres,
581 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
582 if (pbuf != NULL) {
583 glClear(GL_COLOR_BUFFER_BIT); /* find portals */
584 gmDrawPortals(0xff, -1, -1, -1);
585 glReadPixels(0, 0, odev.hres, odev.vres,
586 GL_RED, GL_UNSIGNED_BYTE, pbuf);
587 #ifdef DEBUG
588 glXSwapBuffers(ourdisplay, gwind);
589 #endif
590 }
591 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
592 if (pbuf != NULL && pbuf[dbp-depthbuffer]&0x40)
593 *dbp = FHUGE;
594 else
595 *dbp = mapdepth(*dbp);
596 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
597 odDepthMap(0, depthbuffer); /* transfer depth data */
598 if (pbuf != NULL)
599 free((void *)pbuf); /* free our portal buffer */
600 }
601
602
603 static void
604 freedepth(void) /* free recorded depth buffer */
605 {
606 if (depthbuffer == NULL)
607 return;
608 #ifdef STEREO
609 odDepthMap(1, NULL);
610 free((void *)depthright);
611 depthright = NULL;
612 #endif
613 odDepthMap(0, NULL);
614 free((void *)depthbuffer);
615 depthbuffer = NULL;
616 }
617
618
619 static double
620 getdistance( /* distance from fore plane along view ray */
621 int dx,
622 int dy,
623 FVECT direc
624 )
625 {
626 GLfloat gldepth;
627 double dist;
628
629 if ((dx<0) | (dx>=odev.hres) | (dy<0) | (dy>=odev.vres))
630 return(FHUGE);
631 if (depthbuffer != NULL)
632 dist = depthbuffer[dy*odev.hres + dx];
633 else {
634 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
635 GL_FLOAT, &gldepth);
636 if (gldepth <= FTINY)
637 return (FHUGE); /* call failed */
638 dist = mapdepth(gldepth);
639 }
640 if (dist >= .99*FHUGE)
641 return(FHUGE);
642 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
643 }
644
645
646 #ifdef STEREO
647 static void
648 pushright(void) /* push on right view & buffer */
649 {
650 double d;
651
652 setstereobuf(STEREO_BUFFER_RIGHT);
653 if (viewflags & VWPERSP) {
654 glMatrixMode(GL_MODELVIEW);
655 glPushMatrix();
656 d = -eyesepdist / sqrt(odev.v.hn2);
657 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
658 d*odev.v.hvec[2]);
659 checkglerr("setting right view");
660 }
661 }
662
663
664 static void
665 popright(void) /* pop off right view & buffer */
666 {
667 if (viewflags & VWPERSP) {
668 glMatrixMode(GL_MODELVIEW);
669 glPopMatrix();
670 }
671 setstereobuf(STEREO_BUFFER_LEFT);
672 }
673 #endif
674
675
676 static int
677 mytmflags(void) /* figure out tone mapping flags */
678 {
679 extern char *progname;
680 char *cp, *tail;
681 /* find basic name */
682 for (cp = tail = progname; *cp; cp++)
683 if (*cp == '/')
684 tail = cp+1;
685 for (cp = tail; *cp && *cp != '.'; cp++)
686 ;
687 #ifdef DEBUG
688 if (cp > tail && cp[-1] == 'h')
689 return(TM_F_HUMAN);
690 else
691 return(TM_F_CAMERA);
692 #else
693 if (cp > tail && cp[-1] == 'h')
694 return(TM_F_HUMAN|TM_F_NOSTDERR);
695 else
696 return(TM_F_CAMERA|TM_F_NOSTDERR);
697 #endif
698 }
699
700
701 static void
702 getevent(void) /* get next event */
703 {
704 XNextEvent(ourdisplay, levptr(XEvent));
705 switch (levptr(XEvent)->type) {
706 case ConfigureNotify:
707 resizewindow(levptr(XConfigureEvent));
708 break;
709 case UnmapNotify:
710 viewflags &= ~VWMAPPED;
711 break;
712 case MapNotify:
713 odRemap(0);
714 viewflags |= VWMAPPED;
715 break;
716 case Expose:
717 fixwindow(levptr(XExposeEvent));
718 break;
719 case KeyPress:
720 getkey(levptr(XKeyPressedEvent));
721 break;
722 case ButtonPress:
723 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
724 getframe(levptr(XButtonPressedEvent));
725 else
726 switch (levptr(XButtonPressedEvent)->button) {
727 case Button4: /* wheel up */
728 case Button5: /* wheel down */
729 break;
730 default:
731 getmove(levptr(XButtonPressedEvent));
732 break;
733 }
734 break;
735 }
736 }
737
738
739 static void
740 draw3dline( /* draw 3d line in world coordinates */
741 FVECT wp[2]
742 )
743 {
744 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
745 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
746 }
747
748
749 static void
750 draw_grids( /* draw holodeck section grids */
751 int fore
752 )
753 {
754 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
755 glDisable(GL_LIGHTING);
756 if (fore)
757 glColor3ub(4, 250, 250);
758 else
759 glColor3ub(0, 0, 0);
760 glBegin(GL_LINES); /* draw each grid line */
761 gridlines(draw3dline);
762 glEnd();
763 checkglerr("drawing grid lines");
764 glPopAttrib();
765 }
766
767
768 static int
769 moveview( /* move our view */
770 int dx,
771 int dy,
772 int mov,
773 int orb
774 )
775 {
776 VIEW nv;
777 FVECT odir, v1, wip;
778 double d;
779 #ifdef DOBJ
780 double d1;
781 #endif
782 /* start with old view */
783 nv = odev.v;
784 /* orient our motion */
785 if (viewray(v1, odir, &odev.v,
786 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
787 return(0); /* outside view */
788 if (mov | orb) { /* moving relative to geometry */
789 d = getdistance(dx, dy, odir); /* distance from front plane */
790 #ifdef DOBJ
791 d1 = dobj_trace(NULL, v1, odir);
792 if (d1 < d)
793 d = d1;
794 #endif
795 if (d >= .99*FHUGE)
796 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
797 VSUM(wip, v1, odir, d);
798 VSUB(odir, wip, odev.v.vp);
799 } else /* panning with constant viewpoint */
800 VCOPY(nv.vdir, odir);
801 if (orb && mov) { /* orbit left/right */
802 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
803 VSUM(nv.vp, wip, odir, -1.);
804 spinvector(nv.vdir, nv.vdir, nv.vup, d);
805 } else if (orb) { /* orbit up/down */
806 if (geodesic(odir, odir, nv.vup,
807 d=MOVDEG*PI/180.*orb, GEOD_RAD) == 0.0)
808 return(0);
809 VSUM(nv.vp, wip, odir, -1.);
810 geodesic(nv.vdir, nv.vdir, nv.vup, d, GEOD_RAD);
811 } else if (mov) { /* move forward/backward */
812 d = MOVPCT/100. * mov;
813 VSUM(nv.vp, nv.vp, odir, d);
814 }
815 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
816 VSUM(v1, odev.v.vp, nv.vp, -1.);
817 d = DOT(v1, nv.vup);
818 VSUM(nv.vp, nv.vp, odev.v.vup, d);
819 }
820 if (setview(&nv) != NULL)
821 return(0); /* illegal view */
822 dev_view(&nv);
823 inpresflags |= DFL(DC_SETVIEW);
824 return(1);
825 }
826
827
828 static void
829 getframe( /* get focus frame */
830 XButtonPressedEvent *ebut
831 )
832 {
833 int startx = ebut->x, starty = ebut->y;
834 int endx, endy, midx, midy;
835 FVECT odir, v1;
836 double d;
837 #ifdef DOBJ
838 double d1;
839 #endif
840 /* get mouse drag */
841 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
842 endx = levptr(XButtonReleasedEvent)->x;
843 endy = levptr(XButtonReleasedEvent)->y;
844 midx = (startx + endx) >> 1;
845 midy = (starty + endy) >> 1;
846 /* set focus distance */
847 if (viewray(v1, odir, &odev.v,
848 (midx+.5)/odev.hres, (midy+.5)/odev.vres) < -FTINY)
849 return;
850 d = getdistance(midx, midy, odir); /* distance from front plane */
851 #ifdef DOBJ
852 d1 = dobj_trace(NULL, v1, odir);
853 if (d1 < d)
854 d = d1;
855 #endif
856 if (d < .99*FHUGE)
857 odev.v.vdist = d + sqrt(dist2(v1, odev.v.vp));
858 /* set frame for rendering */
859 if ((endx == startx) | (endy == starty))
860 return;
861 if (endx < startx) {int c = endx; endx = startx; startx = c;}
862 if (endy < starty) {int c = endy; endy = starty; starty = c;}
863 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
864 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
865 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
866 inpresflags |= DFL(DC_FOCUS);
867 }
868
869
870 static void
871 waitabit(void) /* pause a moment */
872 {
873 struct timespec ts;
874 ts.tv_sec = 0;
875 ts.tv_nsec = 100000000L;
876 nanosleep(&ts, NULL);
877 }
878
879
880 static void
881 getmove( /* get view change */
882 XButtonPressedEvent *ebut
883 )
884 {
885 int movdir = MOVDIR(ebut->button);
886 int movorb = MOVORB(ebut->state);
887 int ndrawn;
888 Window rootw, childw;
889 int rootx, rooty, wx, wy;
890 unsigned int statemask;
891
892 XNoOp(ourdisplay); /* makes sure we're not idle */
893
894 viewflags &= ~VWSTEADY; /* flag moving view */
895 setglpersp(); /* start us off in perspective */
896 while (!XCheckMaskEvent(ourdisplay,
897 ButtonReleaseMask, levptr(XEvent))) {
898 /* pause so as not to move too fast */
899 waitabit();
900 /* get cursor position */
901 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
902 &rootx, &rooty, &wx, &wy, &statemask))
903 break; /* on another screen */
904 /* compute view motion */
905 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
906 sleep(1);
907 continue; /* cursor in bad place */
908 }
909 draw_grids(1); /* redraw grid */
910 #ifdef STEREO
911 pushright();
912 draw_grids(1);
913 ndrawn = gmDrawGeom();
914 #ifdef DOBJ
915 ndrawn += dobj_render();
916 #endif
917 popright();
918 #endif
919 /* redraw octrees */
920 ndrawn = gmDrawGeom();
921 #ifdef DOBJ
922 ndrawn += dobj_render(); /* redraw objects */
923 #endif
924 glXSwapBuffers(ourdisplay, gwind);
925 if (!ndrawn)
926 sleep(1); /* for reasonable interaction */
927 }
928 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
929 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
930 wx = levptr(XButtonReleasedEvent)->x;
931 wy = levptr(XButtonReleasedEvent)->y;
932 moveview(wx, odev.vres-1-wy, movdir, movorb);
933 }
934 viewflags |= VWSTEADY; /* done goofing around */
935 }
936
937
938 static void
939 setglpersp(void) /* set perspective view in GL */
940 {
941 double d, xmin, xmax, ymin, ymax;
942 GLfloat vec[4];
943 double depthlim[2];
944 /* set depth limits */
945 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
946 if (depthlim[0] >= depthlim[1]) {
947 dev_zmin = 1.;
948 dev_zmax = 100.;
949 } else {
950 dev_zmin = 0.5*depthlim[0];
951 dev_zmax = 1.25*depthlim[1];
952 if (dev_zmin > dev_zmax/5.)
953 dev_zmin = dev_zmax/5.;
954 }
955 if (odev.v.vfore > FTINY)
956 dev_zmin = odev.v.vfore;
957 if (odev.v.vaft > FTINY)
958 dev_zmax = odev.v.vaft;
959 if (dev_zmin*500. < dev_zmax)
960 dev_zmin = dev_zmax/500.;
961 setzrat();
962 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
963 xmin = -xmax;
964 d = odev.v.hoff * (xmax - xmin);
965 xmin += d; xmax += d;
966 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
967 ymin = -ymax;
968 d = odev.v.voff * (ymax - ymin);
969 ymin += d; ymax += d;
970 /* set view matrix */
971 glMatrixMode(GL_PROJECTION);
972 glLoadIdentity();
973 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
974 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
975 odev.v.vp[0] + odev.v.vdir[0],
976 odev.v.vp[1] + odev.v.vdir[1],
977 odev.v.vp[2] + odev.v.vdir[2],
978 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
979 checkglerr("setting perspective view");
980 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
981 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
982 vec[0] = -odev.v.vdir[0];
983 vec[1] = -odev.v.vdir[1];
984 vec[2] = -odev.v.vdir[2];
985 vec[3] = 0.;
986 glLightfv(GL_LIGHT0, GL_POSITION, vec);
987 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
988 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
989 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
990 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
991 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
992 glEnable(GL_LIGHT0);
993 glEnable(GL_LIGHTING); /* light our GL objects */
994 glShadeModel(GL_SMOOTH);
995 viewflags &= ~VWORTHO;
996 viewflags |= VWPERSP;
997 }
998
999
1000 static void
1001 setglortho(void) /* set up orthographic view for cone drawing */
1002 {
1003 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
1004 /* set view matrix */
1005 glMatrixMode(GL_PROJECTION);
1006 glLoadIdentity();
1007 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
1008 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
1009 checkglerr("setting orthographic view");
1010 glDisable(GL_LIGHTING); /* cones are constant color */
1011 glShadeModel(GL_FLAT);
1012 viewflags &= ~VWPERSP;
1013 viewflags |= VWORTHO;
1014 }
1015
1016
1017 static void
1018 wipeclean(void) /* prepare for redraw */
1019 {
1020 glDrawBuffer(GL_BACK); /* use double-buffer mode */
1021 glReadBuffer(GL_BACK);
1022 /* clear buffers */
1023 #ifdef STEREO
1024 setstereobuf(STEREO_BUFFER_RIGHT);
1025 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1026 setstereobuf(STEREO_BUFFER_LEFT);
1027 #endif
1028 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1029 freedepth();
1030 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
1031 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
1032 odClean();
1033 viewflags &= ~VWCHANGE; /* change noted */
1034 } else if (viewflags & VWSTEADY)
1035 odRedrawAll();
1036 setglpersp(); /* reset view & clipping planes */
1037 }
1038
1039
1040 static void
1041 getkey( /* get input key */
1042 XKeyPressedEvent *ekey
1043 )
1044 {
1045 Window rootw, childw;
1046 int rootx, rooty, wx, wy;
1047 unsigned int statemask;
1048 int n;
1049 char buf[8];
1050
1051 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
1052 if (n != 1)
1053 return;
1054 switch (buf[0]) {
1055 case 'h': /* turn on height motion lock */
1056 viewflags |= VWHEADLOCK;
1057 return;
1058 case 'H': /* turn off height motion lock */
1059 viewflags &= ~VWHEADLOCK;
1060 return;
1061 case 'l': /* retrieve last view */
1062 inpresflags |= DFL(DC_LASTVIEW);
1063 return;
1064 case 'p': /* pause computation */
1065 inpresflags |= DFL(DC_PAUSE);
1066 return;
1067 case 'v': /* spit out view */
1068 inpresflags |= DFL(DC_GETVIEW);
1069 return;
1070 case 'f': /* frame view position */
1071 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
1072 &rootx, &rooty, &wx, &wy, &statemask))
1073 return; /* on another screen */
1074 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
1075 1.-(wy+.5)/odev.vres);
1076 inpresflags |= DFL(DC_FOCUS);
1077 return;
1078 case 'F': /* unfocus */
1079 odev_args[0] = '\0';
1080 inpresflags |= DFL(DC_FOCUS);
1081 return;
1082 case '\n':
1083 case '\r': /* resume computation */
1084 inpresflags |= DFL(DC_RESUME);
1085 return;
1086 case CTRL('R'): /* redraw screen */
1087 odRemap(0); /* new tone mapping */
1088 glClear(GL_DEPTH_BUFFER_BIT);
1089 #ifdef STEREO
1090 setstereobuf(STEREO_BUFFER_RIGHT);
1091 glClear(GL_DEPTH_BUFFER_BIT);
1092 setstereobuf(STEREO_BUFFER_LEFT);
1093 #endif
1094 return;
1095 case CTRL('L'): /* refresh from server */
1096 if (inpresflags & DFL(DC_REDRAW))
1097 return; /* already called */
1098 XRaiseWindow(ourdisplay, gwind);
1099 XFlush(ourdisplay); /* raise up window */
1100 sleep(1); /* wait for restacking */
1101 dev_clear(); /* clear buffer and samples */
1102 odRemap(1); /* start fresh histogram */
1103 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1104 return;
1105 case 'K': /* kill rtrace process(es) */
1106 inpresflags |= DFL(DC_KILL);
1107 break;
1108 case 'R': /* restart rtrace */
1109 inpresflags |= DFL(DC_RESTART);
1110 break;
1111 case 'C': /* clobber holodeck */
1112 inpresflags |= DFL(DC_CLOBBER);
1113 break;
1114 case 'q': /* quit the program */
1115 inpresflags |= DFL(DC_QUIT);
1116 return;
1117 default:
1118 XBell(ourdisplay, 0);
1119 return;
1120 }
1121 }
1122
1123
1124 static void
1125 fixwindow( /* repair damage to window */
1126 XExposeEvent *eexp
1127 )
1128 {
1129 int xmin, ymin, xmax, ymax;
1130
1131 if ((odev.hres == 0) | (odev.vres == 0)) { /* first exposure */
1132 resizewindow((XConfigureEvent *)eexp);
1133 return;
1134 }
1135 xmin = eexp->x; xmax = eexp->x + eexp->width;
1136 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1137
1138 if (xmin <= 0 && xmax >= odev.hres-1 &&
1139 ymin <= 0 && ymax >= odev.vres) {
1140 DCHECK(eexp->count, WARNING, "multiple clear in fixwindow");
1141 wipeclean(); /* make sure we're go */
1142 return;
1143 }
1144 /* clear portion of depth */
1145 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1146 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1147 glDepthFunc(GL_ALWAYS);
1148 glBegin(GL_POLYGON);
1149 glVertex3i(xmin, ymin, OMAXDEPTH);
1150 glVertex3i(xmax, ymin, OMAXDEPTH);
1151 glVertex3i(xmax, ymax, OMAXDEPTH);
1152 glVertex3i(xmin, ymax, OMAXDEPTH);
1153 glEnd();
1154 #ifdef STEREO
1155 setstereobuf(STEREO_BUFFER_RIGHT);
1156 glBegin(GL_POLYGON);
1157 glVertex3i(xmin, ymin, OMAXDEPTH);
1158 glVertex3i(xmax, ymin, OMAXDEPTH);
1159 glVertex3i(xmax, ymax, OMAXDEPTH);
1160 glVertex3i(xmin, ymax, OMAXDEPTH);
1161 glEnd();
1162 odRedraw(1, xmin, ymin, xmax, ymax);
1163 setstereobuf(STEREO_BUFFER_LEFT);
1164 #endif
1165 glPopAttrib();
1166 odRedraw(0, xmin, ymin, xmax, ymax);
1167 }
1168
1169
1170 static void
1171 resizewindow( /* resize window */
1172 XConfigureEvent *ersz
1173 )
1174 {
1175 glViewport(0, 0, ersz->width, ersz->height);
1176
1177 if (ersz->width == odev.hres && ersz->height == odev.vres)
1178 return;
1179
1180 odev.hres = ersz->width;
1181 odev.vres = ersz->height;
1182
1183 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1184 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1185
1186 inpresflags |= DFL(DC_SETVIEW);
1187 viewflags |= VWCHANGE;
1188 }
