root/radiance/src/hd/rhd_ogl.c
Revision: 3.15
Committed: Tue Jan 5 18:16:17 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.14: +10 -7 lines
made VIEWDIST, MINWIDTH and BORWIDTH command-line definable
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * OpenGL driver for holodeck display.
9 * Based on GLX driver using T-mesh.
10 *
11 * Define symbol STEREO for stereo viewing.
12 * Define symbol DOBJ for display object viewing.
13 */
14
15 #ifdef NOSTEREO
16 #ifdef STEREO
17 #undef STEREO
18 #else
19 #undef NOSTEREO
20 #endif
21 #endif
22
23 #include "standard.h"
24
25 #include <sys/types.h>
26 #include <GL/glx.h>
27 #include <GL/glu.h>
28 #ifdef STEREO
29 #include <X11/extensions/SGIStereo.h>
30 #endif
31
32 #include "rhd_odraw.h"
33 #ifdef DOBJ
34 #include "rhdobj.h"
35 #endif
36
37 #include "x11icon.h"
38
39 #ifndef RAYQLEN
40 #define RAYQLEN 0 /* max. rays to queue before flush */
41 #endif
42 #ifndef MINWIDTH
43 #define MINWIDTH 480 /* minimum graphics window width */
44 #define MINHEIGHT 400 /* minimum graphics window height */
45 #endif
46 #ifndef VIEWDIST
47 #define VIEWDIST 356 /* assumed viewing distance (mm) */
48 #endif
49 #ifndef BORWIDTH
50 #define BORWIDTH 5 /* border width */
51 #endif
52
53 #ifndef FEQ
54 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
55 #endif
56
57 #define VWHEADLOCK 01 /* head position is locked flag */
58 #define VWPERSP 02 /* perspective view is set */
59 #define VWORTHO 04 /* orthographic view is set */
60 #define VWCHANGE 010 /* view has changed */
61 #define VWSTEADY 020 /* view is now steady */
62 #define VWMAPPED 040 /* window is mapped */
63
64 #define GAMMA 1.4 /* default gamma correction */
65
66 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
67
68 #define MOVPCT 7 /* percent distance to move /frame */
69 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
70 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
71 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
72
73 #define setstereobuf(bid) (glXWaitGL(), \
74 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
75 glXWaitX())
76
77 #define ourscreen DefaultScreen(ourdisplay)
78 #define ourroot RootWindow(ourdisplay,ourscreen)
79 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
80 ButtonPressMask|ButtonReleaseMask)
81
82 #define levptr(etype) ((etype *)&currentevent)
83
84 struct driver odev; /* global device driver structure */
85
86 char odev_args[64]; /* command arguments */
87
88 static GLfloat *depthbuffer = NULL; /* depth buffer */
89
90 #ifdef STEREO
91 static VIEW vwright; /* right eye view */
92 static GLfloat *depthright = NULL; /* right depth buffer */
93 #endif
94
95 static int rayqleft = 0; /* rays left to queue before flush */
96
97 static XEvent currentevent; /* current event */
98
99 static unsigned long ourblack=0, ourwhite=~0;
100
101 static Display *ourdisplay = NULL; /* our display */
102 static XVisualInfo *ourvinf; /* our visual information */
103 static Window gwind = 0; /* our graphics window */
104 static GLXContext gctx; /* our GLX context */
105
106 static double pwidth, pheight; /* pixel dimensions (mm) */
107
108 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
109 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
110
111 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
112 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
113
114 static int inpresflags; /* input result flags */
115
116 static int viewflags; /* what's happening with view */
117
118 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
119 xferdepth(), freedepth(), setglortho(),
120 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
121
122 static double getdistance();
123
124 #ifdef STEREO
125 static int pushright(), popright();
126 #endif
127
128 extern int gmPortals; /* GL portal list id */
129
130 extern time_t time();
131
132
133 dev_open(id) /* initialize GLX driver */
134 char *id;
135 {
136 extern char *getenv();
137 static RGBPRIMS myprims = STDPRIMS;
138 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
139 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
140 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
141 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
142 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
143 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
144 char *ev;
145 double gamval = GAMMA;
146 RGBPRIMP dpri = stdprims;
147 XSetWindowAttributes ourwinattr;
148 XWMHints ourxwmhints;
149 XSizeHints oursizhints;
150 /* check for unsupported stereo */
151 #ifdef NOSTEREO
152 error(INTERNAL, "stereo display driver unavailable");
153 #endif
154 /* open display server */
155 ourdisplay = XOpenDisplay(NULL);
156 CHECK(ourdisplay==NULL, USER,
157 "cannot open X-windows; DISPLAY variable set?");
158 #ifdef STEREO
159 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
160 case STEREO_TOP:
161 case STEREO_BOTTOM:
162 break;
163 case STEREO_OFF:
164 error(USER,
165 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
166 case X_STEREO_UNSUPPORTED:
167 error(USER, "stereo mode not supported on this screen");
168 default:
169 error(INTERNAL, "unknown stereo mode");
170 }
171 #endif
172 /* find a usable visual */
173 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
174 if (ourvinf == NULL)
175 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
176 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
177 /* get a context */
178 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
179 /* set gamma and tone mapping */
180 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
181 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
182 gamval = atof(ev);
183 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
184 sscanf(ev, "%f %f %f %f %f %f %f %f",
185 &myprims[RED][CIEX],&myprims[RED][CIEY],
186 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
187 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
188 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
189 dpri = myprims;
190 if (tmInit(mytmflags(), dpri, gamval) == NULL)
191 error(SYSTEM, "not enough memory in dev_open");
192 /* open window */
193 ourwinattr.background_pixel = ourblack;
194 ourwinattr.border_pixel = ourblack;
195 ourwinattr.event_mask = ourmask;
196 /* this is stupid */
197 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
198 ourvinf->visual, AllocNone);
199 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
200 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
201 #ifdef STEREO
202 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
203 #else
204 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
205 #endif
206 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
207 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
208 CHECK(gwind==0, SYSTEM, "cannot create window");
209 XStoreName(ourdisplay, gwind, id);
210 /* set window manager hints */
211 ourxwmhints.flags = InputHint|IconPixmapHint;
212 ourxwmhints.input = True;
213 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
214 gwind, x11icon_bits, x11icon_width, x11icon_height);
215 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
216 oursizhints.min_width = MINWIDTH;
217 #ifdef STEREO
218 oursizhints.min_height = MINHEIGHT/2;
219 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
220 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
221 2*BORWIDTH)/2;
222 oursizhints.flags = PMinSize|PMaxSize;
223 #else
224 oursizhints.min_height = MINHEIGHT;
225 oursizhints.flags = PMinSize;
226 #endif
227 XSetNormalHints(ourdisplay, gwind, &oursizhints);
228 /* set GLX context */
229 glXMakeCurrent(ourdisplay, gwind, gctx);
230 glEnable(GL_DEPTH_TEST);
231 glDepthFunc(GL_LEQUAL);
232 glClearColor(0, 0, 0, 0);
233 glFrontFace(GL_CCW);
234 glDisable(GL_CULL_FACE);
235 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
236 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
237 glPixelStorei(GL_PACK_ALIGNMENT, 1);
238 glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
239 /* figure out sensible view */
240 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
241 DisplayWidth(ourdisplay, ourscreen);
242 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
243 DisplayHeight(ourdisplay, ourscreen);
244 #ifdef STEREO
245 pheight *= 2.;
246 setstereobuf(STEREO_BUFFER_LEFT);
247 #endif
248 checkglerr("setting rendering parameters");
249 copystruct(&odev.v, &stdview);
250 odev.v.type = VT_PER;
251 viewflags = VWSTEADY; /* view starts static */
252 /* map the window */
253 XMapWindow(ourdisplay, gwind);
254 dev_input(); /* sets size and view angles */
255 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
256 DisplayHeight(ourdisplay,ourscreen) / 3))
257 error(SYSTEM, "insufficient memory for value storage");
258 odev.name = id;
259 odev.firstuse = 1; /* can't recycle samples */
260 odev.ifd = ConnectionNumber(ourdisplay);
261 }
262
263
264 dev_close() /* close our display and free resources */
265 {
266 #ifdef DOBJ
267 dobj_cleanup();
268 #endif
269 freedepth();
270 gmEndGeom();
271 gmEndPortal();
272 odDone();
273 glXMakeCurrent(ourdisplay, None, NULL);
274 glXDestroyContext(ourdisplay, gctx);
275 XDestroyWindow(ourdisplay, gwind);
276 gwind = 0;
277 XCloseDisplay(ourdisplay);
278 ourdisplay = NULL;
279 tmDone(NULL);
280 odev.v.type = 0;
281 odev.hres = odev.vres = 0;
282 odev.ifd = -1;
283 }
284
285
286 dev_clear() /* clear our representation */
287 {
288 viewflags |= VWCHANGE; /* pretend our view has changed */
289 wipeclean(); /* clean off display and samples */
290 dev_flush(); /* redraw geometry & get depth */
291 rayqleft = 0; /* hold off update */
292 }
293
294
295 int
296 dev_view(nv) /* assign new driver view */
297 register VIEW *nv;
298 {
299 double d;
300
301 if (nv->type != VT_PER || /* check view legality */
302 nv->horiz > 160. || nv->vert > 160.) {
303 error(COMMAND, "illegal view type/angle");
304 nv->type = odev.v.type;
305 nv->horiz = odev.v.horiz;
306 nv->vert = odev.v.vert;
307 return(0);
308 }
309 if (nv != &odev.v) {
310 /* resize window? */
311 if (!FEQ(nv->horiz,odev.v.horiz) ||
312 !FEQ(nv->vert,odev.v.vert)) {
313 int dw = DisplayWidth(ourdisplay,ourscreen);
314 int dh = DisplayHeight(ourdisplay,ourscreen);
315
316 dw -= 25; /* for window frame */
317 dh -= 50;
318 #ifdef STEREO
319 dh /= 2;
320 #endif
321 odev.hres = 2.*VIEWDIST/pwidth *
322 tan(PI/180./2.*nv->horiz);
323 odev.vres = 2.*VIEWDIST/pheight *
324 tan(PI/180./2.*nv->vert);
325 if (odev.hres > dw) {
326 odev.vres = dw * odev.vres / odev.hres;
327 odev.hres = dw;
328 }
329 if (odev.vres > dh) {
330 odev.hres = dh * odev.hres / odev.vres;
331 odev.vres = dh;
332 }
333 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
334 dev_input(); /* get resize event */
335 }
336 copystruct(&odev.v, nv); /* setview() already called */
337 viewflags |= VWCHANGE;
338 }
339 #ifdef STEREO
340 copystruct(&vwright, nv);
341 d = eyesepdist / sqrt(nv->hn2);
342 VSUM(vwright.vp, nv->vp, nv->hvec, d);
343 /* setview(&vwright); -- Unnecessary */
344 #endif
345 wipeclean();
346 return(1);
347 }
348
349
350 dev_section(gfn, pfn) /* add octree for geometry rendering */
351 char *gfn, *pfn;
352 {
353 extern char *index();
354 char *cp;
355
356 if (gfn == NULL) {
357 gmEndGeom();
358 gmEndPortal();
359 wipeclean(); /* new geometry, so redraw it */
360 return;
361 }
362 if (access(gfn, R_OK) == 0)
363 gmNewGeom(gfn);
364 #ifdef DEBUG
365 else {
366 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
367 error(WARNING, errmsg);
368 }
369 #endif
370 if (pfn != NULL)
371 gmNewPortal(pfn);
372 }
373
374
375 dev_auxcom(cmd, args) /* process an auxiliary command */
376 char *cmd, *args;
377 {
378 #ifdef DOBJ
379 int vischange;
380
381 if ((vischange = dobj_command(cmd, args)) >= 0) {
382 if (vischange) {
383 imm_mode = beam_sync(1) > 0;
384 dev_clear();
385 }
386 return;
387 }
388 #endif
389 sprintf(errmsg, "%s: unknown command", cmd);
390 error(COMMAND, errmsg);
391 }
392
393
394 VIEW *
395 dev_auxview(n, hvres) /* return nth auxiliary view */
396 int n;
397 int hvres[2];
398 {
399 hvres[0] = odev.hres; hvres[1] = odev.vres;
400 if (n == 0)
401 return(&odev.v);
402 #ifdef STEREO
403 if (n == 1)
404 return(&vwright);
405 #endif
406 return(NULL);
407 }
408
409
410 int
411 dev_input() /* get X11 input */
412 {
413 inpresflags = 0;
414
415 do
416 getevent();
417
418 while (XPending(ourdisplay) > 0);
419
420 odev.inpready = 0;
421
422 return(inpresflags);
423 }
424
425
426 dev_value(c, d, p) /* add a pixel value to our texture */
427 COLR c;
428 FVECT d, p;
429 {
430 #ifdef DOBJ
431 if (dobj_lightsamp != NULL) { /* in light source sampling */
432 (*dobj_lightsamp)(c, d, p);
433 return;
434 }
435 #endif
436 odSample(c, d, p); /* add to display representation */
437 if (!--rayqleft)
438 dev_flush(); /* flush output */
439 }
440
441
442 int
443 dev_flush() /* flush output as appropriate */
444 {
445 int ndrawn;
446
447 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
448 #ifdef STEREO
449 pushright(); /* draw right eye */
450 ndrawn = gmDrawGeom();
451 #ifdef DOBJ
452 ndrawn += dobj_render();
453 #endif
454 checkglerr("rendering right eye");
455 popright(); /* draw left eye */
456 #endif
457 ndrawn = gmDrawGeom();
458 #ifdef DOBJ
459 ndrawn += dobj_render();
460 #endif
461 glXSwapBuffers(ourdisplay, gwind);
462 checkglerr("rendering base view");
463 }
464 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
465 (VWMAPPED|VWSTEADY|VWPERSP)) {
466 /* first time after steady */
467 if (ndrawn)
468 xferdepth(); /* transfer and clear depth */
469 setglortho(); /* set orthographic view */
470
471 }
472 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
473 (VWMAPPED|VWSTEADY|VWORTHO)) {
474 /* else update cones */
475 #ifdef STEREO
476 pushright();
477 odUpdate(1); /* draw right eye */
478 popright();
479 #endif
480 odUpdate(0); /* draw left eye */
481 glFlush(); /* flush OpenGL */
482 }
483 rayqleft = RAYQLEN;
484 /* flush X11 and return # pending */
485 return(odev.inpready = XPending(ourdisplay));
486 }
487
488
489 checkglerr(where) /* check for GL or GLU error */
490 char *where;
491 {
492 register GLenum errcode;
493
494 while ((errcode = glGetError()) != GL_NO_ERROR) {
495 sprintf(errmsg, "OpenGL error %s: %s",
496 where, gluErrorString(errcode));
497 error(WARNING, errmsg);
498 }
499 }
500
501
502 static
503 xferdepth() /* load and clear depth buffer */
504 {
505 register GLfloat *dbp;
506 register GLubyte *pbuf;
507
508 if (depthbuffer == NULL) { /* allocate private depth buffer */
509 #ifdef STEREO
510 depthright = (GLfloat *)malloc(
511 odev.hres*odev.vres*sizeof(GLfloat));
512 #endif
513 depthbuffer = (GLfloat *)malloc(
514 odev.hres*odev.vres*sizeof(GLfloat));
515 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
516 }
517 /* allocate alpha buffer for portals */
518 if (gmPortals)
519 pbuf = (GLubyte *)malloc(odev.hres*odev.vres*sizeof(GLubyte));
520 else
521 pbuf = NULL;
522 #ifdef STEREO
523 pushright();
524 glReadPixels(0, 0, odev.hres, odev.vres,
525 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
526 if (pbuf != NULL) {
527 glClear(GL_COLOR_BUFFER_BIT);
528 gmDrawPortals(0xff, -1, -1, -1);
529 glReadPixels(0, 0, odev.hres, odev.vres,
530 GL_RED, GL_UNSIGNED_BYTE, pbuf);
531 }
532 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
533 if (pbuf != NULL && pbuf[dbp-depthright]&0x40)
534 *dbp = FHUGE;
535 else
536 *dbp = mapdepth(*dbp);
537 glClear(GL_DEPTH_BUFFER_BIT);
538 odDepthMap(1, depthright);
539 popright();
540 #endif
541 /* read back depth buffer */
542 glReadPixels(0, 0, odev.hres, odev.vres,
543 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
544 if (pbuf != NULL) {
545 glClear(GL_COLOR_BUFFER_BIT); /* find portals */
546 gmDrawPortals(0xff, -1, -1, -1);
547 glReadPixels(0, 0, odev.hres, odev.vres,
548 GL_RED, GL_UNSIGNED_BYTE, pbuf);
549 #ifdef DEBUG
550 glXSwapBuffers(ourdisplay, gwind);
551 #endif
552 }
553 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
554 if (pbuf != NULL && pbuf[dbp-depthbuffer]&0x40)
555 *dbp = FHUGE;
556 else
557 *dbp = mapdepth(*dbp);
558 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
559 odDepthMap(0, depthbuffer); /* transfer depth data */
560 if (pbuf != NULL)
561 free((char *)pbuf); /* free our portal buffer */
562 }
563
564
565 static
566 freedepth() /* free recorded depth buffer */
567 {
568 if (depthbuffer == NULL)
569 return;
570 #ifdef STEREO
571 odDepthMap(1, NULL);
572 free((char *)depthright);
573 depthright = NULL;
574 #endif
575 odDepthMap(0, NULL);
576 free((char *)depthbuffer);
577 depthbuffer = NULL;
578 }
579
580
581 static double
582 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
583 int dx, dy;
584 FVECT direc;
585 {
586 GLfloat gldepth;
587 double dist;
588
589 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
590 return(FHUGE);
591 if (depthbuffer != NULL)
592 dist = depthbuffer[dy*odev.hres + dx];
593 else {
594 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
595 GL_FLOAT, &gldepth);
596 dist = mapdepth(gldepth);
597 }
598 if (dist >= .99*FHUGE)
599 return(FHUGE);
600 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
601 }
602
603
604 #ifdef STEREO
605 static
606 pushright() /* push on right view & buffer */
607 {
608 double d;
609
610 setstereobuf(STEREO_BUFFER_RIGHT);
611 if (viewflags & VWPERSP) {
612 glMatrixMode(GL_MODELVIEW);
613 glPushMatrix();
614 d = -eyesepdist / sqrt(odev.v.hn2);
615 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
616 d*odev.v.hvec[2]);
617 checkglerr("setting right view");
618 }
619 }
620
621
622 static
623 popright() /* pop off right view & buffer */
624 {
625 if (viewflags & VWPERSP) {
626 glMatrixMode(GL_MODELVIEW);
627 glPopMatrix();
628 }
629 setstereobuf(STEREO_BUFFER_LEFT);
630 }
631 #endif
632
633
634 static int
635 mytmflags() /* figure out tone mapping flags */
636 {
637 extern char *progname;
638 register char *cp, *tail;
639 /* find basic name */
640 for (cp = tail = progname; *cp; cp++)
641 if (*cp == '/')
642 tail = cp+1;
643 for (cp = tail; *cp && *cp != '.'; cp++)
644 ;
645 #ifdef DEBUG
646 if (cp > tail && cp[-1] == 'h')
647 return(TM_F_HUMAN);
648 else
649 return(TM_F_CAMERA);
650 #else
651 if (cp > tail && cp[-1] == 'h')
652 return(TM_F_HUMAN|TM_F_NOSTDERR);
653 else
654 return(TM_F_CAMERA|TM_F_NOSTDERR);
655 #endif
656 }
657
658
659 static
660 getevent() /* get next event */
661 {
662 XNextEvent(ourdisplay, levptr(XEvent));
663 switch (levptr(XEvent)->type) {
664 case ConfigureNotify:
665 resizewindow(levptr(XConfigureEvent));
666 break;
667 case UnmapNotify:
668 viewflags &= ~VWMAPPED;
669 break;
670 case MapNotify:
671 odRemap(0);
672 viewflags |= VWMAPPED;
673 break;
674 case Expose:
675 fixwindow(levptr(XExposeEvent));
676 break;
677 case KeyPress:
678 getkey(levptr(XKeyPressedEvent));
679 break;
680 case ButtonPress:
681 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
682 getframe(levptr(XButtonPressedEvent));
683 else
684 getmove(levptr(XButtonPressedEvent));
685 break;
686 }
687 }
688
689
690 static
691 draw3dline(wp) /* draw 3d line in world coordinates */
692 register FVECT wp[2];
693 {
694 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
695 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
696 }
697
698
699 static
700 draw_grids(fore) /* draw holodeck section grids */
701 int fore;
702 {
703 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
704 glDisable(GL_LIGHTING);
705 if (fore)
706 glColor3ub(4, 250, 250);
707 else
708 glColor3ub(0, 0, 0);
709 glBegin(GL_LINES); /* draw each grid line */
710 gridlines(draw3dline);
711 glEnd();
712 checkglerr("drawing grid lines");
713 glPopAttrib();
714 }
715
716
717 static
718 moveview(dx, dy, mov, orb) /* move our view */
719 int dx, dy, mov, orb;
720 {
721 VIEW nv;
722 FVECT odir, v1, wip;
723 double d, d1;
724 register int li;
725 /* start with old view */
726 copystruct(&nv, &odev.v);
727 /* orient our motion */
728 if (viewray(v1, odir, &odev.v,
729 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
730 return(0); /* outside view */
731 if (mov | orb) { /* moving relative to geometry */
732 d = getdistance(dx, dy, odir); /* distance from front plane */
733 #ifdef DOBJ
734 d1 = dobj_trace(NULL, v1, odir);
735 if (d1 < d)
736 d = d1;
737 #endif
738 if (d >= .99*FHUGE)
739 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
740 VSUM(wip, v1, odir, d);
741 VSUB(odir, wip, odev.v.vp);
742 } else /* panning with constant viewpoint */
743 VCOPY(nv.vdir, odir);
744 if (orb && mov) { /* orbit left/right */
745 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
746 VSUM(nv.vp, wip, odir, -1.);
747 spinvector(nv.vdir, nv.vdir, nv.vup, d);
748 } else if (orb) { /* orbit up/down */
749 fcross(v1, odir, nv.vup);
750 if (normalize(v1) == 0.)
751 return(0);
752 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
753 VSUM(nv.vp, wip, odir, -1.);
754 spinvector(nv.vdir, nv.vdir, v1, d);
755 } else if (mov) { /* move forward/backward */
756 d = MOVPCT/100. * mov;
757 VSUM(nv.vp, nv.vp, odir, d);
758 }
759 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
760 VSUM(v1, odev.v.vp, nv.vp, -1.);
761 d = DOT(v1, nv.vup);
762 VSUM(nv.vp, nv.vp, odev.v.vup, d);
763 }
764 if (setview(&nv) != NULL)
765 return(0); /* illegal view */
766 dev_view(&nv);
767 inpresflags |= DFL(DC_SETVIEW);
768 return(1);
769 }
770
771
772 static
773 getframe(ebut) /* get focus frame */
774 XButtonPressedEvent *ebut;
775 {
776 int startx = ebut->x, starty = ebut->y;
777 int endx, endy;
778
779 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
780 endx = levptr(XButtonReleasedEvent)->x;
781 endy = levptr(XButtonReleasedEvent)->y;
782 if (endx == startx | endy == starty) {
783 XBell(ourdisplay, 0);
784 return;
785 }
786 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
787 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
788 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
789 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
790 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
791 inpresflags |= DFL(DC_FOCUS);
792 }
793
794
795 static
796 getmove(ebut) /* get view change */
797 XButtonPressedEvent *ebut;
798 {
799 int movdir = MOVDIR(ebut->button);
800 int movorb = MOVORB(ebut->state);
801 int ndrawn;
802 Window rootw, childw;
803 int rootx, rooty, wx, wy;
804 unsigned int statemask;
805
806 XNoOp(ourdisplay); /* makes sure we're not idle */
807
808 viewflags &= ~VWSTEADY; /* flag moving view */
809 setglpersp(); /* start us off in perspective */
810 while (!XCheckMaskEvent(ourdisplay,
811 ButtonReleaseMask, levptr(XEvent))) {
812 /* get cursor position */
813 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
814 &rootx, &rooty, &wx, &wy, &statemask))
815 break; /* on another screen */
816 /* compute view motion */
817 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
818 sleep(1);
819 continue; /* cursor in bad place */
820 }
821 draw_grids(1); /* redraw grid */
822 #ifdef STEREO
823 pushright();
824 draw_grids(1);
825 ndrawn = gmDrawGeom();
826 #ifdef DOBJ
827 ndrawn += dobj_render();
828 #endif
829 popright();
830 #endif
831 /* redraw octrees */
832 ndrawn = gmDrawGeom();
833 #ifdef DOBJ
834 ndrawn += dobj_render(); /* redraw objects */
835 #endif
836 glXSwapBuffers(ourdisplay, gwind);
837 if (!ndrawn)
838 sleep(1); /* for reasonable interaction */
839 }
840 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
841 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
842 wx = levptr(XButtonReleasedEvent)->x;
843 wy = levptr(XButtonReleasedEvent)->y;
844 moveview(wx, odev.vres-1-wy, movdir, movorb);
845 }
846 viewflags |= VWSTEADY; /* done goofing around */
847 }
848
849
850 static
851 setglpersp() /* set perspective view in GL */
852 {
853 double d, xmin, xmax, ymin, ymax;
854 GLfloat vec[4];
855 double depthlim[2];
856 /* set depth limits */
857 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
858 if (depthlim[0] >= depthlim[1]) {
859 dev_zmin = 1.;
860 dev_zmax = 100.;
861 } else {
862 dev_zmin = 0.5*depthlim[0];
863 dev_zmax = 1.25*depthlim[1];
864 if (dev_zmin > dev_zmax/5.)
865 dev_zmin = dev_zmax/5.;
866 }
867 if (odev.v.vfore > FTINY)
868 dev_zmin = odev.v.vfore;
869 if (odev.v.vaft > FTINY)
870 dev_zmax = odev.v.vaft;
871 if (dev_zmin < dev_zmax/100.)
872 dev_zmin = dev_zmax/100.;
873 setzrat();
874 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
875 xmin = -xmax;
876 d = odev.v.hoff * (xmax - xmin);
877 xmin += d; xmax += d;
878 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
879 ymin = -ymax;
880 d = odev.v.voff * (ymax - ymin);
881 ymin += d; ymax += d;
882 /* set view matrix */
883 glMatrixMode(GL_PROJECTION);
884 glLoadIdentity();
885 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
886 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
887 odev.v.vp[0] + odev.v.vdir[0],
888 odev.v.vp[1] + odev.v.vdir[1],
889 odev.v.vp[2] + odev.v.vdir[2],
890 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
891 checkglerr("setting perspective view");
892 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
893 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
894 vec[0] = -odev.v.vdir[0];
895 vec[1] = -odev.v.vdir[1];
896 vec[2] = -odev.v.vdir[2];
897 vec[3] = 0.;
898 glLightfv(GL_LIGHT0, GL_POSITION, vec);
899 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
900 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
901 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
902 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
903 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
904 glEnable(GL_LIGHT0);
905 glEnable(GL_LIGHTING); /* light our GL objects */
906 glShadeModel(GL_SMOOTH);
907 viewflags &= ~VWORTHO;
908 viewflags |= VWPERSP;
909 }
910
911
912 static
913 setglortho() /* set up orthographic view for cone drawing */
914 {
915 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
916 /* set view matrix */
917 glMatrixMode(GL_PROJECTION);
918 glLoadIdentity();
919 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
920 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
921 checkglerr("setting orthographic view");
922 glDisable(GL_LIGHTING); /* cones are constant color */
923 glShadeModel(GL_FLAT);
924 viewflags &= ~VWPERSP;
925 viewflags |= VWORTHO;
926 }
927
928
929 static
930 wipeclean() /* prepare for redraw */
931 {
932 glDrawBuffer(GL_BACK); /* use double-buffer mode */
933 glReadBuffer(GL_BACK);
934 /* clear buffers */
935 #ifdef STEREO
936 setstereobuf(STEREO_BUFFER_RIGHT);
937 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
938 setstereobuf(STEREO_BUFFER_LEFT);
939 #endif
940 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
941 freedepth();
942 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
943 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
944 odClean();
945 viewflags &= ~VWCHANGE; /* change noted */
946 } else if (viewflags & VWSTEADY)
947 odRedrawAll();
948 setglpersp(&odev.v); /* reset view & clipping planes */
949 }
950
951
952 static
953 getkey(ekey) /* get input key */
954 register XKeyPressedEvent *ekey;
955 {
956 Window rootw, childw;
957 int rootx, rooty, wx, wy;
958 unsigned int statemask;
959 int n;
960 char buf[8];
961
962 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
963 if (n != 1)
964 return;
965 switch (buf[0]) {
966 case 'h': /* turn on height motion lock */
967 viewflags |= VWHEADLOCK;
968 return;
969 case 'H': /* turn off height motion lock */
970 viewflags &= ~VWHEADLOCK;
971 return;
972 case 'l': /* retrieve last view */
973 inpresflags |= DFL(DC_LASTVIEW);
974 return;
975 case 'p': /* pause computation */
976 inpresflags |= DFL(DC_PAUSE);
977 return;
978 case 'v': /* spit out view */
979 inpresflags |= DFL(DC_GETVIEW);
980 return;
981 case 'f': /* frame view position */
982 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
983 &rootx, &rooty, &wx, &wy, &statemask))
984 return; /* on another screen */
985 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
986 1.-(wy+.5)/odev.vres);
987 inpresflags |= DFL(DC_FOCUS);
988 return;
989 case 'F': /* unfocus */
990 odev_args[0] = '\0';
991 inpresflags |= DFL(DC_FOCUS);
992 return;
993 case '\n':
994 case '\r': /* resume computation */
995 inpresflags |= DFL(DC_RESUME);
996 return;
997 case CTRL('R'): /* redraw screen */
998 odRemap(0); /* new tone mapping */
999 glClear(GL_DEPTH_BUFFER_BIT);
1000 #ifdef STEREO
1001 setstereobuf(STEREO_BUFFER_RIGHT);
1002 glClear(GL_DEPTH_BUFFER_BIT);
1003 setstereobuf(STEREO_BUFFER_LEFT);
1004 #endif
1005 return;
1006 case CTRL('L'): /* refresh from server */
1007 if (inpresflags & DFL(DC_REDRAW))
1008 return; /* already called */
1009 XRaiseWindow(ourdisplay, gwind);
1010 XFlush(ourdisplay); /* raise up window */
1011 sleep(1); /* wait for restacking */
1012 dev_clear(); /* clear buffer and samples */
1013 odRemap(1); /* start fresh histogram */
1014 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1015 return;
1016 case 'K': /* kill rtrace process(es) */
1017 inpresflags |= DFL(DC_KILL);
1018 break;
1019 case 'R': /* restart rtrace */
1020 inpresflags |= DFL(DC_RESTART);
1021 break;
1022 case 'C': /* clobber holodeck */
1023 inpresflags |= DFL(DC_CLOBBER);
1024 break;
1025 case 'q': /* quit the program */
1026 inpresflags |= DFL(DC_QUIT);
1027 return;
1028 default:
1029 XBell(ourdisplay, 0);
1030 return;
1031 }
1032 }
1033
1034
1035 static
1036 fixwindow(eexp) /* repair damage to window */
1037 register XExposeEvent *eexp;
1038 {
1039 int xmin, ymin, xmax, ymax;
1040
1041 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
1042 resizewindow((XConfigureEvent *)eexp);
1043 return;
1044 }
1045 xmin = eexp->x; xmax = eexp->x + eexp->width;
1046 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1047
1048 if (xmin <= 0 && xmax >= odev.hres-1 &&
1049 ymin <= 0 && ymax >= odev.vres) {
1050 DCHECK(eexp->count, WARNING, "multiple clear in fixwindow");
1051 wipeclean(); /* make sure we're go */
1052 return;
1053 }
1054 /* clear portion of depth */
1055 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1056 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1057 glDepthFunc(GL_ALWAYS);
1058 glBegin(GL_POLYGON);
1059 glVertex3i(xmin, ymin, OMAXDEPTH);
1060 glVertex3i(xmax, ymin, OMAXDEPTH);
1061 glVertex3i(xmax, ymax, OMAXDEPTH);
1062 glVertex3i(xmin, ymax, OMAXDEPTH);
1063 glEnd();
1064 #ifdef STEREO
1065 setstereobuf(STEREO_BUFFER_RIGHT);
1066 glBegin(GL_POLYGON);
1067 glVertex3i(xmin, ymin, OMAXDEPTH);
1068 glVertex3i(xmax, ymin, OMAXDEPTH);
1069 glVertex3i(xmax, ymax, OMAXDEPTH);
1070 glVertex3i(xmin, ymax, OMAXDEPTH);
1071 glEnd();
1072 odRedraw(1, xmin, ymin, xmax, ymax);
1073 setstereobuf(STEREO_BUFFER_LEFT);
1074 #endif
1075 glPopAttrib();
1076 odRedraw(0, xmin, ymin, xmax, ymax);
1077 }
1078
1079
1080 static
1081 resizewindow(ersz) /* resize window */
1082 register XConfigureEvent *ersz;
1083 {
1084 glViewport(0, 0, ersz->width, ersz->height);
1085
1086 if (ersz->width == odev.hres && ersz->height == odev.vres)
1087 return;
1088
1089 odev.hres = ersz->width;
1090 odev.vres = ersz->height;
1091
1092 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1093 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1094
1095 inpresflags |= DFL(DC_SETVIEW);
1096 viewflags |= VWCHANGE;
1097 }
