root/radiance/src/hd/rhd_ogl.c
Fri Feb 12 00:53:56 2021 UTC (4 years, 8 months ago) by greg
Changes since 3.33: +3 -7 lines
Diff to previous 3.33 , to selected 3.31
refactor: Created comparison macros for RREAL and FVECT types
Fri Oct 5 19:19:16 2018 UTC (7 years ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 3.32: +11 -11 lines
Diff to previous 3.32 , to selected 3.31
Thu Apr 28 16:28:20 2016 UTC (9 years, 5 months ago) by greg
Changes since 3.31: +26 -19 lines
Diff to previous 3.31
Added listening for mouse wheel
Revision 3.31 - (view) (download) (annotate) - [selected]
Thu Sep 6 00:07:43 2012 UTC (13 years, 1 month ago) by greg
Changes since 3.30: +4 -5 lines
Diff to previous 3.30
Wed Jun 7 17:52:04 2006 UTC (19 years, 4 months ago) by schorsch
Changes since 3.29: +9 -3 lines
Diff to previous 3.29 , to selected 3.31
Tue May 23 13:01:07 2006 UTC (19 years, 4 months ago) by greg
Changes since 3.28: +4 -1 lines
Diff to previous 3.28 , to selected 3.31
Added missing variable needed for -DSTEREO
Sun Jul 24 19:53:08 2005 UTC (20 years, 2 months ago) by greg
Changes since 3.27: +3 -3 lines
Diff to previous 3.27 , to selected 3.31
Fri Jan 21 00:52:59 2005 UTC (20 years, 8 months ago) by greg
Changes since 3.26: +21 -6 lines
Diff to previous 3.26 , to selected 3.31
Fri Jan 7 20:33:02 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.25: +6 -3 lines
Diff to previous 3.25 , to selected 3.31
Thu Feb 12 18:55:50 2004 UTC (21 years, 8 months ago) by greg
Changes since 3.24: +2 -1 lines
Diff to previous 3.24 , to selected 3.31
Thu Jan 1 11:21:55 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.23: +127 -80 lines
Diff to previous 3.23 , to selected 3.31
Ansification and prototypes.
Fri Sep 19 18:33:05 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.22: +4 -2 lines
Diff to previous 3.22 , to selected 3.31
Mon Jul 21 22:30:18 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.21: +5 -5 lines
Diff to previous 3.21 , to selected 3.31
Mon May 19 16:32:18 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.20: +0 -1 lines
Diff to previous 3.20 , to selected 3.31
Eliminated unnecessary and problematic external function declarations
Mon Apr 14 16:56:19 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.19: +1 -1 lines
Diff to previous 3.19 , to selected 3.31
Fixed interaction delay timing (supposed to be 50ms -- was 5ms)
Sat Feb 22 02:07:24 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.18: +18 -8 lines
Diff to previous 3.18 , to selected 3.31
Mon Jul 19 20:15:16 1999 UTC (26 years, 3 months ago) by gwlarson
Diff to previous 3.17 , to selected 3.31
changed fore/aft clipping limit
Mon Jun 28 16:30:22 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.16: +1 -1 lines
Diff to previous 3.16 , to selected 3.31
eliminated unnecessary argument to setglpersp()
Mon Mar 8 17:31:49 1999 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.15: +0 -1 lines
Diff to previous 3.15 , to selected 3.31
Tue Jan 5 18:16:17 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.14: +10 -7 lines
Diff to previous 3.14 , to selected 3.31
made VIEWDIST, MINWIDTH and BORWIDTH command-line definable
Sun Jan 3 13:40:25 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.13: +6 -6 lines
Diff to previous 3.13 , to selected 3.31
fixed bug in stereo view computation after window resize
Fri Jan 1 10:41:28 1999 UTC (26 years, 9 months ago) by gwlarson
Diff to previous 3.12 , to selected 3.31
fixed aft clipping plane problem
Thu Dec 31 13:24:36 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.11: +12 -6 lines
Diff to previous 3.11 , to selected 3.31
fixed redrawing of local objects in OpenGL driver
Wed Dec 30 17:13:20 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.10: +9 -17 lines
Diff to previous 3.10 , to selected 3.31
fixed redraw when window is remapped
increased number of samples allocated
turned off incremental updates by default (RAYQLEN)
Wed Dec 23 17:43:42 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.9: +34 -14 lines
Diff to previous 3.9 , to selected 3.31
numerous bug fixes for stereo and object-drawing drivers
Tue Dec 22 12:59:17 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.8: +20 -56 lines
Diff to previous 3.8 , to selected 3.31
changed portal code to write and read back buffer
Tue Dec 22 10:18:44 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.7: +22 -16 lines
Diff to previous 3.7 , to selected 3.31
improved portal code
Tue Dec 22 09:40:32 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.6: +46 -34 lines
Diff to previous 3.6 , to selected 3.31
simplified view conditions with viewflags variable
Mon Dec 21 19:17:28 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.5: +40 -34 lines
Diff to previous 3.5 , to selected 3.31
switched to double-buffered display
Mon Dec 21 15:31:49 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.4: +6 -9 lines
Diff to previous 3.4 , to selected 3.31
replaced error calls with CHECK in some places
Mon Dec 21 15:10:13 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.3: +5 -9 lines
Diff to previous 3.3 , to selected 3.31
fixed problem with initial drawing
Mon Dec 21 11:42:38 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.2: +62 -29 lines
Diff to previous 3.2 , to selected 3.31
got portals working with or without alpha buffer
Sun Dec 20 20:36:48 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.1: +82 -33 lines
Diff to previous 3.1 , to selected 3.31
added port drawing into alpha buffer mask
changed tone remapping call
Fri Dec 18 11:55:19 1998 UTC (26 years, 10 months ago) by gwlarson
Diff to selected 3.31
