| 1 | /* Copyright (c) 1998 Silicon Graphics, Inc. */ |
| 2 |  |
| 3 | #ifndef lint |
| 4 | static char SCCSid[] = "$SunId$ SGI"; |
| 5 | #endif |
| 6 |  |
| 7 | /* |
| 8 | * Routines for drawing samples using depth buffer checks. |
| 9 | */ |
| 10 |  |
| 11 | #include "standard.h" |
| 12 |  |
| 13 | #include <sys/types.h> |
| 14 | #include <GL/glx.h> |
| 15 | #include <GL/glu.h> |
| 16 |  |
| 17 | #include "random.h" |
| 18 | #include "rhd_odraw.h" |
| 19 |  |
| 20 | #ifndef DEPTHEPS |
| 21 | #define DEPTHEPS        0.02            /* depth epsilon */ |
| 22 | #endif |
| 23 | #ifndef SAMPSPERBLOCK |
| 24 | #define SAMPSPERBLOCK   1024            /* target samples per image block */ |
| 25 | #endif |
| 26 | #ifndef SFREEFRAC |
| 27 | #define SFREEFRAC       0.2             /* fraction to free at a time */ |
| 28 | #endif |
| 29 | #ifndef MAXFAN |
| 30 | #define MAXFAN          32              /* maximum arms in a triangle fan */ |
| 31 | #endif |
| 32 | #ifndef MINFAN |
| 33 | #define MINFAN          4               /* minimum arms in a triangle fan */ |
| 34 | #endif |
| 35 | #ifndef FANSIZE |
| 36 | #define FANSIZE         3.5             /* fan sizing factor */ |
| 37 | #endif |
| 38 |  |
| 39 | #define NEWMAP          01              /* need to recompute mapping */ |
| 40 | #define NEWRGB          02              /* need to remap RGB values */ |
| 41 | #define NEWHIST         04              /* clear histogram as well */ |
| 42 |  |
| 43 | struct ODview   *odView;        /* our view list */ |
| 44 | int     odNViews;               /* number of views in our list */ |
| 45 |  |
| 46 | struct ODsamp   odS;            /* sample values */ |
| 47 |  |
| 48 | static int      needmapping;    /* what needs doing with tone map */ |
| 49 |  |
| 50 |  |
| 51 | #define SAMP32  (32*(2*sizeof(short)+sizeof(union ODfunion)+sizeof(TMbright)+\ |
| 52 | 6*sizeof(BYTE))+sizeof(int4)) |
| 53 |  |
| 54 | int |
| 55 | odInit(n)                               /* initialize drawing routines */ |
| 56 | int     n; |
| 57 | { |
| 58 | int     nbytes, i, j, k, nextsamp, count, blockdiv; |
| 59 | int     res[2]; |
| 60 |  |
| 61 | if (odNViews > 0) {             /* deallocate view structures */ |
| 62 | for (i = odNViews; i--; ) { |
| 63 | free((char *)odView[i].bmap); |
| 64 | free((char *)odView[i].pmap); |
| 65 | if (odView[i].emap != NULL) |
| 66 | free((char *)odView[i].emap); |
| 67 | } |
| 68 | free((char *)odView); |
| 69 | odView = NULL; |
| 70 | odNViews = 0; |
| 71 | } |
| 72 | if (n && n != odS.nsamp) { |
| 73 | /* round space up to nearest power of 2 */ |
| 74 | nbytes = (n+31)/32 * SAMP32; |
| 75 | for (i = 1024; nbytes > i-8; i <<= 1) |
| 76 | ; |
| 77 | n = (i-8)/SAMP32 * 32; |
| 78 | needmapping = NEWHIST; |
| 79 | } |
| 80 | if (n != odS.nsamp) {   /* (re)allocate sample array */ |
| 81 | if (odS.nsamp) |
| 82 | free(odS.base); |
| 83 | odS.nsamp = 0; |
| 84 | if (!n) |
| 85 | return(0); |
| 86 | nbytes = (n+31)/32 * SAMP32; |
| 87 | odS.base = (char *)malloc(nbytes); |
| 88 | if (odS.base == NULL) |
| 89 | return(0); |
| 90 | /* assign larger alignment types earlier */ |
| 91 | odS.f = (union ODfunion *)odS.base; |
| 92 | odS.redraw = (int4 *)(odS.f + n); |
| 93 | odS.ip = (short (*)[2])(odS.redraw + n/32); |
| 94 | odS.brt = (TMbright *)(odS.ip + n); |
| 95 | odS.chr = (BYTE (*)[3])(odS.brt + n); |
| 96 | odS.rgb = (BYTE (*)[3])(odS.chr + n); |
| 97 | odS.nsamp = n; |
| 98 | } |
| 99 | if (!n) |
| 100 | return(0); |
| 101 | /* allocate view information */ |
| 102 | count = 0;                      /* count pixels */ |
| 103 | for (i = 0; dev_auxview(i, res) != NULL; i++) |
| 104 | count += res[0]*res[1]; |
| 105 | odView = (struct ODview *)malloc(i*sizeof(struct ODview)); |
| 106 | if (odView == NULL) |
| 107 | return(0); |
| 108 | odNViews = i; |
| 109 | blockdiv = sqrt(count/(n/SAMPSPERBLOCK)) + 0.5; |
| 110 | if (blockdiv < 8) blockdiv = 8; |
| 111 | nextsamp = 0; count /= blockdiv*blockdiv;       /* # blocks */ |
| 112 | while (i--) {                   /* initialize each view */ |
| 113 | dev_auxview(i, res); |
| 114 | odView[i].hhi = res[0]; |
| 115 | odView[i].hlow = (res[0] + blockdiv/2) / blockdiv; |
| 116 | if (odView[i].hlow < 1) odView[i].hlow = 1; |
| 117 | odView[i].vhi = res[1]; |
| 118 | odView[i].vlow = (res[1] + blockdiv/2) / blockdiv; |
| 119 | if (odView[i].vlow < 1) odView[i].vlow = 1; |
| 120 | odView[i].emap = NULL; |
| 121 | odView[i].dmap = NULL; |
| 122 | odView[i].pmap = (int4 *)calloc(FL4NELS(res[0]*res[1]), |
| 123 | sizeof(int4)); |
| 124 | if (odView[i].pmap == NULL) |
| 125 | return(0); |
| 126 | j = odView[i].hlow*odView[i].vlow; |
| 127 | odView[i].bmap = (struct ODblock *)malloc( |
| 128 | j * sizeof(struct ODblock)); |
| 129 | if (odView[i].bmap == NULL) |
| 130 | return(0); |
| 131 | DCHECK(count<=0 | nextsamp>=n, |
| 132 | CONSISTENCY, "counter botch in odInit"); |
| 133 | if (!i) count = j; |
| 134 | while (j--) {           /* initialize blocks & free lists */ |
| 135 | odView[i].bmap[j].pthresh = FHUGE; |
| 136 | odView[i].bmap[j].first = k = nextsamp; |
| 137 | nextsamp += odView[i].bmap[j].nsamp = |
| 138 | (n - nextsamp)/count--; |
| 139 | odView[i].bmap[j].free = k; |
| 140 | while (++k < nextsamp) |
| 141 | odS.nextfree(k-1) = k; |
| 142 | odS.nextfree(k-1) = ENDFREE; |
| 143 | odView[i].bmap[j].nused = 0; |
| 144 | } |
| 145 | } |
| 146 | CLR4ALL(odS.redraw, odS.nsamp);         /* clear redraw flags */ |
| 147 | for (i = odS.nsamp; i--; ) {            /* clear values */ |
| 148 | odS.ip[i][0] = odS.ip[i][1] = -1; |
| 149 | odS.brt[i] = TM_NOBRT; |
| 150 | } |
| 151 | needmapping |= NEWMAP;                  /* compute new map on update */ |
| 152 | return(odS.nsamp);                      /* return number of samples */ |
| 153 | } |
| 154 |  |
| 155 | #undef SAMP32 |
| 156 |  |
| 157 |  |
| 158 | int |
| 159 | sampcmp(s0, s1)                 /* sample order, descending proximity */ |
| 160 | int     *s0, *s1; |
| 161 | { |
| 162 | register double diff = odS.closeness(*s1) - odS.closeness(*s0); |
| 163 |  |
| 164 | return (diff > FTINY ? 1 : diff < -FTINY ? -1 : 0); |
| 165 | } |
| 166 |  |
| 167 |  |
| 168 | int |
| 169 | odAllocBlockSamp(vn, hh, vh, prox)      /* allocate sample from block */ |
| 170 | int     vn, hh, vh; |
| 171 | double  prox; |
| 172 | { |
| 173 | int     si[SAMPSPERBLOCK+SAMPSPERBLOCK/4]; |
| 174 | int     hl, vl; |
| 175 | VIEW    *vw; |
| 176 | FVECT   ro, rd; |
| 177 | int     res[2]; |
| 178 | register struct ODblock *bp; |
| 179 | register int    i, j; |
| 180 | /* get block */ |
| 181 | hl = hh*odView[vn].hlow/odView[vn].hhi; |
| 182 | vl = vh*odView[vn].vlow/odView[vn].vhi; |
| 183 | bp = odView[vn].bmap + vl*odView[vn].hlow + hl; |
| 184 | if (prox > bp->pthresh) |
| 185 | return(-1);             /* worse than free list occupants */ |
| 186 | /* check for duplicate pixel */ |
| 187 | if (CHK4(odView[vn].pmap, vh*odView[vn].hhi + hh)) |
| 188 | i = bp->first + bp->nsamp; |
| 189 | else |
| 190 | i = -1; |
| 191 | while (i-- > bp->first) |
| 192 | if (hh == odS.ip[i][0] && vh == odS.ip[i][1]) { /* found it! */ |
| 193 | /* search free list for it */ |
| 194 | if (i == bp->free) |
| 195 | break;          /* special case */ |
| 196 | if (bp->free != ENDFREE) |
| 197 | for (j = bp->free; odS.nextfree(j) != ENDFREE; |
| 198 | j = odS.nextfree(j)) |
| 199 | if (odS.nextfree(j) == i) { |
| 200 | odS.nextfree(j) = |
| 201 | odS.nextfree(i); |
| 202 | bp->nused++; |
| 203 | goto gotit; |
| 204 | } |
| 205 | if (prox >= 0.999*odS.closeness(i)) |
| 206 | return(-1);     /* previous sample is fine */ |
| 207 | goto gotit; |
| 208 | } |
| 209 | DCHECK(i>=-1, WARNING, "pixel in presence map not found in block"); |
| 210 | if (bp->free != ENDFREE) {      /* allocate from free list */ |
| 211 | i = bp->free; |
| 212 | if (odS.ip[i][0] >= 0 & odS.ip[i][1] >= 0) |
| 213 | CLR4(odView[vn].pmap, odS.ip[i][1]*odView[vn].hhi + |
| 214 | odS.ip[i][0]); |
| 215 | bp->free = odS.nextfree(i); |
| 216 | bp->nused++; |
| 217 | goto gotit; |
| 218 | } |
| 219 | DCHECK(bp->nsamp<=0, CONSISTENCY, |
| 220 | "no available samples in odAllocBlockSamp"); |
| 221 | DCHECK(bp->nsamp > sizeof(si)/sizeof(si[0]), CONSISTENCY, |
| 222 | "too many samples in odAllocBlockSamp"); |
| 223 | /* free some samples */ |
| 224 | if ((vw = dev_auxview(vn, res)) == NULL) |
| 225 | error(CONSISTENCY, "bad view number in odAllocBlockSamp"); |
| 226 | for (i = bp->nsamp; i--; )      /* figure out which are worse */ |
| 227 | si[i] = bp->first + i; |
| 228 | qsort((char *)si, bp->nsamp, sizeof(int), sampcmp); |
| 229 | i = bp->nsamp*SFREEFRAC + .5;   /* put them into free list */ |
| 230 | if (i >= bp->nsamp) i = bp->nsamp-1;    /* paranoia */ |
| 231 | bp->pthresh = odS.closeness(si[i]);     /* new proximity threshold */ |
| 232 | while (--i > 0) { |
| 233 | odS.nextfree(si[i]) = bp->free; |
| 234 | bp->free = si[i]; |
| 235 | bp->nused--; |
| 236 | } |
| 237 | i = si[0];                      /* use worst sample */ |
| 238 | CLR4(odView[vn].pmap, odS.ip[i][1]*odView[vn].hhi + odS.ip[i][0]); |
| 239 | gotit: |
| 240 | odS.ip[i][0] = hh; |
| 241 | odS.ip[i][1] = vh; |
| 242 | odS.closeness(i) = prox; |
| 243 | SET4(odView[vn].pmap, vh*odView[vn].hhi + hh); |
| 244 | return(i); |
| 245 | } |
| 246 |  |
| 247 |  |
| 248 | odSample(c, d, p)                       /* add a sample value */ |
| 249 | COLR    c; |
| 250 | FVECT   d, p; |
| 251 | { |
| 252 | FVECT   disp; |
| 253 | double  d0, d1, h, v, prox; |
| 254 | register VIEW   *vw; |
| 255 | int     hh, vh; |
| 256 | int     res[2]; |
| 257 | register int    i, id; |
| 258 |  |
| 259 | DCHECK(odS.nsamp<=0, CONSISTENCY, "no samples allocated in odSample"); |
| 260 | /* add value to each view */ |
| 261 | for (i = 0; (vw = dev_auxview(i, res)) != NULL; i++) { |
| 262 | DCHECK(i>=odNViews, CONSISTENCY, "too many views in odSample"); |
| 263 | CHECK(vw->type!=VT_PER, INTERNAL, |
| 264 | "cannot handle non-perspective views"); |
| 265 | if (p != NULL) {                /* compute view position */ |
| 266 | VSUB(disp, p, vw->vp); |
| 267 | d0 = DOT(disp, vw->vdir); |
| 268 | if (d0 <= vw->vfore+FTINY) |
| 269 | continue;               /* too close */ |
| 270 | } else { |
| 271 | VCOPY(disp, d); |
| 272 | d0 = DOT(disp, vw->vdir); |
| 273 | if (d0 <= FTINY)                /* behind view */ |
| 274 | continue; |
| 275 | } |
| 276 | h = DOT(disp,vw->hvec)/(d0*vw->hn2) + 0.5 - vw->hoff; |
| 277 | if (h < 0. || h >= 1.) |
| 278 | continue;                       /* left or right */ |
| 279 | v = DOT(disp,vw->vvec)/(d0*vw->vn2) + 0.5 - vw->voff; |
| 280 | if (v < 0. || v >= 1.) |
| 281 | continue;                       /* above or below */ |
| 282 | hh = h * res[0]; |
| 283 | vh = v * res[1]; |
| 284 | if (odView[i].dmap != NULL) {           /* check depth */ |
| 285 | d1 = odView[i].dmap[vh*res[0] + hh]; |
| 286 | if (d1 < 0.99*FHUGE && (d0 > (1.+DEPTHEPS)*d1 || |
| 287 | (1.+DEPTHEPS)*d0 < d1)) |
| 288 | continue;                       /* occlusion error */ |
| 289 | } |
| 290 | if (p != NULL) {                /* compute closeness (sin^2) */ |
| 291 | d1 = DOT(disp, d); |
| 292 | prox = 1. - d1*d1/DOT(disp,disp); |
| 293 | } else |
| 294 | prox = 0.; |
| 295 | /* allocate sample */ |
| 296 | id = odAllocBlockSamp(i, hh, vh, prox); |
| 297 | if (id < 0) |
| 298 | continue;               /* not good enough */ |
| 299 | /* convert color */ |
| 300 | tmCvColrs(&odS.brt[id], odS.chr[id], c, 1); |
| 301 | if (imm_mode | needmapping)             /* if immediate mode */ |
| 302 | needmapping |= NEWRGB;          /* map it later */ |
| 303 | else                                    /* else map it now */ |
| 304 | tmMapPixels(odS.rgb[id], &odS.brt[id], odS.chr[id], 1); |
| 305 | SET4(odS.redraw, id);                   /* mark for redraw */ |
| 306 | } |
| 307 | } |
| 308 |  |
| 309 |  |
| 310 | odRemap(newhist)                        /* recompute tone mapping */ |
| 311 | int     newhist; |
| 312 | { |
| 313 | needmapping |= NEWMAP|NEWRGB; |
| 314 | if (newhist) |
| 315 | needmapping |= NEWHIST; |
| 316 | } |
| 317 |  |
| 318 |  |
| 319 | odRedraw(vn, hmin, vmin, hmax, vmax)    /* redraw view region */ |
| 320 | int     vn, hmin, vmin, hmax, vmax; |
| 321 | { |
| 322 | int     i, j; |
| 323 | register struct ODblock *bp; |
| 324 | register int    k; |
| 325 |  |
| 326 | if (vn<0 | vn>=odNViews) |
| 327 | return; |
| 328 | /* check view limits */ |
| 329 | if (hmin < 0) hmin = 0; |
| 330 | if (hmax >= odView[vn].hhi) hmax = odView[vn].hhi-1; |
| 331 | if (vmin < 0) vmin = 0; |
| 332 | if (vmax >= odView[vn].vhi) vmax = odView[vn].vhi-1; |
| 333 | if (hmax <= hmin | vmax <= vmin) |
| 334 | return; |
| 335 | /* convert to low resolution */ |
| 336 | hmin = hmin * odView[vn].hlow / odView[vn].hhi; |
| 337 | hmax = hmax * odView[vn].hlow / odView[vn].hhi; |
| 338 | vmin = vmin * odView[vn].vlow / odView[vn].vhi; |
| 339 | vmax = vmax * odView[vn].vlow / odView[vn].vhi; |
| 340 | /* mark block samples for redraw, inclusive */ |
| 341 | for (i = hmin; i <= hmax; i++) |
| 342 | for (j = vmin; j <= vmax; j++) { |
| 343 | bp = odView[vn].bmap + j*odView[vn].hlow + i; |
| 344 | for (k = bp->nsamp; k--; ) |
| 345 | if (odS.ip[bp->first+k][0] >= 0) |
| 346 | SET4(odS.redraw, bp->first+k); |
| 347 | } |
| 348 | } |
| 349 |  |
| 350 |  |
| 351 | odDepthMap(vn, dm)                      /* assign depth map for view */ |
| 352 | int     vn; |
| 353 | GLfloat *dm; |
| 354 | { |
| 355 | double  d0, d1; |
| 356 | int     i, j, hmin, hmax, vmin, vmax; |
| 357 | register int    k, l; |
| 358 |  |
| 359 | if (dm == NULL) {                       /* free edge map */ |
| 360 | if (vn<0 | vn>=odNViews) |
| 361 | return;                 /* too late -- they're gone! */ |
| 362 | if (odView[vn].emap != NULL) |
| 363 | free((char *)odView[vn].emap); |
| 364 | odView[vn].emap = NULL; |
| 365 | odView[vn].dmap = NULL; |
| 366 | return; |
| 367 | } |
| 368 | DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, |
| 369 | "bad view number in odDepthMap"); |
| 370 | odView[vn].dmap = dm;                   /* initialize edge map */ |
| 371 | if (odView[vn].emap == NULL) { |
| 372 | odView[vn].emap = (int4 *)malloc( |
| 373 | FL4NELS(odView[vn].hlow*odView[vn].vlow)*sizeof(int4)); |
| 374 | if (odView[vn].emap == NULL) |
| 375 | error(SYSTEM, "out of memory in odDepthMap"); |
| 376 | } |
| 377 | CLR4ALL(odView[vn].emap, odView[vn].hlow*odView[vn].vlow); |
| 378 | /* compute edge map */ |
| 379 | vmin = odView[vn].vhi;                  /* enter loopsville */ |
| 380 | for (j = odView[vn].vlow; j--; ) { |
| 381 | vmax = vmin; |
| 382 | vmin = j*odView[vn].vhi/odView[vn].vlow; |
| 383 | hmin = odView[vn].hhi; |
| 384 | for (i = odView[vn].hlow; i--; ) { |
| 385 | hmax = hmin; |
| 386 | hmin = i*odView[vn].hhi/odView[vn].hlow; |
| 387 | for (l = vmin; l < vmax; l++) { /* vertical edges */ |
| 388 | d1 = dm[l*odView[vn].hhi+hmin]; |
| 389 | for (k = hmin+1; k < hmax; k++) { |
| 390 | d0 = d1; |
| 391 | d1 = dm[l*odView[vn].hhi+k]; |
| 392 | if (d0 > (1.+DEPTHEPS)*d1 || |
| 393 | (1.+DEPTHEPS)*d0 < d1) { |
| 394 | SET4(odView[vn].emap, |
| 395 | j*odView[vn].hlow + i); |
| 396 | break; |
| 397 | } |
| 398 | } |
| 399 | if (k < hmax) |
| 400 | break; |
| 401 | } |
| 402 | if (l < vmax) |
| 403 | continue; |
| 404 | for (k = hmin; k < hmax; k++) { /* horizontal edges */ |
| 405 | d1 = dm[vmin*odView[vn].hhi+k]; |
| 406 | for (l = vmin+1; l < vmax; l++) { |
| 407 | d0 = d1; |
| 408 | d1 = dm[l*odView[vn].hhi+k]; |
| 409 | if (d0 > (1.+DEPTHEPS)*d1 || |
| 410 | (1.+DEPTHEPS)*d0 < d1) { |
| 411 | SET4(odView[vn].emap, |
| 412 | j*odView[vn].hlow + i); |
| 413 | break; |
| 414 | } |
| 415 | } |
| 416 | if (l < vmax) |
| 417 | break; |
| 418 | } |
| 419 | } |
| 420 | } |
| 421 | } |
| 422 |  |
| 423 |  |
| 424 | odUpdate(vn)                            /* update this view */ |
| 425 | int     vn; |
| 426 | { |
| 427 | register int    i, j; |
| 428 |  |
| 429 | DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, |
| 430 | "bad view number in odUpdate"); |
| 431 | /* need to do some tone mapping? */ |
| 432 | if (needmapping & NEWRGB) { |
| 433 | if (needmapping & NEWMAP) { |
| 434 | if (needmapping & NEWHIST) |
| 435 | tmClearHisto(); |
| 436 | if (tmAddHisto(odS.brt,odS.nsamp,1) != TM_E_OK) |
| 437 | return; |
| 438 | if (tmComputeMapping(0.,0.,0.) != TM_E_OK) |
| 439 | return; |
| 440 | for (i = odS.nsamp; i--; )      /* redraw all */ |
| 441 | if (odS.ip[i][0] >= 0) |
| 442 | SET4(odS.redraw, i); |
| 443 | } |
| 444 | if (tmMapPixels(odS.rgb,odS.brt,odS.chr,odS.nsamp) != TM_E_OK) |
| 445 | return; |
| 446 | needmapping = 0;                /* reset flag */ |
| 447 | } |
| 448 | /* draw samples flagged for redraw */ |
| 449 | for (j = FL4NELS(odS.nsamp); j--; ) |
| 450 | for (i = 0; odS.redraw[j]; i++)         /* skips faster */ |
| 451 | if (odS.redraw[j] & 1L<<i) { |
| 452 | odDrawSamp(vn, (j<<5)+i); |
| 453 | odS.redraw[j] &= ~(1L<<i); |
| 454 | } |
| 455 | } |
| 456 |  |
| 457 |  |
| 458 | #if 0 |
| 459 | static |
| 460 | clip_end(p, o, vp)                      /* clip line segment to view */ |
| 461 | GLshort p[3]; |
| 462 | short   o[2]; |
| 463 | register struct ODview  *vp; |
| 464 | { |
| 465 | if (p[0] < 0) { |
| 466 | p[1] = -o[0]*(p[1]-o[1])/(p[0]-o[0]) + o[1]; |
| 467 | p[2] = -o[0]*p[2]/(p[0]-o[0]); |
| 468 | p[0] = 0; |
| 469 | } else if (p[0] >= vp->hhi) { |
| 470 | p[1] = (vp->hhi-1-o[0])*(p[1]-o[1])/(p[0]-o[0]) + o[1]; |
| 471 | p[2] = (vp->hhi-1-o[0])*p[2]/(p[0]-o[0]); |
| 472 | p[0] = vp->hhi-1; |
| 473 | } |
| 474 | if (p[1] < 0) { |
| 475 | p[0] = -o[1]*(p[0]-o[0])/(p[1]-o[1]) + o[0]; |
| 476 | p[2] = -o[1]*p[2]/(p[1]-o[1]); |
| 477 | p[1] = 0; |
| 478 | } else if (p[1] >= vp->vhi) { |
| 479 | p[0] = (vp->vhi-1-o[1])*(p[0]-o[0])/(p[1]-o[1]) + o[0]; |
| 480 | p[2] = (vp->vhi-1-o[1])*p[2]/(p[1]-o[1]); |
| 481 | p[1] = vp->vhi-1; |
| 482 | } |
| 483 | } |
| 484 | #endif |
| 485 |  |
| 486 |  |
| 487 | static int |
| 488 | make_arms(ar, cp, vp, sz)               /* make arms for triangle fan */ |
| 489 | GLshort ar[MAXFAN][3]; |
| 490 | short   cp[2]; |
| 491 | register struct ODview  *vp; |
| 492 | double  sz; |
| 493 | { |
| 494 | int     na, dv; |
| 495 | double  hrad, vrad, phi0, phi; |
| 496 | register int    i; |
| 497 |  |
| 498 | DCHECK(sz > 1, CONSISTENCY, "super-unary size in make_arms"); |
| 499 | na = MAXFAN*sz*sz + 0.5;                /* keep area constant */ |
| 500 | if (na < MINFAN) na = MINFAN; |
| 501 | hrad = FANSIZE*sz*vp->hhi/vp->hlow; |
| 502 | vrad = FANSIZE*sz*vp->vhi/vp->vlow; |
| 503 | if (hrad*vrad < 2.25) |
| 504 | hrad = vrad = 1.5; |
| 505 | phi0 = (2.*PI) * frandom(); |
| 506 | dv = OMAXDEPTH*sz + 0.5; |
| 507 | for (i = 0; i < na; i++) { |
| 508 | phi = phi0 + (2.*PI)*i/na; |
| 509 | ar[i][0] = cp[0] + tcos(phi)*hrad + 0.5; |
| 510 | ar[i][1] = cp[1] + tsin(phi)*vrad + 0.5; |
| 511 | ar[i][2] = dv; |
| 512 | /* clip_end(ar[i], cp, vp); */ |
| 513 | } |
| 514 | return(na); |
| 515 | } |
| 516 |  |
| 517 |  |
| 518 | static int |
| 519 | depthchange(vp, x0, y0, x1, y1)         /* check depth discontinuity */ |
| 520 | register struct ODview  *vp; |
| 521 | int     x0, y0, x1, y1; |
| 522 | { |
| 523 | register double d0, d1; |
| 524 |  |
| 525 | DCHECK(x0<0 | x0>=vp->hhi | y0<0 | y0>=vp->vhi, |
| 526 | CONSISTENCY, "coordinates off view in depthchange"); |
| 527 |  |
| 528 | if (x1<0 | x1>=vp->hhi | y1<0 | y1>=vp->vhi) |
| 529 | return(1); |
| 530 |  |
| 531 | d0 = vp->dmap[y0*vp->hhi + x0]; |
| 532 | d1 = vp->dmap[y1*vp->hhi + x1]; |
| 533 |  |
| 534 | return((1.+DEPTHEPS)*d0 < d1 || d0 > (1.+DEPTHEPS)*d1); |
| 535 | } |
| 536 |  |
| 537 |  |
| 538 | static |
| 539 | clip_edge(p, o, vp)                     /* clip line segment to depth edge */ |
| 540 | GLshort p[3]; |
| 541 | short   o[2]; |
| 542 | register struct ODview  *vp; |
| 543 | { |
| 544 | int     x, y, xstep, ystep, rise, rise2, run, run2, n; |
| 545 |  |
| 546 | DCHECK(vp->dmap==NULL, CONSISTENCY, |
| 547 | "clip_edge called with no depth map"); |
| 548 | x = o[0]; y = o[1]; |
| 549 | run = p[0] - x; |
| 550 | xstep = run > 0 ? 1 : -1; |
| 551 | run *= xstep; |
| 552 | rise = p[1] - y; |
| 553 | ystep = rise > 0 ? 1 : -1; |
| 554 | rise *= ystep; |
| 555 | rise2 = run2 = 0; |
| 556 | if (rise > run) rise2 = 1; |
| 557 | else run2 = 1; |
| 558 | n = rise + run; |
| 559 | while (n--)                     /* run out arm, checking depth */ |
| 560 | if (run2 > rise2) { |
| 561 | if (depthchange(vp, x, y, x+xstep, y)) |
| 562 | break; |
| 563 | x += xstep; |
| 564 | rise2 += rise; |
| 565 | } else { |
| 566 | if (depthchange(vp, x, y, x, y+ystep)) |
| 567 | break; |
| 568 | y += ystep; |
| 569 | run2 += run; |
| 570 | } |
| 571 | if (n < 0)                      /* found something? */ |
| 572 | return; |
| 573 | if (run > rise) |
| 574 | p[2] = (x - o[0])*p[2]/(p[0] - o[0]); |
| 575 | else |
| 576 | p[2] = (y - o[1])*p[2]/(p[1] - o[1]); |
| 577 | p[0] = x; |
| 578 | p[1] = y; |
| 579 | } |
| 580 |  |
| 581 |  |
| 582 | static int |
| 583 | getblock(vp, h, v)                      /* get block index */ |
| 584 | register struct ODview  *vp; |
| 585 | register int    h, v; |
| 586 | { |
| 587 | if (h<0 | h>=vp->hhi | v<0 | v>=vp->vhi) |
| 588 | return(-1); |
| 589 | return(h*vp->hlow/vp->hhi + v*vp->vlow/vp->vhi*vp->hlow); |
| 590 | } |
| 591 |  |
| 592 |  |
| 593 | odDrawSamp(vn, id)                      /* draw view sample */ |
| 594 | int     vn; |
| 595 | register int    id; |
| 596 | { |
| 597 | GLshort arm[MAXFAN][3]; |
| 598 | int     narms, blockindex, bi1; |
| 599 | register struct ODview  *vp; |
| 600 | double  size; |
| 601 | int     home_edges; |
| 602 | register int    i; |
| 603 |  |
| 604 | vp = odView + vn; |
| 605 | blockindex = getblock(vp, odS.ip[id][0], odS.ip[id][1]); |
| 606 | DCHECK(blockindex<0, CONSISTENCY, "bad sample handed to odDrawSamp"); |
| 607 | DCHECK(vp->bmap[blockindex].nused <= 0, |
| 608 | CONSISTENCY, "bad in-use count in odDrawSamp"); |
| 609 | /* create triangle fan */ |
| 610 | size = 1./sqrt((double)vp->bmap[blockindex].nused); |
| 611 | narms = make_arms(arm, odS.ip[id], vp, size); |
| 612 | if (vp->emap != NULL) {         /* check for edge collisions */ |
| 613 | home_edges = CHK4(vp->emap, blockindex); |
| 614 | for (i = 0; i < narms; i++) |
| 615 | /* the following test is flawed, because we could |
| 616 | * be passing through a block on a diagonal run */ |
| 617 | if (home_edges || |
| 618 | ( (bi1 = getblock(vp, arm[i][0], arm[i][1])) |
| 619 | != blockindex && |
| 620 | (bi1 < 0 || CHK4(vp->emap, bi1)) )) |
| 621 | clip_edge(arm[i], odS.ip[id], vp); |
| 622 | } |
| 623 | /* draw triangle fan */ |
| 624 | glColor3ub(odS.rgb[id][0], odS.rgb[id][1], odS.rgb[id][2]); |
| 625 | glBegin(GL_TRIANGLE_FAN); |
| 626 | glVertex3s((GLshort)odS.ip[id][0], (GLshort)odS.ip[id][1], (GLshort)0); |
| 627 | for (i = 0; i < narms; i++) |
| 628 | glVertex3sv(arm[i]); |
| 629 | glVertex3sv(arm[0]);            /* connect last to first */ |
| 630 | glEnd(); |
| 631 | } |
