root/radiance/src/hd/rhd_glx.c
Revision 3.32
Fri Nov 5 03:31:37 2004 UTC (20 years, 11 months ago) by greg
Changes since 3.31: +1 -1 lines
FILE REMOVED
Fri Sep 19 18:33:04 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.30: +3 -1 lines
Diff to previous 3.30
Mon Jul 21 22:30:18 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.29: +5 -5 lines
Diff to previous 3.29
Sat Feb 22 02:07:24 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.28: +3 -6 lines
Diff to previous 3.28
Thu Jun 10 15:22:21 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.27: +57 -39 lines
Diff to previous 3.27
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
Sun Jan 3 13:40:25 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.26: +5 -5 lines
Diff to previous 3.26
fixed bug in stereo view computation after window resize
Mon Dec 28 17:58:45 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.25: +3 -5 lines
Diff to previous 3.25
New insertion routine
New Culling routine based on insertion algorithm
Adapted old insertion code: now used by picking
Point location code returns on-vertex,on-edge, or in-triangle
Added on_edge case for subdivision
implemented  unordered sets
Removed deletion from quadtree- added set compression to replace functionality
Fri Dec 18 11:56:09 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.24: +12 -5 lines
Diff to previous 3.24
Thu Dec 10 10:45:54 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.23: +58 -4 lines
Diff to previous 3.23
created "frame" command to focus calculation
Thu Aug 27 19:33:05 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.22: +19 -13 lines
Diff to previous 3.22
improved grid drawing in stereo mode
Tue Aug 25 18:11:17 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.21: +72 -67 lines
Diff to previous 3.21
bug fixes and improved interactive drawing
Fri Aug 21 11:38:21 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.20: +1 -1 lines
Diff to previous 3.20
changed dobj_trace() to return name of intersected object
improved "show" lighting with front-directed light source
changed MINTHRESH and cosmetic fixes
Thu Aug 20 09:32:52 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.19: +29 -30 lines
Diff to previous 3.19
bug fix for window resizing
Wed Aug 19 17:45:58 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.18: +337 -225 lines
Diff to previous 3.18
first attempt and Delaunay triangulation driver
Wed Jun 17 15:44:07 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 3.17: +9 -1 lines
Diff to previous 3.17
added dev_auxcom() for auxiliary command handling
Thu May 14 13:06:33 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.16: +12 -0 lines
Diff to previous 3.16
added multiple device view capability
Thu Jan 22 10:10:49 1998 UTC (27 years, 9 months ago) by gregl
Diff to previous 3.15
increased number of vertices in cone approximations
Tue Jan 6 13:07:57 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.14: +14 -5 lines
Diff to previous 3.14
added check of DISPLAY_PRIMARIES environment variable
Tue Jan 6 05:26:19 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.13: +8 -0 lines
Diff to previous 3.13
created dev_clear() routine to clear device ray cache
Sun Jan 4 08:32:00 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.12: +1 -0 lines
Diff to previous 3.12
delay update after ^L
Thu Jan 1 16:28:44 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.11: +3 -0 lines
Diff to previous 3.11
added missing test for unmapped window in dev_cone()
Thu Jan 1 14:48:46 1998 UTC (27 years, 9 months ago) by gregl
Diff to previous 3.10
increased leaf allocation by 50%
Thu Jan 1 13:00:15 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.9: +7 -2 lines
Diff to previous 3.9
Tue Dec 30 16:59:46 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.8: +2 -1 lines
Diff to previous 3.8
changed depth epsilon and reduced leaf allocation
Fri Dec 26 21:56:43 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.7: +8 -0 lines
Diff to previous 3.7
added resetting of curzmax to ^R and ^L commands
Fri Dec 26 16:50:03 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.6: +0 -1 lines
Diff to previous 3.6
removed unnecessary call to glClear()
Fri Dec 26 15:33:12 1997 UTC (27 years, 9 months ago) by gregl
Diff to previous 3.5
fixed viewport resizing
Fri Dec 26 14:46:21 1997 UTC (27 years, 9 months ago) by gregl
Diff to previous 3.4
added conservative check for cone radius
Fri Dec 26 14:12:37 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.3: +176 -493 lines
reverted to using quadtree for GLX driver
Wed Dec 24 15:55:43 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.2: +26 -3 lines
added fast redraw for mouse-controlled movement
Wed Dec 24 14:06:40 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.1: +227 -98 lines
first fully working version
Tue Dec 23 18:31:00 1997 UTC (27 years, 10 months ago) by gregl
