root/radiance/src/hd/rhd_geom.c
Fri Oct 5 19:19:16 2018 UTC (7 years ago) by greg
Changes since 3.14: +14 -14 lines
Diff to previous 3.14 , to selected 3.10
Thu Jan 1 11:21:55 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.13: +33 -18 lines
Diff to previous 3.13 , to selected 3.10
Ansification and prototypes.
Mon Jul 21 22:30:18 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 3.12 , to selected 3.10
Mon Jun 30 14:59:11 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.11: +7 -5 lines
Diff to previous 3.11 , to selected 3.10
Thu Jun 26 00:58:10 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 3.10
Revision 3.10 - (view) (download) (annotate) - [selected]
Tue May 13 17:58:33 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.9: +4 -4 lines
Diff to previous 3.9
Sat Feb 22 02:07:24 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.8: +1 -4 lines
Diff to previous 3.8 , to selected 3.10
Fri Jan 29 15:33:36 1999 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.7: +8 -4 lines
Diff to previous 3.7 , to selected 3.10
added number of lists for proper list deallocation
Fri Jan 29 15:04:03 1999 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.6: +4 -2 lines
Diff to previous 3.6 , to selected 3.10
addes savestr() call to gmAddGeom() for safety
Fri Jan 29 11:11:14 1999 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.5: +3 -7 lines
Diff to previous 3.5 , to selected 3.10
added the ability to handle quoted strings in gmNewPortal()
Fri Jan 1 10:41:28 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.4: +2 -1 lines
Diff to previous 3.4 , to selected 3.10
fixed aft clipping plane problem
Wed Dec 23 17:43:20 1998 UTC (26 years, 9 months ago) by gwlarson
Diff to previous 3.3 , to selected 3.10
changed to flat shading in gmDrawPortals()
Mon Dec 21 11:42:37 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.2: +20 -10 lines
Diff to previous 3.2 , to selected 3.10
got portals working with or without alpha buffer
Sun Dec 20 20:35:43 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.1: +128 -38 lines
Diff to previous 3.1 , to selected 3.10
added port drawing into alpha buffer mask
Fri Dec 18 11:55:19 1998 UTC (26 years, 10 months ago) by gwlarson
Diff to selected 3.10
